Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Subject: Re: [Starpu-devel] Error report
- Date: Mon, 28 Sep 2015 10:59:16 +0200 (CEST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=Pass smtp.helo=postmaster@iona.labri.fr
- Ironport-phdr: 9a23:YIQtJRwaQKGUC43XCy+O+j09IxM/srCxBDY+r6Qd0eIWIJqq85mqBkHD//Il1AaPBtWHra8ZwLaL+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStKU0pn8i7360qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGx48sgs/M9YUKj8Y79wDfkBVGxnYCgJ45jNvAXDRA+O6zMyT38TnxxUBECR6hjmXp71sya8uPdn3SScIcreSbk+QzXk4b09GzHyjyJSGTc//2XWwvRxxPZbuBmvrgR+06bUZJuOcvZzKPCONegGTHZMC54CHxdKBZmxOs5WV7IM
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Resent-date: Mon, 28 Sep 2015 13:46:44 +0200
- Resent-from: Nathalie Furmento <nathalie.furmento@labri.fr>
- Resent-message-id: <20150928114644.GB8063@mercantour.bordeaux.inria.fr>
- Resent-to: starpu-devel@lists.gforge.inria.fr, hpcfapix@hlrs.de
Hi Nathalie,
Thanks for you reply and help. However I didn't configure with
--enable-new-check.
Here attached is my files as you mentioned.
- config.log
- examples/scheduler/schedulers.sh.log
the output of my command "uname -a" is:
Linux <hostname> 2.6.32-504.el6.x86_64 #1 SMP <date> x86_64 x86_64 x86_64
GNU/Linux
Besides, I came across also another compilation error like:
vector_scal_cuda.cu(44): error: identifier "starpu_cuda_get_local_stream" is
undefined.
when trying the example "vector_scale".
Thanks very much for your help!
Best regards,
Fangli Pi
----- Original Message -----
From: "Nathalie Furmento" <nathalie.furmento@labri.fr>
To: "Fangli Pi" <hpcfapix@hlrs.de>
Cc: "starpu-devel" <starpu-devel@lists.gforge.inria.fr>
Sent: Friday, September 25, 2015 7:39:33 PM
Hello,
Looks like you called configure wuth the option --enable-new-check, this does
enable functionalities
which are not yet fully supported. Anyway, to find out what went wrong in
your case, we need you to
send us the following files:
- config.log
as well as the output of the command "uname -a"
Cheers,
Nathalie
On Sep 25, 18:33, Fangli Pi wrote:
> Hello,
> I just find an error during my StarPU "make check". the version I am using
> is StarPU 1.1.4, with gnu/4.9.2 compiler and cuda/7.0 compiler
> Could you help me with this? Or any other suggestions?
> FAIL: scheduler/schedulers.sh
> 1 of 41 tests failed
> (4 tests were not run)
> See examples/test-suite.log
> Please report to starpu-devel@lists.gforge.inria.fr
> Thanks for the help!
> Best regards,
> Fangli
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Dr Nathalie Furmento Ingénieur de recherche CNRS
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
FAIL: scheduler/schedulers.sh (exit: 1) ======================================= cholesky.eager [starpu][initialize_eager_center_policy] Warning: you are running the default eager scheduler, which is not very smart. Make sure to read the StarPU documentation about adding performance models in order to be able to use the dmda or dmdas scheduler instead. # size ms GFlops 15360 108507 11.1 cholesky.prio # size ms GFlops 15360 108570 11.1 cholesky.random # size ms GFlops 15360 140300 8.6 cholesky.ws # size ms GFlops 15360 111218 10.9 cholesky.dm # size ms GFlops 15360 108726 11.1 cholesky.dmda [error] test ./scheduler/schedulers.sh has been blocked for 600 seconds. Mark it as failed while looking for core file of ./scheduler/schedulers.sh: core: No such file or directory ./scheduler/schedulers.sh: line 30: 30340 Quit STARPU_SCHED=$sched ./cholesky/cholesky_tag failure
This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by StarPU configure 1.1.4, which was generated by GNU Autoconf 2.69. Invocation command line was $ ./configure --prefix=/opt/runtime/StarPU/1.1.4-gnu-4.9.2/ --enable-new-check ## --------- ## ## Platform. ## ## --------- ## hostname = fe.excess-project.eu uname -m = x86_64 uname -r = 2.6.32-504.el6.x86_64 uname -s = Linux uname -v = #1 SMP Tue Oct 14 11:22:00 CDT 2014 /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = x86_64 /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin PATH: /opt/amd/app-sdk/3.0.124.132-GA/AMDAPPSDK-3.0/include/CL PATH: /opt/amd/app-sdk/3.0.124.132-GA/AMDAPPSDK-3.0/include/GL PATH: /opt/amd/app-sdk/3.0.124.132-GA/AMDAPPSDK-3.0/include/ PATH: /opt/amd/app-sdk/3.0.124.132-GA/AMDAPPSDK-3.0/bin PATH: /opt/compiler/cuda/7.0/bin PATH: /opt/compiler/gnu/4.9.2/bin PATH: /usr/lib64/qt-3.3/bin PATH: /usr/local/bin PATH: /bin PATH: /usr/bin PATH: /usr/local/sbin PATH: /usr/sbin PATH: /sbin PATH: /opt/ibutils/bin PATH: /nas_home//hpcfapix/bin ## ----------- ## ## Core tests. ## ## ----------- ## configure:3275: checking build system type configure:3289: result: x86_64-unknown-linux-gnu configure:3309: checking host system type configure:3322: result: x86_64-unknown-linux-gnu configure:3342: checking target system type configure:3355: result: x86_64-unknown-linux-gnu configure:3399: checking for a BSD-compatible install configure:3467: result: /usr/bin/install -c configure:3478: checking whether build environment is sane configure:3528: result: yes configure:3669: checking for a thread-safe mkdir -p configure:3708: result: /bin/mkdir -p configure:3721: checking for gawk configure:3737: found /bin/gawk configure:3748: result: gawk configure:3759: checking whether make sets $(MAKE) configure:3781: result: yes configure:3810: checking whether make supports nested variables configure:3827: result: yes configure:3912: checking whether make supports nested variables configure:3929: result: yes configure:3955: checking for style of include used by make configure:3983: result: GNU configure:4054: checking for gcc configure:4070: found /opt/compiler/gnu/4.9.2/bin/gcc configure:4081: result: gcc configure:4310: checking for C compiler version configure:4319: gcc --version >&5 gcc (GCC) 4.9.2 Copyright (C) 2014 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. configure:4330: $? = 0 configure:4319: gcc -v >&5 Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/opt/compiler/gnu/4.9.2/libexec/gcc/x86_64-unknown-linux-gnu/4.9.2/lto-wrapper Target: x86_64-unknown-linux-gnu Configured with: /nas_home/hpcdkhab/OPT/compiler/gcc/gcc-4.9.2/configure --prefix=/opt/compiler/gnu/4.9.2/ --mandir=/opt/compiler/gnu/4.9.2/share/man --infodir=/opt/compiler/gnu/4.9.2/share/info --with-local-prefix=/opt/compiler/gnu/4.9.2 --enable-languages=c,c++,fortran,java --with-gmp-lib=/opt/compiler/gnu/4.9.2/lib/ --with-gmp-include=/opt/compiler/gnu/4.9.2/include/ --with-mpc-lib=/opt/compiler/gnu/4.9.2/lib/ --with-mpfr-include=/opt/compiler/gnu/4.9.2/include/ --with-mpfr-include=/opt/compiler/gnu/4.9.2/include/ --disable-multilib Thread model: posix gcc version 4.9.2 (GCC) configure:4330: $? = 0 configure:4319: gcc -V >&5 gcc: error: unrecognized command line option '-V' gcc: fatal error: no input files compilation terminated. configure:4330: $? = 1 configure:4319: gcc -qversion >&5 gcc: error: unrecognized command line option '-qversion' gcc: fatal error: no input files compilation terminated. configure:4330: $? = 1 configure:4350: checking whether the C compiler works configure:4372: gcc conftest.c >&5 configure:4376: $? = 0 configure:4424: result: yes configure:4427: checking for C compiler default output file name configure:4429: result: a.out configure:4435: checking for suffix of executables configure:4442: gcc -o conftest conftest.c >&5 configure:4446: $? = 0 configure:4468: result: configure:4490: checking whether we are cross compiling configure:4498: gcc -o conftest conftest.c >&5 configure:4502: $? = 0 configure:4509: ./conftest configure:4513: $? = 0 configure:4528: result: no configure:4533: checking for suffix of object files configure:4555: gcc -c conftest.c >&5 configure:4559: $? = 0 configure:4580: result: o configure:4584: checking whether we are using the GNU C compiler configure:4603: gcc -c conftest.c >&5 configure:4603: $? = 0 configure:4612: result: yes configure:4621: checking whether gcc accepts -g configure:4641: gcc -c -g conftest.c >&5 configure:4641: $? = 0 configure:4682: result: yes configure:4699: checking for gcc option to accept ISO C89 configure:4762: gcc -c -g -O2 conftest.c >&5 configure:4762: $? = 0 configure:4775: result: none needed configure:4797: checking dependency style of gcc configure:4908: result: gcc3 configure:4973: checking for ar configure:4989: found /usr/bin/ar configure:5000: result: ar configure:5026: checking the archiver (ar) interface configure:5036: gcc -c -g -O2 conftest.c >&5 configure:5036: $? = 0 configure:5038: ar cru libconftest.a conftest.o >&5 configure:5041: $? = 0 configure:5064: result: ar configure:5132: checking for gcc configure:5159: result: gcc configure:5388: checking for C compiler version configure:5397: gcc --version >&5 gcc (GCC) 4.9.2 Copyright (C) 2014 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. configure:5408: $? = 0 configure:5397: gcc -v >&5 Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/opt/compiler/gnu/4.9.2/libexec/gcc/x86_64-unknown-linux-gnu/4.9.2/lto-wrapper Target: x86_64-unknown-linux-gnu Configured with: /nas_home/hpcdkhab/OPT/compiler/gcc/gcc-4.9.2/configure --prefix=/opt/compiler/gnu/4.9.2/ --mandir=/opt/compiler/gnu/4.9.2/share/man --infodir=/opt/compiler/gnu/4.9.2/share/info --with-local-prefix=/opt/compiler/gnu/4.9.2 --enable-languages=c,c++,fortran,java --with-gmp-lib=/opt/compiler/gnu/4.9.2/lib/ --with-gmp-include=/opt/compiler/gnu/4.9.2/include/ --with-mpc-lib=/opt/compiler/gnu/4.9.2/lib/ --with-mpfr-include=/opt/compiler/gnu/4.9.2/include/ --with-mpfr-include=/opt/compiler/gnu/4.9.2/include/ --disable-multilib Thread model: posix gcc version 4.9.2 (GCC) configure:5408: $? = 0 configure:5397: gcc -V >&5 gcc: error: unrecognized command line option '-V' gcc: fatal error: no input files compilation terminated. configure:5408: $? = 1 configure:5397: gcc -qversion >&5 gcc: error: unrecognized command line option '-qversion' gcc: fatal error: no input files compilation terminated. configure:5408: $? = 1 configure:5412: checking whether we are using the GNU C compiler configure:5440: result: yes configure:5449: checking whether gcc accepts -g configure:5510: result: yes configure:5527: checking for gcc option to accept ISO C89 configure:5603: result: none needed configure:5625: checking dependency style of gcc configure:5736: result: gcc3 configure:5752: checking whether gcc and cc understand -c and -o together configure:5783: gcc -c conftest.c -o conftest2.o >&5 configure:5787: $? = 0 configure:5793: gcc -c conftest.c -o conftest2.o >&5 configure:5797: $? = 0 configure:5808: cc -c conftest.c >&5 configure:5812: $? = 0 configure:5820: cc -c conftest.c -o conftest2.o >&5 configure:5824: $? = 0 configure:5830: cc -c conftest.c -o conftest2.o >&5 configure:5834: $? = 0 configure:5852: result: yes configure:5935: checking for g++ configure:5951: found /opt/compiler/gnu/4.9.2/bin/g++ configure:5962: result: g++ configure:5989: checking for C++ compiler version configure:5998: g++ --version >&5 g++ (GCC) 4.9.2 Copyright (C) 2014 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. configure:6009: $? = 0 configure:5998: g++ -v >&5 Using built-in specs. COLLECT_GCC=g++ COLLECT_LTO_WRAPPER=/opt/compiler/gnu/4.9.2/libexec/gcc/x86_64-unknown-linux-gnu/4.9.2/lto-wrapper Target: x86_64-unknown-linux-gnu Configured with: /nas_home/hpcdkhab/OPT/compiler/gcc/gcc-4.9.2/configure --prefix=/opt/compiler/gnu/4.9.2/ --mandir=/opt/compiler/gnu/4.9.2/share/man --infodir=/opt/compiler/gnu/4.9.2/share/info --with-local-prefix=/opt/compiler/gnu/4.9.2 --enable-languages=c,c++,fortran,java --with-gmp-lib=/opt/compiler/gnu/4.9.2/lib/ --with-gmp-include=/opt/compiler/gnu/4.9.2/include/ --with-mpc-lib=/opt/compiler/gnu/4.9.2/lib/ --with-mpfr-include=/opt/compiler/gnu/4.9.2/include/ --with-mpfr-include=/opt/compiler/gnu/4.9.2/include/ --disable-multilib Thread model: posix gcc version 4.9.2 (GCC) configure:6009: $? = 0 configure:5998: g++ -V >&5 g++: error: unrecognized command line option '-V' g++: fatal error: no input files compilation terminated. configure:6009: $? = 1 configure:5998: g++ -qversion >&5 g++: error: unrecognized command line option '-qversion' g++: fatal error: no input files compilation terminated. configure:6009: $? = 1 configure:6013: checking whether we are using the GNU C++ compiler configure:6032: g++ -c conftest.cpp >&5 configure:6032: $? = 0 configure:6041: result: yes configure:6050: checking whether g++ accepts -g configure:6070: g++ -c -g conftest.cpp >&5 configure:6070: $? = 0 configure:6111: result: yes configure:6136: checking dependency style of g++ configure:6247: result: gcc3 configure:6267: checking how to run the C preprocessor configure:6298: gcc -E conftest.c configure:6298: $? = 0 configure:6312: gcc -E conftest.c conftest.c:14:28: fatal error: ac_nonexistent.h: No such file or directory #include <ac_nonexistent.h> ^ compilation terminated. configure:6312: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | /* end confdefs.h. */ | #include <ac_nonexistent.h> configure:6337: result: gcc -E configure:6357: gcc -E conftest.c configure:6357: $? = 0 configure:6371: gcc -E conftest.c conftest.c:14:28: fatal error: ac_nonexistent.h: No such file or directory #include <ac_nonexistent.h> ^ compilation terminated. configure:6371: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | /* end confdefs.h. */ | #include <ac_nonexistent.h> configure:6399: checking for a sed that does not truncate output configure:6463: result: /bin/sed configure:6468: checking whether ln -s works configure:6472: result: yes configure:6532: checking for g77 configure:6562: result: no configure:6532: checking for xlf configure:6562: result: no configure:6532: checking for f77 configure:6562: result: no configure:6532: checking for frt configure:6562: result: no configure:6532: checking for pgf77 configure:6562: result: no configure:6532: checking for cf77 configure:6562: result: no configure:6532: checking for fort77 configure:6562: result: no configure:6532: checking for fl32 configure:6562: result: no configure:6532: checking for af77 configure:6562: result: no configure:6532: checking for xlf90 configure:6562: result: no configure:6532: checking for f90 configure:6562: result: no configure:6532: checking for pgf90 configure:6562: result: no configure:6532: checking for pghpf configure:6562: result: no configure:6532: checking for epcf90 configure:6562: result: no configure:6532: checking for gfortran configure:6548: found /opt/compiler/gnu/4.9.2/bin/gfortran configure:6559: result: gfortran configure:6585: checking for Fortran 77 compiler version configure:6594: gfortran --version >&5 GNU Fortran (GCC) 4.9.2 Copyright (C) 2014 Free Software Foundation, Inc. GNU Fortran comes with NO WARRANTY, to the extent permitted by law. You may redistribute copies of GNU Fortran under the terms of the GNU General Public License. For more information about these matters, see the file named COPYING configure:6605: $? = 0 configure:6594: gfortran -v >&5 Using built-in specs. COLLECT_GCC=gfortran COLLECT_LTO_WRAPPER=/opt/compiler/gnu/4.9.2/libexec/gcc/x86_64-unknown-linux-gnu/4.9.2/lto-wrapper Target: x86_64-unknown-linux-gnu Configured with: /nas_home/hpcdkhab/OPT/compiler/gcc/gcc-4.9.2/configure --prefix=/opt/compiler/gnu/4.9.2/ --mandir=/opt/compiler/gnu/4.9.2/share/man --infodir=/opt/compiler/gnu/4.9.2/share/info --with-local-prefix=/opt/compiler/gnu/4.9.2 --enable-languages=c,c++,fortran,java --with-gmp-lib=/opt/compiler/gnu/4.9.2/lib/ --with-gmp-include=/opt/compiler/gnu/4.9.2/include/ --with-mpc-lib=/opt/compiler/gnu/4.9.2/lib/ --with-mpfr-include=/opt/compiler/gnu/4.9.2/include/ --with-mpfr-include=/opt/compiler/gnu/4.9.2/include/ --disable-multilib Thread model: posix gcc version 4.9.2 (GCC) configure:6605: $? = 0 configure:6594: gfortran -V >&5 gfortran: error: unrecognized command line option '-V' gfortran: fatal error: no input files compilation terminated. configure:6605: $? = 1 configure:6594: gfortran -qversion >&5 gfortran: error: unrecognized command line option '-qversion' gfortran: fatal error: no input files compilation terminated. configure:6605: $? = 1 configure:6614: checking whether we are using the GNU Fortran 77 compiler configure:6627: gfortran -c conftest.F >&5 configure:6627: $? = 0 configure:6636: result: yes configure:6642: checking whether gfortran accepts -g configure:6653: gfortran -c -g conftest.f >&5 configure:6653: $? = 0 configure:6661: result: yes configure:6738: checking how to print strings configure:6765: result: printf configure:6786: checking for a sed that does not truncate output configure:6850: result: /bin/sed configure:6868: checking for grep that handles long lines and -e configure:6926: result: /bin/grep configure:6931: checking for egrep configure:6993: result: /bin/grep -E configure:6998: checking for fgrep configure:7060: result: /bin/grep -F configure:7095: checking for ld used by gcc configure:7162: result: /usr/bin/ld configure:7169: checking if the linker (/usr/bin/ld) is GNU ld configure:7184: result: yes configure:7196: checking for BSD- or MS-compatible name lister (nm) configure:7245: result: /usr/bin/nm -B configure:7375: checking the name lister (/usr/bin/nm -B) interface configure:7382: gcc -c -g -O2 conftest.c >&5 configure:7385: /usr/bin/nm -B "conftest.o" configure:7388: output 0000000000000000 B some_variable configure:7395: result: BSD nm configure:7399: checking the maximum length of command line arguments configure:7529: result: 1966080 configure:7546: checking whether the shell understands some XSI constructs configure:7556: result: yes configure:7560: checking whether the shell understands "+=" configure:7566: result: yes configure:7601: checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format configure:7641: result: func_convert_file_noop configure:7648: checking how to convert x86_64-unknown-linux-gnu file names to toolchain format configure:7668: result: func_convert_file_noop configure:7675: checking for /usr/bin/ld option to reload object files configure:7682: result: -r configure:7756: checking for objdump configure:7772: found /usr/bin/objdump configure:7783: result: objdump configure:7812: checking how to recognize dependent libraries configure:8010: result: pass_all configure:8095: checking for dlltool configure:8125: result: no configure:8152: checking how to associate runtime and link libraries configure:8179: result: printf %s\n configure:8303: checking for archiver @FILE support configure:8320: gcc -c -g -O2 conftest.c >&5 configure:8320: $? = 0 configure:8323: ar cru libconftest.a @conftest.lst >&5 configure:8326: $? = 0 configure:8331: ar cru libconftest.a @conftest.lst >&5 ar: conftest.o: No such file or directory configure:8334: $? = 1 configure:8346: result: @ configure:8404: checking for strip configure:8420: found /usr/bin/strip configure:8431: result: strip configure:8503: checking for ranlib configure:8519: found /usr/bin/ranlib configure:8530: result: ranlib configure:8632: checking command to parse /usr/bin/nm -B output from gcc object configure:8752: gcc -c -g -O2 conftest.c >&5 configure:8755: $? = 0 configure:8759: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' | sed '/ __gnu_lto/d' \> conftest.nm configure:8762: $? = 0 configure:8828: gcc -o conftest -g -O2 conftest.c conftstm.o >&5 configure:8831: $? = 0 configure:8869: result: ok configure:8906: checking for sysroot configure:8936: result: no configure:9013: gcc -c -g -O2 conftest.c >&5 configure:9016: $? = 0 configure:9192: checking for mt configure:9222: result: no configure:9242: checking if : is a manifest tool configure:9248: : '-?' configure:9256: result: no configure:9894: checking for ANSI C header files configure:9914: gcc -c -g -O2 conftest.c >&5 configure:9914: $? = 0 configure:9987: gcc -o conftest -g -O2 conftest.c >&5 configure:9987: $? = 0 configure:9987: ./conftest configure:9987: $? = 0 configure:9998: result: yes configure:10011: checking for sys/types.h configure:10011: gcc -c -g -O2 conftest.c >&5 configure:10011: $? = 0 configure:10011: result: yes configure:10011: checking for sys/stat.h configure:10011: gcc -c -g -O2 conftest.c >&5 configure:10011: $? = 0 configure:10011: result: yes configure:10011: checking for stdlib.h configure:10011: gcc -c -g -O2 conftest.c >&5 configure:10011: $? = 0 configure:10011: result: yes configure:10011: checking for string.h configure:10011: gcc -c -g -O2 conftest.c >&5 configure:10011: $? = 0 configure:10011: result: yes configure:10011: checking for memory.h configure:10011: gcc -c -g -O2 conftest.c >&5 configure:10011: $? = 0 configure:10011: result: yes configure:10011: checking for strings.h configure:10011: gcc -c -g -O2 conftest.c >&5 configure:10011: $? = 0 configure:10011: result: yes configure:10011: checking for inttypes.h configure:10011: gcc -c -g -O2 conftest.c >&5 configure:10011: $? = 0 configure:10011: result: yes configure:10011: checking for stdint.h configure:10011: gcc -c -g -O2 conftest.c >&5 configure:10011: $? = 0 configure:10011: result: yes configure:10011: checking for unistd.h configure:10011: gcc -c -g -O2 conftest.c >&5 configure:10011: $? = 0 configure:10011: result: yes configure:10025: checking for dlfcn.h configure:10025: gcc -c -g -O2 conftest.c >&5 configure:10025: $? = 0 configure:10025: result: yes configure:10541: checking for objdir configure:10556: result: .libs configure:10827: checking if gcc supports -fno-rtti -fno-exceptions configure:10845: gcc -c -g -O2 -fno-rtti -fno-exceptions conftest.c >&5 cc1: warning: command line option '-fno-rtti' is valid for C++/ObjC++ but not for C configure:10849: $? = 0 configure:10862: result: no configure:11189: checking for gcc option to produce PIC configure:11196: result: -fPIC -DPIC configure:11204: checking if gcc PIC flag -fPIC -DPIC works configure:11222: gcc -c -g -O2 -fPIC -DPIC -DPIC conftest.c >&5 configure:11226: $? = 0 configure:11239: result: yes configure:11268: checking if gcc static flag -static works configure:11296: result: yes configure:11311: checking if gcc supports -c -o file.o configure:11332: gcc -c -g -O2 -o out/conftest2.o conftest.c >&5 configure:11336: $? = 0 configure:11358: result: yes configure:11366: checking if gcc supports -c -o file.o configure:11413: result: yes configure:11446: checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries configure:12603: result: yes configure:12640: checking whether -lc should be explicitly linked in configure:12648: gcc -c -g -O2 conftest.c >&5 configure:12651: $? = 0 configure:12666: gcc -shared -fPIC -DPIC conftest.o -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 \| /bin/grep -lc \>/dev/null 2\>\&1 configure:12669: $? = 0 configure:12683: result: no configure:12843: checking dynamic linker characteristics configure:13343: gcc -o conftest -g -O2 -Wl,-rpath -Wl,/foo conftest.c >&5 configure:13343: $? = 0 configure:13577: result: GNU/Linux ld.so configure:13684: checking how to hardcode library paths into programs configure:13709: result: immediate configure:14249: checking whether stripping libraries is possible configure:14254: result: yes configure:14289: checking if libtool supports shared libraries configure:14291: result: yes configure:14294: checking whether to build shared libraries configure:14315: result: yes configure:14318: checking whether to build static libraries configure:14322: result: yes configure:14345: checking how to run the C++ preprocessor configure:14372: g++ -E conftest.cpp configure:14372: $? = 0 configure:14386: g++ -E conftest.cpp conftest.cpp:26:28: fatal error: ac_nonexistent.h: No such file or directory #include <ac_nonexistent.h> ^ compilation terminated. configure:14386: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | /* end confdefs.h. */ | #include <ac_nonexistent.h> configure:14411: result: g++ -E configure:14431: g++ -E conftest.cpp configure:14431: $? = 0 configure:14445: g++ -E conftest.cpp conftest.cpp:26:28: fatal error: ac_nonexistent.h: No such file or directory #include <ac_nonexistent.h> ^ compilation terminated. configure:14445: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | /* end confdefs.h. */ | #include <ac_nonexistent.h> configure:14614: checking for ld used by g++ configure:14681: result: /usr/bin/ld -m elf_x86_64 configure:14688: checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld configure:14703: result: yes configure:14758: checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries configure:15760: result: yes configure:15796: g++ -c -g -O2 conftest.cpp >&5 configure:15799: $? = 0 configure:16319: checking for g++ option to produce PIC configure:16326: result: -fPIC -DPIC configure:16334: checking if g++ PIC flag -fPIC -DPIC works configure:16352: g++ -c -g -O2 -fPIC -DPIC -DPIC conftest.cpp >&5 configure:16356: $? = 0 configure:16369: result: yes configure:16392: checking if g++ static flag -static works configure:16420: result: yes configure:16432: checking if g++ supports -c -o file.o configure:16453: g++ -c -g -O2 -o out/conftest2.o conftest.cpp >&5 configure:16457: $? = 0 configure:16479: result: yes configure:16484: checking if g++ supports -c -o file.o configure:16531: result: yes configure:16561: checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries configure:16600: result: yes configure:16741: checking dynamic linker characteristics configure:17409: result: GNU/Linux ld.so configure:17462: checking how to hardcode library paths into programs configure:17487: result: immediate configure:17635: checking if libtool supports shared libraries configure:17637: result: yes configure:17640: checking whether to build shared libraries configure:17660: result: yes configure:17663: checking whether to build static libraries configure:17667: result: yes configure:17988: checking for gfortran option to produce PIC configure:17995: result: -fPIC configure:18003: checking if gfortran PIC flag -fPIC works configure:18021: gfortran -c -g -O2 -fPIC conftest.f >&5 configure:18025: $? = 0 configure:18038: result: yes configure:18061: checking if gfortran static flag -static works configure:18089: result: yes configure:18101: checking if gfortran supports -c -o file.o configure:18122: gfortran -c -g -O2 -o out/conftest2.o conftest.f >&5 configure:18126: $? = 0 configure:18148: result: yes configure:18153: checking if gfortran supports -c -o file.o configure:18200: result: yes configure:18230: checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries configure:19337: result: yes configure:19478: checking dynamic linker characteristics configure:20140: result: GNU/Linux ld.so configure:20193: checking how to hardcode library paths into programs configure:20218: result: immediate configure:20273: checking whether ln -s works configure:20277: result: yes configure:20285: checking for ANSI C header files configure:20389: result: yes configure:20398: checking for C/C++ restrict keyword configure:20423: gcc -c -g -O2 conftest.c >&5 configure:20423: $? = 0 configure:20431: result: __restrict configure:20450: checking for bash configure:20477: result: /bin/sh configure:20492: checking for svn configure:20510: found /usr/bin/svn configure:20522: result: /usr/bin/svn configure:20532: checking for svnversion configure:20550: found /usr/bin/svnversion configure:20562: result: /usr/bin/svnversion configure:20596: checking for lib configure:20629: result: no configure:20669: checking size of void * configure:20674: gcc -o conftest -g -O2 conftest.c >&5 configure:20674: $? = 0 configure:20674: ./conftest configure:20674: $? = 0 configure:20688: result: 8 configure:20775: checking for pthread_create in -lpthread configure:20800: gcc -o conftest -g -O2 conftest.c -lpthread >&5 configure:20800: $? = 0 configure:20809: result: yes configure:20821: checking for struct timespec configure:20821: gcc -c -g -O2 conftest.c >&5 configure:20821: $? = 0 configure:20821: gcc -c -g -O2 conftest.c >&5 conftest.c: In function 'main': conftest.c:47:30: error: expected expression before ')' token if (sizeof ((struct timespec))) ^ configure:20821: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | /* end confdefs.h. */ | | #include <sys/types.h> | #include <sys/stat.h> | #ifdef HAVE_UNISTD_H | #include <unistd.h> | #endif | #include <time.h> | #ifndef STARPU_NATIVE_WINTHREADS | #include <pthread.h> | #endif | | | int | main () | { | if (sizeof ((struct timespec))) | return 0; | ; | return 0; | } configure:20821: result: yes configure:20840: checking for library containing sqrt configure:20871: gcc -o conftest -g -O2 conftest.c -lpthread >&5 conftest.c:40:6: warning: conflicting types for built-in function 'sqrt' char sqrt (); ^ /tmp/ccShYoen.o: In function `main': /nas_home/hpcfapix/starpu-1.1.4/conftest.c:44: undefined reference to `sqrt' collect2: error: ld returned 1 exit status configure:20871: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | /* end confdefs.h. */ | | /* Override any GCC internal prototype to avoid an error. | Use char because int might match the return type of a GCC | builtin and then its argument prototype would still apply. */ | #ifdef __cplusplus | extern "C" | #endif | char sqrt (); | int | main () | { | return sqrt (); | ; | return 0; | } configure:20871: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 conftest.c:40:6: warning: conflicting types for built-in function 'sqrt' char sqrt (); ^ configure:20871: $? = 0 configure:20888: result: -lm configure:20898: checking for main in -lws2_32 configure:20917: gcc -o conftest -g -O2 conftest.c -lws2_32 -lm -lpthread >&5 /usr/bin/ld: cannot find -lws2_32 collect2: error: ld returned 1 exit status configure:20917: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | /* end confdefs.h. */ | | | int | main () | { | return main (); | ; | return 0; | } configure:20926: result: no configure:20940: checking for sysconf configure:20940: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:20940: $? = 0 configure:20940: result: yes configure:20950: checking for pthread_spin_lock configure:20950: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:20950: $? = 0 configure:20950: result: yes configure:20963: checking for pthread_barrier_init configure:20963: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:20963: $? = 0 configure:20963: result: yes configure:20979: checking for pthread_setaffinity_np configure:20979: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:20979: $? = 0 configure:20979: result: yes configure:20992: checking for posix_memalign configure:20992: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 conftest.c:60:6: warning: conflicting types for built-in function 'posix_memalign' char posix_memalign (); ^ configure:20992: $? = 0 configure:20992: result: yes configure:21005: checking for memalign configure:21005: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21005: $? = 0 configure:21005: