Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] starpu test application
- Date: Mon, 9 Mar 2015 11:04:42 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello starpu developer team, I am student at Faculty of Informatics and Information Technologies in Slovakia. I am trying to develop an test application using starpu. I have installed starpu task programming library and i am looking up to some help or advise how to start up with work.In past I programmed applications using openCL kernels which i run on GPU.
My target application using starpu should perform computations on gpu on at least two nodes connected via network. I would like to ask you some questions about starpu.2. Could you advice me how can I turn on gcc plugin extension or how can i achieve it?
3. Could you recommend me some simple example/s of starpu where is computation using openCL kernel performed? Thank in advance and I look forward to hearing from you.
- [Starpu-devel] starpu test application, Martin Jurík, 09/03/2015
- Re: [Starpu-devel] starpu test application, Samuel Thibault, 13/03/2015
