Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] GPU issue with r12137
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] GPU issue with r12137
  • Date: Thu, 3 Apr 2014 14:42:16 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Indeed, this error is very strange...
Yes I have only one GPU with 11 cores. I can try different configuration if
you want.
Le 3 avr. 2014 à 14:24, Samuel Thibault <samuel.thibault@ens-lyon.org> a
écrit :
> Xavier Lacoste, le Thu 03 Apr 2014 13:44:00 +0200, a écrit :
>> I runned the test several time because i didn't believe this can be the
>> cause....
>> Indeed doing :
>> diff --git a/src/datawizard/coherency.c b/src/datawizard/coherency.c
>> index 6e67156..8e82163 100644
>> --- a/src/datawizard/coherency.c
>> +++ b/src/datawizard/coherency.c
>> @@ -172,13 +172,13 @@ static int worker_supports_direct_access(unsigned
>> node,
>> unsigned handling_node)
>> enum starpu_node_kind kind = starpu_node_get_kind
>> (handling_node);
>> /* GPUs not always allow direct remote access: if
>> CUDA4
>> * is enabled, we allow two CUDA devices to
>> communicate. */
>> - return
>> -#if 0
>> + return kind ==
>> +#if 1
>> /* CUDA does not seem very safe with
>> concurrent
>> * transfer queueing, avoid queueing from
>> CPUs
>> - kind == STARPU_CPU_RAM ||
>> + STARPU_CPU_RAM ||
>> #endif
>> - kind == STARPU_CUDA_RAM;
>> + STARPU_CUDA_RAM;
>> #else
>> /* Direct GPU-GPU transfers are not allowed in
>> general
>> solves the issue.
> Uh?!
> Since kind can not be both STARPU_CPU_RAM || STARPU_CUDA_RAM, it
> basically means always returning 0. What is really disturbing is that
> all it does is disabling GPU-GPU direct transfers. You are testing with
> just one GPU, aren't you?
> Samuel
Haut de le page
