Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Xavier Lacoste <xavier.lacoste@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] GPU issue with r12137
- Date: Thu, 3 Apr 2014 14:24:59 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Xavier Lacoste, le Thu 03 Apr 2014 13:44:00 +0200, a écrit :
> I runned the test several time because i didn't believe this can be the
> cause....
> Indeed doing :
> diff --git a/src/datawizard/coherency.c b/src/datawizard/coherency.c
> index 6e67156..8e82163 100644
> --- a/src/datawizard/coherency.c
> +++ b/src/datawizard/coherency.c
> @@ -172,13 +172,13 @@ static int worker_supports_direct_access(unsigned
> node,
> unsigned handling_node)
> enum starpu_node_kind kind = starpu_node_get_kind
> (handling_node);
> /* GPUs not always allow direct remote access: if
> CUDA4
> * is enabled, we allow two CUDA devices to
> communicate. */
> - return
> -#if 0
> + return kind ==
> +#if 1
> /* CUDA does not seem very safe with
> concurrent
> * transfer queueing, avoid queueing from
> CPUs
> - kind == STARPU_CPU_RAM ||
> + STARPU_CPU_RAM ||
> #endif
> - kind == STARPU_CUDA_RAM;
> + STARPU_CUDA_RAM;
> #else
> /* Direct GPU-GPU transfers are not allowed in
> general
> solves the issue.
Uh?!
Since kind can not be both STARPU_CPU_RAM || STARPU_CUDA_RAM, it
basically means always returning 0. What is really disturbing is that
all it does is disabling GPU-GPU direct transfers. You are testing with
just one GPU, aren't you?
Samuel
- Re: [Starpu-devel] GPU issue with r12137, Samuel Thibault, 02/04/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 02/04/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 03/04/2014
- Re: [Starpu-devel] GPU issue with r12137, Samuel Thibault, 03/04/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 04/04/2014
- Re: [Starpu-devel] GPU issue with r12137, Samuel Thibault, 07/04/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 08/04/2014
