Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Mathieu Faverge <mathieu.faverge@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Cannot find MPI
- Date: Mon, 16 Nov 2015 08:55:00 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=Pass smtp.helo=postmaster@iona.labri.fr
- Ironport-phdr: 9a23:S0gPlR9SXih4ff9uRHKM819IXTAuvvDOBiVQ1KB92uwcTK2v8tzYMVDF4r011RmSDdidtqwP0rOI+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStOU0pr8jrnss7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cYk7sb+sVBSaT3ebgjBfwdVWx+cjN92Mq+kBDfTQqC+zMyW3sbiBVFS1zA5Q36X5rs9CXzqOdn1ySyPMvsTLlyVy70vIlxTxq9ri4bNzc98WyfpNFqia9dvBXp8xp2347dZICYcvRjZKbQe88dbW5IVNxQESJbVNDvJ7ATBvYMaL4L57L2oEED+F7nXVGh
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi Mathieu,
configure only checks if the MPI compiler is executable.
if test ! -x $mpicc_path; then
AC_MSG_RESULT(The mpicc compiler is not valid)
You should change the message below the if
to print the value of $mpicc_path.
Ah, i just saw you specified a value to --with-mpicc, you
should not need to do that. It looks like your system is
finding a MPI runtime in /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/
Cheers,
Nathalie
On Nov 15, 11:26, Mathieu Faverge wrote:
> Hello,
> Any ideas why I always get :
> StarPU Extensions:
> MPI enabled: no
> I don't see why the test fails.
> Mathieu
> Mathieu Faverge
> Maitre de conférence / Assistant Professor
> Institut Polytechnique de Bordeaux - ENSEIRB-Matmeca
> INRIA Bordeaux - Sud-Ouest, HiePACS Team
> 200 avenue de la vielle tour
> 33405 Talence Cedex
> Phone: (+33) 5 24 57 40 73
> This file contains any messages produced by compilers while
> running configure, to aid debugging if configure makes a mistake.
> It was created by StarPU configure 1.2.0rc4, which was
> generated by GNU Autoconf 2.69. Invocation command line was
> $ /lustre/project/k1044/favergm/src/starpu-1.2.0rc4/./configure
> --prefix=/project/k1044/favergm/opt-gcc/starpu-1.2.0rc4 --disable-cuda
> --disable-opencl --with-mpicc=cc --enable-mpi
> ## Platform. ##
> hostname = nid00081
> uname -m = x86_64
> uname -r = 3.0.101-0.46.1_1.0502.8871-cray_ari_c
> uname -s = Linux
> uname -v = #1 SMP Tue Aug 25 21:41:26 UTC 2015
> /usr/bin/uname -p = unknown
> /bin/uname -X = unknown
> /bin/arch = x86_64
> /usr/bin/arch -k = unknown
> /usr/convex/getsysinfo = unknown
> /usr/bin/hostinfo = unknown
> /bin/machine = unknown
> /usr/bin/oslevel = unknown
> /bin/universe = unknown
> PATH: /sw/xc40/cmake/3.1.3/cnl5.2_gnu4.9.2/bin
> PATH: /opt/cray/pmi/5.0.8-1.0000.10843.170.1.ari/bin
> PATH: /opt/toolworks/totalview.8.15.0-15/bin
> PATH: /opt/totalview-support/1.2.0.4/bin
> PATH: /opt/gcc/4.9.3/bin
> PATH: /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/libexec
> PATH: /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin
> PATH: /opt/slurm/default/bin
> PATH: /opt/cray/mpt/7.2.4/gni/bin
> PATH: /opt/cray/craype/2.4.1/bin
> PATH: /opt/cray/dvs/2.5_0.9.0-1.0502.2273.1.146.ari/bin
> PATH: /opt/cray/dw_wlm/1.0-1.0502.65992.22.1.ari/bin
> PATH: /opt/cray/dws/1.0-1.0502.65990.39.2.ari/bin
> PATH: /opt/cray/dws/1.0-1.0502.65990.39.2.ari/sbin
> PATH: /opt/cray/nodehealth/5.1-1.0502.65826.9.1.ari/bin
> PATH: /opt/cray/linux-nvme-ctl/1.0-1.0502.10674.4.1.ari/sbin
> PATH: /opt/cray/iscsitarget/1.4.20-1.0502.2102.1.14.ari/sbin
> PATH: /opt/cray/swap/1.0-1.0502.60589.1.1.ari/sbin
> PATH: /opt/cray/keystone-cle-config/1.0-1.0502.120.2.1.ari/bin
> PATH: /opt/cray/micmcad/1.0-1.0502.60587.1.27.ari/sbin
> PATH: /opt/cray/intel-KNC-host-mpss/3.4.1-1.0502.60578.1.13.ari/sbin
> PATH: /opt/cray/ccm/default/sbin
> PATH: /opt/cray/ccm/default/bin
> PATH: @sbindir@
> PATH: @bindir@
> PATH: /opt/cray/apptermd/1.0-1.0502.9374.1.74.ari/sbin
> PATH: /opt/cray/aeld/1.0-1.0502.9798.2.7.ari/sbin
> PATH: /opt/cray/ncmd/1.0-1.0502.9711.4.8.ari/sbin
> PATH: /opt/cray/ncmd/1.0-1.0502.9711.4.8.ari/bin
> PATH: /opt/cray/alpscomm/1.0-1.0502.9799.4.3.ari/bin
> PATH: /opt/cray/nodehealth-xeon-phi/1.0-1.0502.60588.1.17.ari/bin
> PATH: /opt/cray/rur/1.0-1.0502.65163.6.1.ari/bin
> PATH: /opt/nvidia/cudatoolkit/5.5.51-1.0502.9594.1.1/bin
> PATH: /opt/nvidia/cudatoolkit/5.5.51-1.0502.9594.1.1/libnvvp
> PATH: /opt/cray/batchlimit/1.0-1.0502.60515.1.28.ari/bin
> PATH: /opt/cray/ibverbs/1.1.2-1.0502.10414.1.60.ari/bin
> PATH: /opt/cray/dumpd/1.6.2-1.0502.64645.2.8.ari/bin
> PATH: /opt/cray/msgsupport/1.0-1.0502.60505.1.1.ari/sbin
> PATH: /opt/cray/msgsupport/1.0-1.0502.60505.1.1.ari/bin
> PATH: /opt/cray/lustre-utils/2.3-1.0502.20642.6.13.ari/bin
> PATH: /opt/cray/rsipd/0.9.7.8-1.0502.64831.6.2.ari/sbin
> PATH: /opt/cray/rsipd/0.9.7.8-1.0502.64831.6.2.ari/bin
> PATH: /opt/cray/lbcd/2.1-1.0502.60476.1.1.ari/bin
> PATH: /opt/cray/init-service/1.0-1.0502.63810.3.24.ari/bin
> PATH: /opt/cray/boot/1.0-1.0502.60543.1.60.ari/bin
> PATH: /opt/cray/pdsh/2.26-1.0502.60659.2.1.ari/bin
> PATH: /opt/cray/wlm_detect/1.0-1.0502.64649.2.1.ari/sbin
> PATH: /opt/cray/wlm_detect/1.0-1.0502.64649.2.1.ari/bin
> PATH: /opt/cray/wlm_trans/1.0-1.0502.64650.3.9.ari/sbin
> PATH: /opt/cray/wlm_trans/1.0-1.0502.64650.3.9.ari/bin
> PATH: /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin
> PATH: /opt/cray/hosts/1.0-1.0502.60484.1.61.ari/bin
> PATH: /opt/cray/configuration/1.0-1.0502.60535.1.2.ari/bin
> PATH: /opt/cray/shared-root/1.0-1.0502.60523.1.31.ari/bin
> PATH: /opt/cray/fcheck/2.2-1.0502.60533.1.1.ari/bin
> PATH: /opt/cray/csa/3.0.0-1_2.0502.60510.1.68.ari/sbin
> PATH: /opt/cray/csa/3.0.0-1_2.0502.60510.1.68.ari/bin
> PATH: /opt/cray/account/1.0.0-2.0502.60468.1.40.ari/bin
> PATH: /opt/cray/projdb/1.0.0-1.0502.60538.1.31.ari/bin
> PATH: /opt/cray/sysadm/1.0.1-1.0502.64646.2.6.ari/bin
> PATH: /opt/cray/job/1.5.5-0.1_2.0502.61936.2.32.ari/bin
> PATH: /opt/cray/flexlm/11.6.1-1.0502.8775.10.1.ari/bin
> PATH: /opt/cray/llm/default/bin
> PATH: /opt/cray/llm/default/etc
> PATH: /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin
> PATH: /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin
> PATH: /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin
> PATH:
> /opt/cray/lustre-cray_ari_s/2.5_3.0.101_0.46.1_1.0502.8871.15.1-1.0502.20758.2.7/sbin
> PATH:
> /opt/cray/lustre-cray_ari_s/2.5_3.0.101_0.46.1_1.0502.8871.15.1-1.0502.20758.2.7/bin
> PATH: /opt/cray/sdb/1.1-1.0502.63652.4.25.ari/bin
> PATH: /opt/cray/nodestat/2.2-1.0502.60539.1.31.ari/bin
> PATH: /opt/modules/3.2.10.3/bin
> PATH: /usr/local/bin
> PATH: /usr/bin
> PATH: /bin
> PATH: /usr/bin/X11
> PATH: /usr/X11R6/bin
> PATH: /usr/games
> PATH: /usr/lib/mit/bin
> PATH: /usr/lib/mit/sbin
> PATH: .
> PATH: /usr/lib/qt3/bin
> PATH: /opt/cray/bin
> PATH: /project/k1044/favergm/opt/hwloc-1.11.1/bin
> PATH: /project/k1044/favergm/opt/plasma-2.7.1/bin
> ## Core tests. ##
> configure:3564: checking build system type
> configure:3578: result: x86_64-unknown-linux-gnu
> configure:3598: checking host system type
> configure:3611: result: x86_64-unknown-linux-gnu
> configure:3631: checking target system type
> configure:3644: result: x86_64-unknown-linux-gnu
> configure:3688: checking for a BSD-compatible install
> configure:3756: result: /usr/bin/install -c
> configure:3767: checking whether build environment is sane
> configure:3822: result: yes
> configure:3973: checking for a thread-safe mkdir -p
> configure:4012: result: /bin/mkdir -p
> configure:4019: checking for gawk
> configure:4035: found /usr/bin/gawk
> configure:4046: result: gawk
> configure:4057: checking whether make sets $(MAKE)
> configure:4079: result: yes
> configure:4108: checking whether make supports nested variables
> configure:4125: result: yes
> configure:4263: checking whether make supports nested variables
> configure:4280: result: yes
> configure:4306: checking for style of include used by make
> configure:4334: result: GNU
> configure:4405: checking for gcc
> configure:4432: result: cc
> configure:4661: checking for C compiler version
> configure:4670: cc --version >&5
> gcc (GCC) 4.9.3 20150626 (Cray Inc.)
> Copyright (C) 2015 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions. There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> configure:4681: $? = 0
> configure:4670: cc -v >&5
> Using built-in specs.
> COLLECT_GCC=/opt/gcc/4.9.3/bin/../snos/bin/gcc
> COLLECT_LTO_WRAPPER=/opt/gcc/4.9.3/snos/libexec/gcc/x86_64-suse-linux/4.9.3/lto-wrapper
> Target: x86_64-suse-linux
> Configured with: ../cray-gcc-4.9.3/configure --prefix=/opt/gcc/4.9.3/snos
> --disable-nls --libdir=/opt/gcc/4.9.3/snos/lib
> --enable-languages=c,c++,fortran
> --with-gxx-include-dir=/opt/gcc/4.9.3/snos/include/g++
> --with-slibdir=/opt/gcc/4.9.3/snos/lib --with-system-zlib --enable-shared
> --enable-__cxa_atexit --build=x86_64-suse-linux --with-ppl --with-cloog
> Thread model: posix
> gcc version 4.9.3 20150626 (Cray Inc.) (GCC)
> COMPILER_PATH=/opt/gcc/4.9.3/snos/libexec/gcc/x86_64-suse-linux/4.9.3/:/opt/gcc/4.9.3/snos/libexec/gcc/x86_64-suse-linux/4.9.3/:/opt/gcc/4.9.3/snos/libexec/gcc/x86_64-suse-linux/:/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/:/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/
> LIBRARY_PATH=/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/:/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/../../../:/lib/:/usr/lib/
> COLLECT_GCC_OPTIONS='-march=core-avx2' '-D' '__CRAYXC' '-D'
> '__CRAY_HASWELL' '-D' '__CRAYXT_COMPUTE_LINUX_TARGET' '-D'
> '__TARGET_LINUX__' '-v' '-I'
> '/opt/cray/libsci/13.1.0/GNU/4.9/x86_64/include' '-I'
> '/opt/cray/mpt/7.2.4/gni/mpich2-gnu/4.9/include' '-I'
> '/opt/cray/pmi/5.0.8-1.0000.10843.170.1.ari/include' '-I'
> '/opt/cray/datawarp/1.0-1.0502.65549.14.21.ari/include' '-I'
> '/opt/cray/wlm_detect/1.0-1.0502.64649.2.1.ari/include' '-I'
> '/opt/cray/krca/1.0.0-2.0502.63139.4.31.ari/include' '-I'
> '/opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/include' '-I'
> '/opt/cray/gni-headers/4.0-1.0502.10859.7.8.ari/include' '-I'
> '/opt/cray/ugni/6.0-1.0502.10863.8.29.ari/include' '-I'
> '/opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/include' '-I'
> '/opt/cray/alps/5.2.4-2.0502.9822.32.1.ari/include' '-I'
> '/opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/include' '-I'
> '/opt/cray-hss-devel/7.2.0/include'
> '-L/opt/cray/libsci/13.1.0/GNU/4.9/x86_64/lib'
> '-L/opt/cray/dmapp/default/lib64'
> '-L/opt/cray/mpt/7.2.4/gni/mpich2-gnu/4.9/lib'
> '-L/opt/cray/datawarp/1.0-1.0502.65549.14.21.ari/lib64'
> '-L/opt/cray/atp/1.8.3/libApp'
> ... rest of stderr output deleted ...
> configure:4681: $? = 1
> configure:4670: cc -V >&5
> gcc: error: unrecognized command line option '-V'
> configure:4670: cc -qversion >&5
> gcc: error: unrecognized command line option '-qversion'
> configure:4701: checking whether the C compiler works
> configure:4723: cc conftest.c >&5
> configure:4727: $? = 0
> configure:4775: result: yes
> configure:4778: checking for C compiler default output file name
> configure:4780: result: a.out
> configure:4786: checking for suffix of executables
> configure:4793: cc -o conftest conftest.c >&5
> configure:4797: $? = 0
> configure:4819: result:
> configure:4841: checking whether we are cross compiling
> configure:4849: cc -o conftest conftest.c >&5
> configure:4853: $? = 0
> configure:4860: ./conftest
> configure:4864: $? = 0
> configure:4879: result: no
> configure:4884: checking for suffix of object files
> configure:4906: cc -c conftest.c >&5
> configure:4910: $? = 0
> configure:4931: result: o
> configure:4935: checking whether we are using the GNU C compiler
> configure:4954: cc -c conftest.c >&5
> configure:4954: $? = 0
> configure:4963: result: yes
> configure:4972: checking whether cc accepts -g
> configure:4992: cc -c -g conftest.c >&5
> configure:4992: $? = 0
> configure:5033: result: yes
> configure:5050: checking for cc option to accept ISO C89
> configure:5113: cc -c -g -O2 conftest.c >&5
> configure:5113: $? = 0
> configure:5126: result: none needed
> configure:5151: checking whether cc understands -c and -o together
> configure:5173: cc -c conftest.c -o conftest2.o
> configure:5176: $? = 0
> configure:5188: result: yes
> configure:5207: checking dependency style of cc
> configure:5318: result: gcc3
> configure:5383: checking for ar
> configure:5399: found /usr/bin/ar
> configure:5410: result: ar
> configure:5436: checking the archiver (ar) interface
> configure:5452: cc -c -g -O2 conftest.c >&5
> configure:5452: $? = 0
> configure:5454: ar cru libconftest.a conftest.o >&5
> configure:5457: $? = 0
> configure:5485: result: ar
> configure:5553: checking for gcc
> configure:5580: result: cc
> configure:5809: checking for C compiler version
> configure:5818: cc --version >&5
> configure:5829: $? = 0
> configure:5818: cc -v >&5
> Thread model: posix
> configure:5829: $? = 1
> configure:5818: cc -V >&5
> configure:5818: cc -qversion >&5
> configure:5833: checking whether we are using the GNU C compiler
> configure:5861: result: yes
> configure:5870: checking whether cc accepts -g
> configure:5931: result: yes
> configure:5948: checking for cc option to accept ISO C89
> configure:6024: result: none needed
> configure:6049: checking whether cc understands -c and -o together
> configure:6086: result: yes
> configure:6105: checking dependency style of cc
> configure:6216: result: gcc3
> configure:6344: checking for C++ compiler version
> configure:6353: CC --version >&5
> g++ (GCC) 4.9.3 20150626 (Cray Inc.)
> configure:6364: $? = 0
> configure:6353: CC -v >&5
> COLLECT_GCC=/opt/gcc/4.9.3/bin/../snos/bin/g++
> Thread model: posix
> '-L/opt/cray/atp/1.8.3/libApp' '-shared-libgcc'
> configure:6364: $? = 1
> configure:6353: CC -V >&5
> g++: error: unrecognized command line option '-V'
> configure:6353: CC -qversion >&5
> g++: error: unrecognized command line option '-qversion'
> configure:6368: checking whether we are using the GNU C++ compiler
> configure:6387: CC -c conftest.cpp >&5
> configure:6387: $? = 0
> configure:6396: result: yes
> configure:6405: checking whether CC accepts -g
> configure:6425: CC -c -g conftest.cpp >&5
> configure:6425: $? = 0
> configure:6466: result: yes
> configure:6491: checking dependency style of CC
> configure:6602: result: gcc3
> configure:6622: checking how to run the C preprocessor
> configure:6653: cc -E conftest.c
> configure:6653: $? = 0
> configure:6667: cc -E conftest.c
> conftest.c:14:28: fatal error: ac_nonexistent.h: No such file or directory
> #include <ac_nonexistent.h>
> compilation terminated.
> configure:6667: $? = 1
> configure: failed program was:
> | /* confdefs.h */
> | #define PACKAGE_NAME "StarPU"
> | #define PACKAGE_TARNAME "starpu"
> | #define PACKAGE_VERSION "1.2.0rc4"
> | #define PACKAGE_STRING "StarPU 1.2.0rc4"
> | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
> | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/"
> | #define STARPU_MAJOR_VERSION 1
> | #define STARPU_MINOR_VERSION 2
> | #define STARPU_RELEASE_VERSION 0
> | #define PACKAGE "starpu"
> | #define VERSION "1.2.0rc4"
> | /* end confdefs.h. */
> configure:6692: result: cc -E
> configure:6712: cc -E conftest.c
> configure:6712: $? = 0
> configure:6726: cc -E conftest.c
> configure:6726: $? = 1
> | /* confdefs.h */
> configure:6754: checking for a sed that does not truncate output
> configure:6818: result: /usr/bin/sed
> configure:6823: checking whether ln -s works
> configure:6827: result: yes
> configure:6887: checking for g77
> configure:6917: result: no
> configure:6887: checking for xlf
> configure:6887: checking for f77
> configure:6887: checking for frt
> configure:6887: checking for pgf77
> configure:6887: checking for cf77
> configure:6887: checking for fort77
> configure:6887: checking for fl32
> configure:6887: checking for af77
> configure:6887: checking for xlf90
> configure:6887: checking for f90
> configure:6887: checking for pgf90
> configure:6887: checking for pghpf
> configure:6887: checking for epcf90
> configure:6887: checking for gfortran
> configure:6903: found /opt/gcc/4.9.3/bin/gfortran
> configure:6914: result: gfortran
> configure:6940: checking for Fortran 77 compiler version
> configure:6949: gfortran --version >&5
> GNU Fortran (GCC) 4.9.3 20150626 (Cray Inc.)
> GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
> You may redistribute copies of GNU Fortran
> under the terms of the GNU General Public License.
