Archives de la liste
- From: Malcolm Roberts <malcolm.i.w.roberts@gmail.com>
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] SOCL on Ubuntu error
- Date: Wed, 2 Sep 2015 10:10:04 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=malcolm.i.w.roberts@gmail.com; spf=Pass smtp.mailfrom=malcolm.i.w.roberts@gmail.com; spf=None smtp.helo=postmaster@mail-wi0-f177.google.com
- Ironport-phdr: 9a23:woeTHRdAT1rg6NLgnaeOqYw+lGMj4u6mDksu8pMizoh2WeGdxc69Zx7h7PlgxGXEQZ/co6odzbGG7+a4ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTrkbjqs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cYjdt6qJUFCfmyP/lgDO8QMDNzKHw8/tX28BXOUwaLzn8dSXkN1BVGBBLK4Vf7WI3wu230rLlTwi6faOj/SbszXTHq1aBhRQX0k29TMjc9+2bTj4pxyr0duhWrqgZj2KbbZYiUMLx1eaaLLoBSfnZIQssED38JOYi7dYZaUrIM
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello.
I'm trying to install SOCL on an up-to-date Ubuntu 15.04 and I'm getting errors when I try to run.
I did an install from source (1.2.0rc4), and I did a ./configure ; make ; sudo make install . Then, I added
export SOCL_OCL_LIB_OPENCL=/usr/lib/x86_64-linux-gnu/libOpenCL.so
export LD_PRELOAD=$SOCL_OCL_LIB_OPENCL
export OCL_ICD_VENDORS=socl/vendors/
to my .bashrc .
After opening a new terminal, I get the following error when running clinfo:
clinfo
main:2238: number of platforms : error -1001
I get a similar error when running a simple OpenCL test program; the program segfaults when calling clGetDeviceIDs.
I've also tried installing using the libsocl package from the Ubuntu repository, with similar results.
Is there some environmental variable that I'm missing here?
Thank you kindly,
~Malcolm Roberts
http://malcolmiwroberts.com
- [Starpu-devel] SOCL on Ubuntu error, Malcolm Roberts, 02/09/2015
- Re: [Starpu-devel] SOCL on Ubuntu error, Samuel Thibault, 02/09/2015
- Re: [Starpu-devel] SOCL on Ubuntu error, Malcolm Roberts, 02/09/2015
