Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Memory leak starpu_task_build ?
- Date: Wed, 16 Sep 2015 11:27:14 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=Pass smtp.helo=postmaster@iona.labri.fr
- Ironport-phdr: 9a23:TzQ8CB0Z2DsuTmP/smDT+DRfVm0co7zxezQtwd8ZsekWKfad9pjvdHbS+e9qxAeQG96Lt7Qe2qGP7ejJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6OyZ7mnLnss7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JsKSrnzZbwlCLBVEjkiG2Q0/9Hw8xbNShGA6z0dVH8Xm1xGGUKNuArmV43pr272u/Rw3AGePNbqVvY7VzO44KotSRnyiS5BOSRvo0/NjcklqqtHoBulphE37ZPOZYyTKP02KqXUYdMTQWtMGMhMTSlMBJ+7R48GBfAAe+hC+dqu72ASpAezUFH/TNjkzSVF0yf7
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
It does indeed make sense to set it automatically to 1 when starpu_task_build is called with STARPU_VALUE parameters.
The modification has been done in the trunk and the branch 1.2.
Keep posted for the next release,
Cheers,
Nathalie
On 15/09/2015 17:14, Samuel Thibault wrote:
Jean-Marie Couteyen, le Tue 15 Sep 2015 14:48:36 +0200, a écrit :
Is it normal that cl_arg_free is not set to 1 automatically when usingOne of the idea of starpu_task_build is that you can put whatever you
starpu_task_build ?
want in cl_arg after building the task
Perhaps _starpu_task_insert_create should however automatically set it
to 1 when some STARPU_VALUE was used. Nathalie, what do you think?
Samuel
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] Memory leak starpu_task_build ?, Jean-Marie Couteyen, 15/09/2015
- Re: [Starpu-devel] Memory leak starpu_task_build ?, Samuel Thibault, 15/09/2015
- Re: [Starpu-devel] Memory leak starpu_task_build ?, Nathalie Furmento, 16/09/2015
