Archives de la liste
- To: starpu-devel <starpu-devel@lists.gforge.inria.fr>, Nathalie Furmento <nathalie.furmento@labri.fr>
- Subject: [Starpu-devel] Fwd: Error report
- Date: Mon, 28 Sep 2015 13:12:35 +0200 (CEST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=hpcfapix@hlrs.de; spf=None smtp.mailfrom=hpcfapix@hlrs.de; spf=None smtp.helo=postmaster@mail.hlrs.de
- Ironport-phdr: 9a23:SmUwTByoO29w8D/XCy+O+j09IxM/srCxBDY+r6Qd0OkXIJqq85mqBkHD//Il1AaPBtWHra8ZwLGH+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStKU0pn8jLH60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGx48sgs/M9YUKj8Y79wDfkBVGxnYCgJ45jwqRDZVRbK6nYCX2FexgFUChLd8VT2U4n8tgP+t/Fhw2+VM8rsQr1yWDK47q4tRgW+zG8hPiI5+WXWh4RekbherRS9oFQrxYfIYIiRNfc4cL7HeN4cWW1pWs9bTS0HDJnqPKUVCO9UE+9eoI3872MP5U++HQKiDfvu2hdIgmXtm6E3hbdyWTra1RAtSopd+E/fq8/4YeJLCbi4
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
----- Forwarded Message -----
From: "Nathalie Furmento" <nathalie.furmento@labri.fr>
To: "Fangli Pi" <hpcfapix@hlrs.de>
Sent: Monday, September 28, 2015 11:30:51 AM
Subject: Re: [Starpu-devel] Error report
can you please resend your email by adding
starpu-devel@lists.gforge.inria.fr to the recipients.
Thanks,
Nathalie
On 28/09/2015 10:59, Fangli Pi wrote:
> Hi Nathalie,
> Thanks for you reply and help. However I didn't configure with
> --enable-new-check.
> Here attached is my files as you mentioned.
> - config.log
> - examples/scheduler/schedulers.sh.log
> the output of my command "uname -a" is:
> Linux <hostname> 2.6.32-504.el6.x86_64 #1 SMP <date> x86_64 x86_64 x86_64
> GNU/Linux
> Besides, I came across also another compilation error like:
> vector_scal_cuda.cu(44): error: identifier "starpu_cuda_get_local_stream"
> is undefined.
> when trying the example "vector_scale".
> Thanks very much for your help!
> Best regards,
> Fangli Pi
> ----- Original Message -----
> Cc: "starpu-devel" <starpu-devel@lists.gforge.inria.fr>
> Sent: Friday, September 25, 2015 7:39:33 PM
> Hello,
> Looks like you called configure wuth the option --enable-new-check, this
> does enable functionalities
> which are not yet fully supported. Anyway, to find out what went wrong in
> your case, we need you to
> send us the following files:
> - config.log
> as well as the output of the command "uname -a"
> Cheers,
> Nathalie
> On Sep 25, 18:33, Fangli Pi wrote:
>> Hello,
>> I just find an error during my StarPU "make check". the version I am using
>> is StarPU 1.1.4, with gnu/4.9.2 compiler and cuda/7.0 compiler
>> Could you help me with this? Or any other suggestions?
>> FAIL: scheduler/schedulers.sh
>> 1 of 41 tests failed
>> (4 tests were not run)
>> See examples/test-suite.log
>> Please report to starpu-devel@lists.gforge.inria.fr
>> Thanks for the help!
>> Best regards,
>> Fangli
>> _______________________________________________
>> Starpu-devel mailing list
>> Starpu-devel@lists.gforge.inria.fr
>> http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] Error report, Fangli Pi, 25/09/2015
- Re: [Starpu-devel] Error report, Nathalie Furmento, 25/09/2015
- Re: [Starpu-devel] Error report, Fangli Pi, 28/09/2015
- Message indisponible
- [Starpu-devel] Fwd: Error report, Fangli Pi, 28/09/2015
- Re: [Starpu-devel] Error report, Nathalie Furmento, 28/09/2015
