Archives de la liste
- From: Jean-Marie Couteyen <jean-marie.couteyen@inria.fr>
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] Memory leak starpu_task_build ?
- Date: Tue, 15 Sep 2015 14:48:36 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
Is it normal that cl_arg_free is not set to 1 automatically when using starpu_task_build ?
When passing a STARPU_VALUE, it seems that there is a malloc everytime (starpu_task_insert_utils.c:340, starpu_task_insert_utils.c:77).
Obviously, I can build the task and set the field manually, but I wonder if it should not be set by starpu_task_build_v. I changed starpu_task_insert:131 passing 1 instead of 0 and it seems to work as expected.
Regards,
Jean-Marie Couteyen
- [Starpu-devel] Memory leak starpu_task_build ?, Jean-Marie Couteyen, 15/09/2015
- Re: [Starpu-devel] Memory leak starpu_task_build ?, Samuel Thibault, 15/09/2015
- Re: [Starpu-devel] Memory leak starpu_task_build ?, Nathalie Furmento, 16/09/2015