> For more information about these matters, see the file named COPYING
> configure:6960: $? = 0
> configure:6949: gfortran -v >&5
> COLLECT_GCC=/opt/gcc/4.9.3/bin/../snos/bin/gfortran
> Thread model: posix
> configure:6949: gfortran -V >&5
> gfortran: error: unrecognized command line option '-V'
> gfortran: fatal error: no input files
> configure:6960: $? = 1
> configure:6949: gfortran -qversion >&5
> gfortran: error: unrecognized command line option '-qversion'
> configure:6969: checking whether we are using the GNU Fortran 77 compiler
> configure:6982: gfortran -c conftest.F >&5
> configure:6982: $? = 0
> configure:6991: result: yes
> configure:6997: checking whether gfortran accepts -g
> configure:7008: gfortran -c -g conftest.f >&5
> configure:7008: $? = 0
> configure:7016: result: yes
> configure:7151: checking for Fortran compiler version
> configure:7160: ftn --version >&5
> configure:7171: $? = 0
> configure:7160: ftn -v >&5
> Thread model: posix
> configure:7171: $? = 1
> configure:7160: ftn -V >&5
> configure:7160: ftn -qversion >&5
> configure:7180: checking whether we are using the GNU Fortran compiler
> configure:7193: ftn -c conftest.F >&5
> configure:7193: $? = 0
> configure:7202: result: yes
> configure:7208: checking whether ftn accepts -g
> configure:7219: ftn -c -g conftest.f >&5
> configure:7219: $? = 0
> configure:7227: result: yes
> configure:7260: checking for gstat
> configure:7290: result: no
> configure:7260: checking for stat
> configure:7276: found /usr/bin/stat
> configure:7287: result: stat
> configure:7302: checking for gdate
> configure:7332: result: no
> configure:7302: checking for date
> configure:7318: found /bin/date
> configure:7329: result: date
> configure:7388: checking how to print strings
> configure:7415: result: printf
> configure:7436: checking for a sed that does not truncate output
> configure:7500: result: /usr/bin/sed
> configure:7518: checking for grep that handles long lines and -e
> configure:7576: result: /usr/bin/grep
> configure:7581: checking for egrep
> configure:7643: result: /usr/bin/grep -E
> configure:7648: checking for fgrep
> configure:7710: result: /usr/bin/grep -F
> configure:7745: checking for ld used by cc
> configure:7812: result: /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld
> configure:7819: checking if the linker
> (/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld) is GNU ld
> configure:7834: result: yes
> configure:7846: checking for BSD- or MS-compatible name lister (nm)
> configure:7895: result: /usr/bin/nm -B
> configure:8025: checking the name lister (/usr/bin/nm -B) interface
> configure:8032: cc -c -g -O2 conftest.c >&5
> configure:8035: /usr/bin/nm -B "conftest.o"
> configure:8038: output
> 0000000000000000 B some_variable
> configure:8045: result: BSD nm
> configure:8049: checking the maximum length of command line arguments
> configure:8180: result: 1572864
> configure:8197: checking whether the shell understands some XSI constructs
> configure:8207: result: yes
> configure:8211: checking whether the shell understands "+="
> configure:8217: result: yes
> configure:8252: checking how to convert x86_64-unknown-linux-gnu file names
> to x86_64-unknown-linux-gnu format
> configure:8292: result: func_convert_file_noop
> configure:8299: checking how to convert x86_64-unknown-linux-gnu file names
> to toolchain format
> configure:8319: result: func_convert_file_noop
> configure:8326: checking for /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld
> option to reload object files
> configure:8333: result: -r
> configure:8407: checking for objdump
> configure:8423: found /usr/bin/objdump
> configure:8434: result: objdump
> configure:8463: checking how to recognize dependent libraries
> configure:8661: result: pass_all
> configure:8746: checking for dlltool
> configure:8776: result: no
> configure:8803: checking how to associate runtime and link libraries
> configure:8830: result: printf %s\n
> configure:8954: checking for archiver @FILE support
> configure:8971: cc -c -g -O2 conftest.c >&5
> configure:8971: $? = 0
> configure:8974: ar cru libconftest.a @conftest.lst >&5
> configure:8977: $? = 0
> configure:8982: ar cru libconftest.a @conftest.lst >&5
> ar: conftest.o: No such file or directory
> configure:8985: $? = 1
> configure:8997: result: @
> configure:9055: checking for strip
> configure:9071: found /usr/bin/strip
> configure:9082: result: strip
> configure:9154: checking for ranlib
> configure:9170: found /usr/bin/ranlib
> configure:9181: result: ranlib
> configure:9283: checking command to parse /usr/bin/nm -B output from cc
> object
> configure:9403: cc -c -g -O2 conftest.c >&5
> configure:9406: $? = 0
> configure:9410: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[
> ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2
> \2/p' | sed '/ __gnu_lto/d' \> conftest.nm
> configure:9413: $? = 0
> configure:9479: cc -o conftest -g -O2 conftest.c conftstm.o >&5
> configure:9482: $? = 0
> configure:9520: result: ok
> configure:9557: checking for sysroot
> configure:9587: result: no
> configure:9664: cc -c -g -O2 conftest.c >&5
> configure:9667: $? = 0
> configure:9856: checking for mt
> configure:9872: found /usr/bin/mt
> configure:9883: result: mt
> configure:9906: checking if mt is a manifest tool
> configure:9912: mt '-?'
> mt: invalid option -- ?
> configure:9920: result: no
> configure:10558: checking for ANSI C header files
> configure:10578: cc -c -g -O2 conftest.c >&5
> configure:10578: $? = 0
> configure:10651: cc -o conftest -g -O2 conftest.c >&5
> configure:10651: $? = 0
> configure:10651: ./conftest
> configure:10662: result: yes
> configure:10675: checking for sys/types.h
> configure:10675: cc -c -g -O2 conftest.c >&5
> configure:10675: $? = 0
> configure:10675: result: yes
> configure:10675: checking for sys/stat.h
> configure:10675: checking for stdlib.h
> configure:10675: checking for string.h
> configure:10675: checking for memory.h
> configure:10675: checking for strings.h
> configure:10675: checking for inttypes.h
> configure:10675: checking for stdint.h
> configure:10675: checking for unistd.h
> configure:10689: checking for dlfcn.h
> configure:10689: cc -c -g -O2 conftest.c >&5
> configure:10689: $? = 0
> configure:10689: result: yes
> configure:11206: checking for objdir
> configure:11221: result: .libs
> configure:11492: checking if cc supports -fno-rtti -fno-exceptions
> configure:11510: cc -c -g -O2 -fno-rtti -fno-exceptions conftest.c >&5
> cc1: warning: command line option '-fno-rtti' is valid for C++/ObjC++ but
> not for C
> configure:11514: $? = 0
> configure:11527: result: no
> configure:11854: checking for cc option to produce PIC
> configure:11861: result: -fPIC -DPIC
> configure:11869: checking if cc PIC flag -fPIC -DPIC works
> configure:11887: cc -c -g -O2 -fPIC -DPIC -DPIC conftest.c >&5
> configure:11891: $? = 0
> configure:11904: result: yes
> configure:11933: checking if cc static flag -static works
> configure:11961: result: yes
> configure:11976: checking if cc supports -c -o file.o
> configure:11997: cc -c -g -O2 -o out/conftest2.o conftest.c >&5
> configure:12001: $? = 0
> configure:12023: result: yes
> configure:12031: checking if cc supports -c -o file.o
> configure:12078: result: yes
> configure:12111: checking whether the cc linker
> (/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld -m elf_x86_64) supports
> shared libraries
> configure:13268: result: yes
> configure:13305: checking whether -lc should be explicitly linked in
> configure:13313: cc -c -g -O2 conftest.c >&5
> configure:13316: $? = 0
> configure:13331: cc -shared -fPIC -DPIC conftest.o -v -Wl,-soname
> -Wl,conftest -o conftest 2\>\&1 \| /usr/bin/grep -lc \>/dev/null 2\>\&1
> configure:13334: $? = 0
> configure:13348: result: no
> configure:13508: checking dynamic linker characteristics
> configure:14008: cc -o conftest -g -O2 -Wl,-rpath -Wl,/foo conftest.c >&5
> configure:14008: $? = 0
> configure:14242: result: GNU/Linux ld.so
> configure:14349: checking how to hardcode library paths into programs
> configure:14374: result: immediate
> configure:14914: checking whether stripping libraries is possible
> configure:14919: result: yes
> configure:14954: checking if libtool supports shared libraries
> configure:14956: result: yes
> configure:14959: checking whether to build shared libraries
> configure:14980: result: yes
> configure:14983: checking whether to build static libraries
> configure:14987: result: yes
> configure:15010: checking how to run the C++ preprocessor
> configure:15037: CC -E conftest.cpp
> configure:15037: $? = 0
> configure:15051: CC -E conftest.cpp
> conftest.cpp:26:28: fatal error: ac_nonexistent.h: No such file or directory
> configure:15051: $? = 1
> | /* confdefs.h */
> | #define STDC_HEADERS 1
> | #define HAVE_SYS_TYPES_H 1
> | #define HAVE_SYS_STAT_H 1
> | #define HAVE_STDLIB_H 1
> | #define HAVE_STRING_H 1
> | #define HAVE_MEMORY_H 1
> | #define HAVE_STRINGS_H 1
> | #define HAVE_INTTYPES_H 1
> | #define HAVE_STDINT_H 1
> | #define HAVE_UNISTD_H 1
> | #define HAVE_DLFCN_H 1
> | #define LT_OBJDIR ".libs/"
> configure:15076: result: CC -E
> configure:15096: CC -E conftest.cpp
> configure:15096: $? = 0
> configure:15110: CC -E conftest.cpp
> configure:15110: $? = 1
> | /* confdefs.h */
> configure:15279: checking for ld used by CC
> configure:15346: result: /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld -m
> elf_x86_64
> configure:15353: checking if the linker
> (/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld -m elf_x86_64) is GNU ld
> configure:15368: result: yes
> configure:15423: checking whether the CC linker
> shared libraries
> configure:16425: result: yes
> configure:16461: CC -c -g -O2 conftest.cpp >&5
> configure:16464: $? = 0
> configure:16984: checking for CC option to produce PIC
> configure:16991: result: -fPIC -DPIC
> configure:16999: checking if CC PIC flag -fPIC -DPIC works
> configure:17017: CC -c -g -O2 -fPIC -DPIC -DPIC conftest.cpp >&5
> configure:17021: $? = 0
> configure:17034: result: yes
> configure:17057: checking if CC static flag -static works
> configure:17085: result: yes
> configure:17097: checking if CC supports -c -o file.o
> configure:17118: CC -c -g -O2 -o out/conftest2.o conftest.cpp >&5
> configure:17122: $? = 0
> configure:17144: result: yes
> configure:17149: checking if CC supports -c -o file.o
> configure:17196: result: yes
> configure:17226: checking whether the CC linker
> shared libraries
> configure:17265: result: yes
> configure:17406: checking dynamic linker characteristics
> configure:18074: result: GNU/Linux ld.so
> configure:18127: checking how to hardcode library paths into programs
> configure:18152: result: immediate
> configure:18300: checking if libtool supports shared libraries
> configure:18302: result: yes
> configure:18305: checking whether to build shared libraries
> configure:18325: result: yes
> configure:18328: checking whether to build static libraries
> configure:18332: result: yes
> configure:18653: checking for gfortran option to produce PIC
> configure:18660: result: -fPIC
> configure:18668: checking if gfortran PIC flag -fPIC works
> configure:18686: gfortran -c -g -O2 -fPIC conftest.f >&5
> configure:18690: $? = 0
> configure:18703: result: yes
> configure:18726: checking if gfortran static flag -static works
> configure:18754: result: yes
> configure:18766: checking if gfortran supports -c -o file.o
> configure:18787: gfortran -c -g -O2 -o out/conftest2.o conftest.f >&5
> configure:18791: $? = 0
> configure:18813: result: yes
> configure:18818: checking if gfortran supports -c -o file.o
> configure:18865: result: yes
> configure:18895: checking whether the gfortran linker
> shared libraries
> configure:20002: result: yes
> configure:20143: checking dynamic linker characteristics
> configure:20805: result: GNU/Linux ld.so
> configure:20858: checking how to hardcode library paths into programs
> configure:20883: result: immediate
> configure:21027: checking if libtool supports shared libraries
> configure:21029: result: yes
> configure:21032: checking whether to build shared libraries
> configure:21052: result: yes
> configure:21055: checking whether to build static libraries
> configure:21059: result: yes
> configure:21093: ftn -c -g -O2 conftest.f >&5
> configure:21096: $? = 0
> configure:21525: checking for ftn option to produce PIC
> configure:21532: result: -fPIC
> configure:21540: checking if ftn PIC flag -fPIC works
> configure:21558: ftn -c -g -O2 -fPIC conftest.f >&5
> configure:21562: $? = 0
> configure:21575: result: yes
> configure:21598: checking if ftn static flag -static works
> configure:21626: result: yes
> configure:21638: checking if ftn supports -c -o file.o
> configure:21659: ftn -c -g -O2 -o out/conftest2.o conftest.f >&5
> configure:21663: $? = 0
> configure:21685: result: yes
> configure:21690: checking if ftn supports -c -o file.o
> configure:21737: result: yes
> configure:21767: checking whether the ftn linker
> shared libraries
> configure:22874: result: yes
> configure:23015: checking dynamic linker characteristics
> configure:23677: result: GNU/Linux ld.so
> configure:23730: checking how to hardcode library paths into programs
> configure:23755: result: immediate
> configure:23808: checking whether ln -s works
> configure:23812: result: yes
> configure:23820: checking for ANSI C header files
> configure:23924: result: yes
> configure:23933: checking for C/C++ restrict keyword
> configure:23958: cc -c -g -O2 conftest.c >&5
> configure:23958: $? = 0
> configure:23966: result: __restrict
> configure:23985: checking for bash
> configure:24012: result: /bin/sh
> configure:24027: checking for svn
> configure:24045: found /usr/bin/svn
> configure:24057: result: /usr/bin/svn
> configure:24067: checking for svnversion
> configure:24085: found /usr/bin/svnversion
> configure:24097: result: /usr/bin/svnversion
> configure:24184: checking for lib
> configure:24217: result: no
> configure:24271: checking size of void *
> configure:24276: cc -o conftest -g -O2 conftest.c >&5
> configure:24276: $? = 0
> configure:24276: ./conftest
> configure:24290: result: 8
> configure:24377: checking for pthread_create in -lpthread
> configure:24402: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24402: $? = 0
> configure:24411: result: yes
> configure:24423: checking for struct timespec
> configure:24423: cc -c -g -O2 conftest.c >&5
> configure:24423: $? = 0
> conftest.c: In function 'main':
> conftest.c:49:30: error: expected expression before ')' token
> if (sizeof ((struct timespec)))
> configure:24423: $? = 1
> | /* confdefs.h */
> | #define restrict __restrict
> | #define STARPU_MIC_USE_RMA 1
> | #define STARPU_LINUX_SYS 1
> | #define SIZEOF_VOID_P 8
> | #define STARPU_BUILD_DIR "/project/k1044/favergm/src/starpu-1.2.0rc4"
> | #define STARPU_SRC_DIR
> "/lustre/project/k1044/favergm/src/starpu-1.2.0rc4/."