result: yes configure:21018: checking for drand48 configure:21018: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21018: $? = 0 configure:21018: result: yes configure:21025: checking for erand48_r configure:21025: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21025: $? = 0 configure:21025: result: yes configure:21052: checking for strerror_r configure:21052: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21052: $? = 0 configure:21052: result: yes configure:21061: checking for setenv configure:21061: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21061: $? = 0 configure:21061: result: yes configure:21070: checking for unsetenv configure:21070: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21070: $? = 0 configure:21070: result: yes configure:21079: checking for nearbyintf configure:21079: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 conftest.c:69:6: warning: conflicting types for built-in function 'nearbyintf' char nearbyintf (); ^ configure:21079: $? = 0 configure:21079: result: yes configure:21088: checking for rintf configure:21088: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 conftest.c:70:6: warning: conflicting types for built-in function 'rintf' char rintf (); ^ configure:21088: $? = 0 configure:21088: result: yes configure:21142: checking malloc.h usability configure:21142: gcc -c -g -O2 conftest.c >&5 configure:21142: $? = 0 configure:21142: result: yes configure:21142: checking malloc.h presence configure:21142: gcc -E conftest.c configure:21142: $? = 0 configure:21142: result: yes configure:21142: checking for malloc.h configure:21142: result: yes configure:21165: checking valgrind/valgrind.h usability configure:21165: gcc -c -g -O2 conftest.c >&5 conftest.c:83:31: fatal error: valgrind/valgrind.h: No such file or directory #include <valgrind/valgrind.h> ^ compilation terminated. configure:21165: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <valgrind/valgrind.h> configure:21165: result: no configure:21165: checking valgrind/valgrind.h presence configure:21165: gcc -E conftest.c conftest.c:50:31: fatal error: valgrind/valgrind.h: No such file or directory #include <valgrind/valgrind.h> ^ compilation terminated. configure:21165: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | /* end confdefs.h. */ | #include <valgrind/valgrind.h> configure:21165: result: no configure:21165: checking for valgrind/valgrind.h configure:21165: result: no configure:21179: checking valgrind/helgrind.h usability configure:21179: gcc -c -g -O2 conftest.c >&5 conftest.c:83:31: fatal error: valgrind/helgrind.h: No such file or directory #include <valgrind/helgrind.h> ^ compilation terminated. configure:21179: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <valgrind/helgrind.h> configure:21179: result: no configure:21179: checking valgrind/helgrind.h presence configure:21179: gcc -E conftest.c conftest.c:50:31: fatal error: valgrind/helgrind.h: No such file or directory #include <valgrind/helgrind.h> ^ compilation terminated. configure:21179: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | /* end confdefs.h. */ | #include <valgrind/helgrind.h> configure:21179: result: no configure:21179: checking for valgrind/helgrind.h configure:21179: result: no configure:21198: checking for sched_yield configure:21198: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21198: $? = 0 configure:21198: result: yes configure:21208: checking whether the target supports __sync_val_compare_and_swap configure:21225: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21225: $? = 0 configure:21233: result: yes configure:21243: checking whether the target supports __sync_bool_compare_and_swap configure:21260: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21260: $? = 0 configure:21268: result: yes configure:21278: checking whether the target supports __sync_fetch_and_add configure:21295: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21295: $? = 0 configure:21303: result: yes configure:21313: checking whether the target supports __sync_fetch_and_or configure:21330: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21330: $? = 0 configure:21338: result: yes configure:21348: checking whether the target supports __sync_lock_test_and_set configure:21365: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21365: $? = 0 configure:21373: result: yes configure:21383: checking whether the target supports __sync_synchronize configure:21400: gcc -o conftest -g -O2 conftest.c -lm -lpthread >&5 configure:21400: $? = 0 configure:21408: result: yes configure:21420: checking for library containing set_mempolicy configure:21451: gcc -o conftest -g -O2 -D_GNU_SOURCE conftest.c >&5 /tmp/ccd7o60N.o: In function `main': /nas_home/hpcfapix/starpu-1.1.4/conftest.c:68: undefined reference to `set_mempolicy' collect2: error: ld returned 1 exit status configure:21451: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | /* end confdefs.h. */ | | /* Override any GCC internal prototype to avoid an error. | Use char because int might match the return type of a GCC | builtin and then its argument prototype would still apply. */ | #ifdef __cplusplus | extern "C" | #endif | char set_mempolicy (); | int | main () | { | return set_mempolicy (); | ; | return 0; | } configure:21451: gcc -o conftest -g -O2 -D_GNU_SOURCE conftest.c -lnuma >&5 configure:21451: $? = 0 configure:21468: result: -lnuma configure:21482: checking whether libnuma is available configure:21484: result: yes configure:21497: checking maximum number of sched_ctxs configure:21506: result: 10 configure:21558: checking maximum number of CPUs configure:21567: result: 64 configure:21575: checking whether CPUs should be used configure:21584: result: yes configure:21617: checking maximum number of CUDA devices configure:21626: result: 4 configure:21705: checking whether CUDA is available configure:21708: result: configure:21722: checking cuda.h usability configure:21722: gcc -c -g -O2 -D_GNU_SOURCE conftest.c >&5 conftest.c:96:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:21722: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <cuda.h> configure:21722: result: no configure:21722: checking cuda.h presence configure:21722: gcc -E -D_GNU_SOURCE conftest.c conftest.c:63:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:21722: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cuda.h> configure:21722: result: no configure:21722: checking for cuda.h configure:21722: result: no configure:22189: checking whether CUDA is available configure:22192: result: configure:22206: checking cuda.h usability configure:22206: gcc -c -g -O2 -D_GNU_SOURCE conftest.c >&5 conftest.c:96:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22206: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <cuda.h> configure:22206: result: no configure:22206: checking cuda.h presence configure:22206: gcc -E -D_GNU_SOURCE conftest.c conftest.c:63:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22206: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cuda.h> configure:22206: result: no configure:22206: checking for cuda.h configure:22206: result: no configure:22673: checking whether CUDA is available in /usr/local/cuda configure:22679: result: configure:22693: checking cuda.h usability configure:22693: gcc -c -g -O2 -D_GNU_SOURCE -I/usr/local/cuda/include conftest.c >&5 conftest.c:96:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <cuda.h> configure:22693: result: no configure:22693: checking cuda.h presence configure:22693: gcc -E -D_GNU_SOURCE -I/usr/local/cuda/include conftest.c conftest.c:63:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cuda.h> configure:22693: result: no configure:22693: checking for cuda.h configure:22693: result: no configure:22673: checking whether CUDA is available in /c/cuda configure:22679: result: configure:22693: checking cuda.h usability configure:22693: gcc -c -g -O2 -D_GNU_SOURCE -I/c/cuda/include conftest.c >&5 conftest.c:96:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <cuda.h> configure:22693: result: no configure:22693: checking cuda.h presence configure:22693: gcc -E -D_GNU_SOURCE -I/c/cuda/include conftest.c conftest.c:63:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cuda.h> configure:22693: result: no configure:22693: checking for cuda.h configure:22693: result: no configure:22673: checking whether CUDA is available in /cygdrive/c/cuda configure:22679: result: configure:22693: checking cuda.h usability configure:22693: gcc -c -g -O2 -D_GNU_SOURCE -I/cygdrive/c/cuda/include conftest.c >&5 conftest.c:96:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <cuda.h> configure:22693: result: no configure:22693: checking cuda.h presence configure:22693: gcc -E -D_GNU_SOURCE -I/cygdrive/c/cuda/include conftest.c conftest.c:63:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cuda.h> configure:22693: result: no configure:22693: checking for cuda.h configure:22693: result: no configure:22673: checking whether CUDA is available in /opt/cuda configure:22679: result: configure:22693: checking cuda.h usability configure:22693: gcc -c -g -O2 -D_GNU_SOURCE -I/opt/cuda/include conftest.c >&5 conftest.c:96:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <cuda.h> configure:22693: result: no configure:22693: checking cuda.h presence configure:22693: gcc -E -D_GNU_SOURCE -I/opt/cuda/include conftest.c conftest.c:63:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cuda.h> configure:22693: result: no configure:22693: checking for cuda.h configure:22693: result: no configure:22673: checking whether CUDA is available in /.. configure:22679: result: configure:22693: checking cuda.h usability configure:22693: gcc -c -g -O2 -D_GNU_SOURCE -I/../include conftest.c >&5 conftest.c:96:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <cuda.h> configure:22693: result: no configure:22693: checking cuda.h presence configure:22693: gcc -E -D_GNU_SOURCE -I/../include conftest.c conftest.c:63:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cuda.h> configure:22693: result: no configure:22693: checking for cuda.h configure:22693: result: no configure:22673: checking whether CUDA is available in /.. configure:22679: result: configure:22693: checking cuda.h usability configure:22693: gcc -c -g -O2 -D_GNU_SOURCE -I/../include conftest.c >&5 conftest.c:96:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <cuda.h> configure:22693: result: no configure:22693: checking cuda.h presence configure:22693: gcc -E -D_GNU_SOURCE -I/../include conftest.c conftest.c:63:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cuda.h> configure:22693: result: no configure:22693: checking for cuda.h configure:22693: result: no configure:22673: checking whether CUDA is available in /.. configure:22679: result: configure:22693: checking cuda.h usability configure:22693: gcc -c -g -O2 -D_GNU_SOURCE -I/../include conftest.c >&5 conftest.c:96:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <cuda.h> configure:22693: result: no configure:22693: checking cuda.h presence configure:22693: gcc -E -D_GNU_SOURCE -I/../include conftest.c conftest.c:63:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cuda.h> configure:22693: result: no configure:22693: checking for cuda.h configure:22693: result: no configure:22673: checking whether CUDA is available in /.. configure:22679: result: configure:22693: checking cuda.h usability configure:22693: gcc -c -g -O2 -D_GNU_SOURCE -I/../include conftest.c >&5 conftest.c:96:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <cuda.h> configure:22693: result: no configure:22693: checking cuda.h presence configure:22693: gcc -E -D_GNU_SOURCE -I/../include conftest.c conftest.c:63:18: fatal error: cuda.h: No such file or directory #include <cuda.h> ^ compilation terminated. configure:22693: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cuda.h> configure:22693: result: no configure:22693: checking for cuda.h configure:22693: result: no configure:23148: checking whether CUDA is working configure:23212: result: no configure:23275: checking whether CUDA should be used configure:23277: result: no configure:23376: checking for pkg-config configure:23394: found /usr/bin/pkg-config configure:23406: result: /usr/bin/pkg-config configure:23431: checking pkg-config is at least version 0.9.0 configure:23434: result: yes configure:23533: checking whether MAGMA should be used configure:23535: result: no configure:23539: checking for cufftDoubleComplex configure:23539: gcc -c -g -O2 -D_GNU_SOURCE conftest.c >&5 conftest.c:63:19: fatal error: cufft.h: No such file or directory #include <cufft.h> ^ compilation terminated. configure:23539: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | /* end confdefs.h. */ | #include <cufft.h> | | int | main () | { | if (sizeof (cufftDoubleComplex)) | return 0; | ; | return 0; | } configure:23539: result: no configure:23605: checking whether CURAND is available configure:23607: result: no configure:23663: checking maximum number of OpenCL devices configure:23672: result: 8 configure:23785: checking whether OpenCL is available configure:23788: result: configure:23801: checking CL/cl.h usability configure:23801: gcc -c -g -O2 -D_GNU_SOURCE conftest.c >&5 conftest.c:97:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:23801: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <CL/cl.h> configure:23801: result: no configure:23801: checking CL/cl.h presence configure:23801: gcc -E -D_GNU_SOURCE conftest.c conftest.c:64:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:23801: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <CL/cl.h> configure:23801: result: no configure:23801: checking for CL/cl.h configure:23801: result: no configure:24025: checking whether OpenCL is available in /usr/local/cuda no and no configure:24031: result: configure:24044: checking CL/cl.h usability configure:24044: gcc -c -g -O2 -D_GNU_SOURCE -I/usr/local/cuda/include conftest.c >&5 conftest.c:97:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:24044: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <CL/cl.h> configure:24044: result: no configure:24044: checking CL/cl.h presence configure:24044: gcc -E -D_GNU_SOURCE -I/usr/local/cuda/include conftest.c conftest.c:64:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:24044: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <CL/cl.h> configure:24044: result: no configure:24044: checking for CL/cl.h configure:24044: result: no configure:24025: checking whether OpenCL is available in /c/cuda no and no configure:24031: result: configure:24044: checking CL/cl.h usability configure:24044: gcc -c -g -O2 -D_GNU_SOURCE -I/c/cuda/include conftest.c >&5 conftest.c:97:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:24044: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <CL/cl.h> configure:24044: result: no configure:24044: checking CL/cl.h presence configure:24044: gcc -E -D_GNU_SOURCE -I/c/cuda/include conftest.c conftest.c:64:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:24044: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <CL/cl.h> configure:24044: result: no configure:24044: checking for CL/cl.h configure:24044: result: no configure:24025: checking whether OpenCL is available in /cygdrive/c/cuda no and no configure:24031: result: configure:24044: checking CL/cl.h usability configure:24044: gcc -c -g -O2 -D_GNU_SOURCE -I/cygdrive/c/cuda/include conftest.c >&5 conftest.c:97:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:24044: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <CL/cl.h> configure:24044: result: no configure:24044: checking CL/cl.h presence configure:24044: gcc -E -D_GNU_SOURCE -I/cygdrive/c/cuda/include conftest.c conftest.c:64:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:24044: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <CL/cl.h> configure:24044: result: no configure:24044: checking for CL/cl.h configure:24044: result: no configure:24025: checking whether OpenCL is available in /opt/cuda no and no configure:24031: result: configure:24044: checking CL/cl.h usability configure:24044: gcc -c -g -O2 -D_GNU_SOURCE -I/opt/cuda/include conftest.c >&5 conftest.c:97:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:24044: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <CL/cl.h> configure:24044: result: no configure:24044: checking CL/cl.h presence configure:24044: gcc -E -D_GNU_SOURCE -I/opt/cuda/include conftest.c conftest.c:64:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:24044: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <CL/cl.h> configure:24044: result: no configure:24044: checking for CL/cl.h configure:24044: result: no configure:24025: checking whether OpenCL is available in /.. no and no configure:24031: result: configure:24044: checking CL/cl.h usability configure:24044: gcc -c -g -O2 -D_GNU_SOURCE -I/../include conftest.c >&5 conftest.c:97:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:24044: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <CL/cl.h> configure:24044: result: no configure:24044: checking CL/cl.h presence configure:24044: gcc -E -D_GNU_SOURCE -I/../include conftest.c conftest.c:64:19: fatal error: CL/cl.h: No such file or directory #include <CL/cl.h> ^ compilation terminated. configure:24044: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | /* end confdefs.h. */ | #include <CL/cl.h> configure:24044: result: no configure:24044: checking for CL/cl.h configure:24044: result: no configure:24278: checking whether OpenCL should be used configure:24280: result: no configure:24308: checking whether asynchronous copy should be disabled configure:24321: result: no configure:24329: checking whether asynchronous CUDA copy should be disabled configure:24342: result: no configure:24350: checking whether asynchronous OpenCL copy should be disabled configure:24363: result: no configure:24552: checking whether SimGrid is enabled configure:24554: result: no configure:24557: checking whether blocking drivers should be disabled configure:24566: result: no configure:24582: checking whether debug mode should be enabled configure:24591: result: no configure:24619: checking whether extra checks should be performed configure:24628: result: no configure:24636: checking whether debug messages should be displayed configure:24645: result: no configure:24653: checking whether coverage testing should be enabled configure:24662: result: no configure:24680: checking whether FxT traces should be generated configure:24711: result: no configure:25052: checking whether performance debugging should be enabled configure:25061: result: no configure:25073: checking whether performance model debugging should be enabled configure:25082: result: no configure:25090: checking whether statistics should be generated configure:25099: result: no configure:25111: checking whether memory stats should be displayed configure:25120: result: no configure:25130: checking glpk.h usability configure:25130: gcc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c >&5 conftest.c:98:18: fatal error: glpk.h: No such file or directory #include <glpk.h> ^ compilation terminated. configure:25130: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <glpk.h> configure:25130: result: no configure:25130: checking glpk.h presence configure:25130: gcc -E -D_GNU_SOURCE conftest.c conftest.c:65:18: fatal error: glpk.h: No such file or directory #include <glpk.h> ^ compilation terminated. configure:25130: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | /* end confdefs.h. */ | #include <glpk.h> configure:25130: result: no configure:25130: checking for glpk.h configure:25130: result: no configure:25144: checking for main in -lglpk configure:25163: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lglpk >&5 configure:25163: $? = 0 configure:25172: result: yes configure:25190: checking Ayudame.h usability configure:25190: gcc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c >&5 conftest.c:99:21: fatal error: Ayudame.h: No such file or directory #include <Ayudame.h> ^ compilation terminated. configure:25190: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <Ayudame.h> configure:25190: result: no configure:25190: checking Ayudame.h presence configure:25190: gcc -E -D_GNU_SOURCE conftest.c conftest.c:66:21: fatal error: Ayudame.h: No such file or directory #include <Ayudame.h> ^ compilation terminated. configure:25190: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | /* end confdefs.h. */ | #include <Ayudame.h> configure:25190: result: no configure:25190: checking for Ayudame.h configure:25190: result: no configure:25207: checking how many buffers can be manipulated per task configure:25216: result: 8 configure:25249: checking maximum number of memory nodes configure:25251: result: 1 configure:25260: checking whether allocation cache should be used configure:25269: result: yes configure:25303: checking using explicit performance model location configure:25305: result: no configure:25308: checking performance models location configure:25310: result: $HOME/.starpu/sampling/ configure:25314: checking for clock_gettime in -lrt configure:25339: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lrt -lm -lpthread >&5 configure:25339: $? = 0 configure:25348: result: yes configure:25361: checking for clock_gettime configure:25361: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lrt -lm -lpthread >&5 configure:25361: $? = 0 configure:25361: result: yes configure:25385: checking Maximum number of workers configure:25387: result: 64 configure:25396: checking maximum number of implementations configure:25405: result: 4 configure:25434: checking for mpicc configure:25452: found /opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpicc configure:25465: result: /opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpicc configure:25487: checking mpicc path configure:25489: result: /opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpicc configure:25541: checking for mpiexec configure:25560: found /opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpiexec configure:25573: result: /opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpiexec configure:25585: checking whether mpiexec is available configure:25587: result: /opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpiexec configure:25608: checking whether MPI tests should be run configure:25610: result: no configure:25616: checking whether the StarPU MPI library should be generated configure:25618: result: yes configure:25666: checking for StarPU-Top configure:25675: checking for qmake-qt4 configure:25708: result: no configure:25675: checking for qmake configure:25708: result: no configure:25805: checking whether compiler support -Wall configure:25827: gcc -c -Wall -D_GNU_SOURCE conftest.c >&5 conftest.c: In function 'main': conftest.c:80:18: warning: unused variable 'hello' [-Wunused-variable] const char *hello = "Hello World"; ^ configure:25827: $? = 0 configure:25830: result: yes configure:25844: checking whether compiler support -Werror=implicit configure:25866: gcc -c -Werror=implicit -D_GNU_SOURCE conftest.c >&5 configure:25866: $? = 0 configure:25869: result: yes configure:25883: checking whether compiler support -Werror=implicit-function-declaration configure:25905: gcc -c -Werror=implicit-function-declaration -D_GNU_SOURCE conftest.c >&5 configure:25905: $? = 0 configure:25908: result: yes configure:26153: checking whether GCC supports plug-ins configure:26208: gcc -c -O3 -g -O2 -gdwarf-2 -g3 -I/opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include conftest.c >&5 In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/config.h:6:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:27, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/auto-host.h:1748:0: warning: "PACKAGE_BUGREPORT" redefined #define PACKAGE_BUGREPORT "" ^ conftest.c:6:0: note: this is the location of the previous definition #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/config.h:6:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:27, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/auto-host.h:1754:0: warning: "PACKAGE_NAME" redefined #define PACKAGE_NAME "" ^ conftest.c:2:0: note: this is the location of the previous definition #define PACKAGE_NAME "StarPU" ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/config.h:6:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:27, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/auto-host.h:1760:0: warning: "PACKAGE_STRING" redefined #define PACKAGE_STRING "" ^ conftest.c:5:0: note: this is the location of the previous definition #define PACKAGE_STRING "StarPU 1.1.4" ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/config.h:6:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:27, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/auto-host.h:1766:0: warning: "PACKAGE_TARNAME" redefined #define PACKAGE_TARNAME "" ^ conftest.c:3:0: note: this is the location of the previous definition #define PACKAGE_TARNAME "starpu" ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/config.h:6:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:27, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/auto-host.h:1772:0: warning: "PACKAGE_URL" redefined #define PACKAGE_URL "" ^ conftest.c:7:0: note: this is the location of the previous definition #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/config.h:6:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:27, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/auto-host.h:1778:0: warning: "PACKAGE_VERSION" redefined #define PACKAGE_VERSION "" ^ conftest.c:4:0: note: this is the location of the previous definition #define PACKAGE_VERSION "1.1.4" ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:29:0, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/coretypes.h:171:1: error: unknown type name 'class' class rtl_opt_pass; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/coretypes.h:173:1: error: unknown type name 'namespace' namespace gcc { ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/coretypes.h:173:15: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token namespace gcc { ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:24:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:23, from conftest.c:75: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/machmode.h:262:1: error: unknown type name 'class' class bit_field_mode_iterator ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/machmode.h:263:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token { ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:27:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:23, from conftest.c:75: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:218:8: error: field 'register_overhead' declared as a function void register_overhead (size_t, const char *, int, const char *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:219:8: error: field 'release_overhead' declared as a function void release_overhead (void); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:220:3: error: expected specifier-qualifier-list before 'static' static unsigned calculate_allocation (vec_prefix *, unsigned, bool); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:246:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token vec_prefix::calculate_allocation (vec_prefix *pfx, unsigned reserve, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:256:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename, typename, typename> struct vec; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:279:3: error: expected specifier-qualifier-list before 'typedef' typedef vl_ptr default_layout; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:295:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:319:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:342:3: error: expected specifier-qualifier-list before 'typedef' typedef vl_embed default_layout; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:355:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:370:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:408:21: error: expected identifier or '(' before ':' token struct va_gc_atomic : va_gc ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:424:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:437:3: error: expected specifier-qualifier-list before 'template' template <typename T, typename A, typename L> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:440:8: error: unknown type name 'vnull' extern vnull vNULL; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:469:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:532:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:541:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:550:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:559:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:569:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:580:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:592:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:603:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:612:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:624:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:635:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:648:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:664:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:675:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:686:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:696:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:705:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:723:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:731:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:742:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:757:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:772:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:798:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:817:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:836:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:849:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:862:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:875:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:887:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:899:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:915:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:928:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:940:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:954:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:966:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1003:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1042:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1054:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1067:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1079:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1091:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1100:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1111:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1120:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1128:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, typename A> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1166:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1247:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T, size_t N = 0> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1269:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1283:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1294:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1305:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1325:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1348:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1387:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1407:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1443:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1456:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1468:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1489:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1503:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1520:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1532:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1543:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1554:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1569:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1584:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1597:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1610:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1622:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1633:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1646:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1657:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1668:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1679:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1691:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1707:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/vec.h:1716:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template<typename T> ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:28:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:23, from conftest.c:75: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:58:3: error: expected specifier-qualifier-list before 'static' static double_int from_uhwi (unsigned HOST_WIDE_INT cst); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:207:8: error: unknown type name 'double_int' inline double_int ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:208:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::from_shwi (HOST_WIDE_INT cst) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:230:8: error: unknown type name 'double_int' inline double_int ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:231:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::from_uhwi (unsigned HOST_WIDE_INT cst) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:239:8: error: unknown type name 'double_int' inline double_int ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:240:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::from_pair (HOST_WIDE_INT high, unsigned HOST_WIDE_INT low) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:248:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before '&' token inline double_int & ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:255:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before '&' token inline double_int & ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:262:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before '&' token inline double_int & ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:269:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before '&' token inline double_int & ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:276:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before '&' token inline double_int & ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:287:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::to_shwi () const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:296:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::to_uhwi () const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:304:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::fits_uhwi () const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:313:8: error: unknown type name 'double_int' inline double_int ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:314:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::operator ~ () const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:324:8: error: unknown type name 'double_int' inline double_int ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:325:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::operator | (double_int b) const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:335:8: error: unknown type name 'double_int' inline double_int ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:336:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::operator & (double_int b) const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:346:8: error: unknown type name 'double_int' inline double_int ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:347:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::and_not (double_int b) const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:357:8: error: unknown type name 'double_int' inline double_int ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:358:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::operator ^ (double_int b) const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:366:31: error: unknown type name 'double_int' void dump_double_int (FILE *, double_int, bool); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:377:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::is_zero () const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:385:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::is_one () const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:393:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::is_minus_one () const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:401:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::is_negative () const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:409:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::operator == (double_int cst2) const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:417:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::operator != (double_int cst2) const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:425:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token double_int::popcount () const ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:434:33: error: unknown type name 'double_int' void mpz_set_double_int (mpz_t, double_int, bool); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/double-int.h:435:1: error: unknown type name 'double_int' double_int mpz_get_double_int (const_tree, mpz_t, bool); ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:30:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:23, from conftest.c:75: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/fixed-value.h:29:3: error: unknown type name 'double_int' double_int data; /* Store data up to 2 wide integers. */ ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/fixed-value.h:55:12: error: expected ')' before 'enum' enum machine_mode); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/fixed-value.h:60:30: error: unknown type name 'double_int' const_fixed_from_double_int (double_int payload, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/fixed-value.h:81:9: error: unknown type name 'double_int' double_int, bool, bool); ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/flags.h:24:0, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:32, from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:23, from conftest.c:75: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4086:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4094:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4102:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4110:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4118:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4126:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4134:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4142:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4150:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4158:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4166:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/options.h:4174:28: error: unknown type name 'diagnostic_context' diagnostic_context *dc); ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:23:0, from conftest.c:75: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:1051:3: error: unknown type name 'double_int' double_int int_cst; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:1109:3: error: expected specifier-qualifier-list before 'vec' vec<constructor_elt, va_gc> *elts; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:1233:3: error: expected specifier-qualifier-list before 'vec' vec<tree, va_gc> *nonlocalized_vars; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:1304:3: error: expected specifier-qualifier-list before 'vec' vec<tree, va_gc> *base_accesses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:1704:3: error: expected specifier-qualifier-list before 'vec' vec<tree, va_gc> *pending_statics; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:1752:3: error: expected specifier-qualifier-list before 'vec' vec<tree, va_gc> *to; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:1798:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token extern GTY(()) vec<alias_pair, va_gc> *alias_pairs; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:1811:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token extern GTY (()) vec<tree, va_gc> *all_translation_units; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree-core.h:1833:16: error: unknown type name 'builtin_info_type' extern GTY(()) builtin_info_type builtin_info; ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:29:0, from conftest.c:75: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/fold-const.h:121:8: error: unknown type name 'double_int' extern double_int mem_ref_offset (const_tree); ^ In file included from conftest.c:75:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:2592:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token extern vec<tree, va_gc> **decl_debug_args_lookup (tree); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:2593:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token extern vec<tree, va_gc> **decl_debug_args_insert (tree); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'tree_operand_length': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:880:52: error: request for member 'low' in something not a structure or union #define TREE_INT_CST_LOW(NODE) (TREE_INT_CST (NODE).low) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:1011:9: note: in expansion of macro 'TREE_INT_CST_LOW' ((int)TREE_INT_CST_LOW (VL_EXP_CHECK (NODE)->exp.operands[0])) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3145:12: note: in expansion of macro 'VL_EXP_OPERAND_LENGTH' return VL_EXP_OPERAND_LENGTH (node); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: At top level: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3457:38: error: unknown type name 'vec' extern tree build_nt_call_vec (tree, vec<tree, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3457:48: error: unknown type name 'va_gc' extern tree build_nt_call_vec (tree, vec<tree, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3541:15: error: unknown type name 'double_int' static inline double_int ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3547:39: error: unknown type name 'double_int' extern tree double_int_to_tree (tree, double_int); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3548:52: error: unknown type name 'double_int' extern bool double_int_fits_to_tree_p (const_tree, double_int); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3549:42: error: unknown type name 'double_int' extern tree force_fit_type_double (tree, double_int, int, bool); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'build_int_cstu': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3556:36: error: 'double_int' undeclared (first use in this function) return double_int_to_tree (type, double_int::from_uhwi (cst)); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3556:36: note: each undeclared identifier is reported only once for each function it appears in /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3556:46: error: expected ')' before ':' token return double_int_to_tree (type, double_int::from_uhwi (cst)); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: At top level: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3566:43: error: unknown type name 'vec' extern tree build_vector_from_ctor (tree, vec<constructor_elt, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3566:64: error: unknown type name 'va_gc' extern tree build_vector_from_ctor (tree, vec<constructor_elt, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3568:38: error: unknown type name 'vec' extern tree build_constructor (tree, vec<constructor_elt, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3568:59: error: unknown type name 'va_gc' extern tree build_constructor (tree, vec<constructor_elt, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3581:48: error: expected ';', ',' or ')' before '<' token extern tree build_tree_list_vec_stat (const vec<tree, va_gc> *MEM_STAT_DECL); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3600:41: error: unknown type name 'vec' extern tree build_call_vec (tree, tree, vec<tree, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3600:51: error: unknown type name 'va_gc' extern tree build_call_vec (tree, tree, vec<tree, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3637:37: error: unknown type name 'vec' extern bool vec_member (const_tree, vec<tree, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3637:47: error: unknown type name 'va_gc' extern bool vec_member (const_tree, vec<tree, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'tree_to_shwi': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:880:52: error: request for member 'low' in something not a structure or union #define TREE_INT_CST_LOW(NODE) (TREE_INT_CST (NODE).low) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3662:10: note: in expansion of macro 'TREE_INT_CST_LOW' return TREE_INT_CST_LOW (t); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'tree_to_uhwi': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:880:52: error: request for member 'low' in something not a structure or union #define TREE_INT_CST_LOW(NODE) (TREE_INT_CST (NODE).low) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3669:10: note: in expansion of macro 'TREE_INT_CST_LOW' return TREE_INT_CST_LOW (t); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: At top level: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3877:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token extern vec<tree, va_gc> *ctor_to_vec (tree); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:3964:45: error: unknown type name 'vec' extern void find_placeholder_in_expr (tree, vec<tree> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4063:26: error: unknown type name 'function_args_iterator' function_args_iter_init (function_args_iterator *i, const_tree fntype) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4072:30: error: unknown type name 'function_args_iterator' function_args_iter_cond_ptr (function_args_iterator *i) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4081:26: error: unknown type name 'function_args_iterator' function_args_iter_cond (function_args_iterator *i) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4088:26: error: unknown type name 'function_args_iterator' function_args_iter_next (function_args_iterator *i) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4305:40: error: unknown type name 'call_expr_arg_iterator' init_call_expr_arg_iterator (tree exp, call_expr_arg_iterator *iter) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4313:52: error: unknown type name 'const_call_expr_arg_iterator' init_const_call_expr_arg_iterator (const_tree exp, const_call_expr_arg_iterator *iter) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4323:21: error: unknown type name 'call_expr_arg_iterator' next_call_expr_arg (call_expr_arg_iterator *iter) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4334:27: error: unknown type name 'const_call_expr_arg_iterator' next_const_call_expr_arg (const_call_expr_arg_iterator *iter) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4349:32: error: unknown type name 'call_expr_arg_iterator' first_call_expr_arg (tree exp, call_expr_arg_iterator *iter) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4356:44: error: unknown type name 'const_call_expr_arg_iterator' first_const_call_expr_arg (const_tree exp, const_call_expr_arg_iterator *iter) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4365:30: error: unknown type name 'call_expr_arg_iterator' more_call_expr_args_p (const call_expr_arg_iterator *iter) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'more_call_expr_args_p': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4367:15: error: request for member 'i' in something not a structure or union return (iter->i < iter->n); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4367:25: error: request for member 'n' in something not a structure or union return (iter->i < iter->n); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'builtin_decl_explicit': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4397:22: error: request for member 'decl' in something not a structure or union return builtin_info.decl[(size_t)fncode]; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'builtin_decl_implicit': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4407:20: error: request for member 'implicit_p' in something not a structure or union if (!builtin_info.implicit_p[uns_fncode]) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4410:22: error: request for member 'decl' in something not a structure or union return builtin_info.decl[uns_fncode]; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'set_builtin_decl': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4424:15: error: request for member 'decl' in something not a structure or union builtin_info.decl[ufncode] = decl; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4425:15: error: request for member 'implicit_p' in something not a structure or union builtin_info.implicit_p[ufncode] = implicit_p; ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:28:0, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'set_builtin_decl_implicit_p': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4436:25: error: request for member 'decl' in something not a structure or union && builtin_info.decl[uns_fncode] != NULL_TREE); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/system.h:703:49: note: in definition of macro 'gcc_checking_assert' #define gcc_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:75:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4438:15: error: request for member 'implicit_p' in something not a structure or union builtin_info.implicit_p[uns_fncode] = implicit_p; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'builtin_decl_explicit_p': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4448:23: error: request for member 'decl' in something not a structure or union return (builtin_info.decl[(size_t)fncode] != NULL_TREE); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: In function 'builtin_decl_implicit_p': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4459:23: error: request for member 'decl' in something not a structure or union return (builtin_info.decl[uns_fncode] != NULL_TREE ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4460:19: error: request for member 'implicit_p' in something not a structure or union && builtin_info.implicit_p[uns_fncode]); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h: At top level: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4573:56: error: unknown type name 'vec' extern tree build_call_expr_loc_vec (location_t, tree, vec<tree, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/tree.h:4573:66: error: unknown type name 'va_gc' extern tree build_call_expr_loc_vec (location_t, tree, vec<tree, va_gc> *); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:29:12: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token typedef vec<gimple> gimple_vec; ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:210:34: error: expected identifier or '(' before ':' token gimple_statement_with_ops_base : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:226:29: error: expected identifier or '(' before ':' token gimple_statement_with_ops : public gimple_statement_with_ops_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:241:41: error: expected identifier or '(' before ':' token gimple_statement_with_memory_ops_base : public gimple_statement_with_ops_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:256:36: error: expected identifier or '(' before ':' token gimple_statement_with_memory_ops : ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:272:25: error: expected identifier or '(' before ':' token gimple_statement_call : public gimple_statement_with_memory_ops_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:297:24: error: expected identifier or '(' before ':' token gimple_statement_omp : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:309:25: error: expected identifier or '(' before ':' token gimple_statement_bind : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:333:26: error: expected identifier or '(' before ':' token gimple_statement_catch : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:348:30: error: expected identifier or '(' before ':' token gimple_statement_eh_filter : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:364:28: error: expected identifier or '(' before ':' token gimple_statement_eh_else : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:375:27: error: expected identifier or '(' before ':' token gimple_statement_eh_mnt : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:386:24: error: expected identifier or '(' before ':' token gimple_statement_phi : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:405:28: error: expected identifier or '(' before ':' token gimple_statement_eh_ctrl : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:415:25: error: expected identifier or '(' before ':' token gimple_statement_resx : public gimple_statement_eh_ctrl ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:422:32: error: expected identifier or '(' before ':' token gimple_statement_eh_dispatch : public gimple_statement_eh_ctrl ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:432:24: error: expected identifier or '(' before ':' token gimple_statement_try : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:462:24: error: expected identifier or '(' before ':' token gimple_statement_wce : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:480:24: error: expected identifier or '(' before ':' token gimple_statement_asm : public gimple_statement_with_memory_ops_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:505:33: error: expected identifier or '(' before ':' token gimple_statement_omp_critical : public gimple_statement_omp ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:535:28: error: expected identifier or '(' before ':' token gimple_statement_omp_for : public gimple_statement_omp ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:557:40: error: expected identifier or '(' before ':' token gimple_statement_omp_parallel_layout : public gimple_statement_omp ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:576:32: error: expected identifier or '(' before ':' token gimple_statement_omp_taskreg : public gimple_statement_omp_parallel_layout ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:586:33: error: expected identifier or '(' before ':' token gimple_statement_omp_parallel : public gimple_statement_omp_taskreg ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:593:31: error: expected identifier or '(' before ':' token gimple_statement_omp_target : public gimple_statement_omp_parallel_layout ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:602:29: error: expected identifier or '(' before ':' token gimple_statement_omp_task : public gimple_statement_omp_taskreg ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:624:33: error: expected identifier or '(' before ':' token gimple_statement_omp_sections : public gimple_statement_omp ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:643:33: error: expected identifier or '(' before ':' token gimple_statement_omp_continue : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:657:38: error: expected identifier or '(' before ':' token gimple_statement_omp_single_layout : public gimple_statement_omp ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:666:31: error: expected identifier or '(' before ':' token gimple_statement_omp_single : public gimple_statement_omp_single_layout ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:673:30: error: expected identifier or '(' before ':' token gimple_statement_omp_teams : public gimple_statement_omp_single_layout ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:685:36: error: expected identifier or '(' before ':' token gimple_statement_omp_atomic_load : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:697:44: error: expected identifier or '(' before ':' token gimple_statement_omp_atomic_store_layout : public gimple_statement_base ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:706:37: error: expected identifier or '(' before ':' token gimple_statement_omp_atomic_store : ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:714:31: error: expected identifier or '(' before ':' token gimple_statement_omp_return : ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:750:32: error: expected identifier or '(' before ':' token gimple_statement_transaction : public gimple_statement_with_memory_ops_base ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:768:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:776:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:784:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:792:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:800:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:808:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:816:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:824:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:832:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:840:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:848:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:856:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:864:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:872:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:880:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:888:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:896:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:904:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:912:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:920:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:928:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:936:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:944:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:952:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:960:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:968:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:976:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:984:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:992:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1000:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1008:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1016:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1024:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1032:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1040:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1048:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1056:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1064:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1072:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1080:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1088:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1096:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1104:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1112:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1120:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1128:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1136:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1144:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1167:37: error: unknown type name 'vec' gimple gimple_build_call_vec (tree, vec<tree> ); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1170:41: warning: 'enum internal_fn' declared inside parameter list gimple gimple_build_call_internal (enum internal_fn, unsigned, ...); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1170:41: warning: its scope is only this definition or declaration, which is probably not what you want /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1171:58: error: unknown type name 'vec' gimple gimple_build_call_internal_vec (enum internal_fn, vec<tree> ); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1177:8: error: conflicting types for 'gimple_build_assign_with_ops' gimple gimple_build_assign_with_ops (enum tree_code, tree, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1175:8: note: previous declaration of 'gimple_build_assign_with_ops' was here gimple gimple_build_assign_with_ops (enum tree_code, tree, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1186:44: error: unknown type name 'vec' gimple gimple_build_asm_vec (const char *, vec<tree, va_gc> *, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1186:54: error: unknown type name 'va_gc' gimple gimple_build_asm_vec (const char *, vec<tree, va_gc> *, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1187:9: error: unknown type name 'vec' vec<tree, va_gc> *, vec<tree, va_gc> *, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1187:19: error: unknown type name 'va_gc' vec<tree, va_gc> *, vec<tree, va_gc> *, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1187:29: error: unknown type name 'vec' vec<tree, va_gc> *, vec<tree, va_gc> *, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1187:39: error: unknown type name 'va_gc' vec<tree, va_gc> *, vec<tree, va_gc> *, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1188:9: error: unknown type name 'vec' vec<tree, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1188:19: error: unknown type name 'va_gc' vec<tree, va_gc> *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1193:1: error: unknown type name 'gimple_statement_try' gimple_statement_try *gimple_build_try (gimple_seq, gimple_seq, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1198:41: error: unknown type name 'vec' gimple gimple_build_switch (tree, tree, vec<tree> ); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1224:54: warning: 'enum prediction' declared inside parameter list gimple gimple_build_predict (enum br_predictor, enum prediction); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1224:54: warning: 'enum br_predictor' declared inside parameter list /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1228:59: error: unknown type name 'gimple_stmt_iterator' extern void annotate_all_with_location_after (gimple_seq, gimple_stmt_iterator, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1241:39: error: unknown type name 'gimple_stmt_iterator' void gimple_assign_set_rhs_from_tree (gimple_stmt_iterator *, tree); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1242:40: error: unknown type name 'gimple_stmt_iterator' void gimple_assign_set_rhs_with_ops_1 (gimple_stmt_iterator *, enum tree_code, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1262:13: error: conflicting types for 'gimple_call_builtin_p' extern bool gimple_call_builtin_p (gimple, enum built_in_class); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1261:13: note: previous declaration of 'gimple_call_builtin_p' was here extern bool gimple_call_builtin_p (gimple); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1263:13: error: conflicting types for 'gimple_call_builtin_p' extern bool gimple_call_builtin_p (gimple, enum built_in_function); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1261:13: note: previous declaration of 'gimple_call_builtin_p' was here extern bool gimple_call_builtin_p (gimple); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1268:34: error: expected ')' before '<' token extern void sort_case_labels (vec<tree> ); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1269:54: error: expected ')' before '<' token extern void preprocess_case_label_vec_for_gimple (vec<tree> , tree, tree *); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_stmt_max_uid': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1285:12: error: dereferencing pointer to incomplete type return fn->last_stmt_uid; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'set_gimple_stmt_max_uid': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1292:5: error: dereferencing pointer to incomplete type fn->last_stmt_uid = maxid; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'inc_gimple_stmt_max_uid': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1299:12: error: dereferencing pointer to incomplete type return fn->last_stmt_uid++; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'bb_seq': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1382:15: error: dereferencing pointer to incomplete type return (!