Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Martin Jurík <martin.jurik.91@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] starpu test application
- Date: Fri, 13 Mar 2015 16:39:49 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
Martin Jurík, le Mon 09 Mar 2015 11:04:42 +0100, a écrit :
> 1. Is it necessary to use starpu c extension?
No, one can use the C API directly.
> 2. Could you advice me how can I turn on gcc plugin extension or how can i
> achieve it?
It's enabled by default unless your compiler does not support it. See
config.log for the details.
> 3. Could you recommend me some simple example/s of starpu where is
> computation
> using openCL kernel performed?
examples/basic_examples contains an example, as well as the
documentation.
> 4. Could you recommend me some simple example/s where is scheduling by MPI
> used?
mpi/examples/stencil/ contains a basic stencil examples, and the
documentation explains it. Note that StarPU currently doesn't balance
the load between MPI nodes, it is up to the application to decide the
data/task distribution.
Samuel
- [Starpu-devel] starpu test application, Martin Jurík, 09/03/2015
- Re: [Starpu-devel] starpu test application, Samuel Thibault, 13/03/2015
