Archives de la liste
- To: Jean-Marie Couteyen <jean-marie.couteyen@inria.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Memory leak starpu_task_build ?
- Date: Tue, 15 Sep 2015 17:14:59 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Jean-Marie Couteyen, le Tue 15 Sep 2015 14:48:36 +0200, a écrit :
> Is it normal that cl_arg_free is not set to 1 automatically when using
> starpu_task_build ?
One of the idea of starpu_task_build is that you can put whatever you
want in cl_arg after building the task
Perhaps _starpu_task_insert_create should however automatically set it
to 1 when some STARPU_VALUE was used. Nathalie, what do you think?
Samuel
- [Starpu-devel] Memory leak starpu_task_build ?, Jean-Marie Couteyen, 15/09/2015
- Re: [Starpu-devel] Memory leak starpu_task_build ?, Samuel Thibault, 15/09/2015
- Re: [Starpu-devel] Memory leak starpu_task_build ?, Nathalie Furmento, 16/09/2015