(bb->flags & BB_RTL)) ? bb->il.gimple.seq : NULL; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1382:25: error: 'BB_RTL' undeclared (first use in this function) return (!(bb->flags & BB_RTL)) ? bb->il.gimple.seq : NULL; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1382:38: error: dereferencing pointer to incomplete type return (!(bb->flags & BB_RTL)) ? bb->il.gimple.seq : NULL; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'bb_seq_addr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1388:15: error: dereferencing pointer to incomplete type return (!(bb->flags & BB_RTL)) ? &bb->il.gimple.seq : NULL; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1388:25: error: 'BB_RTL' undeclared (first use in this function) return (!(bb->flags & BB_RTL)) ? &bb->il.gimple.seq : NULL; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1388:39: error: dereferencing pointer to incomplete type return (!(bb->flags & BB_RTL)) ? &bb->il.gimple.seq : NULL; ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:28:0, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'set_bb_seq': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1396:28: error: dereferencing pointer to incomplete type gcc_checking_assert (!(bb->flags & BB_RTL)); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/system.h:703:49: note: in definition of macro 'gcc_checking_assert' #define gcc_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1396:38: error: 'BB_RTL' undeclared (first use in this function) gcc_checking_assert (!(bb->flags & BB_RTL)); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/system.h:703:49: note: in definition of macro 'gcc_checking_assert' #define gcc_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1397:5: error: dereferencing pointer to incomplete type bb->il.gimple.seq = seq; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: At top level: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1648:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1656:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1672:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1680:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token template <> ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_use_ops': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1693:9: error: unknown type name 'gimple_statement_with_ops' const gimple_statement_with_ops *ops_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1694:5: error: 'dyn_cast' undeclared (first use in this function) dyn_cast <const gimple_statement_with_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1694:15: error: expected expression before 'const' dyn_cast <const gimple_statement_with_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1697:18: error: request for member 'use_ops' in something not a structure or union return ops_stmt->use_ops; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_set_use_ops': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1706:3: error: unknown type name 'gimple_statement_with_ops' gimple_statement_with_ops *ops_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1707:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_with_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1707:11: error: 'gimple_statement_with_ops' undeclared (first use in this function) as_a <gimple_statement_with_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1708:11: error: request for member 'use_ops' in something not a structure or union ops_stmt->use_ops = use; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_vuse': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1717:9: error: unknown type name 'gimple_statement_with_memory_ops' const gimple_statement_with_memory_ops *mem_ops_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1718:6: error: 'dyn_cast' undeclared (first use in this function) dyn_cast <const gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1718:16: error: expected expression before 'const' dyn_cast <const gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1721:22: error: request for member 'vuse' in something not a structure or union return mem_ops_stmt->vuse; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_vdef': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1729:9: error: unknown type name 'gimple_statement_with_memory_ops' const gimple_statement_with_memory_ops *mem_ops_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1730:6: error: 'dyn_cast' undeclared (first use in this function) dyn_cast <const gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1730:16: error: expected expression before 'const' dyn_cast <const gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1733:22: error: request for member 'vdef' in something not a structure or union return mem_ops_stmt->vdef; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_vuse_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1741:3: error: unknown type name 'gimple_statement_with_memory_ops' gimple_statement_with_memory_ops *mem_ops_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1742:6: error: 'dyn_cast' undeclared (first use in this function) dyn_cast <gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1742:16: error: 'gimple_statement_with_memory_ops' undeclared (first use in this function) dyn_cast <gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1745:23: error: request for member 'vuse' in something not a structure or union return &mem_ops_stmt->vuse; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_vdef_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1753:3: error: unknown type name 'gimple_statement_with_memory_ops' gimple_statement_with_memory_ops *mem_ops_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1754:6: error: 'dyn_cast' undeclared (first use in this function) dyn_cast <gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1754:16: error: 'gimple_statement_with_memory_ops' undeclared (first use in this function) dyn_cast <gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1757:23: error: request for member 'vdef' in something not a structure or union return &mem_ops_stmt->vdef; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_set_vuse': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1765:3: error: unknown type name 'gimple_statement_with_memory_ops' gimple_statement_with_memory_ops *mem_ops_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1766:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1766:11: error: 'gimple_statement_with_memory_ops' undeclared (first use in this function) as_a <gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1767:15: error: request for member 'vuse' in something not a structure or union mem_ops_stmt->vuse = vuse; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_set_vdef': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1775:3: error: unknown type name 'gimple_statement_with_memory_ops' gimple_statement_with_memory_ops *mem_ops_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1776:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1776:11: error: 'gimple_statement_with_memory_ops' undeclared (first use in this function) as_a <gimple_statement_with_memory_ops> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1777:15: error: request for member 'vdef' in something not a structure or union mem_ops_stmt->vdef = vdef; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_return_set_lhs': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1907:3: error: unknown type name 'gimple_statement_omp_return' gimple_statement_omp_return *omp_return_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1908:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_return> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1908:11: error: 'gimple_statement_omp_return' undeclared (first use in this function) as_a <gimple_statement_omp_return> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1909:18: error: request for member 'val' in something not a structure or union omp_return_stmt->val = lhs; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_return_lhs': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1918:9: error: unknown type name 'gimple_statement_omp_return' const gimple_statement_omp_return *omp_return_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1919:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_return> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1919:11: error: expected expression before 'const' as_a <const gimple_statement_omp_return> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1920:25: error: request for member 'val' in something not a structure or union return omp_return_stmt->val; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_return_lhs_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1929:3: error: unknown type name 'gimple_statement_omp_return' gimple_statement_omp_return *omp_return_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1930:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_return> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1930:11: error: 'gimple_statement_omp_return' undeclared (first use in this function) as_a <gimple_statement_omp_return> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:1931:26: error: request for member 'val' in something not a structure or union return &omp_return_stmt->val; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: At top level: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2260:33: error: unknown type name 'gimple_stmt_iterator' gimple_assign_set_rhs_with_ops (gimple_stmt_iterator *gsi, enum tree_code code, ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2445:1: error: return type is an incomplete type gimple_call_internal_fn (const_gimple gs) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_call_internal_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2448:10: error: 'static_cast' undeclared (first use in this function) return static_cast <const gimple_statement_call *> (gs)->u.internal_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2448:23: error: expected expression before 'const' return static_cast <const gimple_statement_call *> (gs)->u.internal_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2448:3: warning: 'return' with a value, in function returning void return static_cast <const gimple_statement_call *> (gs)->u.internal_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_call_fntype': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2480:9: error: unknown type name 'gimple_statement_call' const gimple_statement_call *call_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2481:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_call> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2481:11: error: expected expression before 'const' as_a <const gimple_statement_call> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2484:19: error: request for member 'u' in something not a structure or union return call_stmt->u.fntype; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_call_set_fntype': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2492:3: error: unknown type name 'gimple_statement_call' gimple_statement_call *call_stmt = as_a <gimple_statement_call> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2492:38: error: 'as_a' undeclared (first use in this function) gimple_statement_call *call_stmt = as_a <gimple_statement_call> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2492:44: error: 'gimple_statement_call' undeclared (first use in this function) gimple_statement_call *call_stmt = as_a <gimple_statement_call> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2494:12: error: request for member 'u' in something not a structure or union call_stmt->u.fntype = fntype; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: At top level: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2544:58: error: parameter 2 ('fn') has incomplete type gimple_call_set_internal_fn (gimple gs, enum internal_fn fn) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_call_set_internal_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2546:3: error: unknown type name 'gimple_statement_call' gimple_statement_call *call_stmt = as_a <gimple_statement_call> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2546:38: error: 'as_a' undeclared (first use in this function) gimple_statement_call *call_stmt = as_a <gimple_statement_call> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2546:44: error: 'gimple_statement_call' undeclared (first use in this function) gimple_statement_call *call_stmt = as_a <gimple_statement_call> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2548:12: error: request for member 'u' in something not a structure or union call_stmt->u.internal_fn = fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_call_fndecl': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2559:3: warning: return makes pointer from integer without a cast return gimple_call_addr_fndecl (gimple_call_fn (gs)); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_call_use_set': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2824:3: error: unknown type name 'gimple_statement_call' gimple_statement_call *call_stmt = as_a <gimple_statement_call> (call); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2824:38: error: 'as_a' undeclared (first use in this function) gimple_statement_call *call_stmt = as_a <gimple_statement_call> (call); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2824:44: error: 'gimple_statement_call' undeclared (first use in this function) gimple_statement_call *call_stmt = as_a <gimple_statement_call> (call); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2825:20: error: request for member 'call_used' in something not a structure or union return &call_stmt->call_used; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_call_clobber_set': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2835:3: error: unknown type name 'gimple_statement_call' gimple_statement_call *call_stmt = as_a <gimple_statement_call> (call); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2835:38: error: 'as_a' undeclared (first use in this function) gimple_statement_call *call_stmt = as_a <gimple_statement_call> (call); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2835:44: error: 'gimple_statement_call' undeclared (first use in this function) gimple_statement_call *call_stmt = as_a <gimple_statement_call> (call); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:2836:20: error: request for member 'call_clobbered' in something not a structure or union return &call_stmt->call_clobbered; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_bind_vars': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3104:9: error: unknown type name 'gimple_statement_bind' const gimple_statement_bind *bind_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3105:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3105:11: error: expected expression before 'const' as_a <const gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3106:19: error: request for member 'vars' in something not a structure or union return bind_stmt->vars; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_bind_set_vars': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3116:3: error: unknown type name 'gimple_statement_bind' gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3116:38: error: 'as_a' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3116:44: error: 'gimple_statement_bind' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3117:12: error: request for member 'vars' in something not a structure or union bind_stmt->vars = vars; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_bind_append_vars': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3127:3: error: unknown type name 'gimple_statement_bind' gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3127:38: error: 'as_a' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3127:44: error: 'gimple_statement_bind' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3128:12: error: request for member 'vars' in something not a structure or union bind_stmt->vars = chainon (bind_stmt->vars, vars); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3128:39: error: request for member 'vars' in something not a structure or union bind_stmt->vars = chainon (bind_stmt->vars, vars); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_bind_body_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3135:3: error: unknown type name 'gimple_statement_bind' gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3135:38: error: 'as_a' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3135:44: error: 'gimple_statement_bind' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3136:20: error: request for member 'body' in something not a structure or union return &bind_stmt->body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_bind_set_body': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3154:3: error: unknown type name 'gimple_statement_bind' gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3154:38: error: 'as_a' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3154:44: error: 'gimple_statement_bind' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3155:12: error: request for member 'body' in something not a structure or union bind_stmt->body = seq; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_bind_add_stmt': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3164:3: error: unknown type name 'gimple_statement_bind' gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3164:38: error: 'as_a' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3164:44: error: 'gimple_statement_bind' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3165:34: error: request for member 'body' in something not a structure or union gimple_seq_add_stmt (&bind_stmt->body, stmt); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_bind_add_seq': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3174:3: error: unknown type name 'gimple_statement_bind' gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3174:38: error: 'as_a' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3174:44: error: 'gimple_statement_bind' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3175:33: error: request for member 'body' in something not a structure or union gimple_seq_add_seq (&bind_stmt->body, seq); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_bind_block': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3185:9: error: unknown type name 'gimple_statement_bind' const gimple_statement_bind *bind_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3186:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3186:11: error: expected expression before 'const' as_a <const gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3187:19: error: request for member 'block' in something not a structure or union return bind_stmt->block; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_bind_set_block': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3197:3: error: unknown type name 'gimple_statement_bind' gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3197:38: error: 'as_a' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3197:44: error: 'gimple_statement_bind' undeclared (first use in this function) gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3200:12: error: request for member 'block' in something not a structure or union bind_stmt->block = block; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_ninputs': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3209:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3210:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3210:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3211:18: error: request for member 'ni' in something not a structure or union return asm_stmt->ni; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_noutputs': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3220:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3221:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3221:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3222:18: error: request for member 'no' in something not a structure or union return asm_stmt->no; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_nclobbers': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3231:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3232:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3232:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3233:18: error: request for member 'nc' in something not a structure or union return asm_stmt->nc; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_nlabels': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3241:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3242:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3242:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3243:18: error: request for member 'nl' in something not a structure or union return asm_stmt->nl; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_input_op': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3251:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3252:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3252:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3253:47: error: request for member 'ni' in something not a structure or union gcc_gimple_checking_assert (index < asm_stmt->ni); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3254:41: error: request for member 'no' in something not a structure or union return gimple_op (gs, index + asm_stmt->no); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_input_op_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3262:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3263:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3263:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3264:47: error: request for member 'ni' in something not a structure or union gcc_gimple_checking_assert (index < asm_stmt->ni); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3265:45: error: request for member 'no' in something not a structure or union return gimple_op_ptr (gs, index + asm_stmt->no); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_set_input_op': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3274:3: error: unknown type name 'gimple_statement_asm' gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3274:36: error: 'as_a' undeclared (first use in this function) gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3274:42: error: 'gimple_statement_asm' undeclared (first use in this function) gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3275:47: error: request for member 'ni' in something not a structure or union gcc_gimple_checking_assert (index < asm_stmt->ni ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3277:38: error: request for member 'no' in something not a structure or union gimple_set_op (gs, index + asm_stmt->no, in_op); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_output_op': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3286:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3287:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3287:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3288:47: error: request for member 'no' in something not a structure or union gcc_gimple_checking_assert (index < asm_stmt->no); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_output_op_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3297:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3298:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3298:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3299:47: error: request for member 'no' in something not a structure or union gcc_gimple_checking_assert (index < asm_stmt->no); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_set_output_op': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3309:3: error: unknown type name 'gimple_statement_asm' gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3309:36: error: 'as_a' undeclared (first use in this function) gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3309:42: error: 'gimple_statement_asm' undeclared (first use in this function) gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3310:47: error: request for member 'no' in something not a structure or union gcc_gimple_checking_assert (index < asm_stmt->no ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_clobber_op': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3321:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3322:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3322:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3323:47: error: request for member 'nc' in something not a structure or union gcc_gimple_checking_assert (index < asm_stmt->nc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3324:41: error: request for member 'ni' in something not a structure or union return gimple_op (gs, index + asm_stmt->ni + asm_stmt->no); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3324:56: error: request for member 'no' in something not a structure or union return gimple_op (gs, index + asm_stmt->ni + asm_stmt->no); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_set_clobber_op': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3333:3: error: unknown type name 'gimple_statement_asm' gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3333:36: error: 'as_a' undeclared (first use in this function) gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3333:42: error: 'gimple_statement_asm' undeclared (first use in this function) gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3334:47: error: request for member 'nc' in something not a structure or union gcc_gimple_checking_assert (index < asm_stmt->nc ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3336:38: error: request for member 'ni' in something not a structure or union gimple_set_op (gs, index + asm_stmt->ni + asm_stmt->no, clobber_op); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3336:53: error: request for member 'no' in something not a structure or union gimple_set_op (gs, index + asm_stmt->ni + asm_stmt->no, clobber_op); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_label_op': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3344:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3345:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3345:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3346:47: error: request for member 'nl' in something not a structure or union gcc_gimple_checking_assert (index < asm_stmt->nl); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3347:41: error: request for member 'ni' in something not a structure or union return