starpu-devel@inria.fr
Archives de la liste
- To: Malcolm Roberts <malcolm.i.w.roberts@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] SOCL on Ubuntu error
- Date: Wed, 2 Sep 2015 11:40:00 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
Just to make sure
Malcolm Roberts, le Wed 02 Sep 2015 10:10:04 +0200, a écrit :
> export SOCL_OCL_LIB_OPENCL=/usr/lib/x86_64-linux-gnu/libOpenCL.so
Does this file exist?
> export OCL_ICD_VENDORS=socl/vendors/
> After opening a new terminal, I get the following error when running clinfo:
> clinfo
> main:2238: number of platforms : error -1001
is socl/vendors (where socl.icd resides) available in the current path
when you run clinfo?
You'll probably want to set an absolute path in OCL_ICD_VENDORS.
Also, are you using ocl-icd-libopencl1 for the ICD? I don't know if the
NVIDIA or AMD implementation support the OCL_ICD_VENDORS variable.
Samuel
- [Starpu-devel] SOCL on Ubuntu error, Malcolm Roberts, 02/09/2015
- Re: [Starpu-devel] SOCL on Ubuntu error, Samuel Thibault, 02/09/2015
- Re: [Starpu-devel] SOCL on Ubuntu error, Malcolm Roberts, 02/09/2015