> | #define HAVE_LIBPTHREAD 1
> | #include <sys/types.h>
> | #include <sys/stat.h>
> | #ifdef HAVE_UNISTD_H
> | #include <unistd.h>
> | #endif
> | #include <time.h>
> | #ifndef STARPU_NATIVE_WINTHREADS
> | #include <pthread.h>
> | #endif
> | int
> | main ()
> | return 0;
> | return 0;
> configure:24423: result: yes
> configure:24442: checking for library containing sqrt
> configure:24473: cc -o conftest -g -O2 conftest.c -lpthread >&5
> conftest.c:42:6: warning: conflicting types for built-in function 'sqrt'
> char sqrt ();
> configure:24473: $? = 0
> configure:24490: result: none required
> configure:24500: checking for main in -lws2_32
> configure:24519: cc -o conftest -g -O2 conftest.c -lws2_32 -lpthread >&5
> /usr/bin/ld: cannot find -lws2_32
> collect2: error: ld returned 1 exit status
> configure:24519: $? = 1
> | /* confdefs.h */
> | #define STARPU_HAVE_STRUCT_TIMESPEC /**/
> | int
> | main ()
> | return main ();
> | return 0;
> configure:24528: result: no
> configure:24542: checking for sysconf
> configure:24542: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24542: $? = 0
> configure:24542: result: yes
> configure:24552: checking for pthread_spin_lock
> configure:24552: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24552: $? = 0
> configure:24552: result: yes
> configure:24568: checking for pthread_barrier_init
> configure:24568: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24568: $? = 0
> configure:24568: result: yes
> configure:24584: checking for pthread_setaffinity_np
> configure:24584: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24584: $? = 0
> configure:24584: result: yes
> configure:24597: checking for posix_memalign
> configure:24597: cc -o conftest -g -O2 conftest.c -lpthread >&5
> conftest.c:63:6: warning: conflicting types for built-in function
> 'posix_memalign'
> char posix_memalign ();
> configure:24597: $? = 0
> configure:24597: result: yes
> configure:24610: checking for memalign
> configure:24610: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24610: $? = 0
> configure:24610: result: yes
> configure:24623: checking for drand48
> configure:24623: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24623: $? = 0
> configure:24623: result: yes
> configure:24630: checking for erand48_r
> configure:24630: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24630: $? = 0
> configure:24630: result: yes
> configure:24657: checking for strerror_r
> configure:24657: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24657: $? = 0
> configure:24657: result: yes
> configure:24666: checking for setenv
> configure:24666: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24666: $? = 0
> configure:24666: result: yes
> configure:24675: checking for unsetenv
> configure:24675: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24675: $? = 0
> configure:24675: result: yes
> configure:24684: checking for nearbyintf
> configure:24684: cc -o conftest -g -O2 conftest.c -lpthread >&5
> conftest.c:72:6: warning: conflicting types for built-in function
> 'nearbyintf'
> char nearbyintf ();
> configure:24684: $? = 0
> configure:24684: result: yes
> configure:24693: checking for rintf
> configure:24693: cc -o conftest -g -O2 conftest.c -lpthread >&5
> conftest.c:73:6: warning: conflicting types for built-in function 'rintf'
> char rintf ();
> configure:24693: $? = 0
> configure:24693: result: yes
> configure:24769: checking malloc.h usability
> configure:24769: cc -c -g -O2 conftest.c >&5
> configure:24769: $? = 0
> configure:24769: result: yes
> configure:24769: checking malloc.h presence
> configure:24769: cc -E conftest.c
> configure:24769: checking for malloc.h
> configure:24792: checking valgrind/valgrind.h usability
> configure:24792: cc -c -g -O2 conftest.c >&5
> conftest.c:86:31: fatal error: valgrind/valgrind.h: No such file or
> directory
> #include <valgrind/valgrind.h>
> configure:24792: $? = 1
> | /* confdefs.h */
> | #define HAVE_SYSCONF 1
> | #define HAVE_PTHREAD_SPIN_LOCK /**/
> | #define STARPU_HAVE_PTHREAD_SPIN_LOCK /**/
> | #define STARPU_HAVE_PTHREAD_BARRIER /**/
> | #define HAVE_PTHREAD_SETAFFINITY_NP 1
> | #define HAVE_POSIX_MEMALIGN 1
> | #define STARPU_HAVE_POSIX_MEMALIGN 1
> | #define HAVE_MEMALIGN 1
> | #define STARPU_HAVE_MEMALIGN 1
> | #define STARPU_USE_DRAND48 1
> | #define STARPU_USE_ERAND48_R 1
> | #define STARPU_HAVE_STRERROR_R 1
> | #define STARPU_HAVE_SETENV 1
> | #define STARPU_HAVE_UNSETENV 1
> | #define STARPU_HAVE_NEARBYINTF 1
> | #define STARPU_HAVE_RINTF 1
> | #define HAVE_MALLOC_H 1
> | #define STARPU_HAVE_MALLOC_H 1
> | #include <stdio.h>
> | #ifdef HAVE_SYS_TYPES_H
> | # include <sys/types.h>
> | #endif
> | #ifdef HAVE_SYS_STAT_H
> | # include <sys/stat.h>
> | #endif
> | #ifdef STDC_HEADERS
> | # include <stdlib.h>
> | # include <stddef.h>
> | #else
> | # ifdef HAVE_STDLIB_H
> | # endif
> | #endif
> | #ifdef HAVE_STRING_H
> | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
> | # include <memory.h>
> | # endif
> | # include <string.h>
> | #endif
> | #ifdef HAVE_STRINGS_H
> | # include <strings.h>
> | #endif
> | #ifdef HAVE_INTTYPES_H
> | # include <inttypes.h>
> | #endif
> | #ifdef HAVE_STDINT_H
> | # include <stdint.h>
> | #endif
> | # include <unistd.h>
> | #endif
> configure:24792: result: no
> configure:24792: checking valgrind/valgrind.h presence
> configure:24792: cc -E conftest.c
> conftest.c:53:31: fatal error: valgrind/valgrind.h: No such file or
> directory
> | /* confdefs.h */
> configure:24792: checking for valgrind/valgrind.h
> configure:24806: checking valgrind/memcheck.h usability
> configure:24806: cc -c -g -O2 conftest.c >&5
> conftest.c:86:31: fatal error: valgrind/memcheck.h: No such file or
> directory
> #include <valgrind/memcheck.h>
> configure:24806: $? = 1
> | /* confdefs.h */
> | #include <stdio.h>
> | #endif
> | #endif
> | #ifdef STDC_HEADERS
> | #else
> | # endif
> | #endif
> | # endif
> | #endif
> | #endif
> | #endif
> | #endif
> | #endif
> configure:24806: result: no
> configure:24806: checking valgrind/memcheck.h presence
> configure:24806: cc -E conftest.c
> conftest.c:53:31: fatal error: valgrind/memcheck.h: No such file or
> directory
> | /* confdefs.h */
> configure:24806: checking for valgrind/memcheck.h
> configure:24820: checking valgrind/helgrind.h usability
> configure:24820: cc -c -g -O2 conftest.c >&5
> conftest.c:86:31: fatal error: valgrind/helgrind.h: No such file or
> directory
> #include <valgrind/helgrind.h>
> configure:24820: $? = 1
> | /* confdefs.h */
> | #include <stdio.h>
> | #endif
> | #endif
> | #ifdef STDC_HEADERS
> | #else
> | # endif
> | #endif
> | # endif
> | #endif
> | #endif
> | #endif
> | #endif
> | #endif
> configure:24820: result: no
> configure:24820: checking valgrind/helgrind.h presence
> configure:24820: cc -E conftest.c
> conftest.c:53:31: fatal error: valgrind/helgrind.h: No such file or
> directory
> | /* confdefs.h */
> configure:24820: checking for valgrind/helgrind.h
> configure:24839: checking for sched_yield
> configure:24839: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24839: $? = 0
> configure:24839: result: yes
> configure:24849: checking aio.h usability
> configure:24849: cc -c -g -O2 conftest.c >&5
> configure:24849: $? = 0
> configure:24849: result: yes
> configure:24849: checking aio.h presence
> configure:24849: cc -E conftest.c
> configure:24849: checking for aio.h
> configure:24862: checking for mkostemp
> configure:24862: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24862: $? = 0
> configure:24862: result: yes
> configure:24875: checking for pread
> configure:24875: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24875: $? = 0
> configure:24875: result: yes
> configure:24875: checking for pwrite
> configure:24887: checking whether the target supports
> __sync_val_compare_and_swap
> configure:24904: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24904: $? = 0
> configure:24912: result: yes
> configure:24922: checking whether the target supports
> __sync_bool_compare_and_swap
> configure:24939: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24939: $? = 0
> configure:24947: result: yes
> configure:24957: checking whether the target supports __sync_fetch_and_add
> configure:24974: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:24974: $? = 0
> configure:24982: result: yes
> configure:24992: checking whether the target supports __sync_fetch_and_or
> configure:25009: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:25009: $? = 0
> configure:25017: result: yes
> configure:25027: checking whether the target supports
> __sync_lock_test_and_set
> configure:25044: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:25044: $? = 0
> configure:25052: result: yes
> configure:25062: checking whether the target supports __sync_synchronize
> configure:25079: cc -o conftest -g -O2 conftest.c -lpthread >&5
> configure:25079: $? = 0
> configure:25087: result: yes
> configure:25099: checking for library containing set_mempolicy
> configure:25130: cc -o conftest -g -O2 -D_GNU_SOURCE conftest.c >&5
> /tmp/ccZ2aqYb.o: In function `main':
> /project/k1044/favergm/src/starpu-1.2.0rc4/conftest.c:75: undefined
> reference to `set_mempolicy'
> /usr/bin/ld: link errors found, deleting executable `conftest'
> configure:25130: $? = 1
> | /* confdefs.h */
> | #define STARPU_HAVE_SCHED_YIELD 1
> | #define HAVE_AIO_H 1
> | #define HAVE_MKOSTEMP 1
> | #define HAVE_PREAD 1
> | #define HAVE_PWRITE 1
> | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
> | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
> | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
> | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
> | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
> | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
> | /* Override any GCC internal prototype to avoid an error.
> | Use char because int might match the return type of a GCC
> | builtin and then its argument prototype would still apply. */
> | #ifdef __cplusplus
> | extern "C"
> | #endif
> | char set_mempolicy ();
> | int
> | main ()
> | return set_mempolicy ();
> | return 0;
> configure:25130: cc -o conftest -g -O2 -D_GNU_SOURCE conftest.c -lnuma
> >&5
> configure:25130: $? = 0
> configure:25147: result: -lnuma
> configure:25161: checking whether libnuma is available
> configure:25163: result: yes
> configure:25176: checking maximum number of sched_ctxs
> configure:25185: result: 10
> configure:25263: checking maximum number of CPUs
> configure:25272: result: 64
> configure:25280: checking whether CPUs should be used
> configure:25289: result: yes
> configure:25314: checking maximum number of CUDA devices
> configure:25323: result: 4
> configure:27121: checking whether CUDA should be used
> configure:27123: result: no
> configure:27222: checking for pkg-config
> configure:27240: found /usr/bin/pkg-config
> configure:27252: result: /usr/bin/pkg-config
> configure:27277: checking pkg-config is at least version 0.9.0
> configure:27280: result: yes
> configure:27379: checking whether MAGMA should be used
> configure:27381: result: no
> configure:27385: checking for cufftDoubleComplex
> configure:27385: cc -c -g -O2 -D_GNU_SOURCE conftest.c >&5
> conftest.c:69:19: fatal error: cufft.h: No such file or directory
> #include <cufft.h>
> configure:27385: $? = 1
> | /* confdefs.h */
> | #define STARPU_HAVE_LIBNUMA /**/
> | #define STARPU_NMAX_SCHED_CTXS 10
> | #define STARPU_MAXCPUS 64
> | #define STARPU_USE_CPU 1
> | #define STARPU_MAXCUDADEVS 4
> | #include <cufft.h>
> | int
> | main ()
> | if (sizeof (cufftDoubleComplex))
> | return 0;
> | return 0;
> configure:27385: result: no
> configure:27451: checking whether CURAND is available
> configure:27453: result: no
> configure:27509: checking maximum number of OpenCL devices
> configure:27518: result: 8
> configure:28138: checking whether OpenCL should be used
> configure:28140: result: no
> configure:28168: checking whether asynchronous copy should be disabled
> configure:28181: result: no
> configure:28189: checking whether asynchronous CUDA copy should be disabled
> configure:28202: result: no
> configure:28210: checking whether asynchronous OpenCL copy should be
> disabled
> configure:28223: result: no
> configure:28231: checking whether asynchronous MIC copy should be disabled
> configure:28244: result: no
> configure:28480: checking whether SimGrid is enabled
> configure:28482: result: no
> configure:28485: checking whether blocking drivers should be enabled
> configure:28494: result: no
> configure:28509: checking maximum number of MIC devices
> configure:28518: result: 4
> configure:28527: checking maximum number of MIC threads
> configure:28536: result:
> configure:29109: checking RCCE.h usability
> configure:29109: cc -c -g -O2 -D_GNU_SOURCE conftest.c >&5
> conftest.c:107:18: fatal error: RCCE.h: No such file or directory
> #include <RCCE.h>
> configure:29109: $? = 1
> | /* confdefs.h */
> | #define STARPU_MAXOPENCLDEVS 8
> | #define STARPU_NON_BLOCKING_DRIVERS 1
> | #define STARPU_MAXMICDEVS 4
> | #define STARPU_MAXMICCORES 120
> | #define STARPU_MAXSCCDEVS 47
> | #include <stdio.h>
> | #endif
> | #endif
> | #ifdef STDC_HEADERS
> | #else
> | # endif
> | #endif
> | # endif
> | #endif
> | #endif
> | #endif
> | #endif
> | #endif
> | #include <RCCE.h>
> configure:29109: result: no
> configure:29109: checking RCCE.h presence
> configure:29109: cc -E -D_GNU_SOURCE conftest.c
> conftest.c:74:18: fatal error: RCCE.h: No such file or directory
> #include <RCCE.h>
> | /* confdefs.h */
> | #include <RCCE.h>
> configure:29109: checking for RCCE.h
> configure:29125: checking for RCCE_init in -lRCCE_bigflags_nongory_nopwrmgmt
> configure:29150: cc -o conftest -g -O2 -D_GNU_SOURCE conftest.c
> -lRCCE_bigflags_nongory_nopwrmgmt -lpthread >&5
> /usr/bin/ld: cannot find -lRCCE_bigflags_nongory_nopwrmgmt
> configure:29150: $? = 1
> | /* confdefs.h */
> | #ifdef __cplusplus
> | extern "C"
> | #endif
> | char RCCE_init ();
> | int
> | main ()
> | return RCCE_init ();
> | return 0;
> configure:29159: result: no
> configure:29207: checking whether RCCE should be used
> configure:29209: result: no
> configure:29248: checking Maximum number of message-passing kernels
> configure:29257: result: 10
> configure:29273: checking whether debug mode should be enabled
> configure:29282: result: no
> configure:29313: checking whether extra checks should be performed
> configure:29322: result: no
> configure:29330: checking whether debug messages should be displayed
> configure:29339: result: no
> configure:29355: checking whether coverage testing should be enabled
> configure:29364: result: no
> configure:29383: checking whether FxT traces should be generated
> configure:29414: result: no
> configure:29767: checking whether additional locking systems FxT traces
> should be enabled
> configure:29776: result: no
> configure:29784: checking whether performance debugging should be enabled
> configure:29793: result: no
> configure:29805: checking whether performance model debugging should be
> enabled
> configure:29814: result: no
> configure:29822: checking whether statistics should be generated
> configure:29831: result: no
> configure:29843: checking whether memory stats should be displayed
> configure:29852: result: no
> configure:29862: checking glpk.h usability
> configure:29862: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c
> >&5
> conftest.c:109:18: fatal error: glpk.h: No such file or directory
> #include <glpk.h>
> configure:29862: $? = 1
> | /* confdefs.h */
> | #define STARPU_USE_MP 1
> | #define STARPU_MAXMPKERNELS 10
> | #include <stdio.h>
> | #endif
> | #endif
> | #ifdef STDC_HEADERS
> | #else
> | # endif
> | #endif
> | # endif
> | #endif
> | #endif
> | #endif
> | #endif
> | #endif
> | #include <glpk.h>
> configure:29862: result: no
> configure:29862: checking glpk.h presence
> configure:29862: cc -E -D_GNU_SOURCE conftest.c
> conftest.c:76:18: fatal error: glpk.h: No such file or directory
> #include <glpk.h>
> | /* confdefs.h */
> | #include <glpk.h>
> configure:29862: checking for glpk.h
> configure:29876: checking for main in -lglpk
> configure:29895: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> conftest.c -lglpk >&5
> /usr/bin/ld: cannot find -lglpk
> configure:29895: $? = 1
> | /* confdefs.h */
> | int
> | main ()
> | return main ();
> | return 0;
> configure:29904: result: no
> configure:29922: checking Ayudame.h usability
> configure:29922: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c
> >&5
> conftest.c:109:21: fatal error: Ayudame.h: No such file or directory
> #include <Ayudame.h>
> configure:29922: $? = 1
> | /* confdefs.h */
> | #include <stdio.h>
> | #endif
> | #endif
> | #ifdef STDC_HEADERS
> | #else
> | # endif
> | #endif
> | # endif
> | #endif
> | #endif
> | #endif
> | #endif
> | #endif
> configure:29922: result: no
> configure:29922: checking Ayudame.h presence
> configure:29922: cc -E -D_GNU_SOURCE conftest.c
> conftest.c:76:21: fatal error: Ayudame.h: No such file or directory
> | /* confdefs.h */
> configure:29922: checking for Ayudame.h
> configure:29939: checking how many buffers can be manipulated per task
> configure:29948: result: 8
> configure:29956: checking maximum number of nodes to use
> configure:30005: checking maximum number of memory nodes
> configure:30007: result: 4
> configure:30016: checking whether allocation cache should be used
> configure:30025: result: yes
> configure:30059: checking using explicit performance model location
> configure:30061: result: no
> configure:30064: checking performance models location
> configure:30066: result: $HOME/.starpu/sampling/
> configure:30070: checking for clock_gettime in -lrt
> configure:30095: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> conftest.c -lrt -lpthread >&5
> configure:30095: $? = 0
> configure:30104: result: yes
> configure:30117: checking for clock_gettime
> configure:30117: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> configure:30117: $? = 0
> configure:30117: result: yes
> configure:30147: checking Maximum number of workers
> configure:30149: result: 64
> configure:30159: checking Maximum number of workers combinations
> configure:30161: result: 64
> configure:30172: checking maximum number of implementations
> configure:30181: result: 4
> configure:30198: checking leveldb/db.h usability
> configure:30198: CC -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> conftest.cpp >&5
> conftest.cpp:117:24: fatal error: leveldb/db.h: No such file or directory
> #include <leveldb/db.h>
> configure:30198: $? = 1
> | /* confdefs.h */
> | #define STARPU_NMAXBUFS 8
> | #define STARPU_MAXNODES 4
> | #define STARPU_USE_ALLOCATION_CACHE 1
> | #define HAVE_LIBRT 1
> | #define HAVE_CLOCK_GETTIME 1
> | #define STARPU_NMAXWORKERS 64
> | #define STARPU_NMAX_COMBINEDWORKERS 64
> | #define STARPU_MAXIMPLEMENTATIONS 4
> | #include <stdio.h>
> | #endif
> | #endif
> | #ifdef STDC_HEADERS
> | #else
> | # endif
> | #endif
> | # endif
> | #endif
> | #endif
> | #endif
> | #endif
> | #endif
> configure:30198: result: no
> configure:30198: checking leveldb/db.h presence
> configure:30198: CC -E -D_GNU_SOURCE conftest.cpp
> conftest.cpp:84:24: fatal error: leveldb/db.h: No such file or directory
> | /* confdefs.h */
> configure:30198: checking for leveldb/db.h
> configure:30212: checking for main in -lleveldb
> configure:30231: CC -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> conftest.cpp -lleveldb >&5
> /usr/bin/ld: cannot find -lleveldb
> configure:30231: $? = 1
> | /* confdefs.h */
> | int
> | main ()
> | return main ();
> | return 0;
> configure:30240: result: no
> configure:30272: checking calibration heuristic of history-based StarPU
> calibrator
> configure:30281: result: 50
> configure:30362: result: The mpicc compiler is not valid
> configure:30412: checking mpicc path
> configure:30414: result: cc
> configure:30466: checking for mpiexec
> configure:30485: found /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/mpiexec
> configure:30498: result: /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/mpiexec
> configure:30510: checking whether mpiexec is available
> configure:30512: result: /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/mpiexec
> configure:30541: checking whether the StarPU MPI library should be generated
> configure:30543: result: no
> configure:30591: checking for StarPU-Top
> configure:30600: checking for qmake-qt4
> configure:30633: result: no
> configure:30618: found /usr/bin/qmake
> configure:30630: result: /usr/bin/qmake
> configure:30646: $PKG_CONFIG --exists --print-errors "QtGui QtNetwork
> QtOpenGL QtSql"
> configure:30649: $? = 0
> configure:30730: checking whether compiler support -Wall
> configure:30752: cc -c -Wall -D_GNU_SOURCE conftest.c >&5
> conftest.c:91:18: warning: unused variable 'hello' [-Wunused-variable]
> const char *hello = "Hello World";
> configure:30752: $? = 0
> configure:30755: result: yes
> configure:30769: checking whether compiler support -Werror=implicit
> configure:30791: cc -c -Werror=implicit -D_GNU_SOURCE conftest.c >&5
> configure:30791: $? = 0
> configure:30794: result: yes
> configure:30808: checking whether compiler support
> -Werror=implicit-function-declaration
> configure:30830: cc -c -Werror=implicit-function-declaration -D_GNU_SOURCE
> conftest.c >&5
> configure:30830: $? = 0
> configure:30833: result: yes
> configure:31078: checking whether GCC supports plug-ins
> configure:31133: cc -c -O3 -g -O2 -gdwarf-2 -g3
> -I/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include
> conftest.c >&5
> In file included from
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/config.h:6:0,
> from
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gcc-plugin.h:27,
> from conftest.c:85:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/auto-host.h:1766:0:
> warning: "PACKAGE_BUGREPORT" redefined
> #define PACKAGE_BUGREPORT ""
> conftest.c:6:0: note: this is the location of the previous definition
> from
> from conftest.c:85:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/auto-host.h:1772:0:
> warning: "PACKAGE_NAME" redefined
> #define PACKAGE_NAME ""
> conftest.c:2:0: note: this is the location of the previous definition
> from
> from conftest.c:85:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/auto-host.h:1778:0:
> warning: "PACKAGE_STRING" redefined
> #define PACKAGE_STRING ""
> conftest.c:5:0: note: this is the location of the previous definition
> from
> from conftest.c:85:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/auto-host.h:1784:0:
> warning: "PACKAGE_TARNAME" redefined
> #define PACKAGE_TARNAME ""
> conftest.c:3:0: note: this is the location of the previous definition
> from
> from conftest.c:85:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/auto-host.h:1790:0:
> warning: "PACKAGE_URL" redefined
> #define PACKAGE_URL ""
> conftest.c:7:0: note: this is the location of the previous definition
> from
> from conftest.c:85:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/auto-host.h:1796:0:
> warning: "PACKAGE_VERSION" redefined
> #define PACKAGE_VERSION ""
> conftest.c:4:0: note: this is the location of the previous definition
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gcc-plugin.h:29:0,
> from conftest.c:85:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/coretypes.h:171:1:
> error: unknown type name 'class'
> class rtl_opt_pass;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/coretypes.h:173:1:
> error: unknown type name 'namespace'
> namespace gcc {
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/coretypes.h:173:15:
> error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
> namespace gcc {
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:24:0,
> from
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:23,
> from conftest.c:86:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/machmode.h:262:1:
> class bit_field_mode_iterator
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/machmode.h:263:1:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:27:0,
> from
> from conftest.c:86:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:218:8:
> error: field 'register_overhead' declared as a function
> void register_overhead (size_t, const char *, int, const char *);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:219:8:
> error: field 'release_overhead' declared as a function
> void release_overhead (void);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:220:3:
> error: expected specifier-qualifier-list before 'static'
> static unsigned calculate_allocation (vec_prefix *, unsigned, bool);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:246:11:
> error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
> vec_prefix::calculate_allocation (vec_prefix *pfx, unsigned reserve,
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:256:9:
> error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token
> template<typename, typename, typename> struct vec;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:279:3:
> error: expected specifier-qualifier-list before 'typedef'
> typedef vl_ptr default_layout;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:295:9:
> template<typename T>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:319:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:342:3:
> typedef vl_embed default_layout;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:355:9:
> template<typename T, typename A>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:370:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:408:21:
> error: expected identifier or '(' before ':' token
> struct va_gc_atomic : va_gc
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:424:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:437:3:
> error: expected specifier-qualifier-list before 'template'
> template <typename T, typename A, typename L>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:440:8:
> error: unknown type name 'vnull'
> extern vnull vNULL;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:469:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:532:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:541:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:550:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:559:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:569:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:580:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:592:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:603:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:612:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:624:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:635:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:648:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:664:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:675:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:686:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:696:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:705:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:723:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:731:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:742:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:757:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:772:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:798:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:817:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:836:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:849:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:862:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:875:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:887:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:899:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:915:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:928:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:940:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:954:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:966:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1003:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1042:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1054:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1067:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1079:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1091:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1100:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1111:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1120:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1128:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1166:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1247:9:
> template<typename T, size_t N = 0>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1269:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1283:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1294:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1305:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1325:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1348:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1387:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1407:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1443:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1456:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1468:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1489:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1503:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1520:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1532:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1543:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1554:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1569:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1584:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1597:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1610:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1622:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1633:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1646:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1657:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1668:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1679:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1691:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1707:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/vec.h:1716:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:28:0,
> from
> from conftest.c:86:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:58:3:
> static double_int from_uhwi (unsigned HOST_WIDE_INT cst);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:207:8:
> error: unknown type name 'double_int'
> inline double_int
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:208:11:
> double_int::from_shwi (HOST_WIDE_INT cst)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:230:8:
> inline double_int
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:231:11:
> double_int::from_uhwi (unsigned HOST_WIDE_INT cst)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:239:8:
> inline double_int
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:240:11:
> double_int::from_pair (HOST_WIDE_INT high, unsigned HOST_WIDE_INT low)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:248:19:
> error: expected '=', ',', ';', 'asm' or '__attribute__' before '&' token
> inline double_int &
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:255:19:
> inline double_int &
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:262:19:
> inline double_int &
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:269:19:
> inline double_int &
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:276:19:
> inline double_int &
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:287:11:
> double_int::to_shwi () const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:296:11:
> double_int::to_uhwi () const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:304:11:
> double_int::fits_uhwi () const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:313:8:
> inline double_int
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:314:11:
> double_int::operator ~ () const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:324:8:
> inline double_int
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:325:11:
> double_int::operator | (double_int b) const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:335:8:
> inline double_int
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:336:11:
> double_int::operator & (double_int b) const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:346:8:
> inline double_int
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:347:11:
> double_int::and_not (double_int b) const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:357:8:
> inline double_int
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:358:11:
> double_int::operator ^ (double_int b) const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:366:31:
> void dump_double_int (FILE *, double_int, bool);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:377:11:
> double_int::is_zero () const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:385:11:
> double_int::is_one () const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:393:11:
> double_int::is_minus_one () const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:401:11:
> double_int::is_negative () const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:409:11:
> double_int::operator == (double_int cst2) const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:417:11:
> double_int::operator != (double_int cst2) const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:425:11:
> double_int::popcount () const
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:434:33:
> void mpz_set_double_int (mpz_t, double_int, bool);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/double-int.h:435:1:
> double_int mpz_get_double_int (const_tree, mpz_t, bool);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:30:0,
> from
> from conftest.c:86:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/fixed-value.h:29:3:
> double_int data; /* Store data up to 2 wide integers. */
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/fixed-value.h:55:12:
> error: expected ')' before 'enum'
> enum machine_mode);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/fixed-value.h:60:30:
> const_fixed_from_double_int (double_int payload,
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/fixed-value.h:81:9:
> double_int, bool, bool);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/flags.h:24:0,
> from
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:32,
> from
> from conftest.c:86:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4093:28:
> error: unknown type name 'diagnostic_context'
> diagnostic_context *dc);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4101:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4109:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4117:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4125:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4133:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4141:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4149:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4157:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4165:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4173:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/options.h:4181:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:23:0,
> from conftest.c:86:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:1051:3:
> double_int int_cst;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:1109:3:
> error: expected specifier-qualifier-list before 'vec'
> vec<constructor_elt, va_gc> *elts;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:1233:3:
> vec<tree, va_gc> *nonlocalized_vars;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:1304:3:
> vec<tree, va_gc> *base_accesses;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:1704:3:
> vec<tree, va_gc> *pending_statics;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:1752:3:
> vec<tree, va_gc> *to;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:1798:19:
> extern GTY(()) vec<alias_pair, va_gc> *alias_pairs;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:1811:20:
> extern GTY (()) vec<tree, va_gc> *all_translation_units;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree-core.h:1833:16:
> error: unknown type name 'builtin_info_type'
> extern GTY(()) builtin_info_type builtin_info;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:29:0,
> from conftest.c:86:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/fold-const.h:121:8:
> extern double_int mem_ref_offset (const_tree);
> In file included from conftest.c:86:0:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:2592:11:
> extern vec<tree, va_gc> **decl_debug_args_lookup (tree);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:2593:11:
> extern vec<tree, va_gc> **decl_debug_args_insert (tree);
> In function 'tree_operand_length':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:880:52:
> error: request for member 'low' in something not a structure or union
> #define TREE_INT_CST_LOW(NODE) (TREE_INT_CST (NODE).low)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:1011:9:
> note: in expansion of macro 'TREE_INT_CST_LOW'
> ((int)TREE_INT_CST_LOW (VL_EXP_CHECK (NODE)->exp.operands[0]))
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3145:12:
> note: in expansion of macro 'VL_EXP_OPERAND_LENGTH'
> return VL_EXP_OPERAND_LENGTH (node);
> At top level:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3457:38:
> error: unknown type name 'vec'
> extern tree build_nt_call_vec (tree, vec<tree, va_gc> *);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3457:48:
> error: unknown type name 'va_gc'
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3541:15:
> static inline double_int
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3547:39:
> extern tree double_int_to_tree (tree, double_int);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3548:52:
> extern bool double_int_fits_to_tree_p (const_tree, double_int);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3549:42:
> extern tree force_fit_type_double (tree, double_int, int, bool);
> In function 'build_int_cstu':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3556:36:
> error: 'double_int' undeclared (first use in this function)
> return double_int_to_tree (type, double_int::from_uhwi (cst));
> note: each undeclared identifier is reported only once for each function
> it appears in
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3556:46:
> error: expected ')' before ':' token
> At top level:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3566:43:
> extern tree build_vector_from_ctor (tree, vec<constructor_elt, va_gc> *);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3566:64:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3568:38:
> extern tree build_constructor (tree, vec<constructor_elt, va_gc> *);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3568:59:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3581:48:
> error: expected ';', ',' or ')' before '<' token
> extern tree build_tree_list_vec_stat (const vec<tree, va_gc>
> *MEM_STAT_DECL);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3600:41:
> extern tree build_call_vec (tree, tree, vec<tree, va_gc> *);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3600:51:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3637:37:
> extern bool vec_member (const_tree, vec<tree, va_gc> *);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3637:47:
> In function 'tree_to_shwi':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3662:10:
> return TREE_INT_CST_LOW (t);
> In function 'tree_to_uhwi':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3669:10:
> At top level:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3877:11:
> extern vec<tree, va_gc> *ctor_to_vec (tree);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:3964:45:
> extern void find_placeholder_in_expr (tree, vec<tree> *);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4063:26:
> error: unknown type name 'function_args_iterator'
> function_args_iter_init (function_args_iterator *i, const_tree fntype)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4072:30:
> function_args_iter_cond_ptr (function_args_iterator *i)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4081:26:
> function_args_iter_cond (function_args_iterator *i)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4088:26:
> function_args_iter_next (function_args_iterator *i)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4305:40:
> error: unknown type name 'call_expr_arg_iterator'
> init_call_expr_arg_iterator (tree exp, call_expr_arg_iterator *iter)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4313:52:
> error: unknown type name 'const_call_expr_arg_iterator'
> init_const_call_expr_arg_iterator (const_tree exp,
> const_call_expr_arg_iterator *iter)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4323:21:
> next_call_expr_arg (call_expr_arg_iterator *iter)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4334:27:
> next_const_call_expr_arg (const_call_expr_arg_iterator *iter)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4349:32:
> first_call_expr_arg (tree exp, call_expr_arg_iterator *iter)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4356:44:
> first_const_call_expr_arg (const_tree exp, const_call_expr_arg_iterator
> *iter)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4365:30:
> more_call_expr_args_p (const call_expr_arg_iterator *iter)
> In function 'more_call_expr_args_p':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4367:15:
> error: request for member 'i' in something not a structure or union
> return (iter->i < iter->n);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4367:25:
> error: request for member 'n' in something not a structure or union
> In function 'builtin_decl_explicit':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4397:22:
> error: request for member 'decl' in something not a structure or union
> return builtin_info.decl[(size_t)fncode];
> In function 'builtin_decl_implicit':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4407:20:
> error: request for member 'implicit_p' in something not a structure or
> union
> if (!builtin_info.implicit_p[uns_fncode])
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4410:22:
> return builtin_info.decl[uns_fncode];
> In function 'set_builtin_decl':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4424:15:
> builtin_info.decl[ufncode] = decl;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4425:15:
> union
> builtin_info.implicit_p[ufncode] = implicit_p;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gcc-plugin.h:28:0,
> from conftest.c:85:
> In function 'set_builtin_decl_implicit_p':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4436:25:
> && builtin_info.decl[uns_fncode] != NULL_TREE);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/system.h:703:49:
> note: in definition of macro 'gcc_checking_assert'
> #define gcc_checking_assert(EXPR) ((void)(0 && (EXPR)))
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4438:15:
> union
> builtin_info.implicit_p[uns_fncode] = implicit_p;
> In function 'builtin_decl_explicit_p':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4448:23:
> return (builtin_info.decl[(size_t)fncode] != NULL_TREE);
> In function 'builtin_decl_implicit_p':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4459:23:
> return (builtin_info.decl[uns_fncode] != NULL_TREE
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4460:19:
> union
> && builtin_info.implicit_p[uns_fncode]);
> At top level:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4573:56:
> extern tree build_call_expr_loc_vec (location_t, tree, vec<tree, va_gc> *);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/tree.h:4573:66:
> In file included from conftest.c:87:0:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:29:12:
> typedef vec<gimple> gimple_vec;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:210:34:
> gimple_statement_with_ops_base : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:226:29:
> gimple_statement_with_ops : public gimple_statement_with_ops_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:241:41:
> gimple_statement_with_memory_ops_base : public
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:256:36:
> gimple_statement_with_memory_ops :
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:272:25:
> gimple_statement_call : public gimple_statement_with_memory_ops_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:297:24:
> gimple_statement_omp : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:309:25:
> gimple_statement_bind : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:333:26:
> gimple_statement_catch : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:348:30:
> gimple_statement_eh_filter : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:364:28:
> gimple_statement_eh_else : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:375:27:
> gimple_statement_eh_mnt : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:386:24:
> gimple_statement_phi : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:405:28:
> gimple_statement_eh_ctrl : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:415:25:
> gimple_statement_resx : public gimple_statement_eh_ctrl
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:422:32:
> gimple_statement_eh_dispatch : public gimple_statement_eh_ctrl
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:432:24:
> gimple_statement_try : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:462:24:
> gimple_statement_wce : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:480:24:
> gimple_statement_asm : public gimple_statement_with_memory_ops_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:505:33:
> gimple_statement_omp_critical : public gimple_statement_omp
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:535:28:
> gimple_statement_omp_for : public gimple_statement_omp
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:557:40:
> gimple_statement_omp_parallel_layout : public gimple_statement_omp
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:576:32:
> gimple_statement_omp_taskreg : public
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:586:33:
> gimple_statement_omp_parallel : public gimple_statement_omp_taskreg
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:593:31:
> gimple_statement_omp_target : public gimple_statement_omp_parallel_layout
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:602:29:
> gimple_statement_omp_task : public gimple_statement_omp_taskreg
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:624:33:
> gimple_statement_omp_sections : public gimple_statement_omp
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:643:33:
> gimple_statement_omp_continue : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:657:38:
> gimple_statement_omp_single_layout : public gimple_statement_omp
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:666:31:
> gimple_statement_omp_single : public gimple_statement_omp_single_layout
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:673:30:
> gimple_statement_omp_teams : public gimple_statement_omp_single_layout
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:685:36:
> gimple_statement_omp_atomic_load : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:697:44:
> gimple_statement_omp_atomic_store_layout : public gimple_statement_base
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:706:37:
> gimple_statement_omp_atomic_store :
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:714:31:
> gimple_statement_omp_return :
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:750:32:
> gimple_statement_transaction : public
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:768:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:776:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:784:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:792:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:800:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:808:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:816:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:824:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:832:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:840:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:848:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:856:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:864:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:872:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:880:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:888:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:896:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:904:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:912:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:920:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:928:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:936:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:944:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:952:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:960:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:968:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:976:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:984:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:992:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1000:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1008:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1016:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1024:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1032:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1040:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1048:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1056:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1064:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1072:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1080:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1088:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1096:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1104:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1112:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1120:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1128:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1136:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1144:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1167:37:
> gimple gimple_build_call_vec (tree, vec<tree> );
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1170:41:
> warning: 'enum internal_fn' declared inside parameter list
> gimple gimple_build_call_internal (enum internal_fn, unsigned, ...);
> warning: its scope is only this definition or declaration, which is
> probably not what you want
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1171:58:
> gimple gimple_build_call_internal_vec (enum internal_fn, vec<tree> );
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1177:8:
> error: conflicting types for 'gimple_build_assign_with_ops'
> gimple gimple_build_assign_with_ops (enum tree_code, tree,
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1175:8:
> note: previous declaration of 'gimple_build_assign_with_ops' was here
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1186:44:
> gimple gimple_build_asm_vec (const char *, vec<tree, va_gc> *,
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1186:54:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1187:9:
> vec<tree, va_gc> *, vec<tree, va_gc> *,
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1187:19:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1187:29:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1187:39:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1188:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1188:19:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1193:1:
> error: unknown type name 'gimple_statement_try'
> gimple_statement_try *gimple_build_try (gimple_seq, gimple_seq,
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1198:41:
> gimple gimple_build_switch (tree, tree, vec<tree> );
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1224:54:
> warning: 'enum prediction' declared inside parameter list
> gimple gimple_build_predict (enum br_predictor, enum prediction);
> warning: 'enum br_predictor' declared inside parameter list
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1228:59:
> error: unknown type name 'gimple_stmt_iterator'
> extern void annotate_all_with_location_after (gimple_seq,
> gimple_stmt_iterator,
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1241:39:
> void gimple_assign_set_rhs_from_tree (gimple_stmt_iterator *, tree);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1242:40:
> void gimple_assign_set_rhs_with_ops_1 (gimple_stmt_iterator *, enum
> tree_code,
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1262:13:
> error: conflicting types for 'gimple_call_builtin_p'
> extern bool gimple_call_builtin_p (gimple, enum built_in_class);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1261:13:
> note: previous declaration of 'gimple_call_builtin_p' was here
> extern bool gimple_call_builtin_p (gimple);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1263:13:
> extern bool gimple_call_builtin_p (gimple, enum built_in_function);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1268:34:
> error: expected ')' before '<' token
> extern void sort_case_labels (vec<tree> );
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1269:54:
> extern void preprocess_case_label_vec_for_gimple (vec<tree> , tree, tree
> In function 'gimple_stmt_max_uid':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1285:12:
> error: dereferencing pointer to incomplete type
> return fn->last_stmt_uid;
> In function 'set_gimple_stmt_max_uid':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1292:5:
> fn->last_stmt_uid = maxid;
> In function 'inc_gimple_stmt_max_uid':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1299:12:
> return fn->last_stmt_uid++;
> In function 'bb_seq':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1382:15:
> return (!(bb->flags & BB_RTL)) ? bb->il.gimple.seq : NULL;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1382:25:
> error: 'BB_RTL' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1382:38:
> In function 'bb_seq_addr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1388:15:
> return (!(bb->flags & BB_RTL)) ? &bb->il.gimple.seq : NULL;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1388:25:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1388:39:
> from conftest.c:85:
> In function 'set_bb_seq':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1396:28:
> gcc_checking_assert (!(bb->flags & BB_RTL));
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1396:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1397:5:
> bb->il.gimple.seq = seq;
> At top level:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1648:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1656:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1672:10:
> template <>
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1680:10:
> template <>
> In function 'gimple_use_ops':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1693:9:
> error: unknown type name 'gimple_statement_with_ops'
> const gimple_statement_with_ops *ops_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1694:5:
> error: 'dyn_cast' undeclared (first use in this function)
> dyn_cast <const gimple_statement_with_ops> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1694:15:
> error: expected expression before 'const'
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1697:18:
> error: request for member 'use_ops' in something not a structure or union
> return ops_stmt->use_ops;
> In function 'gimple_set_use_ops':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1706:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1707:5:
> error: 'as_a' undeclared (first use in this function)
> as_a <gimple_statement_with_ops> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1707:11:
> error: 'gimple_statement_with_ops' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1708:11:
> ops_stmt->use_ops = use;
> In function 'gimple_vuse':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1717:9:
> error: unknown type name 'gimple_statement_with_memory_ops'
> const gimple_statement_with_memory_ops *mem_ops_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1718:6:
> dyn_cast <const gimple_statement_with_memory_ops> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1718:16:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1721:22:
> error: request for member 'vuse' in something not a structure or union
> return mem_ops_stmt->vuse;
> In function 'gimple_vdef':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1729:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1730:6:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1730:16:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1733:22:
> error: request for member 'vdef' in something not a structure or union
> return mem_ops_stmt->vdef;
> In function 'gimple_vuse_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1741:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1742:6:
> dyn_cast <gimple_statement_with_memory_ops> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1742:16:
> error: 'gimple_statement_with_memory_ops' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1745:23:
> return &mem_ops_stmt->vuse;
> In function 'gimple_vdef_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1753:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1754:6:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1754:16:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1757:23:
> return &mem_ops_stmt->vdef;
> In function 'gimple_set_vuse':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1765:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1766:5:
> as_a <gimple_statement_with_memory_ops> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1766:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1767:15:
> mem_ops_stmt->vuse = vuse;
> In function 'gimple_set_vdef':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1775:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1776:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1776:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1777:15:
> mem_ops_stmt->vdef = vdef;
> In function 'gimple_omp_return_set_lhs':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1907:3:
> error: unknown type name 'gimple_statement_omp_return'
> gimple_statement_omp_return *omp_return_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1908:5:
> as_a <gimple_statement_omp_return> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1908:11:
> error: 'gimple_statement_omp_return' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1909:18:
> error: request for member 'val' in something not a structure or union
> omp_return_stmt->val = lhs;
> In function 'gimple_omp_return_lhs':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1918:9:
> const gimple_statement_omp_return *omp_return_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1919:5:
> as_a <const gimple_statement_omp_return> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1919:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1920:25:
> return omp_return_stmt->val;
> In function 'gimple_omp_return_lhs_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1929:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1930:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1930:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:1931:26:
> return &omp_return_stmt->val;
> At top level:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2260:33:
> gimple_assign_set_rhs_with_ops (gimple_stmt_iterator *gsi, enum tree_code
> code,
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2445:1:
> error: return type is an incomplete type
> gimple_call_internal_fn (const_gimple gs)
> In function 'gimple_call_internal_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2448:10:
> error: 'static_cast' undeclared (first use in this function)
> return static_cast <const gimple_statement_call *> (gs)->u.internal_fn;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2448:23:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2448:3:
> warning: 'return' with a value, in function returning void
> In function 'gimple_call_fntype':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2480:9:
> error: unknown type name 'gimple_statement_call'
> const gimple_statement_call *call_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2481:5:
> as_a <const gimple_statement_call> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2481:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2484:19:
> error: request for member 'u' in something not a structure or union
> return call_stmt->u.fntype;
> In function 'gimple_call_set_fntype':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2492:3:
> gimple_statement_call *call_stmt = as_a <gimple_statement_call> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2492:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2492:44:
> error: 'gimple_statement_call' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2494:12:
> call_stmt->u.fntype = fntype;
> At top level:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2544:58:
> error: parameter 2 ('fn') has incomplete type
> gimple_call_set_internal_fn (gimple gs, enum internal_fn fn)
> In function 'gimple_call_set_internal_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2546:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2546:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2546:44:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2548:12:
> call_stmt->u.internal_fn = fn;
> In function 'gimple_call_fndecl':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2559:3:
> warning: return makes pointer from integer without a cast
> return gimple_call_addr_fndecl (gimple_call_fn (gs));
> In function 'gimple_call_use_set':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2824:3:
> gimple_statement_call *call_stmt = as_a <gimple_statement_call> (call);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2824:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2824:44:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2825:20:
> error: request for member 'call_used' in something not a structure or union
> return &call_stmt->call_used;
> In function 'gimple_call_clobber_set':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2835:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2835:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2835:44:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:2836:20:
> error: request for member 'call_clobbered' in something not a structure or
> union
> return &call_stmt->call_clobbered;
> In function 'gimple_bind_vars':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3104:9:
> error: unknown type name 'gimple_statement_bind'
> const gimple_statement_bind *bind_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3105:5:
> as_a <const gimple_statement_bind> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3105:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3106:19:
> error: request for member 'vars' in something not a structure or union
> return bind_stmt->vars;
> In function 'gimple_bind_set_vars':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3116:3:
> gimple_statement_bind *bind_stmt = as_a <gimple_statement_bind> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3116:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3116:44:
> error: 'gimple_statement_bind' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3117:12:
> bind_stmt->vars = vars;
> In function 'gimple_bind_append_vars':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3127:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3127:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3127:44:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3128:12:
> bind_stmt->vars = chainon (bind_stmt->vars, vars);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3128:39:
> In function 'gimple_bind_body_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3135:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3135:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3135:44:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3136:20:
> error: request for member 'body' in something not a structure or union
> return &bind_stmt->body;
> In function 'gimple_bind_set_body':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3154:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3154:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3154:44:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3155:12:
> bind_stmt->body = seq;
> In function 'gimple_bind_add_stmt':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3164:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3164:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3164:44:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3165:34:
> gimple_seq_add_stmt (&bind_stmt->body, stmt);
> In function 'gimple_bind_add_seq':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3174:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3174:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3174:44:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3175:33:
> gimple_seq_add_seq (&bind_stmt->body, seq);
> In function 'gimple_bind_block':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3185:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3186:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3186:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3187:19:
> error: request for member 'block' in something not a structure or union
> return bind_stmt->block;
> In function 'gimple_bind_set_block':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3197:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3197:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3197:44:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3200:12:
> bind_stmt->block = block;
> In function 'gimple_asm_ninputs':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3209:9:
> error: unknown type name 'gimple_statement_asm'
> const gimple_statement_asm *asm_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3210:5:
> as_a <const gimple_statement_asm> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3210:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3211:18:
> error: request for member 'ni' in something not a structure or union
> return asm_stmt->ni;
> In function 'gimple_asm_noutputs':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3220:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3221:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3221:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3222:18:
> error: request for member 'no' in something not a structure or union
> return asm_stmt->no;
> In function 'gimple_asm_nclobbers':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3231:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3232:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3232:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3233:18:
> error: request for member 'nc' in something not a structure or union
> return asm_stmt->nc;
> In function 'gimple_asm_nlabels':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3241:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3242:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3242:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3243:18:
> error: request for member 'nl' in something not a structure or union
> return asm_stmt->nl;
> In function 'gimple_asm_input_op':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3251:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3252:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3252:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3253:47:
> gcc_gimple_checking_assert (index < asm_stmt->ni);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:56:56:
> note: in definition of macro 'gcc_gimple_checking_assert'
> #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR)))
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3254:41:
> return gimple_op (gs, index + asm_stmt->no);
> In function 'gimple_asm_input_op_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3262:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3263:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3263:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3264:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3265:45:
> return gimple_op_ptr (gs, index + asm_stmt->no);
> In function 'gimple_asm_set_input_op':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3274:3:
> gimple_statement_asm *asm_stmt = as_a <gimple_statement_asm> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3274:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3274:42:
> error: 'gimple_statement_asm' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3275:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3277:38:
> gimple_set_op (gs, index + asm_stmt->no, in_op);
> In function 'gimple_asm_output_op':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3286:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3287:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3287:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3288:47:
> gcc_gimple_checking_assert (index < asm_stmt->no);
> In function 'gimple_asm_output_op_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3297:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3298:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3298:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3299:47:
> In function 'gimple_asm_set_output_op':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3309:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3309:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3309:42:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3310:47:
> In function 'gimple_asm_clobber_op':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3321:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3322:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3322:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3323:47:
> gcc_gimple_checking_assert (index < asm_stmt->nc);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3324:41:
> return gimple_op (gs, index + asm_stmt->ni + asm_stmt->no);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3324:56:
> In function 'gimple_asm_set_clobber_op':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3333:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3333:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3333:42:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3334:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3336:38:
> gimple_set_op (gs, index + asm_stmt->ni + asm_stmt->no, clobber_op);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3336:53:
> In function 'gimple_asm_label_op':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3344:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3345:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3345:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3346:47:
> gcc_gimple_checking_assert (index < asm_stmt->nl);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3347:41:
> return gimple_op (gs, index + asm_stmt->ni + asm_stmt->nc);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3347:56:
> In function 'gimple_asm_set_label_op':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3355:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3355:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3355:42:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3356:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3358:38:
> gimple_set_op (gs, index + asm_stmt->ni + asm_stmt->nc, label_op);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3358:53:
> In function 'gimple_asm_string':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3367:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3368:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3368:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3369:18:
> error: request for member 'string' in something not a structure or union
> return asm_stmt->string;
> In function 'gimple_catch_types':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3424:9:
> error: unknown type name 'gimple_statement_catch'
> const gimple_statement_catch *catch_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3425:5:
> as_a <const gimple_statement_catch> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3425:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3426:20:
> error: request for member 'types' in something not a structure or union
> return catch_stmt->types;
> In function 'gimple_catch_types_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3435:3:
> gimple_statement_catch *catch_stmt = as_a <gimple_statement_catch> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3435:40:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3435:46:
> error: 'gimple_statement_catch' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3436:21:
> return &catch_stmt->types;
> In function 'gimple_catch_handler_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3446:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3446:40:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3446:46:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3447:21:
> error: request for member 'handler' in something not a structure or union
> return &catch_stmt->handler;
> In function 'gimple_catch_set_types':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3466:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3466:40:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3466:46:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3467:13:
> catch_stmt->types = t;
> In function 'gimple_catch_set_handler':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3476:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3476:40:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3476:46:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3477:13:
> catch_stmt->handler = handler;
> In function 'gimple_eh_filter_types':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3486:9:
> error: unknown type name 'gimple_statement_eh_filter'
> const gimple_statement_eh_filter *eh_filter_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3487:5:
> as_a <const gimple_statement_eh_filter> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3487:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3488:24:
> return eh_filter_stmt->types;
> In function 'gimple_eh_filter_types_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3498:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3499:5:
> as_a <gimple_statement_eh_filter> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3499:11:
> error: 'gimple_statement_eh_filter' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3500:25:
> return &eh_filter_stmt->types;
> In function 'gimple_eh_filter_failure_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3510:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3511:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3511:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3512:25:
> error: request for member 'failure' in something not a structure or union
> return &eh_filter_stmt->failure;
> In function 'gimple_eh_filter_set_types':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3531:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3532:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3532:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3533:17:
> eh_filter_stmt->types = types;
> In function 'gimple_eh_filter_set_failure':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3543:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3544:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3544:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3545:17:
> eh_filter_stmt->failure = failure;
> In function 'gimple_eh_must_not_throw_fndecl':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3553:3:
> error: unknown type name 'gimple_statement_eh_mnt'
> gimple_statement_eh_mnt *eh_mnt_stmt = as_a <gimple_statement_eh_mnt>
> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3553:42:
> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3553:48:
> error: 'gimple_statement_eh_mnt' undeclared (first use in this function)
> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3554:21:
> error: request for member 'fndecl' in something not a structure or union
> return eh_mnt_stmt->fndecl;
> In function 'gimple_eh_must_not_throw_set_fndecl':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3562:3:
> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3562:42:
> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3562:48:
> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3563:14:
> eh_mnt_stmt->fndecl = decl;
> In function 'gimple_eh_else_n_body_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3571:3:
> error: unknown type name 'gimple_statement_eh_else'
> gimple_statement_eh_else *eh_else_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3572:5:
> as_a <gimple_statement_eh_else> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3572:11:
> error: 'gimple_statement_eh_else' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3573:23:
> error: request for member 'n_body' in something not a structure or union
> return &eh_else_stmt->n_body;
> In function 'gimple_eh_else_e_body_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3585:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3586:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3586:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3587:23:
> error: request for member 'e_body' in something not a structure or union
> return &eh_else_stmt->e_body;
> In function 'gimple_eh_else_set_n_body':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3599:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3600:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3600:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3601:15:
> eh_else_stmt->n_body = seq;
> In function 'gimple_eh_else_set_e_body':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3607:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3608:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3608:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3609:15:
> eh_else_stmt->e_body = seq;
> In function 'gimple_try_eval_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3654:3:
> gimple_statement_try *try_stmt = as_a <gimple_statement_try> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3654:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3654:42:
> error: 'gimple_statement_try' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3655:19:
> error: request for member 'eval' in something not a structure or union
> return &try_stmt->eval;
> In function 'gimple_try_cleanup_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3674:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3674:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3674:42:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3675:19:
> error: request for member 'cleanup' in something not a structure or union
> return &try_stmt->cleanup;
> In function 'gimple_try_set_eval':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3708:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3708:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3708:42:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3709:11:
> try_stmt->eval = eval;
> In function 'gimple_try_set_cleanup':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3719:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3719:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3719:42:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3720:11:
> try_stmt->cleanup = cleanup;
> In function 'gimple_wce_cleanup_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3729:3:
> error: unknown type name 'gimple_statement_wce'
> gimple_statement_wce *wce_stmt = as_a <gimple_statement_wce> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3729:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3729:42:
> error: 'gimple_statement_wce' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3730:19:
> return &wce_stmt->cleanup;
> In function 'gimple_wce_set_cleanup':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3748:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3748:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3748:42:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3749:11:
> wce_stmt->cleanup = cleanup;
> In function 'gimple_phi_capacity':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3778:9:
> error: unknown type name 'gimple_statement_phi'
> const gimple_statement_phi *phi_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3779:5:
> as_a <const gimple_statement_phi> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3779:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3780:18:
> error: request for member 'capacity' in something not a structure or union
> return phi_stmt->capacity;
> In function 'gimple_phi_num_args':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3791:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3792:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3792:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3793:18:
> error: request for member 'nargs' in something not a structure or union
> return phi_stmt->nargs;
> In function 'gimple_phi_result':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3802:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3803:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3803:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3804:18:
> error: request for member 'result' in something not a structure or union
> return phi_stmt->result;
> In function 'gimple_phi_result_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3812:3:
> gimple_statement_phi *phi_stmt = as_a <gimple_statement_phi> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3812:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3812:42:
> error: 'gimple_statement_phi' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3813:19:
> return &phi_stmt->result;
> In function 'gimple_phi_set_result':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3821:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3821:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3821:42:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3822:11:
> phi_stmt->result = result;
> In function 'gimple_phi_arg':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3834:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3834:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3834:42:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3835:48:
> gcc_gimple_checking_assert (index <= phi_stmt->capacity);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3836:20:
> error: request for member 'args' in something not a structure or union
> return &(phi_stmt->args[index]);
> In function 'gimple_phi_set_arg':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3845:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3845:36:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3845:42:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3846:48:
> gcc_gimple_checking_assert (index <= phi_stmt->nargs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3847:11:
> phi_stmt->args[index] = *phiarg;
> from conftest.c:85:
> In function 'phi_nodes':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3856:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3856:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3857:12:
> return bb->il.gimple.phi_nodes;
> from conftest.c:85:
> In function 'phi_nodes_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3865:28:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3865:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3866:13:
> return &bb->il.gimple.phi_nodes;
> In function 'gimple_phi_arg_edge':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3891:3:
> return EDGE_PRED (gimple_bb (gs), i);
> In function 'gimple_phi_arg_location_from_edge':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3907:31:
> return gimple_phi_arg (gs, e->dest_idx)->locus;
> In function 'gimple_resx_region':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3932:9:
> error: unknown type name 'gimple_statement_resx'
> const gimple_statement_resx *resx_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3933:5:
> as_a <const gimple_statement_resx> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3933:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3934:19:
> error: request for member 'region' in something not a structure or union
> return resx_stmt->region;
> In function 'gimple_resx_set_region':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3942:3:
> gimple_statement_resx *resx_stmt = as_a <gimple_statement_resx> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3942:38:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3942:44:
> error: 'gimple_statement_resx' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3943:12:
> resx_stmt->region = region;
> In function 'gimple_eh_dispatch_region':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3951:9:
> error: unknown type name 'gimple_statement_eh_dispatch'
> const gimple_statement_eh_dispatch *eh_dispatch_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3952:5:
> as_a <const gimple_statement_eh_dispatch> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3952:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3953:26:
> return eh_dispatch_stmt->region;
> In function 'gimple_eh_dispatch_set_region':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3961:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3962:5:
> as_a <gimple_statement_eh_dispatch> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3962:11:
> error: 'gimple_statement_eh_dispatch' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:3963:19:
> eh_dispatch_stmt->region = region;
> In function 'gimple_omp_body_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4248:11:
> return &static_cast <gimple_statement_omp *> (gs)->body;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4248:24:
> error: 'gimple_statement_omp' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4248:46:
> error: expected expression before '>' token
> In function 'gimple_omp_set_body':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4264:3:
> static_cast <gimple_statement_omp *> (gs)->body = body;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4264:16:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4264:38:
> In function 'gimple_omp_critical_name':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4273:9:
> error: unknown type name 'gimple_statement_omp_critical'
> const gimple_statement_omp_critical *omp_critical_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4274:5:
> as_a <const gimple_statement_omp_critical> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4274:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4275:27:
> error: request for member 'name' in something not a structure or union
> return omp_critical_stmt->name;
> In function 'gimple_omp_critical_name_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4284:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4285:5:
> as_a <gimple_statement_omp_critical> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4285:11:
> error: 'gimple_statement_omp_critical' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4286:28:
> return &omp_critical_stmt->name;
> In function 'gimple_omp_critical_set_name':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4295:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4296:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4296:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4297:20:
> omp_critical_stmt->name = name;
> In function 'gimple_omp_for_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4377:9:
> error: unknown type name 'gimple_statement_omp_for'
> const gimple_statement_omp_for *omp_for_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4378:5:
> as_a <const gimple_statement_omp_for> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4378:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4379:22:
> error: request for member 'clauses' in something not a structure or union
> return omp_for_stmt->clauses;
> In function 'gimple_omp_for_clauses_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4388:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4389:5:
> as_a <gimple_statement_omp_for> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4389:11:
> error: 'gimple_statement_omp_for' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4390:23:
> return &omp_for_stmt->clauses;
> In function 'gimple_omp_for_set_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4399:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4400:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4400:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4401:15:
> omp_for_stmt->clauses = clauses;
> In function 'gimple_omp_for_collapse':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4410:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4411:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4411:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4412:22:
> error: request for member 'collapse' in something not a structure or union
> return omp_for_stmt->collapse;
> In function 'gimple_omp_for_index':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4421:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4422:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4422:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4423:47:
> gcc_gimple_checking_assert (i < omp_for_stmt->collapse);
> In file included from conftest.c:87:0:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4424:22:
> error: request for member 'iter' in something not a structure or union
> return omp_for_stmt->iter[i].index;
> In function 'gimple_omp_for_index_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4433:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4434:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4434:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4435:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4436:23:
> return &omp_for_stmt->iter[i].index;
> In function 'gimple_omp_for_set_index':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4445:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4446:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4446:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4447:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4448:15:
> omp_for_stmt->iter[i].index = index;
> In function 'gimple_omp_for_initial':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4457:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4458:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4458:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4459:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4460:22:
> return omp_for_stmt->iter[i].initial;
> In function 'gimple_omp_for_initial_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4469:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4470:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4470:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4471:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4472:23:
> return &omp_for_stmt->iter[i].initial;
> In function 'gimple_omp_for_set_initial':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4481:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4482:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4482:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4483:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4484:15:
> omp_for_stmt->iter[i].initial = initial;
> In function 'gimple_omp_for_final':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4493:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4494:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4494:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4495:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4496:22:
> return omp_for_stmt->iter[i].final;
> In function 'gimple_omp_for_final_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4505:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4506:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4506:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4507:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4508:23:
> return &omp_for_stmt->iter[i].final;
> In function 'gimple_omp_for_set_final':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4517:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4518:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4518:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4519:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4520:15:
> omp_for_stmt->iter[i].final = final;
> In function 'gimple_omp_for_incr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4529:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4530:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4530:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4531:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4532:22:
> return omp_for_stmt->iter[i].incr;
> In function 'gimple_omp_for_incr_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4541:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4542:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4542:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4543:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4544:23:
> return &omp_for_stmt->iter[i].incr;
> In function 'gimple_omp_for_set_incr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4553:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4554:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4554:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4555:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4556:15:
> omp_for_stmt->iter[i].incr = incr;
> In function 'gimple_omp_for_pre_body_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4566:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4567:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4567:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4568:23:
> error: request for member 'pre_body' in something not a structure or union
> return &omp_for_stmt->pre_body;
> In function 'gimple_omp_for_set_pre_body':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4588:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4589:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4589:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4590:15:
> omp_for_stmt->pre_body = pre_body;
> In function 'gimple_omp_parallel_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4599:9:
> error: unknown type name 'gimple_statement_omp_parallel'
> const gimple_statement_omp_parallel *omp_parallel_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4600:5:
> as_a <const gimple_statement_omp_parallel> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4600:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4601:27:
> return omp_parallel_stmt->clauses;
> In function 'gimple_omp_parallel_clauses_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4610:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4611:5:
> as_a <gimple_statement_omp_parallel> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4611:11:
> error: 'gimple_statement_omp_parallel' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4612:28:
> return &omp_parallel_stmt->clauses;
> In function 'gimple_omp_parallel_set_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4622:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4623:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4623:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4624:20:
> omp_parallel_stmt->clauses = clauses;
> In function 'gimple_omp_parallel_child_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4633:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4634:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4634:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4635:27:
> error: request for member 'child_fn' in something not a structure or union
> return omp_parallel_stmt->child_fn;
> In function 'gimple_omp_parallel_child_fn_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4644:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4645:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4645:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4646:28:
> return &omp_parallel_stmt->child_fn;
> In function 'gimple_omp_parallel_set_child_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4655:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4656:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4656:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4657:20:
> omp_parallel_stmt->child_fn = child_fn;
> In function 'gimple_omp_parallel_data_arg':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4667:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4668:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4668:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4669:27:
> error: request for member 'data_arg' in something not a structure or union
> return omp_parallel_stmt->data_arg;
> In function 'gimple_omp_parallel_data_arg_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4678:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4679:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4679:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4680:28:
> return &omp_parallel_stmt->data_arg;
> In function 'gimple_omp_parallel_set_data_arg':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4689:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4690:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4690:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4691:20:
> omp_parallel_stmt->data_arg = data_arg;
> In function 'gimple_omp_task_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4700:9:
> error: unknown type name 'gimple_statement_omp_task'
> const gimple_statement_omp_task *omp_task_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4701:5:
> as_a <const gimple_statement_omp_task> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4701:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4702:23:
> return omp_task_stmt->clauses;
> In function 'gimple_omp_task_clauses_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4711:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4712:5:
> as_a <gimple_statement_omp_task> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4712:11:
> error: 'gimple_statement_omp_task' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4713:24:
> return &omp_task_stmt->clauses;
> In function 'gimple_omp_task_set_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4723:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4724:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4724:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4725:16:
> omp_task_stmt->clauses = clauses;
> In function 'gimple_omp_task_child_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4734:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4735:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4735:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4736:23:
> return omp_task_stmt->child_fn;
> In function 'gimple_omp_task_child_fn_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4745:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4746:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4746:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4747:24:
> return &omp_task_stmt->child_fn;
> In function 'gimple_omp_task_set_child_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4756:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4757:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4757:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4758:16:
> omp_task_stmt->child_fn = child_fn;
> In function 'gimple_omp_task_data_arg':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4768:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4769:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4769:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4770:23:
> return omp_task_stmt->data_arg;
> In function 'gimple_omp_task_data_arg_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4779:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4780:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4780:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4781:24:
> return &omp_task_stmt->data_arg;
> In function 'gimple_omp_task_set_data_arg':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4790:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4791:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4791:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4792:16:
> omp_task_stmt->data_arg = data_arg;
> In function 'gimple_omp_taskreg_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4801:9:
> error: unknown type name 'gimple_statement_omp_taskreg'
> const gimple_statement_omp_taskreg *omp_taskreg_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4802:5:
> as_a <const gimple_statement_omp_taskreg> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4802:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4803:26:
> return omp_taskreg_stmt->clauses;
> In function 'gimple_omp_taskreg_clauses_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4812:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4813:5:
> as_a <gimple_statement_omp_taskreg> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4813:11:
> error: 'gimple_statement_omp_taskreg' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4814:27:
> return &omp_taskreg_stmt->clauses;
> In function 'gimple_omp_taskreg_set_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4824:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4825:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4825:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4826:19:
> omp_taskreg_stmt->clauses = clauses;
> In function 'gimple_omp_taskreg_child_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4835:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4836:5:
> error: 'as_a' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4836:11:
> error: expected expression before 'const'
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4837:26:
> return omp_taskreg_stmt->child_fn;
> In function 'gimple_omp_taskreg_child_fn_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4846:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4847:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4847:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4848:27:
> return &omp_taskreg_stmt->child_fn;
> In function 'gimple_omp_taskreg_set_child_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4857:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4858:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4858:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4859:19:
> omp_taskreg_stmt->child_fn = child_fn;
> In function 'gimple_omp_taskreg_data_arg':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4869:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4870:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4870:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4871:26:
> return omp_taskreg_stmt->data_arg;
> In function 'gimple_omp_taskreg_data_arg_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4880:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4881:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4881:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4882:27:
> return &omp_taskreg_stmt->data_arg;
> In function 'gimple_omp_taskreg_set_data_arg':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4891:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4892:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4892:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4893:19:
> omp_taskreg_stmt->data_arg = data_arg;
> In function 'gimple_omp_task_copy_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4902:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4903:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4903:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4904:23:
> error: request for member 'copy_fn' in something not a structure or union
> return omp_task_stmt->copy_fn;
> In function 'gimple_omp_task_copy_fn_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4913:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4914:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4914:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4915:24:
> return &omp_task_stmt->copy_fn;
> In function 'gimple_omp_task_set_copy_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4924:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4925:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4925:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4926:16:
> omp_task_stmt->copy_fn = copy_fn;
> In function 'gimple_omp_task_arg_size':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4935:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4936:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4936:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4937:23:
> error: request for member 'arg_size' in something not a structure or union
> return omp_task_stmt->arg_size;
> In function 'gimple_omp_task_arg_size_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4946:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4947:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4947:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4948:24:
> return &omp_task_stmt->arg_size;
> In function 'gimple_omp_task_set_arg_size':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4957:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4958:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4958:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4959:16:
> omp_task_stmt->arg_size = arg_size;
> In function 'gimple_omp_task_arg_align':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4968:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4969:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4969:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4970:23:
> error: request for member 'arg_align' in something not a structure or union
> return omp_task_stmt->arg_align;
> In function 'gimple_omp_task_arg_align_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4979:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4980:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4980:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4981:24:
> return &omp_task_stmt->arg_align;
> In function 'gimple_omp_task_set_arg_align':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4990:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4991:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4991:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:4992:16:
> omp_task_stmt->arg_align = arg_align;
> In function 'gimple_omp_single_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5001:9:
> error: unknown type name 'gimple_statement_omp_single'
> const gimple_statement_omp_single *omp_single_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5002:5:
> as_a <const gimple_statement_omp_single> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5002:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5003:25:
> return omp_single_stmt->clauses;
> In function 'gimple_omp_single_clauses_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5012:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5013:5:
> as_a <gimple_statement_omp_single> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5013:11:
> error: 'gimple_statement_omp_single' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5014:26:
> return &omp_single_stmt->clauses;
> In function 'gimple_omp_single_set_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5023:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5024:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5024:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5025:18:
> omp_single_stmt->clauses = clauses;
> In function 'gimple_omp_target_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5034:9:
> error: unknown type name 'gimple_statement_omp_target'
> const gimple_statement_omp_target *omp_target_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5035:5:
> as_a <const gimple_statement_omp_target> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5035:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5036:25:
> return omp_target_stmt->clauses;
> In function 'gimple_omp_target_clauses_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5045:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5046:5:
> as_a <gimple_statement_omp_target> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5046:11:
> error: 'gimple_statement_omp_target' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5047:26:
> return &omp_target_stmt->clauses;
> In function 'gimple_omp_target_set_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5056:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5057:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5057:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5058:18:
> omp_target_stmt->clauses = clauses;
> In function 'gimple_omp_target_child_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5088:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5089:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5089:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5090:25:
> return omp_target_stmt->child_fn;
> In function 'gimple_omp_target_child_fn_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5099:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5100:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5100:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5101:26:
> return &omp_target_stmt->child_fn;
> In function 'gimple_omp_target_set_child_fn':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5110:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5111:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5111:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5112:18:
> omp_target_stmt->child_fn = child_fn;
> In function 'gimple_omp_target_data_arg':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5122:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5123:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5123:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5124:25:
> return omp_target_stmt->data_arg;
> In function 'gimple_omp_target_data_arg_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5133:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5134:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5134:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5135:26:
> return &omp_target_stmt->data_arg;
> In function 'gimple_omp_target_set_data_arg':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5144:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5145:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5145:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5146:18:
> omp_target_stmt->data_arg = data_arg;
> In function 'gimple_omp_teams_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5155:9:
> error: unknown type name 'gimple_statement_omp_teams'
> const gimple_statement_omp_teams *omp_teams_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5156:5:
> as_a <const gimple_statement_omp_teams> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5156:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5157:24:
> return omp_teams_stmt->clauses;
> In function 'gimple_omp_teams_clauses_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5166:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5167:5:
> as_a <gimple_statement_omp_teams> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5167:11:
> error: 'gimple_statement_omp_teams' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5168:25:
> return &omp_teams_stmt->clauses;
> In function 'gimple_omp_teams_set_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5177:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5178:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5178:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5179:17:
> omp_teams_stmt->clauses = clauses;
> In function 'gimple_omp_sections_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5188:9:
> error: unknown type name 'gimple_statement_omp_sections'
> const gimple_statement_omp_sections *omp_sections_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5189:5:
> as_a <const gimple_statement_omp_sections> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5189:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5190:27:
> return omp_sections_stmt->clauses;
> In function 'gimple_omp_sections_clauses_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5199:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5200:5:
> as_a <gimple_statement_omp_sections> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5200:11:
> error: 'gimple_statement_omp_sections' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5201:28:
> return &omp_sections_stmt->clauses;
> In function 'gimple_omp_sections_set_clauses':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5211:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5212:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5212:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5213:20:
> omp_sections_stmt->clauses = clauses;
> In function 'gimple_omp_sections_control':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5223:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5224:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5224:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5225:27:
> error: request for member 'control' in something not a structure or union
> return omp_sections_stmt->control;
> In function 'gimple_omp_sections_control_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5235:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5236:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5236:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5237:28:
> return &omp_sections_stmt->control;
> In function 'gimple_omp_sections_set_control':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5247:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5248:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5248:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5249:20:
> omp_sections_stmt->control = control;
> In function 'gimple_omp_for_set_cond':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5258:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5259:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5259:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5261:29:
> && i < omp_for_stmt->collapse);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:56:56:
> note: in definition of macro 'gcc_gimple_checking_assert'
> #define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR)))
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5262:15:
> omp_for_stmt->iter[i].cond = cond;
> In function 'gimple_omp_for_cond':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5271:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5272:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5272:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5273:47:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5274:22:
> return omp_for_stmt->iter[i].cond;
> In function 'gimple_omp_atomic_store_set_val':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5283:3:
> error: unknown type name 'gimple_statement_omp_atomic_store'
> gimple_statement_omp_atomic_store *omp_atomic_store_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5284:5:
> as_a <gimple_statement_omp_atomic_store> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5284:11:
> error: 'gimple_statement_omp_atomic_store' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5285:24:
> error: request for member 'val' in something not a structure or union
> omp_atomic_store_stmt->val = val;
> In function 'gimple_omp_atomic_store_val':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5294:9:
> const gimple_statement_omp_atomic_store *omp_atomic_store_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5295:5:
> as_a <const gimple_statement_omp_atomic_store> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5295:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5296:31:
> return omp_atomic_store_stmt->val;
> In function 'gimple_omp_atomic_store_val_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5305:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5306:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5306:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5307:32:
> return &omp_atomic_store_stmt->val;
> In function 'gimple_omp_atomic_load_set_lhs':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5316:3:
> error: unknown type name 'gimple_statement_omp_atomic_load'
> gimple_statement_omp_atomic_load *omp_atomic_load_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5317:5:
> as_a <gimple_statement_omp_atomic_load> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5317:11:
> error: 'gimple_statement_omp_atomic_load' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5318:23:
> error: request for member 'lhs' in something not a structure or union
> omp_atomic_load_stmt->lhs = lhs;
> In function 'gimple_omp_atomic_load_lhs':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5327:9:
> const gimple_statement_omp_atomic_load *omp_atomic_load_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5328:5:
> as_a <const gimple_statement_omp_atomic_load> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5328:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5329:30:
> return omp_atomic_load_stmt->lhs;
> In function 'gimple_omp_atomic_load_lhs_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5338:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5339:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5339:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5340:31:
> return &omp_atomic_load_stmt->lhs;
> In function 'gimple_omp_atomic_load_set_rhs':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5349:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5350:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5350:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5351:23:
> error: request for member 'rhs' in something not a structure or union
> omp_atomic_load_stmt->rhs = rhs;
> In function 'gimple_omp_atomic_load_rhs':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5360:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5361:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5361:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5362:30:
> return omp_atomic_load_stmt->rhs;
> In function 'gimple_omp_atomic_load_rhs_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5371:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5372:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5372:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5373:31:
> return &omp_atomic_load_stmt->rhs;
> In function 'gimple_omp_continue_control_def':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5382:9:
> error: unknown type name 'gimple_statement_omp_continue'
> const gimple_statement_omp_continue *omp_continue_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5383:5:
> as_a <const gimple_statement_omp_continue> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5383:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5384:27:
> error: request for member 'control_def' in something not a structure or
> union
> return omp_continue_stmt->control_def;
> In function 'gimple_omp_continue_control_def_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5392:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5393:5:
> as_a <gimple_statement_omp_continue> (g);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5393:11:
> error: 'gimple_statement_omp_continue' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5394:28:
> union
> return &omp_continue_stmt->control_def;
> In function 'gimple_omp_continue_set_control_def':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5402:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5403:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5403:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5404:20:
> union
> omp_continue_stmt->control_def = def;
> In function 'gimple_omp_continue_control_use':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5413:9:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5414:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5414:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5415:27:
> error: request for member 'control_use' in something not a structure or
> union
> return omp_continue_stmt->control_use;
> In function 'gimple_omp_continue_control_use_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5424:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5425:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5425:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5426:28:
> union
> return &omp_continue_stmt->control_use;
> In function 'gimple_omp_continue_set_control_use':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5435:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5436:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5436:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5437:20:
> union
> omp_continue_stmt->control_use = use;
> In function 'gimple_transaction_body_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5445:3:
> error: unknown type name 'gimple_statement_transaction'
> gimple_statement_transaction *transaction_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5446:5:
> as_a <gimple_statement_transaction> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5446:11:
> error: 'gimple_statement_transaction' undeclared (first use in this
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5447:27:
> error: request for member 'body' in something not a structure or union
> return &transaction_stmt->body;
> In function 'gimple_transaction_label':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5463:9:
> const gimple_statement_transaction *transaction_stmt =
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5464:5:
> as_a <const gimple_statement_transaction> (gs);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5464:11:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5465:26:
> error: request for member 'label' in something not a structure or union
> return transaction_stmt->label;
> In function 'gimple_transaction_label_ptr':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5471:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5472:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5472:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5473:27:
> return &transaction_stmt->label;
> In function 'gimple_transaction_set_body':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5490:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5491:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5491:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5492:19:
> transaction_stmt->body = body;
> In function 'gimple_transaction_set_label':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5500:3:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5501:5:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5501:11:
> function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5502:19:
> transaction_stmt->label = label;
> At top level:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5598:1:
> error: return type is an incomplete type
> gimple_predict_predictor (gimple gs)
> In function 'gimple_predict_predictor':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5601:16:
> error: conversion to incomplete type
> return (enum br_predictor) (gs->subcode & ~GF_PREDICT_TAKEN);
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5601:3:
> warning: 'return' with a value, in function returning void
> At top level:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5608:60:
> error: parameter 2 ('predictor') has incomplete type
> gimple_predict_set_predictor (gimple gs, enum br_predictor predictor)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5619:1:
> gimple_predict_outcome (gimple gs)
> In function 'gimple_predict_outcome':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5622:45:
> error: 'TAKEN' undeclared (first use in this function)
> return (gs->subcode & GF_PREDICT_TAKEN) ? TAKEN : NOT_TAKEN;
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5622:53:
> error: 'NOT_TAKEN' undeclared (first use in this function)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5622:3:
> At top level:
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5629:56:
> error: parameter 2 ('outcome') has incomplete type
> gimple_predict_set_outcome (gimple gs, enum prediction outcome)
> In function 'gimple_predict_set_outcome':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5632:18:
> if (outcome == TAKEN)
> In function 'gimple_expr_type':
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5657:45:
> error: 'IFN_MASK_STORE' undeclared (first use in this function)
> && gimple_call_internal_fn (stmt) == IFN_MASK_STORE)
> /opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include/gimple.h:5657:8:
> error: void value not ignored as it ought to be
> conftest.c: At top level:
> conftest.c:90:45: warning: missing terminating ' character
> Beware, this compiler is a fake. Don't use it.
> conftest.c: In function 'foo':
> conftest.c:101:10: warning: return makes pointer from integer without a cast
> return lookup_name (get_identifier ("puts"));
> configure:31133: $? = 1
> configure: failed program was:
> | /* confdefs.h */
> | #define PACKAGE_NAME "StarPU"
> | #define PACKAGE_TARNAME "starpu"
> | #define PACKAGE_VERSION "1.2.0rc4"
> | #define PACKAGE_STRING "StarPU 1.2.0rc4"
> | #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
> | #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/"
> | #define STARPU_MAJOR_VERSION 1
> | #define STARPU_MINOR_VERSION 2
> | #define STARPU_RELEASE_VERSION 0
> | #define PACKAGE "starpu"
> | #define VERSION "1.2.0rc4"
> | #define STDC_HEADERS 1
> | #define HAVE_SYS_TYPES_H 1
> | #define HAVE_SYS_STAT_H 1
> | #define HAVE_STDLIB_H 1
> | #define HAVE_STRING_H 1
> | #define HAVE_MEMORY_H 1
> | #define HAVE_STRINGS_H 1
> | #define HAVE_INTTYPES_H 1
> | #define HAVE_STDINT_H 1
> | #define HAVE_UNISTD_H 1
> | #define HAVE_DLFCN_H 1
> | #define LT_OBJDIR ".libs/"
> | #define restrict __restrict
> | #define STARPU_MIC_USE_RMA 1
> | #define STARPU_LINUX_SYS 1
> | #define SIZEOF_VOID_P 8
> | #define STARPU_BUILD_DIR "/project/k1044/favergm/src/starpu-1.2.0rc4"
> | #define STARPU_SRC_DIR
> "/lustre/project/k1044/favergm/src/starpu-1.2.0rc4/."
> | #define HAVE_LIBPTHREAD 1
> | #define STARPU_HAVE_STRUCT_TIMESPEC /**/
> | #define HAVE_SYSCONF 1
> | #define HAVE_PTHREAD_SPIN_LOCK /**/
> | #define STARPU_HAVE_PTHREAD_SPIN_LOCK /**/
> | #define STARPU_HAVE_PTHREAD_BARRIER /**/
> | #define HAVE_PTHREAD_SETAFFINITY_NP 1
> | #define HAVE_POSIX_MEMALIGN 1
> | #define STARPU_HAVE_POSIX_MEMALIGN 1
> | #define HAVE_MEMALIGN 1
> | #define STARPU_HAVE_MEMALIGN 1
> | #define STARPU_USE_DRAND48 1
> | #define STARPU_USE_ERAND48_R 1
> | #define STARPU_HAVE_STRERROR_R 1
> | #define STARPU_HAVE_SETENV 1
> | #define STARPU_HAVE_UNSETENV 1
> | #define STARPU_HAVE_NEARBYINTF 1
> | #define STARPU_HAVE_RINTF 1
> | #define HAVE_MALLOC_H 1
> | #define STARPU_HAVE_MALLOC_H 1
> | #define STARPU_HAVE_SCHED_YIELD 1
> | #define HAVE_AIO_H 1
> | #define HAVE_MKOSTEMP 1
> | #define HAVE_PREAD 1
> | #define HAVE_PWRITE 1
> | #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
> | #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
> | #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
> | #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
> | #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
> | #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
> | #define STARPU_HAVE_LIBNUMA /**/
> | #define STARPU_NMAX_SCHED_CTXS 10
> | #define STARPU_MAXCPUS 64
> | #define STARPU_USE_CPU 1
> | #define STARPU_MAXCUDADEVS 4
> | #define STARPU_MAXOPENCLDEVS 8
> | #define STARPU_NON_BLOCKING_DRIVERS 1
> | #define STARPU_MAXMICDEVS 4
> | #define STARPU_MAXMICCORES 120
> | #define STARPU_MAXSCCDEVS 47
> | #define STARPU_USE_MP 1
> | #define STARPU_MAXMPKERNELS 10
> | #define STARPU_NMAXBUFS 8
> | #define STARPU_MAXNODES 4
> | #define STARPU_USE_ALLOCATION_CACHE 1
> | #define HAVE_LIBRT 1
> | #define HAVE_CLOCK_GETTIME 1
> | #define STARPU_NMAXWORKERS 64
> | #define STARPU_NMAX_COMBINEDWORKERS 64
> | #define STARPU_MAXIMPLEMENTATIONS 4
> | #define STARPU_HISTORYMAXERROR 50
> | /* end confdefs.h. */
> | #include <gcc-plugin.h>
> | #include <tree.h>
> | #include <gimple.h>
> | #if defined __INTEL_COMPILER || defined __ICC
> | #endif
> | tree fndecl; gimple call;
> | int
> | main ()
> | /* Clang 3.1 doesn't support nested functions, so try to
> | discriminate it this way. */
> | tree foo (void)
> | fndecl = foo ();
> | call = gimple_build_call (fndecl, 0);
> | return 0;
> configure:31149: result: no
> configure:31433: WARNING: GCC plug-ins not supported; StarPU's GCC plug-in
> will not be built
> configure:31571: checking for OpenMP runtime support
> configure:31588: result: no
> configure:31605: checking for SOCL
> configure:31620: result: no
> configure:31669: checking for gdb
> configure:31687: found /usr/bin/gdb
> configure:31700: result: /usr/bin/gdb
> configure:31912: checking whether OpenGL rendering is enabled
> configure:31916: result: no
> configure:31927: checking for X
> configure:32066: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> conftest.c -lX11 -lrt -lpthread >&5
> configure:32066: $? = 0
> configure:32116: result: libraries , headers
> configure:32215: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> conftest.c -lrt -lpthread -lX11 >&5
> configure:32215: $? = 0
> configure:32313: checking for gethostbyname
> configure:32313: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> conftest.c -lrt -lpthread >&5
> configure:32313: $? = 0
> configure:32313: result: yes
> configure:32410: checking for connect
> configure:32410: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> configure:32410: $? = 0
> configure:32410: result: yes
> configure:32459: checking for remove
> configure:32459: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> configure:32459: $? = 0
> configure:32459: result: yes
> configure:32508: checking for shmat
> configure:32508: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> configure:32508: $? = 0
> configure:32508: result: yes
> configure:32566: checking for IceConnectionNumber in -lICE
> configure:32591: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> conftest.c -lICE -lrt -lpthread >&5
> configure:32591: $? = 0
> configure:32600: result: yes
> configure:33051: checking for library containing sgemm_
> configure:33082: cc -o conftest -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
> conftest.c >&5
> configure:33082: $? = 0
> configure:33099: result: none required
> configure:33170: checking which BLAS lib should be used
> configure:33172: result: system
> configure:33196: checking for FFTW
> configure:33204: $PKG_CONFIG --exists --print-errors "fftw3"
> Package fftw3 was not found in the pkg-config search path.