gimple_op (gs, index + asm_stmt->ni + asm_stmt->nc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3347:56: error: request for member 'nc' in something not a structure or union return gimple_op (gs, index + asm_stmt->ni + asm_stmt->nc); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_set_label_op': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3355:3: error: unknown type name 'gimple_statement_asm' gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3355:36: error: 'as_a' undeclared (first use in this function) gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3355:42: error: 'gimple_statement_asm' undeclared (first use in this function) gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3356:47: error: request for member 'nl' in something not a structure or union gcc_gimple_checking_assert (index < asm_stmt->nl ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3358:38: error: request for member 'ni' in something not a structure or union gimple_set_op (gs, index + asm_stmt->ni + asm_stmt->nc, label_op); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3358:53: error: request for member 'nc' in something not a structure or union gimple_set_op (gs, index + asm_stmt->ni + asm_stmt->nc, label_op); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_asm_string': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3367:9: error: unknown type name 'gimple_statement_asm' const gimple_statement_asm *asm_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3368:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3368:11: error: expected expression before 'const' as_a <const gimple_statement_asm> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3369:18: error: request for member 'string' in something not a structure or union return asm_stmt->string; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_catch_types': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3424:9: error: unknown type name 'gimple_statement_catch' const gimple_statement_catch *catch_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3425:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3425:11: error: expected expression before 'const' as_a <const gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3426:20: error: request for member 'types' in something not a structure or union return catch_stmt->types; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_catch_types_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3435:3: error: unknown type name 'gimple_statement_catch' gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3435:40: error: 'as_a' undeclared (first use in this function) gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3435:46: error: 'gimple_statement_catch' undeclared (first use in this function) gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3436:21: error: request for member 'types' in something not a structure or union return &catch_stmt->types; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_catch_handler_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3446:3: error: unknown type name 'gimple_statement_catch' gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3446:40: error: 'as_a' undeclared (first use in this function) gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3446:46: error: 'gimple_statement_catch' undeclared (first use in this function) gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3447:21: error: request for member 'handler' in something not a structure or union return &catch_stmt->handler; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_catch_set_types': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3466:3: error: unknown type name 'gimple_statement_catch' gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3466:40: error: 'as_a' undeclared (first use in this function) gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3466:46: error: 'gimple_statement_catch' undeclared (first use in this function) gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3467:13: error: request for member 'types' in something not a structure or union catch_stmt->types = t; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_catch_set_handler': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3476:3: error: unknown type name 'gimple_statement_catch' gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3476:40: error: 'as_a' undeclared (first use in this function) gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3476:46: error: 'gimple_statement_catch' undeclared (first use in this function) gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3477:13: error: request for member 'handler' in something not a structure or union catch_stmt->handler = handler; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_filter_types': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3486:9: error: unknown type name 'gimple_statement_eh_filter' const gimple_statement_eh_filter *eh_filter_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3487:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_eh_filter> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3487:11: error: expected expression before 'const' as_a <const gimple_statement_eh_filter> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3488:24: error: request for member 'types' in something not a structure or union return eh_filter_stmt->types; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_filter_types_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3498:3: error: unknown type name 'gimple_statement_eh_filter' gimple_statement_eh_filter *eh_filter_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3499:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_eh_filter> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3499:11: error: 'gimple_statement_eh_filter' undeclared (first use in this function) as_a <gimple_statement_eh_filter> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3500:25: error: request for member 'types' in something not a structure or union return &eh_filter_stmt->types; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_filter_failure_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3510:3: error: unknown type name 'gimple_statement_eh_filter' gimple_statement_eh_filter *eh_filter_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3511:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_eh_filter> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3511:11: error: 'gimple_statement_eh_filter' undeclared (first use in this function) as_a <gimple_statement_eh_filter> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3512:25: error: request for member 'failure' in something not a structure or union return &eh_filter_stmt->failure; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_filter_set_types': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3531:3: error: unknown type name 'gimple_statement_eh_filter' gimple_statement_eh_filter *eh_filter_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3532:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_eh_filter> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3532:11: error: 'gimple_statement_eh_filter' undeclared (first use in this function) as_a <gimple_statement_eh_filter> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3533:17: error: request for member 'types' in something not a structure or union eh_filter_stmt->types = types; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_filter_set_failure': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3543:3: error: unknown type name 'gimple_statement_eh_filter' gimple_statement_eh_filter *eh_filter_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3544:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_eh_filter> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3544:11: error: 'gimple_statement_eh_filter' undeclared (first use in this function) as_a <gimple_statement_eh_filter> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3545:17: error: request for member 'failure' in something not a structure or union eh_filter_stmt->failure = failure; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_must_not_throw_fndecl': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3553:3: error: unknown type name 'gimple_statement_eh_mnt' gimple_statement_eh_mnt *eh_mnt_stmt = as_a <gimple_statement_eh_mnt> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3553:42: error: 'as_a' undeclared (first use in this function) gimple_statement_eh_mnt *eh_mnt_stmt = as_a <gimple_statement_eh_mnt> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3553:48: error: 'gimple_statement_eh_mnt' undeclared (first use in this function) gimple_statement_eh_mnt *eh_mnt_stmt = as_a <gimple_statement_eh_mnt> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3554:21: error: request for member 'fndecl' in something not a structure or union return eh_mnt_stmt->fndecl; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_must_not_throw_set_fndecl': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3562:3: error: unknown type name 'gimple_statement_eh_mnt' gimple_statement_eh_mnt *eh_mnt_stmt = as_a <gimple_statement_eh_mnt> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3562:42: error: 'as_a' undeclared (first use in this function) gimple_statement_eh_mnt *eh_mnt_stmt = as_a <gimple_statement_eh_mnt> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3562:48: error: 'gimple_statement_eh_mnt' undeclared (first use in this function) gimple_statement_eh_mnt *eh_mnt_stmt = as_a <gimple_statement_eh_mnt> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3563:14: error: request for member 'fndecl' in something not a structure or union eh_mnt_stmt->fndecl = decl; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_else_n_body_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3571:3: error: unknown type name 'gimple_statement_eh_else' gimple_statement_eh_else *eh_else_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3572:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_eh_else> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3572:11: error: 'gimple_statement_eh_else' undeclared (first use in this function) as_a <gimple_statement_eh_else> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3573:23: error: request for member 'n_body' in something not a structure or union return &eh_else_stmt->n_body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_else_e_body_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3585:3: error: unknown type name 'gimple_statement_eh_else' gimple_statement_eh_else *eh_else_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3586:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_eh_else> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3586:11: error: 'gimple_statement_eh_else' undeclared (first use in this function) as_a <gimple_statement_eh_else> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3587:23: error: request for member 'e_body' in something not a structure or union return &eh_else_stmt->e_body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_else_set_n_body': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3599:3: error: unknown type name 'gimple_statement_eh_else' gimple_statement_eh_else *eh_else_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3600:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_eh_else> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3600:11: error: 'gimple_statement_eh_else' undeclared (first use in this function) as_a <gimple_statement_eh_else> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3601:15: error: request for member 'n_body' in something not a structure or union eh_else_stmt->n_body = seq; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_else_set_e_body': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3607:3: error: unknown type name 'gimple_statement_eh_else' gimple_statement_eh_else *eh_else_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3608:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_eh_else> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3608:11: error: 'gimple_statement_eh_else' undeclared (first use in this function) as_a <gimple_statement_eh_else> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3609:15: error: request for member 'e_body' in something not a structure or union eh_else_stmt->e_body = seq; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_try_eval_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3654:3: error: unknown type name 'gimple_statement_try' gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3654:36: error: 'as_a' undeclared (first use in this function) gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3654:42: error: 'gimple_statement_try' undeclared (first use in this function) gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3655:19: error: request for member 'eval' in something not a structure or union return &try_stmt->eval; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_try_cleanup_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3674:3: error: unknown type name 'gimple_statement_try' gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3674:36: error: 'as_a' undeclared (first use in this function) gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3674:42: error: 'gimple_statement_try' undeclared (first use in this function) gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3675:19: error: request for member 'cleanup' in something not a structure or union return &try_stmt->cleanup; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_try_set_eval': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3708:3: error: unknown type name 'gimple_statement_try' gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3708:36: error: 'as_a' undeclared (first use in this function) gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3708:42: error: 'gimple_statement_try' undeclared (first use in this function) gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3709:11: error: request for member 'eval' in something not a structure or union try_stmt->eval = eval; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_try_set_cleanup': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3719:3: error: unknown type name 'gimple_statement_try' gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3719:36: error: 'as_a' undeclared (first use in this function) gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3719:42: error: 'gimple_statement_try' undeclared (first use in this function) gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3720:11: error: request for member 'cleanup' in something not a structure or union try_stmt->cleanup = cleanup; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_wce_cleanup_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3729:3: error: unknown type name 'gimple_statement_wce' gimple_statement_wce *wce_stmt = as_a <gimple_statement_wce> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3729:36: error: 'as_a' undeclared (first use in this function) gimple_statement_wce *wce_stmt = as_a <gimple_statement_wce> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3729:42: error: 'gimple_statement_wce' undeclared (first use in this function) gimple_statement_wce *wce_stmt = as_a <gimple_statement_wce> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3730:19: error: request for member 'cleanup' in something not a structure or union return &wce_stmt->cleanup; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_wce_set_cleanup': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3748:3: error: unknown type name 'gimple_statement_wce' gimple_statement_wce *wce_stmt = as_a <gimple_statement_wce> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3748:36: error: 'as_a' undeclared (first use in this function) gimple_statement_wce *wce_stmt = as_a <gimple_statement_wce> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3748:42: error: 'gimple_statement_wce' undeclared (first use in this function) gimple_statement_wce *wce_stmt = as_a <gimple_statement_wce> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3749:11: error: request for member 'cleanup' in something not a structure or union wce_stmt->cleanup = cleanup; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_phi_capacity': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3778:9: error: unknown type name 'gimple_statement_phi' const gimple_statement_phi *phi_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3779:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3779:11: error: expected expression before 'const' as_a <const gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3780:18: error: request for member 'capacity' in something not a structure or union return phi_stmt->capacity; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_phi_num_args': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3791:9: error: unknown type name 'gimple_statement_phi' const gimple_statement_phi *phi_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3792:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3792:11: error: expected expression before 'const' as_a <const gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3793:18: error: request for member 'nargs' in something not a structure or union return phi_stmt->nargs; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_phi_result': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3802:9: error: unknown type name 'gimple_statement_phi' const gimple_statement_phi *phi_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3803:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3803:11: error: expected expression before 'const' as_a <const gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3804:18: error: request for member 'result' in something not a structure or union return phi_stmt->result; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_phi_result_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3812:3: error: unknown type name 'gimple_statement_phi' gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3812:36: error: 'as_a' undeclared (first use in this function) gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3812:42: error: 'gimple_statement_phi' undeclared (first use in this function) gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3813:19: error: request for member 'result' in something not a structure or union return &phi_stmt->result; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_phi_set_result': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3821:3: error: unknown type name 'gimple_statement_phi' gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3821:36: error: 'as_a' undeclared (first use in this function) gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3821:42: error: 'gimple_statement_phi' undeclared (first use in this function) gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3822:11: error: request for member 'result' in something not a structure or union phi_stmt->result = result; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_phi_arg': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3834:3: error: unknown type name 'gimple_statement_phi' gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3834:36: error: 'as_a' undeclared (first use in this function) gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3834:42: error: 'gimple_statement_phi' undeclared (first use in this function) gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3835:48: error: request for member 'capacity' in something not a structure or union gcc_gimple_checking_assert (index <= phi_stmt->capacity); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3836:20: error: request for member 'args' in something not a structure or union return &(phi_stmt->args[index]); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_phi_set_arg': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3845:3: error: unknown type name 'gimple_statement_phi' gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3845:36: error: 'as_a' undeclared (first use in this function) gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3845:42: error: 'gimple_statement_phi' undeclared (first use in this function) gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3846:48: error: request for member 'nargs' in something not a structure or union gcc_gimple_checking_assert (index <= phi_stmt->nargs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3847:11: error: request for member 'args' in something not a structure or union phi_stmt->args[index] = *phiarg; ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:28:0, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'phi_nodes': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3856:28: error: dereferencing pointer to incomplete type gcc_checking_assert (!(bb->flags & BB_RTL)); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/system.h:703:49: note: in definition of macro 'gcc_checking_assert' #define gcc_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3856:38: error: 'BB_RTL' undeclared (first use in this function) gcc_checking_assert (!(bb->flags & BB_RTL)); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/system.h:703:49: note: in definition of macro 'gcc_checking_assert' #define gcc_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3857:12: error: dereferencing pointer to incomplete type return bb->il.gimple.phi_nodes; ^ In file included from /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gcc-plugin.h:28:0, from conftest.c:74: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'phi_nodes_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3865:28: error: dereferencing pointer to incomplete type gcc_checking_assert (!(bb->flags & BB_RTL)); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/system.h:703:49: note: in definition of macro 'gcc_checking_assert' #define gcc_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3865:38: error: 'BB_RTL' undeclared (first use in this function) gcc_checking_assert (!(bb->flags & BB_RTL)); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/system.h:703:49: note: in definition of macro 'gcc_checking_assert' #define gcc_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3866:13: error: dereferencing pointer to incomplete type return &bb->il.gimple.phi_nodes; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_phi_arg_edge': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3891:3: warning: return makes pointer from integer without a cast return EDGE_PRED (gimple_bb (gs), i); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_phi_arg_location_from_edge': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3907:31: error: dereferencing pointer to incomplete type return gimple_phi_arg (gs, e->dest_idx)->locus; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_resx_region': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3932:9: error: unknown type name 'gimple_statement_resx' const gimple_statement_resx *resx_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3933:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_resx> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3933:11: error: expected expression before 'const' as_a <const gimple_statement_resx> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3934:19: error: request for member 'region' in something not a structure or union return resx_stmt->region; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_resx_set_region': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3942:3: error: unknown type name 'gimple_statement_resx' gimple_statement_resx *resx_stmt = as_a <gimple_statement_resx> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3942:38: error: 'as_a' undeclared (first use in this function) gimple_statement_resx *resx_stmt = as_a <gimple_statement_resx> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3942:44: error: 'gimple_statement_resx' undeclared (first use in this function) gimple_statement_resx *resx_stmt = as_a <gimple_statement_resx> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3943:12: error: request for member 'region' in something not a structure or union resx_stmt->region = region; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_dispatch_region': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3951:9: error: unknown type name 'gimple_statement_eh_dispatch' const gimple_statement_eh_dispatch *eh_dispatch_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3952:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_eh_dispatch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3952:11: error: expected expression before 'const' as_a <const gimple_statement_eh_dispatch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3953:26: error: request for member 'region' in something not a structure or union return eh_dispatch_stmt->region; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_eh_dispatch_set_region': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3961:3: error: unknown type name 'gimple_statement_eh_dispatch' gimple_statement_eh_dispatch *eh_dispatch_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3962:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_eh_dispatch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3962:11: error: 'gimple_statement_eh_dispatch' undeclared (first use in this function) as_a <gimple_statement_eh_dispatch> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:3963:19: error: request for member 'region' in something not a structure or union eh_dispatch_stmt->region = region; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_body_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4248:11: error: 'static_cast' undeclared (first use in this function) return &static_cast <gimple_statement_omp *> (gs)->body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4248:24: error: 'gimple_statement_omp' undeclared (first use in this function) return &static_cast <gimple_statement_omp *> (gs)->body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4248:46: error: expected expression before '>' token return &static_cast <gimple_statement_omp *> (gs)->body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_set_body': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4264:3: error: 'static_cast' undeclared (first use in this function) static_cast <gimple_statement_omp *> (gs)->body = body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4264:16: error: 'gimple_statement_omp' undeclared (first use in this function) static_cast <gimple_statement_omp *> (gs)->body = body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4264:38: error: expected expression before '>' token static_cast <gimple_statement_omp *> (gs)->body = body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_critical_name': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4273:9: error: unknown type name 'gimple_statement_omp_critical' const gimple_statement_omp_critical *omp_critical_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4274:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_critical> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4274:11: error: expected expression before 'const' as_a <const gimple_statement_omp_critical> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4275:27: error: request for member 'name' in something not a structure or union return omp_critical_stmt->name; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_critical_name_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4284:3: error: unknown type name 'gimple_statement_omp_critical' gimple_statement_omp_critical *omp_critical_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4285:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_critical> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4285:11: error: 'gimple_statement_omp_critical' undeclared (first use in this function) as_a <gimple_statement_omp_critical> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4286:28: error: request for member 'name' in something not a structure or union return &omp_critical_stmt->name; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_critical_set_name': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4295:3: error: unknown type name 'gimple_statement_omp_critical' gimple_statement_omp_critical *omp_critical_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4296:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_critical> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4296:11: error: 'gimple_statement_omp_critical' undeclared (first use in this function) as_a <gimple_statement_omp_critical> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4297:20: error: request for member 'name' in something not a structure or union omp_critical_stmt->name = name; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4377:9: error: unknown type name 'gimple_statement_omp_for' const gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4378:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4378:11: error: expected expression before 'const' as_a <const gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4379:22: error: request for member 'clauses' in something not a structure or union return omp_for_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_clauses_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4388:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4389:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4389:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4390:23: error: request for member 'clauses' in something not a structure or union return &omp_for_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_set_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4399:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4400:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4400:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4401:15: error: request for member 'clauses' in something not a structure or union omp_for_stmt->clauses = clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_collapse': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4410:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4411:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4411:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4412:22: error: request for member 'collapse' in something not a structure or union return omp_for_stmt->collapse; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_index': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4421:9: error: unknown type name 'gimple_statement_omp_for' const gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4422:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4422:11: error: expected expression before 'const' as_a <const gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4423:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4424:22: error: request for member 'iter' in something not a structure or union return omp_for_stmt->iter[i].index; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_index_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4433:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4434:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4434:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4435:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4436:23: error: request for member 'iter' in something not a structure or union return &omp_for_stmt->iter[i].index; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_set_index': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4445:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4446:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4446:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4447:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4448:15: error: request for member 'iter' in something not a structure or union omp_for_stmt->iter[i].index = index; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_initial': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4457:9: error: unknown type name 'gimple_statement_omp_for' const gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4458:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4458:11: error: expected expression before 'const' as_a <const gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4459:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4460:22: error: request for member 'iter' in something not a structure or union return omp_for_stmt->iter[i].initial; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_initial_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4469:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4470:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4470:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4471:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4472:23: error: request for member 'iter' in something not a structure or union return &omp_for_stmt->iter[i].initial; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_set_initial': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4481:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4482:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4482:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4483:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4484:15: error: request for member 'iter' in something not a structure or union omp_for_stmt->iter[i].initial = initial; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_final': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4493:9: error: unknown type name 'gimple_statement_omp_for' const gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4494:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4494:11: error: expected expression before 'const' as_a <const gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4495:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4496:22: error: request for member 'iter' in something not a structure or union return omp_for_stmt->iter[i].final; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_final_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4505:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4506:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4506:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4507:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4508:23: error: request for member 'iter' in something not a structure or union return &omp_for_stmt->iter[i].final; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_set_final': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4517:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4518:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4518:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4519:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4520:15: error: request for member 'iter' in something not a structure or union omp_for_stmt->iter[i].final = final; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_incr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4529:9: error: unknown type name 'gimple_statement_omp_for' const gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4530:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4530:11: error: expected expression before 'const' as_a <const gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4531:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4532:22: error: request for member 'iter' in something not a structure or union return omp_for_stmt->iter[i].incr; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_incr_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4541:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4542:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4542:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4543:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4544:23: error: request for member 'iter' in something not a structure or union return &omp_for_stmt->iter[i].incr; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_set_incr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4553:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4554:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4554:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4555:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4556:15: error: request for member 'iter' in something not a structure or union omp_for_stmt->iter[i].incr = incr; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_pre_body_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4566:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4567:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4567:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4568:23: error: request for member 'pre_body' in something not a structure or union return &omp_for_stmt->pre_body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_set_pre_body': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4588:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4589:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4589:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4590:15: error: request for member 'pre_body' in something not a structure or union omp_for_stmt->pre_body = pre_body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_parallel_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4599:9: error: unknown type name 'gimple_statement_omp_parallel' const gimple_statement_omp_parallel *omp_parallel_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4600:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4600:11: error: expected expression before 'const' as_a <const gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4601:27: error: request for member 'clauses' in something not a structure or union return omp_parallel_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_parallel_clauses_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4610:3: error: unknown type name 'gimple_statement_omp_parallel' gimple_statement_omp_parallel *omp_parallel_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4611:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4611:11: error: 'gimple_statement_omp_parallel' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4612:28: error: request for member 'clauses' in something not a structure or union return &omp_parallel_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_parallel_set_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4622:3: error: unknown type name 'gimple_statement_omp_parallel' gimple_statement_omp_parallel *omp_parallel_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4623:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4623:11: error: 'gimple_statement_omp_parallel' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4624:20: error: request for member 'clauses' in something not a structure or union omp_parallel_stmt->clauses = clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_parallel_child_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4633:9: error: unknown type name 'gimple_statement_omp_parallel' const gimple_statement_omp_parallel *omp_parallel_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4634:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4634:11: error: expected expression before 'const' as_a <const gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4635:27: error: request for member 'child_fn' in something not a structure or union return omp_parallel_stmt->child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_parallel_child_fn_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4644:3: error: unknown type name 'gimple_statement_omp_parallel' gimple_statement_omp_parallel *omp_parallel_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4645:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4645:11: error: 'gimple_statement_omp_parallel' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4646:28: error: request for member 'child_fn' in something not a structure or union return &omp_parallel_stmt->child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_parallel_set_child_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4655:3: error: unknown type name 'gimple_statement_omp_parallel' gimple_statement_omp_parallel *omp_parallel_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4656:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4656:11: error: 'gimple_statement_omp_parallel' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4657:20: error: request for member 'child_fn' in something not a structure or union omp_parallel_stmt->child_fn = child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_parallel_data_arg': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4667:9: error: unknown type name 'gimple_statement_omp_parallel' const gimple_statement_omp_parallel *omp_parallel_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4668:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4668:11: error: expected expression before 'const' as_a <const gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4669:27: error: request for member 'data_arg' in something not a structure or union return omp_parallel_stmt->data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_parallel_data_arg_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4678:3: error: unknown type name 'gimple_statement_omp_parallel' gimple_statement_omp_parallel *omp_parallel_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4679:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4679:11: error: 'gimple_statement_omp_parallel' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4680:28: error: request for member 'data_arg' in something not a structure or union return &omp_parallel_stmt->data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_parallel_set_data_arg': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4689:3: error: unknown type name 'gimple_statement_omp_parallel' gimple_statement_omp_parallel *omp_parallel_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4690:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4690:11: error: 'gimple_statement_omp_parallel' undeclared (first use in this function) as_a <gimple_statement_omp_parallel> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4691:20: error: request for member 'data_arg' in something not a structure or union omp_parallel_stmt->data_arg = data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4700:9: error: unknown type name 'gimple_statement_omp_task' const gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4701:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4701:11: error: expected expression before 'const' as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4702:23: error: request for member 'clauses' in something not a structure or union return omp_task_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_clauses_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4711:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4712:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4712:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4713:24: error: request for member 'clauses' in something not a structure or union return &omp_task_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_set_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4723:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4724:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4724:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4725:16: error: request for member 'clauses' in something not a structure or union omp_task_stmt->clauses = clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_child_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4734:9: error: unknown type name 'gimple_statement_omp_task' const gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4735:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4735:11: error: expected expression before 'const' as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4736:23: error: request for member 'child_fn' in something not a structure or union return omp_task_stmt->child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_child_fn_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4745:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4746:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4746:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4747:24: error: request for member 'child_fn' in something not a structure or union return &omp_task_stmt->child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_set_child_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4756:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4757:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4757:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4758:16: error: request for member 'child_fn' in something not a structure or union omp_task_stmt->child_fn = child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_data_arg': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4768:9: error: unknown type name 'gimple_statement_omp_task' const gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4769:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4769:11: error: expected expression before 'const' as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4770:23: error: request for member 'data_arg' in something not a structure or union return omp_task_stmt->data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_data_arg_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4779:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4780:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4780:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4781:24: error: request for member 'data_arg' in something not a structure or union return &omp_task_stmt->data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_set_data_arg': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4790:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4791:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4791:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4792:16: error: request for member 'data_arg' in something not a structure or union omp_task_stmt->data_arg = data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_taskreg_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4801:9: error: unknown type name 'gimple_statement_omp_taskreg' const gimple_statement_omp_taskreg *omp_taskreg_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4802:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4802:11: error: expected expression before 'const' as_a <const gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4803:26: error: request for member 'clauses' in something not a structure or union return omp_taskreg_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_taskreg_clauses_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4812:3: error: unknown type name 'gimple_statement_omp_taskreg' gimple_statement_omp_taskreg *omp_taskreg_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4813:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4813:11: error: 'gimple_statement_omp_taskreg' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4814:27: error: request for member 'clauses' in something not a structure or union return &omp_taskreg_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_taskreg_set_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4824:3: error: unknown type name 'gimple_statement_omp_taskreg' gimple_statement_omp_taskreg *omp_taskreg_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4825:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4825:11: error: 'gimple_statement_omp_taskreg' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4826:19: error: request for member 'clauses' in something not a structure or union omp_taskreg_stmt->clauses = clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_taskreg_child_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4835:9: error: unknown type name 'gimple_statement_omp_taskreg' const gimple_statement_omp_taskreg *omp_taskreg_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4836:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4836:11: error: expected expression before 'const' as_a <const gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4837:26: error: request for member 'child_fn' in something not a structure or union return omp_taskreg_stmt->child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_taskreg_child_fn_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4846:3: error: unknown type name 'gimple_statement_omp_taskreg' gimple_statement_omp_taskreg *omp_taskreg_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4847:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4847:11: error: 'gimple_statement_omp_taskreg' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4848:27: error: request for member 'child_fn' in something not a structure or union return &omp_taskreg_stmt->child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_taskreg_set_child_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4857:3: error: unknown type name 'gimple_statement_omp_taskreg' gimple_statement_omp_taskreg *omp_taskreg_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4858:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4858:11: error: 'gimple_statement_omp_taskreg' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4859:19: error: request for member 'child_fn' in something not a structure or union omp_taskreg_stmt->child_fn = child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_taskreg_data_arg': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4869:9: error: unknown type name 'gimple_statement_omp_taskreg' const gimple_statement_omp_taskreg *omp_taskreg_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4870:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4870:11: error: expected expression before 'const' as_a <const gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4871:26: error: request for member 'data_arg' in something not a structure or union return omp_taskreg_stmt->data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_taskreg_data_arg_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4880:3: error: unknown type name 'gimple_statement_omp_taskreg' gimple_statement_omp_taskreg *omp_taskreg_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4881:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4881:11: error: 'gimple_statement_omp_taskreg' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4882:27: error: request for member 'data_arg' in something not a structure or union return &omp_taskreg_stmt->data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_taskreg_set_data_arg': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4891:3: error: unknown type name 'gimple_statement_omp_taskreg' gimple_statement_omp_taskreg *omp_taskreg_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4892:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4892:11: error: 'gimple_statement_omp_taskreg' undeclared (first use in this function) as_a <gimple_statement_omp_taskreg> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4893:19: error: request for member 'data_arg' in something not a structure or union omp_taskreg_stmt->data_arg = data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_copy_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4902:9: error: unknown type name 'gimple_statement_omp_task' const gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4903:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4903:11: error: expected expression before 'const' as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4904:23: error: request for member 'copy_fn' in something not a structure or union return omp_task_stmt->copy_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_copy_fn_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4913:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4914:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4914:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4915:24: error: request for member 'copy_fn' in something not a structure or union return &omp_task_stmt->copy_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_set_copy_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4924:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4925:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4925:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4926:16: error: request for member 'copy_fn' in something not a structure or union omp_task_stmt->copy_fn = copy_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_arg_size': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4935:9: error: unknown type name 'gimple_statement_omp_task' const gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4936:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4936:11: error: expected expression before 'const' as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4937:23: error: request for member 'arg_size' in something not a structure or union return omp_task_stmt->arg_size; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_arg_size_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4946:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4947:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4947:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4948:24: error: request for member 'arg_size' in something not a structure or union return &omp_task_stmt->arg_size; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_set_arg_size': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4957:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4958:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4958:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4959:16: error: request for member 'arg_size' in something not a structure or union omp_task_stmt->arg_size = arg_size; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_arg_align': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4968:9: error: unknown type name 'gimple_statement_omp_task' const gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4969:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4969:11: error: expected expression before 'const' as_a <const gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4970:23: error: request for member 'arg_align' in something not a structure or union return omp_task_stmt->arg_align; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_arg_align_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4979:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4980:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4980:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4981:24: error: request for member 'arg_align' in something not a structure or union return &omp_task_stmt->arg_align; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_task_set_arg_align': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4990:3: error: unknown type name 'gimple_statement_omp_task' gimple_statement_omp_task *omp_task_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4991:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4991:11: error: 'gimple_statement_omp_task' undeclared (first use in this function) as_a <gimple_statement_omp_task> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:4992:16: error: request for member 'arg_align' in something not a structure or union omp_task_stmt->arg_align = arg_align; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_single_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5001:9: error: unknown type name 'gimple_statement_omp_single' const gimple_statement_omp_single *omp_single_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5002:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_single> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5002:11: error: expected expression before 'const' as_a <const gimple_statement_omp_single> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5003:25: error: request for member 'clauses' in something not a structure or union return omp_single_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_single_clauses_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5012:3: error: unknown type name 'gimple_statement_omp_single' gimple_statement_omp_single *omp_single_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5013:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_single> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5013:11: error: 'gimple_statement_omp_single' undeclared (first use in this function) as_a <gimple_statement_omp_single> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5014:26: error: request for member 'clauses' in something not a structure or union return &omp_single_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_single_set_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5023:3: error: unknown type name 'gimple_statement_omp_single' gimple_statement_omp_single *omp_single_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5024:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_single> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5024:11: error: 'gimple_statement_omp_single' undeclared (first use in this function) as_a <gimple_statement_omp_single> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5025:18: error: request for member 'clauses' in something not a structure or union omp_single_stmt->clauses = clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_target_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5034:9: error: unknown type name 'gimple_statement_omp_target' const gimple_statement_omp_target *omp_target_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5035:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5035:11: error: expected expression before 'const' as_a <const gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5036:25: error: request for member 'clauses' in something not a structure or union return omp_target_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_target_clauses_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5045:3: error: unknown type name 'gimple_statement_omp_target' gimple_statement_omp_target *omp_target_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5046:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5046:11: error: 'gimple_statement_omp_target' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5047:26: error: request for member 'clauses' in something not a structure or union return &omp_target_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_target_set_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5056:3: error: unknown type name 'gimple_statement_omp_target' gimple_statement_omp_target *omp_target_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5057:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5057:11: error: 'gimple_statement_omp_target' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5058:18: error: request for member 'clauses' in something not a structure or union omp_target_stmt->clauses = clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_target_child_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5088:9: error: unknown type name 'gimple_statement_omp_target' const gimple_statement_omp_target *omp_target_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5089:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5089:11: error: expected expression before 'const' as_a <const gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5090:25: error: request for member 'child_fn' in something not a structure or union return omp_target_stmt->child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_target_child_fn_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5099:3: error: unknown type name 'gimple_statement_omp_target' gimple_statement_omp_target *omp_target_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5100:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5100:11: error: 'gimple_statement_omp_target' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5101:26: error: request for member 'child_fn' in something not a structure or union return &omp_target_stmt->child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_target_set_child_fn': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5110:3: error: unknown type name 'gimple_statement_omp_target' gimple_statement_omp_target *omp_target_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5111:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5111:11: error: 'gimple_statement_omp_target' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5112:18: error: request for member 'child_fn' in something not a structure or union omp_target_stmt->child_fn = child_fn; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_target_data_arg': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5122:9: error: unknown type name 'gimple_statement_omp_target' const gimple_statement_omp_target *omp_target_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5123:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5123:11: error: expected expression before 'const' as_a <const gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5124:25: error: request for member 'data_arg' in something not a structure or union return omp_target_stmt->data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_target_data_arg_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5133:3: error: unknown type name 