Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] StarPU v1.1.4 released
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: starpu-announce@lists.gforge.inria.fr
  • Subject: [Starpu-devel] StarPU v1.1.4 released
  • Date: Wed, 11 Mar 2015 10:04:07 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
All,
The StarPU team is pleased to announce the release of v1.1.4. The tarball along with the md5sum file and the OpenPGP signature are available on the Gforge web site
https://gforge.inria.fr/frs/?group_id=1570
or on the secondary web site
http://runtime.bordeaux.inria.fr/StarPU/files/
Nathalie, for the StarPU team.
StarPU 1.1.4 (svn revision 14854)
The scheduling context release
New features:
* Fix and actually enable the cache allocation.
* Enable allocation cache in main RAM when STARPU_LIMIT_CPU_MEM is
set by the user.
* New MPI functions starpu_mpi_issend and starpu_mpi_issend_detached
to send data using a synchronous and non-blocking mode (internally
uses MPI_Issend)
* New data access mode flag STARPU_SSEND to be set when calling
starpu_mpi_insert_task to specify the data has to be sent using a
* New environment variable STARPU_PERF_MODEL_DIR which can be set to
specify a directory where to store performance model files in.
When unset, the files are stored in $STARPU_HOME/.starpu/sampling
* MPI:
- New function starpu_mpi_data_register_comm to register a data
with another communicator than MPI_COMM_WORLD
- New functions starpu_mpi_data_set_rank() and
starpu_mpi_data_set_tag()
which call starpu_mpi_data_register_comm()
Small features:
* Add starpu_memory_wait_available() to wait for a given size to
become available on a given node.
* New environment variable STARPU_RAND_SEED to set the seed used
for random numbers.
* New function starpu_mpi_cache_set() to enable or disable the
communication cache at runtime
* Add starpu_paje_sort which sorts Pajé traces.
Changes:
* Fix complexity of implicit task/data dependency, from quadratic to
linear.
  • [Starpu-devel] StarPU v1.1.4 released, Nathalie Furmento, 11/03/2015
Haut de le page