> Perhaps you should add the directory containing `fftw3.pc'
> to the PKG_CONFIG_PATH environment variable
> No package 'fftw3' found
> configure:33207: $? = 1
> configure:33222: $PKG_CONFIG --exists --print-errors "fftw3"
> configure:33225: $? = 1
> configure:33253: result: no
> configure:33283: checking for FFTWF
> configure:33291: $PKG_CONFIG --exists --print-errors "fftw3f"
> Package fftw3f was not found in the pkg-config search path.
> Perhaps you should add the directory containing `fftw3f.pc'
> No package 'fftw3f' found
> configure:33294: $? = 1
> configure:33309: $PKG_CONFIG --exists --print-errors "fftw3f"
> configure:33312: $? = 1
> configure:33340: result: no
> configure:33370: checking for FFTWL
> configure:33378: $PKG_CONFIG --exists --print-errors "fftw3l"
> Package fftw3l was not found in the pkg-config search path.
> Perhaps you should add the directory containing `fftw3l.pc'
> No package 'fftw3l' found
> configure:33381: $? = 1
> configure:33396: $PKG_CONFIG --exists --print-errors "fftw3l"
> configure:33399: $? = 1
> configure:33427: result: no
> configure:33523: checking for HWLOC
> configure:33531: $PKG_CONFIG --exists --print-errors "hwloc"
> configure:33534: $? = 0
> configure:33549: $PKG_CONFIG --exists --print-errors "hwloc"
> configure:33552: $? = 0
> configure:33592: result: yes
> configure:33671: checking whether hwloc_cuda_get_device_osdev_by_index is
> declared
> configure:33671: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c
> >&5
> In file included from conftest.c:89:0:
> /usr/include/hwloc/cuda.h:24:18: fatal error: cuda.h: No such file or
> directory
> #include <cuda.h>
> compilation terminated.
> configure:33671: $? = 1
> | /* confdefs.h */
> | #define STARPU_GDB_PATH "/usr/bin/gdb"
> | #define STARPU_HAVE_X11 1
> | #define STARPU_SYSTEM_BLAS 1
> | #define STARPU_HAVE_HWLOC 1
> | #include <hwloc/cuda.h>
> | int
> | main ()
> | #ifndef hwloc_cuda_get_device_osdev_by_index
> | #ifdef __cplusplus
> | (void) hwloc_cuda_get_device_osdev_by_index;
> | #else
> | #endif
> | #endif
> | return 0;
> configure:33671: result: no
> configure:33693: checking whether hwloc should be used
> configure:33695: result: yes
> configure:33700: checking f77.h usability
> configure:33700: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c
> >&5
> conftest.c:123:17: fatal error: f77.h: No such file or directory
> #include <f77.h>
> configure:33700: $? = 1
> | /* confdefs.h */
> | #define HAVE_DECL_HWLOC_CUDA_GET_DEVICE_OSDEV_BY_INDEX 0
> | #include <stdio.h>
> | #ifdef HAVE_SYS_TYPES_H
> | # include <sys/types.h>
> | #endif
> | #ifdef HAVE_SYS_STAT_H
> | # include <sys/stat.h>
> | #endif
> | #ifdef STDC_HEADERS
> | # include <stdlib.h>
> | # include <stddef.h>
> | #else
> | # ifdef HAVE_STDLIB_H
> | # endif
> | #endif
> | #ifdef HAVE_STRING_H
> | # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
> | # include <memory.h>
> | # endif
> | # include <string.h>
> | #endif
> | #ifdef HAVE_STRINGS_H
> | # include <strings.h>
> | #endif
> | #ifdef HAVE_INTTYPES_H
> | # include <inttypes.h>
> | #endif
> | #ifdef HAVE_STDINT_H
> | # include <stdint.h>
> | #endif
> | #ifdef HAVE_UNISTD_H
> | # include <unistd.h>
> | #endif
> | #include <f77.h>
> configure:33700: result: no
> configure:33700: checking f77.h presence
> configure:33700: cc -E -D_GNU_SOURCE conftest.c
> conftest.c:90:17: fatal error: f77.h: No such file or directory
> #include <f77.h>
> | /* confdefs.h */
> | #include <f77.h>
> configure:33700: checking for f77.h
> configure:33729: checking for icc
> configure:33759: result: no
> configure:33841: checking for help2man
> configure:33871: result: no
> configure:33892: checking for struct cudaDeviceProp.pciDomainID
> configure:33892: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c
> >&5
> conftest.c:91:30: fatal error: cuda_runtime_api.h: No such file or directory
> #include <cuda_runtime_api.h>
> configure:33892: $? = 1
> | /* confdefs.h */
> | #define STARPU_HAVE_FC /**/
> | int
> | main ()
> | static struct cudaDeviceProp ac_aggr;
> | if (ac_aggr.pciDomainID)
> | return 0;
> | return 0;
> >&5
> | /* confdefs.h */
> | int
> | main ()
> | if (sizeof ac_aggr.pciDomainID)
> | return 0;
> | return 0;
> configure:33892: result: no
> configure:33901: checking for struct cudaDeviceProp.pciBusID
> configure:33901: cc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c
> >&5
> configure:33901: $? = 1
> | /* confdefs.h */
> | int
> | main ()
> | if (ac_aggr.pciBusID)
> | return 0;
> | return 0;
> >&5
> | /* confdefs.h */
> | int
> | main ()
> | if (sizeof ac_aggr.pciBusID)
> | return 0;
> | return 0;
> configure:33901: result: no
> configure:33935: checking for doxygen
> configure:33953: found /usr/bin/doxygen
> configure:33965: result: /usr/bin/doxygen
> configure:33978: checking for pdflatex
> configure:34011: result: no
> configure:34021: checking for epstopdf
> configure:34054: result: no
> configure:34063: checking whether documentation should be compiled
> configure:34065: result: no
> configure:34240: checking that generated files are newer than configure
> configure:34246: result: done
> configure:34489: creating ./config.status
> ## Running config.status. ##
> This file was extended by StarPU config.status 1.2.0rc4, which was
> generated by GNU Autoconf 2.69. Invocation command line was
> CONFIG_FILES =
> CONFIG_HEADERS =
> CONFIG_LINKS =
> CONFIG_COMMANDS =
> $ ./config.status
> on nid00081
> config.status:1630: creating tests/regression/regression.sh
> config.status:1630: creating tests/regression/profiles
> config.status:1630: creating tests/regression/profiles.build.only
> config.status:1630: creating Makefile
> config.status:1630: creating src/Makefile
> config.status:1630: creating tools/Makefile
> config.status:1630: creating tools/starpu_codelet_profile
> config.status:1630: creating tools/starpu_codelet_histo_profile
> config.status:1630: creating tools/starpu_workers_activity
> config.status:1630: creating tools/starpu_paje_draw_histogram
> config.status:1630: creating tools/starpu_paje_state_stats
> config.status:1630: creating tools/starpu_paje_summary
> config.status:1630: creating tools/starpu_paje_sort
> config.status:1630: creating tools/starpu_smpirun
> config.status:1630: creating socl/Makefile
> config.status:1630: creating socl/src/Makefile
> config.status:1630: creating socl/examples/Makefile
> config.status:1630: creating socl/vendors/socl.icd
> config.status:1630: creating socl/vendors/install/socl.icd
> config.status:1630: creating libstarpu.pc
> config.status:1630: creating starpu-1.0.pc
> config.status:1630: creating starpu-1.1.pc
> config.status:1630: creating starpu-1.2.pc
> config.status:1630: creating mpi/libstarpumpi.pc
> config.status:1630: creating mpi/starpumpi-1.0.pc
> config.status:1630: creating mpi/starpumpi-1.1.pc
> config.status:1630: creating mpi/starpumpi-1.2.pc
> config.status:1630: creating starpufft/Makefile
> config.status:1630: creating starpufft/src/Makefile
> config.status:1630: creating starpufft/tests/Makefile
> config.status:1630: creating starpufft/libstarpufft.pc
> config.status:1630: creating starpufft/starpufft-1.0.pc
> config.status:1630: creating starpufft/starpufft-1.1.pc
> config.status:1630: creating starpufft/starpufft-1.2.pc
> config.status:1630: creating examples/Makefile
> config.status:1630: creating examples/stencil/Makefile
> config.status:1630: creating tests/Makefile
> config.status:1630: creating tests/loader-cross.sh
> config.status:1630: creating mpi/Makefile
> config.status:1630: creating mpi/src/Makefile
> config.status:1630: creating mpi/tests/Makefile
> config.status:1630: creating mpi/examples/Makefile
> config.status:1630: creating starpu-top/StarPU-Top.pro
> config.status:1630: creating starpu-top/StarPU-Top-qwt-embed.pri
> config.status:1630: creating starpu-top/StarPU-Top-qwt-system.pri
> config.status:1630: creating gcc-plugin/Makefile
> config.status:1630: creating gcc-plugin/src/Makefile
> config.status:1630: creating gcc-plugin/tests/Makefile
> config.status:1630: creating gcc-plugin/tests/run-test
> config.status:1630: creating gcc-plugin/examples/Makefile
> config.status:1630: creating sc_hypervisor/Makefile
> config.status:1630: creating sc_hypervisor/src/Makefile
> config.status:1630: creating sc_hypervisor/examples/Makefile
> config.status:1630: creating doc/Makefile
> config.status:1630: creating doc/doxygen/Makefile
> config.status:1630: creating doc/doxygen/doxygen-config.cfg
> config.status:1630: creating doc/doxygen/doxygen_filter.sh
> config.status:1630: creating tools/msvc/starpu_var.bat
> config.status:1630: creating src/common/config.h
> config.status:1630: creating include/starpu_config.h
> config.status:1630: creating gcc-plugin/include/starpu-gcc/config.h
> config.status:1630: creating starpu-top/config.h
> config.status:1856: linking /etc/OpenCL/vendors/nvidia.icd to
> socl/vendors/nvidia.icd
> config.status:1875: executing depfiles commands
> config.status:1875: executing libtool commands
> config.status:1875: executing executable-scripts commands
> configure:37570: WARNING: unrecognized options: --enable-mpi
> configure:37622:
> CPUs enabled: yes
> CUDA enabled: no
> OpenCL enabled: no
> SCC enabled: no
> MIC enabled: no
> Compile-time limits
> (change these with --enable-maxcpus, --enable-maxcudadev,
> --enable-maxopencldev, --enable-maxmicdev, --enable-maxnodes,
> --enable-maxbuffers)
> (Note these numbers do not represent the number of detected
> devices, but the maximum number of devices StarPU can manage)
> Maximum number of CPUs: 64
> Maximum number of CUDA devices: 0
> Maximum number of OpenCL devices: 0
> Maximum number of SCC devices: 0
> Maximum number of MIC threads: 0
> Maximum number of memory nodes: 4
> Maximum number of task buffers: 8
> GPU-GPU transfers: no
> Allocation cache: yes
> Magma enabled: no
> BLAS library: system
> hwloc: yes
> FxT trace enabled: no
> StarPU-Top: no
> Documentation: no
> Examples: yes
> StarPU Extensions:
> MPI enabled: no
> MPI test suite: no
> FFT Support: no
> GCC plug-in: no
> GCC plug-in test suite (requires GNU Guile): no
> OpenMP runtime support enabled: no
> SOCL enabled: no
> SOCL test suite: no
> Scheduler Hypervisor: no
> simgrid enabled: no
> ayudame enabled: no
> ## Cache variables. ##
> ac_cv_build=x86_64-unknown-linux-gnu
> ac_cv_c_compiler_gnu=yes
> ac_cv_c_restrict=__restrict
> ac_cv_cxx_compiler_gnu=yes
> ac_cv_env_BLAS_LIBS_set=
> ac_cv_env_BLAS_LIBS_value=
> ac_cv_env_CCC_set=
> ac_cv_env_CCC_value=
> ac_cv_env_CC_set=set
> ac_cv_env_CC_value=cc
> ac_cv_env_CFLAGS_set=
> ac_cv_env_CFLAGS_value=
> ac_cv_env_CPPFLAGS_set=
> ac_cv_env_CPPFLAGS_value=
> ac_cv_env_CPP_set=
> ac_cv_env_CPP_value=
> ac_cv_env_CXXCPP_set=
> ac_cv_env_CXXCPP_value=
> ac_cv_env_CXXFLAGS_set=
> ac_cv_env_CXXFLAGS_value=
> ac_cv_env_CXX_set=set
> ac_cv_env_CXX_value=CC
> ac_cv_env_F77_set=
> ac_cv_env_F77_value=
> ac_cv_env_FCFLAGS_set=
> ac_cv_env_FCFLAGS_value=
> ac_cv_env_FC_set=set
> ac_cv_env_FC_value=ftn
> ac_cv_env_FFLAGS_set=
> ac_cv_env_FFLAGS_value=
> ac_cv_env_FFTWF_CFLAGS_set=
> ac_cv_env_FFTWF_CFLAGS_value=
> ac_cv_env_FFTWF_LIBS_set=
> ac_cv_env_FFTWF_LIBS_value=
> ac_cv_env_FFTWL_CFLAGS_set=
> ac_cv_env_FFTWL_CFLAGS_value=
> ac_cv_env_FFTWL_LIBS_set=
> ac_cv_env_FFTWL_LIBS_value=
> ac_cv_env_FFTW_CFLAGS_set=
> ac_cv_env_FFTW_CFLAGS_value=
> ac_cv_env_FFTW_LIBS_set=
> ac_cv_env_FFTW_LIBS_value=
> ac_cv_env_FXT_CFLAGS_set=
> ac_cv_env_FXT_CFLAGS_value=
> ac_cv_env_FXT_LDFLAGS_set=
> ac_cv_env_FXT_LDFLAGS_value=
> ac_cv_env_FXT_LIBS_set=
> ac_cv_env_FXT_LIBS_value=
> ac_cv_env_HWLOC_CFLAGS_set=
> ac_cv_env_HWLOC_CFLAGS_value=
> ac_cv_env_HWLOC_LIBS_set=
> ac_cv_env_HWLOC_LIBS_value=
> ac_cv_env_LDFLAGS_set=
> ac_cv_env_LDFLAGS_value=
> ac_cv_env_LIBS_set=
> ac_cv_env_LIBS_value=
> ac_cv_env_MAGMA_CFLAGS_set=
> ac_cv_env_MAGMA_CFLAGS_value=
> ac_cv_env_MAGMA_LIBS_set=
> ac_cv_env_MAGMA_LIBS_value=
> ac_cv_env_NVCCFLAGS_set=
> ac_cv_env_NVCCFLAGS_value=
> ac_cv_env_NVCC_set=
> ac_cv_env_NVCC_value=
> ac_cv_env_PKG_CONFIG_set=
> ac_cv_env_PKG_CONFIG_value=
> ac_cv_env_POTI_CFLAGS_set=
> ac_cv_env_POTI_CFLAGS_value=
> ac_cv_env_POTI_LIBS_set=
> ac_cv_env_POTI_LIBS_value=
> ac_cv_env_STARPU_MS_LIB_set=
> ac_cv_env_STARPU_MS_LIB_value=
> ac_cv_env_XMKMF_set=
> ac_cv_env_XMKMF_value=
> ac_cv_env_build_alias_set=
> ac_cv_env_build_alias_value=
> ac_cv_env_host_alias_set=
> ac_cv_env_host_alias_value=
> ac_cv_env_target_alias_set=
> ac_cv_env_target_alias_value=
> ac_cv_f77_compiler_gnu=yes
> ac_cv_fc_compiler_gnu=yes
> ac_cv_func_clock_gettime=yes
> ac_cv_func_connect=yes
> ac_cv_func_drand48=yes
> ac_cv_func_erand48_r=yes
> ac_cv_func_gethostbyname=yes
> ac_cv_func_memalign=yes
> ac_cv_func_mkostemp=yes
> ac_cv_func_nearbyintf=yes
> ac_cv_func_posix_memalign=yes
> ac_cv_func_pread=yes
> ac_cv_func_pthread_barrier_init=yes
> ac_cv_func_pthread_setaffinity_np=yes
> ac_cv_func_pthread_spin_lock=yes
> ac_cv_func_pwrite=yes
> ac_cv_func_remove=yes
> ac_cv_func_rintf=yes
> ac_cv_func_sched_yield=yes
> ac_cv_func_setenv=yes
> ac_cv_func_shmat=yes
> ac_cv_func_strerror_r=yes
> ac_cv_func_sysconf=yes
> ac_cv_func_unsetenv=yes
> ac_cv_have_decl_hwloc_cuda_get_device_osdev_by_index=no
> ac_cv_have_gcc_plugins=no
> ac_cv_have_sync_bool_compare_and_swap=yes
> ac_cv_have_sync_fetch_and_add=yes
> ac_cv_have_sync_fetch_and_or=yes
> ac_cv_have_sync_lock_test_and_set=yes
> ac_cv_have_sync_synchronize=yes
> ac_cv_have_sync_val_compare_and_swap=yes
> ac_cv_have_x='have_x=yes ac_x_includes='\'''\''
> ac_x_libraries='\'''\'''
> ac_cv_header_Ayudame_h=no
> ac_cv_header_RCCE_h=no
> ac_cv_header_aio_h=yes
> ac_cv_header_dlfcn_h=yes
> ac_cv_header_f77_h=no
> ac_cv_header_glpk_h=no
> ac_cv_header_inttypes_h=yes
> ac_cv_header_leveldb_db_h=no