'gimple_statement_omp_target' gimple_statement_omp_target *omp_target_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5134:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5134:11: error: 'gimple_statement_omp_target' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5135:26: error: request for member 'data_arg' in something not a structure or union return &omp_target_stmt->data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_target_set_data_arg': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5144:3: error: unknown type name 'gimple_statement_omp_target' gimple_statement_omp_target *omp_target_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5145:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5145:11: error: 'gimple_statement_omp_target' undeclared (first use in this function) as_a <gimple_statement_omp_target> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5146:18: error: request for member 'data_arg' in something not a structure or union omp_target_stmt->data_arg = data_arg; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_teams_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5155:9: error: unknown type name 'gimple_statement_omp_teams' const gimple_statement_omp_teams *omp_teams_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5156:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_teams> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5156:11: error: expected expression before 'const' as_a <const gimple_statement_omp_teams> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5157:24: error: request for member 'clauses' in something not a structure or union return omp_teams_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_teams_clauses_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5166:3: error: unknown type name 'gimple_statement_omp_teams' gimple_statement_omp_teams *omp_teams_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5167:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_teams> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5167:11: error: 'gimple_statement_omp_teams' undeclared (first use in this function) as_a <gimple_statement_omp_teams> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5168:25: error: request for member 'clauses' in something not a structure or union return &omp_teams_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_teams_set_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5177:3: error: unknown type name 'gimple_statement_omp_teams' gimple_statement_omp_teams *omp_teams_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5178:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_teams> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5178:11: error: 'gimple_statement_omp_teams' undeclared (first use in this function) as_a <gimple_statement_omp_teams> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5179:17: error: request for member 'clauses' in something not a structure or union omp_teams_stmt->clauses = clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_sections_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5188:9: error: unknown type name 'gimple_statement_omp_sections' const gimple_statement_omp_sections *omp_sections_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5189:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5189:11: error: expected expression before 'const' as_a <const gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5190:27: error: request for member 'clauses' in something not a structure or union return omp_sections_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_sections_clauses_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5199:3: error: unknown type name 'gimple_statement_omp_sections' gimple_statement_omp_sections *omp_sections_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5200:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5200:11: error: 'gimple_statement_omp_sections' undeclared (first use in this function) as_a <gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5201:28: error: request for member 'clauses' in something not a structure or union return &omp_sections_stmt->clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_sections_set_clauses': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5211:3: error: unknown type name 'gimple_statement_omp_sections' gimple_statement_omp_sections *omp_sections_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5212:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5212:11: error: 'gimple_statement_omp_sections' undeclared (first use in this function) as_a <gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5213:20: error: request for member 'clauses' in something not a structure or union omp_sections_stmt->clauses = clauses; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_sections_control': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5223:9: error: unknown type name 'gimple_statement_omp_sections' const gimple_statement_omp_sections *omp_sections_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5224:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5224:11: error: expected expression before 'const' as_a <const gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5225:27: error: request for member 'control' in something not a structure or union return omp_sections_stmt->control; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_sections_control_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5235:3: error: unknown type name 'gimple_statement_omp_sections' gimple_statement_omp_sections *omp_sections_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5236:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5236:11: error: 'gimple_statement_omp_sections' undeclared (first use in this function) as_a <gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5237:28: error: request for member 'control' in something not a structure or union return &omp_sections_stmt->control; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_sections_set_control': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5247:3: error: unknown type name 'gimple_statement_omp_sections' gimple_statement_omp_sections *omp_sections_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5248:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5248:11: error: 'gimple_statement_omp_sections' undeclared (first use in this function) as_a <gimple_statement_omp_sections> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5249:20: error: request for member 'control' in something not a structure or union omp_sections_stmt->control = control; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_set_cond': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5258:3: error: unknown type name 'gimple_statement_omp_for' gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5259:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5259:11: error: 'gimple_statement_omp_for' undeclared (first use in this function) as_a <gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5261:29: error: request for member 'collapse' in something not a structure or union && i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5262:15: error: request for member 'iter' in something not a structure or union omp_for_stmt->iter[i].cond = cond; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_for_cond': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5271:9: error: unknown type name 'gimple_statement_omp_for' const gimple_statement_omp_for *omp_for_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5272:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_for> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5272:11: error: expected expression before 'const' as_a <const gimple_statement_omp_for> (gs); ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5273:47: error: request for member 'collapse' in something not a structure or union gcc_gimple_checking_assert (i < omp_for_stmt->collapse); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:56:56: note: in definition of macro 'gcc_gimple_checking_assert' #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR))) ^ In file included from conftest.c:76:0: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5274:22: error: request for member 'iter' in something not a structure or union return omp_for_stmt->iter[i].cond; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_atomic_store_set_val': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5283:3: error: unknown type name 'gimple_statement_omp_atomic_store' gimple_statement_omp_atomic_store *omp_atomic_store_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5284:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_store> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5284:11: error: 'gimple_statement_omp_atomic_store' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_store> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5285:24: error: request for member 'val' in something not a structure or union omp_atomic_store_stmt->val = val; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_atomic_store_val': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5294:9: error: unknown type name 'gimple_statement_omp_atomic_store' const gimple_statement_omp_atomic_store *omp_atomic_store_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5295:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_atomic_store> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5295:11: error: expected expression before 'const' as_a <const gimple_statement_omp_atomic_store> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5296:31: error: request for member 'val' in something not a structure or union return omp_atomic_store_stmt->val; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_atomic_store_val_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5305:3: error: unknown type name 'gimple_statement_omp_atomic_store' gimple_statement_omp_atomic_store *omp_atomic_store_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5306:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_store> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5306:11: error: 'gimple_statement_omp_atomic_store' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_store> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5307:32: error: request for member 'val' in something not a structure or union return &omp_atomic_store_stmt->val; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_atomic_load_set_lhs': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5316:3: error: unknown type name 'gimple_statement_omp_atomic_load' gimple_statement_omp_atomic_load *omp_atomic_load_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5317:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5317:11: error: 'gimple_statement_omp_atomic_load' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5318:23: error: request for member 'lhs' in something not a structure or union omp_atomic_load_stmt->lhs = lhs; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_atomic_load_lhs': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5327:9: error: unknown type name 'gimple_statement_omp_atomic_load' const gimple_statement_omp_atomic_load *omp_atomic_load_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5328:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5328:11: error: expected expression before 'const' as_a <const gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5329:30: error: request for member 'lhs' in something not a structure or union return omp_atomic_load_stmt->lhs; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_atomic_load_lhs_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5338:3: error: unknown type name 'gimple_statement_omp_atomic_load' gimple_statement_omp_atomic_load *omp_atomic_load_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5339:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5339:11: error: 'gimple_statement_omp_atomic_load' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5340:31: error: request for member 'lhs' in something not a structure or union return &omp_atomic_load_stmt->lhs; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_atomic_load_set_rhs': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5349:3: error: unknown type name 'gimple_statement_omp_atomic_load' gimple_statement_omp_atomic_load *omp_atomic_load_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5350:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5350:11: error: 'gimple_statement_omp_atomic_load' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5351:23: error: request for member 'rhs' in something not a structure or union omp_atomic_load_stmt->rhs = rhs; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_atomic_load_rhs': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5360:9: error: unknown type name 'gimple_statement_omp_atomic_load' const gimple_statement_omp_atomic_load *omp_atomic_load_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5361:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5361:11: error: expected expression before 'const' as_a <const gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5362:30: error: request for member 'rhs' in something not a structure or union return omp_atomic_load_stmt->rhs; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_atomic_load_rhs_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5371:3: error: unknown type name 'gimple_statement_omp_atomic_load' gimple_statement_omp_atomic_load *omp_atomic_load_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5372:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5372:11: error: 'gimple_statement_omp_atomic_load' undeclared (first use in this function) as_a <gimple_statement_omp_atomic_load> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5373:31: error: request for member 'rhs' in something not a structure or union return &omp_atomic_load_stmt->rhs; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_continue_control_def': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5382:9: error: unknown type name 'gimple_statement_omp_continue' const gimple_statement_omp_continue *omp_continue_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5383:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5383:11: error: expected expression before 'const' as_a <const gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5384:27: error: request for member 'control_def' in something not a structure or union return omp_continue_stmt->control_def; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_continue_control_def_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5392:3: error: unknown type name 'gimple_statement_omp_continue' gimple_statement_omp_continue *omp_continue_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5393:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5393:11: error: 'gimple_statement_omp_continue' undeclared (first use in this function) as_a <gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5394:28: error: request for member 'control_def' in something not a structure or union return &omp_continue_stmt->control_def; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_continue_set_control_def': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5402:3: error: unknown type name 'gimple_statement_omp_continue' gimple_statement_omp_continue *omp_continue_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5403:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5403:11: error: 'gimple_statement_omp_continue' undeclared (first use in this function) as_a <gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5404:20: error: request for member 'control_def' in something not a structure or union omp_continue_stmt->control_def = def; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_continue_control_use': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5413:9: error: unknown type name 'gimple_statement_omp_continue' const gimple_statement_omp_continue *omp_continue_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5414:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5414:11: error: expected expression before 'const' as_a <const gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5415:27: error: request for member 'control_use' in something not a structure or union return omp_continue_stmt->control_use; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_continue_control_use_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5424:3: error: unknown type name 'gimple_statement_omp_continue' gimple_statement_omp_continue *omp_continue_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5425:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5425:11: error: 'gimple_statement_omp_continue' undeclared (first use in this function) as_a <gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5426:28: error: request for member 'control_use' in something not a structure or union return &omp_continue_stmt->control_use; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_omp_continue_set_control_use': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5435:3: error: unknown type name 'gimple_statement_omp_continue' gimple_statement_omp_continue *omp_continue_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5436:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5436:11: error: 'gimple_statement_omp_continue' undeclared (first use in this function) as_a <gimple_statement_omp_continue> (g); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5437:20: error: request for member 'control_use' in something not a structure or union omp_continue_stmt->control_use = use; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_transaction_body_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5445:3: error: unknown type name 'gimple_statement_transaction' gimple_statement_transaction *transaction_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5446:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_transaction> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5446:11: error: 'gimple_statement_transaction' undeclared (first use in this function) as_a <gimple_statement_transaction> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5447:27: error: request for member 'body' in something not a structure or union return &transaction_stmt->body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_transaction_label': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5463:9: error: unknown type name 'gimple_statement_transaction' const gimple_statement_transaction *transaction_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5464:5: error: 'as_a' undeclared (first use in this function) as_a <const gimple_statement_transaction> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5464:11: error: expected expression before 'const' as_a <const gimple_statement_transaction> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5465:26: error: request for member 'label' in something not a structure or union return transaction_stmt->label; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_transaction_label_ptr': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5471:3: error: unknown type name 'gimple_statement_transaction' gimple_statement_transaction *transaction_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5472:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_transaction> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5472:11: error: 'gimple_statement_transaction' undeclared (first use in this function) as_a <gimple_statement_transaction> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5473:27: error: request for member 'label' in something not a structure or union return &transaction_stmt->label; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_transaction_set_body': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5490:3: error: unknown type name 'gimple_statement_transaction' gimple_statement_transaction *transaction_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5491:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_transaction> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5491:11: error: 'gimple_statement_transaction' undeclared (first use in this function) as_a <gimple_statement_transaction> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5492:19: error: request for member 'body' in something not a structure or union transaction_stmt->body = body; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_transaction_set_label': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5500:3: error: unknown type name 'gimple_statement_transaction' gimple_statement_transaction *transaction_stmt = ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5501:5: error: 'as_a' undeclared (first use in this function) as_a <gimple_statement_transaction> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5501:11: error: 'gimple_statement_transaction' undeclared (first use in this function) as_a <gimple_statement_transaction> (gs); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5502:19: error: request for member 'label' in something not a structure or union transaction_stmt->label = label; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: At top level: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5598:1: error: return type is an incomplete type gimple_predict_predictor (gimple gs) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_predict_predictor': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5601:16: error: conversion to incomplete type return (enum br_predictor) (gs->subcode & ~GF_PREDICT_TAKEN); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5601:3: warning: 'return' with a value, in function returning void return (enum br_predictor) (gs->subcode & ~GF_PREDICT_TAKEN); ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: At top level: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5608:60: error: parameter 2 ('predictor') has incomplete type gimple_predict_set_predictor (gimple gs, enum br_predictor predictor) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5619:1: error: return type is an incomplete type gimple_predict_outcome (gimple gs) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_predict_outcome': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5622:45: error: 'TAKEN' undeclared (first use in this function) return (gs->subcode & GF_PREDICT_TAKEN) ? TAKEN : NOT_TAKEN; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5622:53: error: 'NOT_TAKEN' undeclared (first use in this function) return (gs->subcode & GF_PREDICT_TAKEN) ? TAKEN : NOT_TAKEN; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5622:3: warning: 'return' with a value, in function returning void return (gs->subcode & GF_PREDICT_TAKEN) ? TAKEN : NOT_TAKEN; ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: At top level: /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5629:56: error: parameter 2 ('outcome') has incomplete type gimple_predict_set_outcome (gimple gs, enum prediction outcome) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_predict_set_outcome': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5632:18: error: 'TAKEN' undeclared (first use in this function) if (outcome == TAKEN) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h: In function 'gimple_expr_type': /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5657:45: error: 'IFN_MASK_STORE' undeclared (first use in this function) && gimple_call_internal_fn (stmt) == IFN_MASK_STORE) ^ /opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include/gimple.h:5657:8: error: void value not ignored as it ought to be && gimple_call_internal_fn (stmt) == IFN_MASK_STORE) ^ conftest.c: At top level: conftest.c:79:45: warning: missing terminating ' character Beware, this compiler is a fake. Don't use it. ^ conftest.c: In function 'foo': conftest.c:90:10: warning: return makes pointer from integer without a cast return lookup_name (get_identifier ("puts")); ^ configure:26208: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | #define STARPU_NMAXBUFS 8 | #define STARPU_MAXNODES 1 | #define STARPU_USE_ALLOCATION_CACHE 1 | #define HAVE_LIBRT 1 | #define HAVE_CLOCK_GETTIME 1 | #define STARPU_NMAXWORKERS 64 | #define STARPU_MAXIMPLEMENTATIONS 4 | #define STARPU_USE_MPI /**/ | /* end confdefs.h. */ | #include <gcc-plugin.h> | #include <tree.h> | #include <gimple.h> | | #if defined __INTEL_COMPILER || defined __ICC | Beware, this compiler is a fake. Don't use it. | #endif | | tree fndecl; gimple call; | int | main () | { | /* Clang 3.1 doesn't support nested functions, so try to | discriminate it this way. */ | tree foo (void) | { | return lookup_name (get_identifier ("puts")); | } | fndecl = foo (); | call = gimple_build_call (fndecl, 0); | ; | return 0; | } configure:26224: result: no configure:26508: WARNING: GCC plug-ins not supported; StarPU's GCC plug-in will not be built configure:26646: checking for SOCL configure:26661: result: no configure:26709: checking for gdb configure:26727: found /usr/bin/gdb configure:26740: result: /usr/bin/gdb configure:26952: checking whether OpenGL rendering is enabled configure:26956: result: no configure:26967: checking for X configure:27075: gcc -E -D_GNU_SOURCE conftest.c configure:27075: $? = 0 configure:27106: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lX11 -lrt -lm -lpthread >&5 configure:27106: $? = 0 configure:27156: result: libraries , headers configure:27255: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lrt -lm -lpthread -lX11 >&5 configure:27255: $? = 0 configure:27353: checking for gethostbyname configure:27353: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lrt -lm -lpthread >&5 configure:27353: $? = 0 configure:27353: result: yes configure:27450: checking for connect configure:27450: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lrt -lm -lpthread >&5 configure:27450: $? = 0 configure:27450: result: yes configure:27499: checking for remove configure:27499: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lrt -lm -lpthread >&5 configure:27499: $? = 0 configure:27499: result: yes configure:27548: checking for shmat configure:27548: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lrt -lm -lpthread >&5 configure:27548: $? = 0 configure:27548: result: yes configure:27606: checking for IceConnectionNumber in -lICE configure:27631: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lICE -lrt -lm -lpthread >&5 /usr/bin/ld: cannot find -lICE collect2: error: ld returned 1 exit status configure:27631: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | #define STARPU_NMAXBUFS 8 | #define STARPU_MAXNODES 1 | #define STARPU_USE_ALLOCATION_CACHE 1 | #define HAVE_LIBRT 1 | #define HAVE_CLOCK_GETTIME 1 | #define STARPU_NMAXWORKERS 64 | #define STARPU_MAXIMPLEMENTATIONS 4 | #define STARPU_USE_MPI /**/ | #define STARPU_GDB_PATH "/usr/bin/gdb" | /* end confdefs.h. */ | | /* Override any GCC internal prototype to avoid an error. | Use char because int might match the return type of a GCC | builtin and then its argument prototype would still apply. */ | #ifdef __cplusplus | extern "C" | #endif | char IceConnectionNumber (); | int | main () | { | return IceConnectionNumber (); | ; | return 0; | } configure:27640: result: no configure:28089: checking for library containing sgemm_ configure:28120: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c >&5 /tmp/ccNyjqTC.o: In function `main': /nas_home/hpcfapix/starpu-1.1.4/conftest.c:87: undefined reference to `sgemm_' collect2: error: ld returned 1 exit status configure:28120: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | #define STARPU_NMAXBUFS 8 | #define STARPU_MAXNODES 1 | #define STARPU_USE_ALLOCATION_CACHE 1 | #define HAVE_LIBRT 1 | #define HAVE_CLOCK_GETTIME 1 | #define STARPU_NMAXWORKERS 64 | #define STARPU_MAXIMPLEMENTATIONS 4 | #define STARPU_USE_MPI /**/ | #define STARPU_GDB_PATH "/usr/bin/gdb" | #define STARPU_HAVE_X11 1 | /* end confdefs.h. */ | | /* Override any GCC internal prototype to avoid an error. | Use char because int might match the return type of a GCC | builtin and then its argument prototype would still apply. */ | #ifdef __cplusplus | extern "C" | #endif | char sgemm_ (); | int | main () | { | return sgemm_ (); | ; | return 0; | } configure:28120: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c -lblas >&5 configure:28120: $? = 0 configure:28137: result: -lblas configure:28208: checking which BLAS lib should be used configure:28210: result: system configure:28234: checking for FFTW configure:28242: $PKG_CONFIG --exists --print-errors "fftw3" Package fftw3 was not found in the pkg-config search path. Perhaps you should add the directory containing `fftw3.pc' to the PKG_CONFIG_PATH environment variable No package 'fftw3' found configure:28245: $? = 1 configure:28260: $PKG_CONFIG --exists --print-errors "fftw3" Package fftw3 was not found in the pkg-config search path. Perhaps you should add the directory containing `fftw3.pc' to the PKG_CONFIG_PATH environment variable No package 'fftw3' found configure:28263: $? = 1 No package 'fftw3' found configure:28291: result: no configure:28321: checking for FFTWF configure:28329: $PKG_CONFIG --exists --print-errors "fftw3f" Package fftw3f was not found in the pkg-config search path. Perhaps you should add the directory containing `fftw3f.pc' to the PKG_CONFIG_PATH environment variable No package 'fftw3f' found configure:28332: $? = 1 configure:28347: $PKG_CONFIG --exists --print-errors "fftw3f" Package fftw3f was not found in the pkg-config search path. Perhaps you should add the directory containing `fftw3f.pc' to the PKG_CONFIG_PATH environment variable No package 'fftw3f' found configure:28350: $? = 1 No package 'fftw3f' found configure:28378: result: no configure:28408: checking for FFTWL configure:28416: $PKG_CONFIG --exists --print-errors "fftw3l" Package fftw3l was not found in the pkg-config search path. Perhaps you should add the directory containing `fftw3l.pc' to the PKG_CONFIG_PATH environment variable No package 'fftw3l' found configure:28419: $? = 1 configure:28434: $PKG_CONFIG --exists --print-errors "fftw3l" Package fftw3l was not found in the pkg-config search path. Perhaps you should add the directory containing `fftw3l.pc' to the PKG_CONFIG_PATH environment variable No package 'fftw3l' found configure:28437: $? = 1 No package 'fftw3l' found configure:28465: result: no configure:28561: checking for HWLOC configure:28569: $PKG_CONFIG --exists --print-errors "hwloc" configure:28572: $? = 0 configure:28587: $PKG_CONFIG --exists --print-errors "hwloc" configure:28590: $? = 0 configure:28630: result: yes configure:28719: checking whether hwloc should be used configure:28721: result: yes configure:28726: checking f77.h usability configure:28726: