Archives de la liste
- From: Malcolm Roberts <malcolm.i.w.roberts@gmail.com>
- To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] SOCL on Ubuntu error
- Date: Wed, 2 Sep 2015 11:09:53 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=malcolm.i.w.roberts@gmail.com; spf=Pass smtp.mailfrom=malcolm.i.w.roberts@gmail.com; spf=None smtp.helo=postmaster@mail-wi0-f171.google.com
- Ironport-phdr: 9a23:SGWGdhVvUEW4+eXqE+9EVSAY7DXV8LGtZVwlr6E/grcLSJyIuqrYZxaCt8tkgFKBZ4jH8fUM07OQ6PC8HzRYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7z0o8WbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6LoJvvRNWqTifqk+UacQTHF/azh0t4XXskz4RA6S639UbmUXmBNVBxSNuArzW4r8tm3mtut30TSeIeX3S6o1UHKs9fEvAAT0gT0fKns1/X/ajuR0jblHu1SuqRtlzIOSYYePNfM4cLmOU8kdQD9kV8JaUChESrm7ZYYVE/FJaeNRq4L6o15IrF2hQxOrDu711iRgiXr/3Kl82OMkR1KVlDc8Fs4D5SyH5O7+M70fBKXslPHF
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello.
Thanks for getting back to me!
I have two OpenCL platforms installed; the AMD CPU platform and and an NVIDIA CUDA OpenCL platform.
The output of
dpkg -l \*opencl\* | grep ^.i
is
ii nvidia-opencl-dev:amd64 6.5.14-1 amd64 NVIDIA OpenCL development files
ii nvidia-opencl-icd-346 346.59-0ubuntu1 amd64 NVIDIA OpenCL ICD
ii ocl-icd-libopencl1:amd64 2.2.3-1 amd64 Generic OpenCL ICD Loader
ii opencl-headers 1.2-svn26009-1 all OpenCL (Open Computing Language) header files
ii unity-scope-openclipart 0.1+13.10.20130723-0ubuntu1 all OpenClipArt scope for Unity
When I remove the SOCL / StarPU lines from my .bashrc, I can run clinfo and my OpenCL programs without getting an error.
Thank you kindly,
~Malcolm
On 02/09/2015 11:00, Samuel Thibault wrote:
Hello,
Malcolm Roberts, le Wed 02 Sep 2015 10:10:04 +0200, a écrit :
After opening a new terminal, I get the following error when running clinfo:Do you have an implementation of opencl installed? What does the
clinfo
main:2238: number of platforms : error -1001
I get a similar error when running a simple OpenCL test program; the program
segfaults when calling clGetDeviceIDs.
following command return?
SOCL does not provide an implementation of OpenCL, just a layer to
inject StarPU between your OpenCL application and an existing OpenCL
implementation.
Samuel
http://malcolmiwroberts.com
- [Starpu-devel] SOCL on Ubuntu error, Malcolm Roberts, 02/09/2015
- Re: [Starpu-devel] SOCL on Ubuntu error, Samuel Thibault, 02/09/2015
- Re: [Starpu-devel] SOCL on Ubuntu error, Malcolm Roberts, 02/09/2015
