Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Error report
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Fangli Pi <hpcfapix@hlrs.de>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Error report
  • Date: Mon, 28 Sep 2015 13:50:48 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=Pass smtp.helo=postmaster@iona.labri.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Please reconfigure without --enable-new-check
(config.log showed that you did call configure with the option).
What do you mean by trying the example vector_scal? The one in examples/basic_examples/ ? Did you compile it yourself or using the StarPU Makefile?
Regards,
Nathalie
On 28/09/2015 10:59, Fangli Pi wrote:
Hi Nathalie,
Thanks for you reply and help. However I didn't configure with
--enable-new-check.
Here attached is my files as you mentioned.
- config.log
- examples/scheduler/schedulers.sh.log
the output of my command "uname -a" is:
Linux <hostname> 2.6.32-504.el6.x86_64 #1 SMP <date> x86_64 x86_64 x86_64
GNU/Linux
Besides, I came across also another compilation error like:
vector_scal_cuda.cu(44): error: identifier "starpu_cuda_get_local_stream" is
undefined.
when trying the example "vector_scale".
Thanks very much for your help!
Best regards,
Fangli Pi
----- Original Message -----
From: "Nathalie Furmento" <nathalie.furmento@labri.fr>
To: "Fangli Pi" <hpcfapix@hlrs.de>
Cc: "starpu-devel" <starpu-devel@lists.gforge.inria.fr>
Sent: Friday, September 25, 2015 7:39:33 PM
Hello,
Looks like you called configure wuth the option --enable-new-check, this does
enable functionalities
which are not yet fully supported. Anyway, to find out what went wrong in
your case, we need you to
send us the following files:
- config.log
as well as the output of the command "uname -a"
Cheers,
Nathalie
On Sep 25, 18:33, Fangli Pi wrote:
Hello,
I just find an error during my StarPU "make check". the version I am using is
StarPU 1.1.4, with gnu/4.9.2 compiler and cuda/7.0 compiler
Could you help me with this? Or any other suggestions?
FAIL: scheduler/schedulers.sh
1 of 41 tests failed
(4 tests were not run)
See examples/test-suite.log
Please report to starpu-devel@lists.gforge.inria.fr
Thanks for the help!
Best regards,
Fangli
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Haut de le page