gcc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c >&5 conftest.c:111:17: fatal error: f77.h: No such file or directory #include <f77.h> ^ compilation terminated. configure:28726: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | #define STARPU_NMAXBUFS 8 | #define STARPU_MAXNODES 1 | #define STARPU_USE_ALLOCATION_CACHE 1 | #define HAVE_LIBRT 1 | #define HAVE_CLOCK_GETTIME 1 | #define STARPU_NMAXWORKERS 64 | #define STARPU_MAXIMPLEMENTATIONS 4 | #define STARPU_USE_MPI /**/ | #define STARPU_GDB_PATH "/usr/bin/gdb" | #define STARPU_HAVE_X11 1 | #define STARPU_SYSTEM_BLAS 1 | #define STARPU_HAVE_HWLOC 1 | /* end confdefs.h. */ | #include <stdio.h> | #ifdef HAVE_SYS_TYPES_H | # include <sys/types.h> | #endif | #ifdef HAVE_SYS_STAT_H | # include <sys/stat.h> | #endif | #ifdef STDC_HEADERS | # include <stdlib.h> | # include <stddef.h> | #else | # ifdef HAVE_STDLIB_H | # include <stdlib.h> | # endif | #endif | #ifdef HAVE_STRING_H | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H | # include <memory.h> | # endif | # include <string.h> | #endif | #ifdef HAVE_STRINGS_H | # include <strings.h> | #endif | #ifdef HAVE_INTTYPES_H | # include <inttypes.h> | #endif | #ifdef HAVE_STDINT_H | # include <stdint.h> | #endif | #ifdef HAVE_UNISTD_H | # include <unistd.h> | #endif | #include <f77.h> configure:28726: result: no configure:28726: checking f77.h presence configure:28726: gcc -E -D_GNU_SOURCE conftest.c conftest.c:78:17: fatal error: f77.h: No such file or directory #include <f77.h> ^ compilation terminated. configure:28726: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | #define STARPU_NMAXBUFS 8 | #define STARPU_MAXNODES 1 | #define STARPU_USE_ALLOCATION_CACHE 1 | #define HAVE_LIBRT 1 | #define HAVE_CLOCK_GETTIME 1 | #define STARPU_NMAXWORKERS 64 | #define STARPU_MAXIMPLEMENTATIONS 4 | #define STARPU_USE_MPI /**/ | #define STARPU_GDB_PATH "/usr/bin/gdb" | #define STARPU_HAVE_X11 1 | #define STARPU_SYSTEM_BLAS 1 | #define STARPU_HAVE_HWLOC 1 | /* end confdefs.h. */ | #include <f77.h> configure:28726: result: no configure:28726: checking for f77.h configure:28726: result: no configure:28755: checking for icc configure:28785: result: no configure:28852: checking for help2man configure:28882: result: no configure:28903: checking for struct cudaDeviceProp.pciDomainID configure:28903: gcc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c >&5 conftest.c:78:30: fatal error: cuda_runtime_api.h: No such file or directory #include <cuda_runtime_api.h> ^ compilation terminated. configure:28903: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | #define STARPU_NMAXBUFS 8 | #define STARPU_MAXNODES 1 | #define STARPU_USE_ALLOCATION_CACHE 1 | #define HAVE_LIBRT 1 | #define HAVE_CLOCK_GETTIME 1 | #define STARPU_NMAXWORKERS 64 | #define STARPU_MAXIMPLEMENTATIONS 4 | #define STARPU_USE_MPI /**/ | #define STARPU_GDB_PATH "/usr/bin/gdb" | #define STARPU_HAVE_X11 1 | #define STARPU_SYSTEM_BLAS 1 | #define STARPU_HAVE_HWLOC 1 | /* end confdefs.h. */ | #include <cuda_runtime_api.h> | | int | main () | { | static struct cudaDeviceProp ac_aggr; | if (ac_aggr.pciDomainID) | return 0; | ; | return 0; | } configure:28903: gcc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c >&5 conftest.c:78:30: fatal error: cuda_runtime_api.h: No such file or directory #include <cuda_runtime_api.h> ^ compilation terminated. configure:28903: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | #define STARPU_NMAXBUFS 8 | #define STARPU_MAXNODES 1 | #define STARPU_USE_ALLOCATION_CACHE 1 | #define HAVE_LIBRT 1 | #define HAVE_CLOCK_GETTIME 1 | #define STARPU_NMAXWORKERS 64 | #define STARPU_MAXIMPLEMENTATIONS 4 | #define STARPU_USE_MPI /**/ | #define STARPU_GDB_PATH "/usr/bin/gdb" | #define STARPU_HAVE_X11 1 | #define STARPU_SYSTEM_BLAS 1 | #define STARPU_HAVE_HWLOC 1 | /* end confdefs.h. */ | #include <cuda_runtime_api.h> | | int | main () | { | static struct cudaDeviceProp ac_aggr; | if (sizeof ac_aggr.pciDomainID) | return 0; | ; | return 0; | } configure:28903: result: no configure:28912: checking for struct cudaDeviceProp.pciBusID configure:28912: gcc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c >&5 conftest.c:78:30: fatal error: cuda_runtime_api.h: No such file or directory #include <cuda_runtime_api.h> ^ compilation terminated. configure:28912: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | #define STARPU_NMAXBUFS 8 | #define STARPU_MAXNODES 1 | #define STARPU_USE_ALLOCATION_CACHE 1 | #define HAVE_LIBRT 1 | #define HAVE_CLOCK_GETTIME 1 | #define STARPU_NMAXWORKERS 64 | #define STARPU_MAXIMPLEMENTATIONS 4 | #define STARPU_USE_MPI /**/ | #define STARPU_GDB_PATH "/usr/bin/gdb" | #define STARPU_HAVE_X11 1 | #define STARPU_SYSTEM_BLAS 1 | #define STARPU_HAVE_HWLOC 1 | /* end confdefs.h. */ | #include <cuda_runtime_api.h> | | int | main () | { | static struct cudaDeviceProp ac_aggr; | if (ac_aggr.pciBusID) | return 0; | ; | return 0; | } configure:28912: gcc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c >&5 conftest.c:78:30: fatal error: cuda_runtime_api.h: No such file or directory #include <cuda_runtime_api.h> ^ compilation terminated. configure:28912: $? = 1 configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "StarPU" | #define PACKAGE_TARNAME "starpu" | #define PACKAGE_VERSION "1.1.4" | #define PACKAGE_STRING "StarPU 1.1.4" | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" | #define STARPU_MAJOR_VERSION 1 | #define STARPU_MINOR_VERSION 1 | #define STARPU_RELEASE_VERSION 4 | #define PACKAGE "starpu" | #define VERSION "1.1.4" | #define STDC_HEADERS 1 | #define HAVE_SYS_TYPES_H 1 | #define HAVE_SYS_STAT_H 1 | #define HAVE_STDLIB_H 1 | #define HAVE_STRING_H 1 | #define HAVE_MEMORY_H 1 | #define HAVE_STRINGS_H 1 | #define HAVE_INTTYPES_H 1 | #define HAVE_STDINT_H 1 | #define HAVE_UNISTD_H 1 | #define HAVE_DLFCN_H 1 | #define LT_OBJDIR ".libs/" | #define STDC_HEADERS 1 | #define restrict __restrict | #define SIZEOF_VOID_P 8 | #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" | #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." | #define HAVE_LIBPTHREAD 1 | #define STARPU_HAVE_STRUCT_TIMESPEC /**/ | #define HAVE_SYSCONF 1 | #define HAVE_PTHREAD_SPIN_LOCK /**/ | #define STARPU_HAVE_PTHREAD_BARRIER /**/ | #define HAVE_PTHREAD_SETAFFINITY_NP 1 | #define HAVE_POSIX_MEMALIGN 1 | #define STARPU_HAVE_POSIX_MEMALIGN 1 | #define HAVE_MEMALIGN 1 | #define STARPU_HAVE_MEMALIGN 1 | #define STARPU_USE_DRAND48 1 | #define STARPU_USE_ERAND48_R 1 | #define STARPU_HAVE_STRERROR_R 1 | #define STARPU_HAVE_SETENV 1 | #define STARPU_HAVE_UNSETENV 1 | #define STARPU_HAVE_NEARBYINTF 1 | #define STARPU_HAVE_RINTF 1 | #define HAVE_MALLOC_H 1 | #define STARPU_HAVE_MALLOC_H 1 | #define STARPU_HAVE_SCHED_YIELD 1 | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 | #define STARPU_HAVE_LIBNUMA /**/ | #define STARPU_NMAX_SCHED_CTXS 10 | #define STARPU_MAXCPUS 64 | #define STARPU_USE_CPU 1 | #define STARPU_NMAX_COMBINEDWORKERS 128 | #define STARPU_MAXCUDADEVS 4 | #define STARPU_MAXOPENCLDEVS 8 | #define STARPU_NON_BLOCKING_DRIVERS 1 | #define HAVE_LIBGLPK 1 | #define STARPU_NMAXBUFS 8 | #define STARPU_MAXNODES 1 | #define STARPU_USE_ALLOCATION_CACHE 1 | #define HAVE_LIBRT 1 | #define HAVE_CLOCK_GETTIME 1 | #define STARPU_NMAXWORKERS 64 | #define STARPU_MAXIMPLEMENTATIONS 4 | #define STARPU_USE_MPI /**/ | #define STARPU_GDB_PATH "/usr/bin/gdb" | #define STARPU_HAVE_X11 1 | #define STARPU_SYSTEM_BLAS 1 | #define STARPU_HAVE_HWLOC 1 | /* end confdefs.h. */ | #include <cuda_runtime_api.h> | | int | main () | { | static struct cudaDeviceProp ac_aggr; | if (sizeof ac_aggr.pciBusID) | return 0; | ; | return 0; | } configure:28912: result: no configure:28946: checking for doxygen configure:28964: found /usr/bin/doxygen configure:28976: result: /usr/bin/doxygen configure:28997: checking for pdflatex configure:29015: found /usr/bin/pdflatex configure:29027: result: /usr/bin/pdflatex configure:29040: checking for epstopdf configure:29058: found /usr/bin/epstopdf configure:29070: result: /usr/bin/epstopdf configure:29082: checking whether documentation should be compiled configure:29084: result: no configure:29446: creating ./config.status ## ---------------------- ## ## Running config.status. ## ## ---------------------- ## This file was extended by StarPU config.status 1.1.4, which was generated by GNU Autoconf 2.69. Invocation command line was CONFIG_FILES = CONFIG_HEADERS = CONFIG_LINKS = CONFIG_COMMANDS = $ ./config.status on fe.excess-project.eu config.status:1521: creating tests/regression/regression.sh config.status:1521: creating tests/regression/profiles config.status:1521: creating tests/regression/profiles.build.only config.status:1521: creating Makefile config.status:1521: creating src/Makefile config.status:1521: creating tools/Makefile config.status:1521: creating tools/starpu_codelet_profile config.status:1521: creating tools/starpu_codelet_histo_profile config.status:1521: creating tools/starpu_workers_activity config.status:1521: creating tools/starpu_paje_draw_histogram config.status:1521: creating tools/starpu_paje_state_stats config.status:1521: creating tools/starpu_paje_summary config.status:1521: creating tools/starpu_paje_sort config.status:1521: creating socl/Makefile config.status:1521: creating socl/src/Makefile config.status:1521: creating socl/examples/Makefile config.status:1521: creating socl/vendors/socl.icd config.status:1521: creating socl/vendors/install/socl.icd config.status:1521: creating libstarpu.pc config.status:1521: creating starpu-1.0.pc config.status:1521: creating starpu-1.1.pc config.status:1521: creating mpi/libstarpumpi.pc config.status:1521: creating mpi/starpumpi-1.0.pc config.status:1521: creating mpi/starpumpi-1.1.pc config.status:1521: creating starpufft/Makefile config.status:1521: creating starpufft/src/Makefile config.status:1521: creating starpufft/tests/Makefile config.status:1521: creating starpufft/libstarpufft.pc config.status:1521: creating starpufft/starpufft-1.0.pc config.status:1521: creating starpufft/starpufft-1.1.pc config.status:1521: creating examples/Makefile config.status:1521: creating examples/stencil/Makefile config.status:1521: creating tests/Makefile config.status:1521: creating mpi/Makefile config.status:1521: creating mpi/src/Makefile config.status:1521: creating mpi/tests/Makefile config.status:1521: creating mpi/examples/Makefile config.status:1521: creating starpu-top/StarPU-Top.pro config.status:1521: creating starpu-top/StarPU-Top-qwt-embed.pri config.status:1521: creating starpu-top/StarPU-Top-qwt-system.pri config.status:1521: creating gcc-plugin/Makefile config.status:1521: creating gcc-plugin/src/Makefile config.status:1521: creating gcc-plugin/tests/Makefile config.status:1521: creating gcc-plugin/tests/run-test config.status:1521: creating gcc-plugin/examples/Makefile config.status:1521: creating sc_hypervisor/Makefile config.status:1521: creating sc_hypervisor/src/Makefile config.status:1521: creating sc_hypervisor/examples/Makefile config.status:1521: creating doc/Makefile config.status:1521: creating doc/doxygen/Makefile config.status:1521: creating doc/doxygen/doxygen-config.cfg config.status:1521: creating doc/doxygen/doxygen_filter.sh config.status:1521: creating tools/mvsc/starpu_var.bat config.status:1521: creating src/common/config.h config.status:1702: src/common/config.h is unchanged config.status:1521: creating include/starpu_config.h config.status:1702: include/starpu_config.h is unchanged config.status:1521: creating gcc-plugin/include/starpu-gcc/config.h config.status:1702: gcc-plugin/include/starpu-gcc/config.h is unchanged config.status:1521: creating starpu-top/config.h config.status:1702: starpu-top/config.h is unchanged config.status:1781: executing depfiles commands config.status:1781: executing libtool commands config.status:1781: executing executable-scripts commands configure:32283: WARNING: unrecognized options: --enable-new-check configure:32329: CPUs enabled: yes CUDA enabled: no OpenCL enabled: no Compile-time limits (change these with --enable-maxcpus, --enable-maxcudadev, --enable-maxopencldev, --enable-maxbuffers) (Note these numbers do not represent the number of detected devices, but the maximum number of devices StarPU can manage) Maximum number of CPUs: 64 Maximum number of CUDA devices: 0 Maximum number of OpenCL devices: 0 Maximum number of memory nodes: 1 Maximum number of task buffers: 8 GPU-GPU transfers: no Allocation cache: yes Magma enabled: no BLAS library: system hwloc: yes FxT trace enabled: no StarPU-Top: no Documentation: no Examples: yes StarPU Extensions: MPI enabled: yes MPI test suite: no FFT Support: no GCC plug-in: no GCC plug-in test suite (requires GNU Guile): no SOCL enabled: no SOCL test suite: no Scheduler Hypervisor: no simgrid enabled: no ayudame enabled: no ## ---------------- ## ## Cache variables. ## ## ---------------- ## ac_cv_build=x86_64-unknown-linux-gnu ac_cv_c_compiler_gnu=yes ac_cv_c_restrict=__restrict ac_cv_cxx_compiler_gnu=yes ac_cv_env_BLAS_LIBS_set= ac_cv_env_BLAS_LIBS_value= ac_cv_env_CCC_set= ac_cv_env_CCC_value= ac_cv_env_CC_set= ac_cv_env_CC_value= ac_cv_env_CFLAGS_set= ac_cv_env_CFLAGS_value= ac_cv_env_CPPFLAGS_set= ac_cv_env_CPPFLAGS_value= ac_cv_env_CPP_set= ac_cv_env_CPP_value= ac_cv_env_CXXCPP_set= ac_cv_env_CXXCPP_value= ac_cv_env_CXXFLAGS_set= ac_cv_env_CXXFLAGS_value= ac_cv_env_CXX_set= ac_cv_env_CXX_value= ac_cv_env_F77_set= ac_cv_env_F77_value= ac_cv_env_FFLAGS_set= ac_cv_env_FFLAGS_value= ac_cv_env_FFTWF_CFLAGS_set= ac_cv_env_FFTWF_CFLAGS_value= ac_cv_env_FFTWF_LIBS_set= ac_cv_env_FFTWF_LIBS_value= ac_cv_env_FFTWL_CFLAGS_set= ac_cv_env_FFTWL_CFLAGS_value= ac_cv_env_FFTWL_LIBS_set= ac_cv_env_FFTWL_LIBS_value= ac_cv_env_FFTW_CFLAGS_set= ac_cv_env_FFTW_CFLAGS_value= ac_cv_env_FFTW_LIBS_set= ac_cv_env_FFTW_LIBS_value= ac_cv_env_FXT_CFLAGS_set= ac_cv_env_FXT_CFLAGS_value= ac_cv_env_FXT_LDFLAGS_set= ac_cv_env_FXT_LDFLAGS_value= ac_cv_env_FXT_LIBS_set= ac_cv_env_FXT_LIBS_value= ac_cv_env_HWLOC_CFLAGS_set= ac_cv_env_HWLOC_CFLAGS_value= ac_cv_env_HWLOC_LIBS_set= ac_cv_env_HWLOC_LIBS_value= ac_cv_env_LDFLAGS_set= ac_cv_env_LDFLAGS_value= ac_cv_env_LIBS_set= ac_cv_env_LIBS_value= ac_cv_env_MAGMA_CFLAGS_set= ac_cv_env_MAGMA_CFLAGS_value= ac_cv_env_MAGMA_LIBS_set= ac_cv_env_MAGMA_LIBS_value= ac_cv_env_NVCCFLAGS_set= ac_cv_env_NVCCFLAGS_value= ac_cv_env_NVCC_set= ac_cv_env_NVCC_value= ac_cv_env_PKG_CONFIG_set= ac_cv_env_PKG_CONFIG_value= ac_cv_env_POTI_CFLAGS_set= ac_cv_env_POTI_CFLAGS_value= ac_cv_env_POTI_LIBS_set= ac_cv_env_POTI_LIBS_value= ac_cv_env_STARPU_MS_LIB_set= ac_cv_env_STARPU_MS_LIB_value= ac_cv_env_XMKMF_set= ac_cv_env_XMKMF_value= ac_cv_env_build_alias_set= ac_cv_env_build_alias_value= ac_cv_env_host_alias_set= ac_cv_env_host_alias_value= ac_cv_env_target_alias_set= ac_cv_env_target_alias_value= ac_cv_f77_compiler_gnu=yes ac_cv_func_clock_gettime=yes ac_cv_func_connect=yes ac_cv_func_drand48=yes ac_cv_func_erand48_r=yes ac_cv_func_gethostbyname=yes ac_cv_func_memalign=yes ac_cv_func_nearbyintf=yes ac_cv_func_posix_memalign=yes ac_cv_func_pthread_barrier_init=yes ac_cv_func_pthread_setaffinity_np=yes ac_cv_func_pthread_spin_lock=yes ac_cv_func_remove=yes ac_cv_func_rintf=yes ac_cv_func_sched_yield=yes ac_cv_func_setenv=yes ac_cv_func_shmat=yes ac_cv_func_strerror_r=yes ac_cv_func_sysconf=yes ac_cv_func_unsetenv=yes ac_cv_have_gcc_plugins=no ac_cv_have_sync_bool_compare_and_swap=yes ac_cv_have_sync_fetch_and_add=yes ac_cv_have_sync_fetch_and_or=yes ac_cv_have_sync_lock_test_and_set=yes ac_cv_have_sync_synchronize=yes ac_cv_have_sync_val_compare_and_swap=yes ac_cv_have_x='have_x=yes ac_x_includes='\'''\'' ac_x_libraries='\'''\''' ac_cv_header_Ayudame_h=no ac_cv_header_dlfcn_h=yes ac_cv_header_f77_h=no ac_cv_header_glpk_h=no ac_cv_header_inttypes_h=yes ac_cv_header_malloc_h=yes ac_cv_header_memory_h=yes ac_cv_header_stdc=yes ac_cv_header_stdint_h=yes ac_cv_header_stdlib_h=yes ac_cv_header_string_h=yes ac_cv_header_strings_h=yes ac_cv_header_sys_stat_h=yes ac_cv_header_sys_types_h=yes ac_cv_header_unistd_h=yes ac_cv_header_valgrind_helgrind_h=no ac_cv_header_valgrind_valgrind_h=no ac_cv_host=x86_64-unknown-linux-gnu ac_cv_lib_ICE_IceConnectionNumber=no ac_cv_lib_glpk_main=yes ac_cv_lib_pthread_pthread_create=yes ac_cv_lib_rt_clock_gettime=yes ac_cv_lib_ws2_32=ac_cv_lib_ws2_32_main ac_cv_lib_ws2_32_main=no ac_cv_member_struct_cudaDeviceProp_pciBusID=no ac_cv_member_struct_cudaDeviceProp_pciDomainID=no ac_cv_objext=o ac_cv_path_EGREP='/bin/grep -E' ac_cv_path_FGREP='/bin/grep -F' ac_cv_path_GDB=/usr/bin/gdb ac_cv_path_GREP=/bin/grep ac_cv_path_SED=/bin/sed ac_cv_path_ac_pt_PKG_CONFIG=/usr/bin/pkg-config ac_cv_path_doxygencommand=/usr/bin/doxygen ac_cv_path_epstopdfcommand=/usr/bin/epstopdf ac_cv_path_install='/usr/bin/install -c' ac_cv_path_mkdir=/bin/mkdir ac_cv_path_mpicc_path=/opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpicc ac_cv_path_mpiexec_path=/opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpiexec ac_cv_path_pdflatexcommand=/usr/bin/pdflatex ac_cv_path_svncommand=/usr/bin/svn ac_cv_path_svnversioncommand=/usr/bin/svnversion ac_cv_prog_AWK=gawk ac_cv_prog_BASH=/bin/sh ac_cv_prog_CPP='gcc -E' ac_cv_prog_CXXCPP='g++ -E' ac_cv_prog_ac_ct_AR=ar ac_cv_prog_ac_ct_CC=gcc ac_cv_prog_ac_ct_CXX=g++ ac_cv_prog_ac_ct_F77=gfortran ac_cv_prog_ac_ct_OBJDUMP=objdump ac_cv_prog_ac_ct_RANLIB=ranlib ac_cv_prog_ac_ct_STRIP=strip ac_cv_prog_cc_c89= ac_cv_prog_cc_g=yes ac_cv_prog_cc_gcc_c_o=yes ac_cv_prog_cxx_g=yes ac_cv_prog_f77_g=yes ac_cv_prog_make_make_set=yes ac_cv_search_set_mempolicy=-lnuma ac_cv_search_sgemm_=-lblas ac_cv_search_sqrt=-lm ac_cv_sizeof_void_p=8 ac_cv_target=x86_64-unknown-linux-gnu ac_cv_type_cufftDoubleComplex=no ac_cv_type_struct_timespec=yes am_cv_CC_dependencies_compiler_type=gcc3 am_cv_CXX_dependencies_compiler_type=gcc3 am_cv_ar_interface=ar am_cv_make_support_nested_variables=yes lt_cv_ar_at_file=@ lt_cv_archive_cmds_need_lc=no lt_cv_deplibs_check_method=pass_all lt_cv_file_magic_cmd='$MAGIC_CMD' lt_cv_file_magic_test_file= lt_cv_ld_reload_flag=-r lt_cv_nm_interface='BSD nm' lt_cv_objdir=.libs lt_cv_path_LD=/usr/bin/ld lt_cv_path_LDCXX='/usr/bin/ld -m elf_x86_64' lt_cv_path_NM='/usr/bin/nm -B' lt_cv_path_mainfest_tool=no lt_cv_prog_compiler_c_o=yes lt_cv_prog_compiler_c_o_CXX=yes lt_cv_prog_compiler_c_o_F77=yes lt_cv_prog_compiler_pic='-fPIC -DPIC' lt_cv_prog_compiler_pic_CXX='-fPIC -DPIC' lt_cv_prog_compiler_pic_F77=-fPIC lt_cv_prog_compiler_pic_works=yes lt_cv_prog_compiler_pic_works_CXX=yes lt_cv_prog_compiler_pic_works_F77=yes lt_cv_prog_compiler_rtti_exceptions=no lt_cv_prog_compiler_static_works=yes lt_cv_prog_compiler_static_works_CXX=yes lt_cv_prog_compiler_static_works_F77=yes lt_cv_prog_gnu_ld=yes lt_cv_prog_gnu_ldcxx=yes lt_cv_sharedlib_from_linklib_cmd='printf %s\n' lt_cv_shlibpath_overrides_runpath=no lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed '\''/ __gnu_lto/d'\''' lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/ {"\2", (void *) \&\2},/p'\''' lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \(lib[^ ]*\)$/ {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/ {"lib\2", (void *) \&\2},/p'\''' lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\''' lt_cv_sys_max_cmd_len=1966080 lt_cv_to_host_file_cmd=func_convert_file_noop lt_cv_to_tool_file_cmd=func_convert_file_noop pkg_cv_HWLOC_CFLAGS='-I/usr/include/libxml2 ' pkg_cv_HWLOC_LIBS='-lhwloc ' ## ----------------- ## ## Output variables. ## ## ----------------- ## ACLOCAL='${SHELL} /nas_home/hpcfapix/starpu-1.1.4/build-aux/missing --run aclocal-1.11' AMDEPBACKSLASH='\' AMDEP_FALSE='#' AMDEP_TRUE='' AMTAR='$${TAR-tar}' AM_BACKSLASH='\' AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)' AM_DEFAULT_VERBOSITY='0' AM_V='$(V)' AR='ar' AS='as' ATLASDIR='' ATLAS_BLAS_LIB_FALSE='' ATLAS_BLAS_LIB_TRUE='#' AUTOCONF='${SHELL} /nas_home/hpcfapix/starpu-1.1.4/build-aux/missing --run autoconf' AUTOHEADER='${SHELL} /nas_home/hpcfapix/starpu-1.1.4/build-aux/missing --run autoheader' AUTOMAKE='${SHELL} /nas_home/hpcfapix/starpu-1.1.4/build-aux/missing --run automake-1.11' AWK='gawk' BASH='/bin/sh' BLAS_LIB='system' BLAS_LIBS='' BUILD_DOC_FALSE='' BUILD_DOC_TRUE='#' BUILD_EXAMPLES_FALSE='#' BUILD_EXAMPLES_TRUE='' BUILD_GCC_PLUGIN_FALSE='' BUILD_GCC_PLUGIN_TRUE='#' BUILD_SOCL_FALSE='' BUILD_SOCL_TRUE='#' BUILD_STARPUFFT_EXAMPLES_FALSE='' BUILD_STARPUFFT_EXAMPLES_TRUE='#' BUILD_STARPUFFT_FALSE='' BUILD_STARPUFFT_TRUE='#' BUILD_STARPU_TOP_FALSE='' BUILD_STARPU_TOP_TRUE='#' CC='gcc' CCDEPMODE='depmode=gcc3' CC_OR_MPICC='/opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpicc' CFLAGS='-O3 -g -O2 -gdwarf-2 -g3 ' COVERAGE='no' CPP='gcc -E' CPPFLAGS=' -D_GNU_SOURCE ' CXX='g++' CXXCPP='g++ -E' CXXDEPMODE='depmode=gcc3' CXXFLAGS='-g -O2' CYGPATH_W='echo' DEFS='-DHAVE_CONFIG_H' DEPDIR='.deps' DLLTOOL='false' DSYMUTIL='' DUMPBIN='' ECHO_C='' ECHO_N='-n' ECHO_T='' EGREP='/bin/grep -E' EXEEXT='' F77='gfortran' FFLAGS='-g -O2' FFTWF_CFLAGS='' FFTWF_LIBS='' FFTWL_CFLAGS='' FFTWL_LIBS='' FFTW_CFLAGS='' FFTW_LIBS='' FGREP='/bin/grep -F' FXTDIR='' FXT_CFLAGS='' FXT_LDFLAGS='' FXT_LIBS='' GCC_FOR_PLUGIN='' GCC_FOR_PLUGIN_LIBTOOL_TAG='' GCC_PLUGIN_DIR_PKGCONFIG='' GCC_PLUGIN_INCLUDE_DIR='/opt/compiler/gnu/4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2/plugin/include' GCC_PLUGIN_PKGCONFIG='' GDB='/usr/bin/gdb' GLOBAL_AM_CFLAGS=' -Wall -Werror=implicit -Werror=implicit-function-declaration' GOTODIR='' GOTO_BLAS_LIB_FALSE='' GOTO_BLAS_LIB_TRUE='#' GREP='/bin/grep' GUILE='' HAVE_FFTWFL='' HAVE_OPENGL_FALSE='' HAVE_OPENGL_TRUE='#' HAVE_PTR_DEREFS_MAY_ALIAS_P_FALSE='' HAVE_PTR_DEREFS_MAY_ALIAS_P_TRUE='#' HAVE_X11_FALSE='#' HAVE_X11_TRUE='' HELP2MAN='' HWLOC_CFLAGS='-I/usr/include/libxml2 ' HWLOC_LIBS='-lhwloc ' HWLOC_REQUIRES='hwloc' ICC='' INSTALL_DATA='${INSTALL} -m 644' INSTALL_PROGRAM='${INSTALL}' INSTALL_SCRIPT='${INSTALL}' INSTALL_STRIP_PROGRAM='$(install_sh) -c -s' LD='/usr/bin/ld -m elf_x86_64' LDFLAGS='' LIBOBJS='' LIBS='-lrt -lm -lpthread ' LIBSOCL_INTERFACE_AGE='0' LIBSOCL_INTERFACE_CURRENT='1' LIBSOCL_INTERFACE_REVISION='2' LIBSTARPUFFT_INTERFACE_AGE='0' LIBSTARPUFFT_INTERFACE_CURRENT='1' LIBSTARPUFFT_INTERFACE_REVISION='2' LIBSTARPUMPI_INTERFACE_AGE='0' LIBSTARPUMPI_INTERFACE_CURRENT='3' LIBSTARPUMPI_INTERFACE_REVISION='0' LIBSTARPU_INTERFACE_AGE='0' LIBSTARPU_INTERFACE_CURRENT='9' LIBSTARPU_INTERFACE_REVISION='0' LIBSTARPU_LDFLAGS=' -lglpk ' LIBSTARPU_LINK='libstarpu-1.1.la' LIBTOOL='$(SHELL) $(top_builddir)/libtool' LIPO='' LN_S='ln -s' LTLIBOBJS='' MAGMA_CFLAGS='' MAGMA_LIBS='' MAKEINFO='${SHELL} /nas_home/hpcfapix/starpu-1.1.4/build-aux/missing --run makeinfo' MANIFEST_TOOL=':' MKDIR_P='/bin/mkdir -p' MKL_BLAS_LIB_FALSE='' MKL_BLAS_LIB_TRUE='#' MPICC='/opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpicc' MPICC_LDFLAGS='' MPIEXEC='/opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpiexec' NM='/usr/bin/nm -B' NMEDIT='' NO_BLAS_LIB_FALSE='' NO_BLAS_LIB_TRUE='#' NVCC='' NVCCFLAGS='' OBJDUMP='objdump' OBJEXT='o' OTOOL64='' OTOOL='' PACKAGE='starpu' PACKAGE_BUGREPORT='starpu-devel@lists.gforge.inria.fr' PACKAGE_NAME='StarPU' PACKAGE_STRING='StarPU 1.1.4' PACKAGE_TARNAME='starpu' PACKAGE_URL='http://runtime.bordeaux.inria.fr/StarPU/' PACKAGE_VERSION='1.1.4' PATH_SEPARATOR=':' PKG_CONFIG='/usr/bin/pkg-config' POTI_CFLAGS='' POTI_LIBS='' QMAKE='not-found' QWT_PRI='' RANLIB='ranlib' RUN_GCC_PLUGIN_TESTS_FALSE='' RUN_GCC_PLUGIN_TESTS_TRUE='#' SED='/bin/sed' SET_MAKE='' SHELL='/bin/sh' SIMGRID_CFLAGS='' SIMGRID_LIBS='' SOCL_OCL_LIB_OPENCL='' SOCL_VENDORS='vendors/install/socl.icd' STARPU_BLAS_LDFLAGS=' -lblas ' STARPU_BUILD_DIR='/nas_home/hpcfapix/starpu-1.1.4' STARPU_BUILD_SC_HYPERVISOR_FALSE='' STARPU_BUILD_SC_HYPERVISOR_TRUE='#' STARPU_COVERAGE_ENABLED_FALSE='' STARPU_COVERAGE_ENABLED_TRUE='#' STARPU_CUDA_CPPFLAGS='' STARPU_CUDA_FORTRAN_LDFLAGS='' STARPU_CUDA_LDFLAGS='' STARPU_CUFFT_LDFLAGS='' STARPU_CURAND_LDFLAGS='' STARPU_DEVEL_FALSE='' STARPU_DEVEL_TRUE='#' STARPU_EFFECTIVE_VERSION='1.1' STARPU_ENABLE_STATS='no' STARPU_GCC_VERSION_MAJOR='' STARPU_GCC_VERSION_MINOR='' STARPU_GLPK_LDFLAGS=' -lglpk ' STARPU_HAVE_AM111_FALSE='#' STARPU_HAVE_AM111_TRUE='' STARPU_HAVE_CUFFTDOUBLECOMPLEX_FALSE='' STARPU_HAVE_CUFFTDOUBLECOMPLEX_TRUE='#' STARPU_HAVE_F77_H='no' STARPU_HAVE_F77_H_FALSE='' STARPU_HAVE_F77_H_TRUE='#' STARPU_HAVE_FFTW='' STARPU_HAVE_FFTWF='' STARPU_HAVE_FFTWF_FALSE='' STARPU_HAVE_FFTWF_TRUE='#' STARPU_HAVE_FFTWL_FALSE='' STARPU_HAVE_FFTWL_TRUE='#' STARPU_HAVE_FFTW_FALSE='' STARPU_HAVE_FFTW_TRUE='#' STARPU_HAVE_HELP2MAN_FALSE='' STARPU_HAVE_HELP2MAN_TRUE='#' STARPU_HAVE_HWLOC='1' STARPU_HAVE_ICC_FALSE='' STARPU_HAVE_ICC_TRUE='#' STARPU_HAVE_MAGMA='' STARPU_HAVE_MAGMA_FALSE='' STARPU_HAVE_MAGMA_TRUE='#' STARPU_HAVE_MS_LIB_FALSE='' STARPU_HAVE_MS_LIB_TRUE='#' STARPU_HAVE_WINDOWS_FALSE='' STARPU_HAVE_WINDOWS_TRUE='#' STARPU_LIBNUMA_LDFLAGS=' -lnuma ' STARPU_LONG_CHECK_FALSE='' STARPU_LONG_CHECK_TRUE='#' STARPU_MAJOR_VERSION='1' STARPU_MINOR_VERSION='1' STARPU_MPI_CHECK_FALSE='' STARPU_MPI_CHECK_TRUE='#' STARPU_MS_LIB='' STARPU_MS_LIB_ARCH='X64' STARPU_OPENCL_CPPFLAGS='' STARPU_OPENCL_DATAdir='' STARPU_OPENCL_LDFLAGS='' STARPU_OPENGL_RENDER='no' STARPU_OPENGL_RENDER_LDFLAGS='' STARPU_PERF_DEBUG='no' STARPU_QUICK_CHECK_FALSE='' STARPU_QUICK_CHECK_TRUE='#' STARPU_QWT_INCLUDE='' STARPU_QWT_LDFLAGS='' STARPU_RELEASE_VERSION='4' STARPU_SC_HYPERVISOR='' STARPU_SIMGRID_FALSE='' STARPU_SIMGRID_TRUE='#' STARPU_SRC_DIR='/nas_home/hpcfapix/starpu-1.1.4/.' STARPU_USE_CPU='yes' STARPU_USE_CPU_FALSE='#' STARPU_USE_CPU_TRUE='' STARPU_USE_CUDA='no' STARPU_USE_CUDA_FALSE='' STARPU_USE_CUDA_TRUE='#' STARPU_USE_FXT='no' STARPU_USE_FXT_FALSE='' STARPU_USE_FXT_TRUE='#' STARPU_USE_OPENCL='no' STARPU_USE_OPENCL_FALSE='' STARPU_USE_OPENCL_TRUE='#' STARPU_USE_SC_HYPERVISOR_FALSE='' STARPU_USE_SC_HYPERVISOR_TRUE='#' STARPU_USE_SOCL_FALSE='' STARPU_USE_SOCL_TRUE='#' STARPU_USE_TOP='no' STATS='no' STRIP='strip' SYSTEM_BLAS_LIB_FALSE='#' SYSTEM_BLAS_LIB_TRUE='' USE_MPI='yes' USE_MPI_FALSE='#' USE_MPI_TRUE='' VERSION='1.1.4' XMKMF='' X_CFLAGS='' X_EXTRA_LIBS='' X_LIBS='' X_PRE_LIBS='' YACC='${SHELL} /nas_home/hpcfapix/starpu-1.1.4/build-aux/missing --run bison' ac_ct_AR='ar' ac_ct_CC='gcc' ac_ct_CXX='g++' ac_ct_DUMPBIN='' ac_ct_F77='gfortran' am__EXEEXT_FALSE='' am__EXEEXT_TRUE='#' am__fastdepCC_FALSE='#' am__fastdepCC_TRUE='' am__fastdepCXX_FALSE='#' am__fastdepCXX_TRUE='' am__include='include' am__isrc='' am__leading_dot='.' am__nodep='_no' am__quote='' am__tar='$${TAR-tar} chof - "$$tardir"' am__untar='$${TAR-tar} xf -' bindir='${exec_prefix}/bin' build='x86_64-unknown-linux-gnu' build_alias='' build_cpu='x86_64' build_os='linux-gnu' build_vendor='unknown' datadir='${datarootdir}' datarootdir='${prefix}/share' docdir='${datarootdir}/doc/${PACKAGE_TARNAME}' doxygencommand='/usr/bin/doxygen' dvidir='${docdir}' epstopdfcommand='/usr/bin/epstopdf' exec_prefix='${prefix}' gccplugindir='' host='x86_64-unknown-linux-gnu' host_alias='' host_cpu='x86_64' host_os='linux-gnu' host_vendor='unknown' htmldir='${docdir}' includedir='${prefix}/include' infodir='${datarootdir}/info' install_sh='${SHELL} /nas_home/hpcfapix/starpu-1.1.4/build-aux/install-sh' libdir='${exec_prefix}/lib' libexecdir='${exec_prefix}/libexec' localedir='${datarootdir}/locale' localstatedir='${prefix}/var' mandir='${datarootdir}/man' mkdir_p='/bin/mkdir -p' mpicc_path='/opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpicc' mpiexec_path='/opt/mpi/mpich/mpich-3.1-gnu-4.9.2/bin/mpiexec' oldincludedir='/usr/include' pdfdir='${docdir}' pdflatexcommand='/usr/bin/pdflatex' pkglibdir='${libdir}/starpu' prefix='/opt/runtime/StarPU/1.1.4-gnu-4.9.2' program_transform_name='s,x,x,' psdir='${docdir}' sbindir='${exec_prefix}/sbin' sharedstatedir='${prefix}/com' svncommand='/usr/bin/svn' svnversioncommand='/usr/bin/svnversion' sysconfdir='${prefix}/etc' target='x86_64-unknown-linux-gnu' target_alias='' target_cpu='x86_64' target_os='linux-gnu' target_vendor='unknown' ## ----------- ## ## confdefs.h. ## ## ----------- ## /* confdefs.h */ #define PACKAGE_NAME "StarPU" #define PACKAGE_TARNAME "starpu" #define PACKAGE_VERSION "1.1.4" #define PACKAGE_STRING "StarPU 1.1.4" #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr" #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/" #define STARPU_MAJOR_VERSION 1 #define STARPU_MINOR_VERSION 1 #define STARPU_RELEASE_VERSION 4 #define PACKAGE "starpu" #define VERSION "1.1.4" #define STDC_HEADERS 1 #define HAVE_SYS_TYPES_H 1 #define HAVE_SYS_STAT_H 1 #define HAVE_STDLIB_H 1 #define HAVE_STRING_H 1 #define HAVE_MEMORY_H 1 #define HAVE_STRINGS_H 1 #define HAVE_INTTYPES_H 1 #define HAVE_STDINT_H 1 #define HAVE_UNISTD_H 1 #define HAVE_DLFCN_H 1 #define LT_OBJDIR ".libs/" #define STDC_HEADERS 1 #define restrict __restrict #define SIZEOF_VOID_P 8 #define STARPU_BUILD_DIR "/nas_home/hpcfapix/starpu-1.1.4" #define STARPU_SRC_DIR "/nas_home/hpcfapix/starpu-1.1.4/." #define HAVE_LIBPTHREAD 1 #define STARPU_HAVE_STRUCT_TIMESPEC /**/ #define HAVE_SYSCONF 1 #define HAVE_PTHREAD_SPIN_LOCK /**/ #define STARPU_HAVE_PTHREAD_BARRIER /**/ #define HAVE_PTHREAD_SETAFFINITY_NP 1 #define HAVE_POSIX_MEMALIGN 1 #define STARPU_HAVE_POSIX_MEMALIGN 1 #define HAVE_MEMALIGN 1 #define STARPU_HAVE_MEMALIGN 1 #define STARPU_USE_DRAND48 1 #define STARPU_USE_ERAND48_R 1 #define STARPU_HAVE_STRERROR_R 1 #define STARPU_HAVE_SETENV 1 #define STARPU_HAVE_UNSETENV 1 #define STARPU_HAVE_NEARBYINTF 1 #define STARPU_HAVE_RINTF 1 #define HAVE_MALLOC_H 1 #define STARPU_HAVE_MALLOC_H 1 #define STARPU_HAVE_SCHED_YIELD 1 #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1 #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1 #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1 #define STARPU_HAVE_SYNC_FETCH_AND_OR 1 #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1 #define STARPU_HAVE_SYNC_SYNCHRONIZE 1 #define STARPU_HAVE_LIBNUMA /**/ #define STARPU_NMAX_SCHED_CTXS 10 #define STARPU_MAXCPUS 64 #define STARPU_USE_CPU 1 #define STARPU_NMAX_COMBINEDWORKERS 128 #define STARPU_MAXCUDADEVS 4 #define STARPU_MAXOPENCLDEVS 8 #define STARPU_NON_BLOCKING_DRIVERS 1 #define HAVE_LIBGLPK 1 #define STARPU_NMAXBUFS 8 #define STARPU_MAXNODES 1 #define STARPU_USE_ALLOCATION_CACHE 1 #define HAVE_LIBRT 1 #define HAVE_CLOCK_GETTIME 1 #define STARPU_NMAXWORKERS 64 #define STARPU_MAXIMPLEMENTATIONS 4 #define STARPU_USE_MPI /**/ #define STARPU_GDB_PATH "/usr/bin/gdb" #define STARPU_HAVE_X11 1 #define STARPU_SYSTEM_BLAS 1 #define STARPU_HAVE_HWLOC 1 configure: exit 0
- [Starpu-devel] Error report, Fangli Pi, 25/09/2015
- Re: [Starpu-devel] Error report, Nathalie Furmento, 25/09/2015
- Re: [Starpu-devel] Error report, Fangli Pi, 28/09/2015
- Message indisponible
- [Starpu-devel] Fwd: Error report, Fangli Pi, 28/09/2015
- Re: [Starpu-devel] Error report, Nathalie Furmento, 28/09/2015