> ac_cv_header_malloc_h=yes
> ac_cv_header_memory_h=yes
> ac_cv_header_stdc=yes
> ac_cv_header_stdint_h=yes
> ac_cv_header_stdlib_h=yes
> ac_cv_header_string_h=yes
> ac_cv_header_strings_h=yes
> ac_cv_header_sys_stat_h=yes
> ac_cv_header_sys_types_h=yes
> ac_cv_header_unistd_h=yes
> ac_cv_header_valgrind_helgrind_h=no
> ac_cv_header_valgrind_memcheck_h=no
> ac_cv_header_valgrind_valgrind_h=no
> ac_cv_host=x86_64-unknown-linux-gnu
> ac_cv_lib_ICE_IceConnectionNumber=yes
> ac_cv_lib_RCCE_bigflags_nongory_nopwrmgmt_RCCE_init=no
> ac_cv_lib_glpk_main=no
> ac_cv_lib_leveldb_main=no
> ac_cv_lib_pthread_pthread_create=yes
> ac_cv_lib_rt_clock_gettime=yes
> ac_cv_lib_ws2_32=ac_cv_lib_ws2_32_main
> ac_cv_lib_ws2_32_main=no
> ac_cv_member_struct_cudaDeviceProp_pciBusID=no
> ac_cv_member_struct_cudaDeviceProp_pciDomainID=no
> ac_cv_objext=o
> ac_cv_path_EGREP='/usr/bin/grep -E'
> ac_cv_path_FGREP='/usr/bin/grep -F'
> ac_cv_path_GDB=/usr/bin/gdb
> ac_cv_path_GREP=/usr/bin/grep
> ac_cv_path_QMAKE=/usr/bin/qmake
> ac_cv_path_SED=/usr/bin/sed
> ac_cv_path_ac_pt_PKG_CONFIG=/usr/bin/pkg-config
> ac_cv_path_doxygencommand=/usr/bin/doxygen
> ac_cv_path_install='/usr/bin/install -c'
> ac_cv_path_mkdir=/bin/mkdir
> ac_cv_path_mpiexec_path=/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/mpiexec
> ac_cv_path_svncommand=/usr/bin/svn
> ac_cv_path_svnversioncommand=/usr/bin/svnversion
> ac_cv_prog_AWK=gawk
> ac_cv_prog_BASH=/bin/sh
> ac_cv_prog_CPP='cc -E'
> ac_cv_prog_CXXCPP='CC -E'
> ac_cv_prog_PROG_DATE=date
> ac_cv_prog_PROG_STAT=stat
> ac_cv_prog_ac_ct_AR=ar
> ac_cv_prog_ac_ct_CC=cc
> ac_cv_prog_ac_ct_F77=gfortran
> ac_cv_prog_ac_ct_MANIFEST_TOOL=mt
> ac_cv_prog_ac_ct_OBJDUMP=objdump
> ac_cv_prog_ac_ct_RANLIB=ranlib
> ac_cv_prog_ac_ct_STRIP=strip
> ac_cv_prog_cc_c89=
> ac_cv_prog_cc_g=yes
> ac_cv_prog_cxx_g=yes
> ac_cv_prog_f77_g=yes
> ac_cv_prog_fc_g=yes
> ac_cv_prog_make_make_set=yes
> ac_cv_search_set_mempolicy=-lnuma
> ac_cv_search_sgemm_='none required'
> ac_cv_search_sqrt='none required'
> ac_cv_sizeof_void_p=8
> ac_cv_target=x86_64-unknown-linux-gnu
> ac_cv_type_cufftDoubleComplex=no
> ac_cv_type_struct_timespec=yes
> am_cv_CC_dependencies_compiler_type=gcc3
> am_cv_CXX_dependencies_compiler_type=gcc3
> am_cv_ar_interface=ar
> am_cv_make_support_nested_variables=yes
> am_cv_prog_cc_c_o=yes
> lt_cv_ar_at_file=@
> lt_cv_archive_cmds_need_lc=no
> lt_cv_deplibs_check_method=pass_all
> lt_cv_file_magic_cmd='$MAGIC_CMD'
> lt_cv_file_magic_test_file=
> lt_cv_ld_reload_flag=-r
> lt_cv_nm_interface='BSD nm'
> lt_cv_objdir=.libs
> lt_cv_path_LD=/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld
> lt_cv_path_LDCXX='/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld -m
> elf_x86_64'
> lt_cv_path_NM='/usr/bin/nm -B'
> lt_cv_path_mainfest_tool=no
> lt_cv_prog_compiler_c_o=yes
> lt_cv_prog_compiler_c_o_CXX=yes
> lt_cv_prog_compiler_c_o_F77=yes
> lt_cv_prog_compiler_c_o_FC=yes
> lt_cv_prog_compiler_pic='-fPIC -DPIC'
> lt_cv_prog_compiler_pic_CXX='-fPIC -DPIC'
> lt_cv_prog_compiler_pic_F77=-fPIC
> lt_cv_prog_compiler_pic_FC=-fPIC
> lt_cv_prog_compiler_pic_works=yes
> lt_cv_prog_compiler_pic_works_CXX=yes
> lt_cv_prog_compiler_pic_works_F77=yes
> lt_cv_prog_compiler_pic_works_FC=yes
> lt_cv_prog_compiler_rtti_exceptions=no
> lt_cv_prog_compiler_static_works=yes
> lt_cv_prog_compiler_static_works_CXX=yes
> lt_cv_prog_compiler_static_works_F77=yes
> lt_cv_prog_compiler_static_works_FC=yes
> lt_cv_prog_gnu_ld=yes
> lt_cv_prog_gnu_ldcxx=yes
> lt_cv_sharedlib_from_linklib_cmd='printf %s\n'
> lt_cv_shlibpath_overrides_runpath=yes
> lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[
> ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][
> ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed '\''/ __gnu_lto/d'\'''
> lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\)[
> ]*$/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^
> ]*\)$/ {"\2", (void *) \&\2},/p'\'''
> lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^:
> \([^ ]*\)[ ]*$/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^
> ]*\) \(lib[^ ]*\)$/ {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRSTW]*
> \([^ ]*\) \([^ ]*\)$/ {"lib\2", (void *) \&\2},/p'\'''
> lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int
> \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''
> lt_cv_sys_max_cmd_len=1572864
> lt_cv_to_host_file_cmd=func_convert_file_noop
> lt_cv_to_tool_file_cmd=func_convert_file_noop
> pkg_cv_HWLOC_CFLAGS='-I/project/k1044/favergm/opt-gcc/hwloc-1.11.1/include '
> pkg_cv_HWLOC_LIBS='-L/project/k1044/favergm/opt-gcc/hwloc-1.11.1/lib
> -lhwloc '
> ## Output variables. ##
> ACLOCAL='${SHELL}
> /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux/missing aclocal-1.14'
> AMDEPBACKSLASH='\'
> AMDEP_FALSE='#'
> AMDEP_TRUE=''
> AMTAR='$${TAR-tar}'
> AM_BACKSLASH='\'
> AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
> AM_DEFAULT_VERBOSITY='0'
> AM_V='$(V)'
> AR='ar'
> AS='as'
> ATLASDIR=''
> ATLAS_BLAS_LIB_FALSE=''
> ATLAS_BLAS_LIB_TRUE='#'
> AUTOCONF='${SHELL}
> /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux/missing autoconf'
> AUTOHEADER='${SHELL}
> /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux/missing autoheader'
> AUTOMAKE='${SHELL}
> /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux/missing automake-1.14'
> AWK='gawk'
> BASH='/bin/sh'
> BLAS_LIB='system'
> BLAS_LIBS=''
> BUILD_DOC_FALSE=''
> BUILD_DOC_TRUE='#'
> BUILD_EXAMPLES_FALSE='#'
> BUILD_EXAMPLES_TRUE=''
> BUILD_GCC_PLUGIN_FALSE=''
> BUILD_GCC_PLUGIN_TRUE='#'
> BUILD_SOCL_FALSE=''
> BUILD_SOCL_TRUE='#'
> BUILD_STARPUFFT_EXAMPLES_FALSE=''
> BUILD_STARPUFFT_EXAMPLES_TRUE='#'
> BUILD_STARPUFFT_FALSE=''
> BUILD_STARPUFFT_TRUE='#'
> BUILD_STARPU_TOP_FALSE=''
> BUILD_STARPU_TOP_TRUE='#'
> CC='cc'
> CCDEPMODE='depmode=gcc3'
> CC_OR_MPICC='cc'
> CFLAGS='-O3 -g -O2 -gdwarf-2 -g3 '
> COVERAGE='no'
> CPP='cc -E'
> CPPFLAGS=' -D_GNU_SOURCE '
> CXX='CC'
> CXXCPP='CC -E'
> CXXDEPMODE='depmode=gcc3'
> CXXFLAGS='-O3 -g -O2 -gdwarf-2 -g3 '
> CYGPATH_W='echo'
> DEFS='-DHAVE_CONFIG_H'
> DEPDIR='.deps'
> DLLTOOL='false'
> DSYMUTIL=''
> DUMPBIN=''
> ECHO_C=''
> ECHO_N='-n'
> ECHO_T=''
> EXEEXT=''
> F77='gfortran'
> FC='ftn'
> FCFLAGS='-g -O2'
> FFLAGS='-g -O2'
> FFTWF_CFLAGS=''
> FFTWF_LIBS=''
> FFTWL_CFLAGS=''
> FFTWL_LIBS=''
> FFTW_CFLAGS=''
> FFTW_LIBS=''
> FXTDIR=''
> FXT_CFLAGS=''
> FXT_LDFLAGS=''
> FXT_LIBS=''
> GCC_FOR_PLUGIN=''
> GCC_FOR_PLUGIN_LIBTOOL_TAG=''
> GCC_PLUGIN_DIR_PKGCONFIG=''
> GCC_PLUGIN_INCLUDE_DIR='/opt/gcc/4.9.3/snos/lib/gcc/x86_64-suse-linux/4.9.3/plugin/include'
> GCC_PLUGIN_PKGCONFIG=''
> GDB='/usr/bin/gdb'
> GLOBAL_AM_CFLAGS=' -Wall -Werror=implicit
> -Werror=implicit-function-declaration'
> GOTODIR=''
> GOTO_BLAS_LIB_FALSE=''
> GOTO_BLAS_LIB_TRUE='#'
> GREP='/usr/bin/grep'
> GUILE=''
> HAVE_FFTWFL=''
> HAVE_OPENGL_FALSE=''
> HAVE_OPENGL_TRUE='#'
> HAVE_PTR_DEREFS_MAY_ALIAS_P_FALSE=''
> HAVE_PTR_DEREFS_MAY_ALIAS_P_TRUE='#'
> HAVE_X11_FALSE='#'
> HAVE_X11_TRUE=''
> HELP2MAN=''
> HWLOC_LIBS='-L/project/k1044/favergm/opt-gcc/hwloc-1.11.1/lib -lhwloc '
> HWLOC_REQUIRES='hwloc'
> ICC=''
> INSTALL_DATA='${INSTALL} -m 644'
> INSTALL_PROGRAM='${INSTALL}'
> INSTALL_SCRIPT='${INSTALL}'
> INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
> LD='/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/ld -m elf_x86_64'
> LDFLAGS=''
> LIBOBJS=''
> LIBS='-lrt -lpthread '
> LIBSOCL_INTERFACE_AGE='0'
> LIBSOCL_INTERFACE_CURRENT='0'
> LIBSOCL_INTERFACE_REVISION='0'
> LIBSTARPUFFT_INTERFACE_AGE='0'
> LIBSTARPUFFT_INTERFACE_CURRENT='0'
> LIBSTARPUFFT_INTERFACE_REVISION='0'
> LIBSTARPUMPI_INTERFACE_AGE='0'
> LIBSTARPUMPI_INTERFACE_CURRENT='1'
> LIBSTARPUMPI_INTERFACE_REVISION='1'
> LIBSTARPU_INTERFACE_AGE='0'
> LIBSTARPU_INTERFACE_CURRENT='3'
> LIBSTARPU_INTERFACE_REVISION='0'
> LIBSTARPU_LDFLAGS=' '
> LIBSTARPU_LINK='libstarpu-1.2.la'
> LIBTOOL='$(SHELL) $(top_builddir)/libtool'
> LIPO=''
> LN_S='ln -s'
> LTLIBOBJS=''
> MAGMA_CFLAGS=''
> MAGMA_LIBS=''
> MAKEINFO='${SHELL}
> /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux/missing makeinfo'
> MANIFEST_TOOL=':'
> MKDIR_P='/bin/mkdir -p'
> MKL_BLAS_LIB_FALSE=''
> MKL_BLAS_LIB_TRUE='#'
> MPICC='cc'
> MPICC_LDFLAGS=''
> MPIEXEC=''
> NM='/usr/bin/nm -B'
> NMEDIT=''
> NO_BLAS_LIB_FALSE=''
> NO_BLAS_LIB_TRUE='#'
> NVCC=''
> NVCCFLAGS=''
> OBJDUMP='objdump'
> OBJEXT='o'
> OTOOL64=''
> OTOOL=''
> PACKAGE='starpu'
> PACKAGE_BUGREPORT='starpu-devel@lists.gforge.inria.fr'
> PACKAGE_NAME='StarPU'
> PACKAGE_STRING='StarPU 1.2.0rc4'
> PACKAGE_TARNAME='starpu'
> PACKAGE_URL='http://runtime.bordeaux.inria.fr/StarPU/'
> PACKAGE_VERSION='1.2.0rc4'
> PATH_SEPARATOR=':'
> PKG_CONFIG='/usr/bin/pkg-config'
> POTI_CFLAGS=''
> POTI_LIBS=''
> PROG_DATE='date'
> PROG_STAT='stat'
> QMAKE='/usr/bin/qmake'
> QWT_PRI='embed'
> RANLIB='ranlib'
> RUN_GCC_PLUGIN_TESTS_FALSE=''
> RUN_GCC_PLUGIN_TESTS_TRUE='#'
> SED='/usr/bin/sed'
> SET_MAKE=''
> SHELL='/bin/sh'
> SIMGRID_CFLAGS=''
> SIMGRID_LIBS=''
> SOCL_OCL_LIB_OPENCL_DIR=''
> SOCL_VENDORS='vendors/install/socl.icd vendors/nvidia.icd'
> STARPU_BLAS_LDFLAGS=' '
> STARPU_BUILD_DIR='/project/k1044/favergm/src/starpu-1.2.0rc4'
> STARPU_BUILD_SC_HYPERVISOR_FALSE=''
> STARPU_BUILD_SC_HYPERVISOR_TRUE='#'
> STARPU_COI_CPPFLAGS=''
> STARPU_COI_LDFLAGS=''
> STARPU_COVERAGE_ENABLED_FALSE=''
> STARPU_COVERAGE_ENABLED_TRUE='#'
> STARPU_CROSS_COMPILING_FALSE=''
> STARPU_CROSS_COMPILING_TRUE='#'
> STARPU_CUDA_CPPFLAGS=''
> STARPU_CUDA_FORTRAN_LDFLAGS=''
> STARPU_CUDA_LDFLAGS=''
> STARPU_CUFFT_LDFLAGS=''
> STARPU_CURAND_LDFLAGS=''
> STARPU_DEVEL_FALSE=''
> STARPU_DEVEL_TRUE='#'
> STARPU_EFFECTIVE_VERSION='1.2'
> STARPU_ENABLE_STATS='no'
> STARPU_EXPORT_DYNAMIC='-rdynamic'
> STARPU_GCC_VERSION_MAJOR=''
> STARPU_GCC_VERSION_MINOR=''
> STARPU_GLPK_LDFLAGS=' '
> STARPU_HAVE_AM111_FALSE='#'
> STARPU_HAVE_AM111_TRUE=''
> STARPU_HAVE_CUFFTDOUBLECOMPLEX_FALSE=''
> STARPU_HAVE_CUFFTDOUBLECOMPLEX_TRUE='#'
> STARPU_HAVE_F77_H='no'
> STARPU_HAVE_F77_H_FALSE=''
> STARPU_HAVE_F77_H_TRUE='#'
> STARPU_HAVE_FC_FALSE='#'
> STARPU_HAVE_FC_TRUE=''
> STARPU_HAVE_FFTW=''
> STARPU_HAVE_FFTWF=''
> STARPU_HAVE_FFTWF_FALSE=''
> STARPU_HAVE_FFTWF_TRUE='#'
> STARPU_HAVE_FFTWL_FALSE=''
> STARPU_HAVE_FFTWL_TRUE='#'
> STARPU_HAVE_FFTW_FALSE=''
> STARPU_HAVE_FFTW_TRUE='#'
> STARPU_HAVE_HELP2MAN_FALSE=''
> STARPU_HAVE_HELP2MAN_TRUE='#'
> STARPU_HAVE_HWLOC='1'
> STARPU_HAVE_ICC_FALSE=''
> STARPU_HAVE_ICC_TRUE='#'
> STARPU_HAVE_LEVELDB_FALSE=''
> STARPU_HAVE_LEVELDB_TRUE='#'
> STARPU_HAVE_MAGMA=''
> STARPU_HAVE_MAGMA_FALSE=''
> STARPU_HAVE_MAGMA_TRUE='#'
> STARPU_HAVE_MS_LIB_FALSE=''
> STARPU_HAVE_MS_LIB_TRUE='#'
> STARPU_HAVE_WINDOWS_FALSE=''
> STARPU_HAVE_WINDOWS_TRUE='#'
> STARPU_LEVELDB_LDFLAGS=' '
> STARPU_LIBNUMA_LDFLAGS=' -lnuma '
> STARPU_LINUX_SYS_FALSE='#'
> STARPU_LINUX_SYS_TRUE=''
> STARPU_LONG_CHECK_FALSE=''
> STARPU_LONG_CHECK_TRUE='#'
> STARPU_MAJOR_VERSION='1'
> STARPU_MINOR_VERSION='2'
> STARPU_MPI_CHECK_FALSE=''
> STARPU_MPI_CHECK_TRUE='#'
> STARPU_MS_LIB=''
> STARPU_MS_LIB_ARCH='X64'
> STARPU_NEW_CHECK_FALSE=''
> STARPU_NEW_CHECK_TRUE='#'
> STARPU_OPENCL_CPPFLAGS=''
> STARPU_OPENCL_DATAdir=''
> STARPU_OPENCL_LDFLAGS=''
> STARPU_OPENGL_RENDER='no'
> STARPU_OPENGL_RENDER_LDFLAGS=''
> STARPU_OPENMP_FALSE=''
> STARPU_OPENMP_TRUE='#'
> STARPU_PERF_DEBUG='no'
> STARPU_QUICK_CHECK_FALSE=''
> STARPU_QUICK_CHECK_TRUE='#'
> STARPU_QWT_INCLUDE=''
> STARPU_QWT_LDFLAGS=''
> STARPU_RCCE_CFLAGS=''
> STARPU_RCCE_CPPFLAGS=''
> STARPU_RCCE_LDFLAGS=''
> STARPU_RELEASE_VERSION='0'
> STARPU_SANITIZE_FALSE=''
> STARPU_SANITIZE_TRUE='#'
> STARPU_SCIF_CPPFLAGS=''
> STARPU_SCIF_LDFLAGS=''
> STARPU_SC_HYPERVISOR=''
> STARPU_SC_HYPERVISOR_DEBUG='no'
> STARPU_SC_HYPERVISOR_DEBUG_FALSE=''
> STARPU_SC_HYPERVISOR_DEBUG_TRUE='#'
> STARPU_SIMGRID_FALSE=''
> STARPU_SIMGRID_TRUE='#'
> STARPU_SRC_DIR='/lustre/project/k1044/favergm/src/starpu-1.2.0rc4/.'
> STARPU_USE_CPU='yes'
> STARPU_USE_CPU_FALSE='#'
> STARPU_USE_CPU_TRUE=''
> STARPU_USE_CUDA='no'
> STARPU_USE_CUDA_FALSE=''
> STARPU_USE_CUDA_TRUE='#'
> STARPU_USE_FXT='no'
> STARPU_USE_FXT_FALSE=''
> STARPU_USE_FXT_TRUE='#'
> STARPU_USE_MIC_FALSE=''
> STARPU_USE_MIC_TRUE='#'
> STARPU_USE_MP_FALSE='#'
> STARPU_USE_MP_TRUE=''
> STARPU_USE_OPENCL='no'
> STARPU_USE_OPENCL_FALSE=''
> STARPU_USE_OPENCL_TRUE='#'
> STARPU_USE_SCC_FALSE=''
> STARPU_USE_SCC_TRUE='#'
> STARPU_USE_SC_HYPERVISOR_FALSE=''
> STARPU_USE_SC_HYPERVISOR_TRUE='#'
> STARPU_USE_SOCL_FALSE=''
> STARPU_USE_SOCL_TRUE='#'
> STARPU_USE_TOP='no'
> STATS='no'
> STRIP='strip'
> SYSTEM_BLAS_LIB_FALSE='#'
> SYSTEM_BLAS_LIB_TRUE=''
> USE_MPI='no'
> USE_MPI_FALSE=''
> USE_MPI_TRUE='#'
> VERSION='1.2.0rc4'
> XMKMF=''
> X_CFLAGS=''
> X_EXTRA_LIBS=''
> X_LIBS=''
> X_PRE_LIBS=' -lSM -lICE'
> YACC='${SHELL} /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux/missing
> bison'
> ac_ct_AR='ar'
> ac_ct_CC='cc'
> ac_ct_CXX=''
> ac_ct_DUMPBIN=''
> ac_ct_F77='gfortran'
> ac_ct_FC=''
> am__EXEEXT_FALSE=''
> am__EXEEXT_TRUE='#'
> am__fastdepCC_FALSE='#'
> am__fastdepCC_TRUE=''
> am__fastdepCXX_FALSE='#'
> am__fastdepCXX_TRUE=''
> am__include='include'
> am__isrc=' -I$(srcdir)'
> am__leading_dot='.'
> am__nodep='_no'
> am__quote=''
> am__tar='$${TAR-tar} chof - "$$tardir"'
> am__untar='$${TAR-tar} xf -'
> bindir='${exec_prefix}/bin'
> build='x86_64-unknown-linux-gnu'
> build_alias=''
> build_cpu='x86_64'
> build_os='linux-gnu'
> build_vendor='unknown'
> datadir='${datarootdir}'
> datarootdir='${prefix}/share'
> docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
> doxygencommand='/usr/bin/doxygen'
> dvidir='${docdir}'
> epstopdfcommand=''
> exec_prefix='${prefix}'
> gccplugindir=''
> host='x86_64-unknown-linux-gnu'
> host_alias=''
> host_cpu='x86_64'
> host_os='linux-gnu'
> host_vendor='unknown'
> htmldir='${docdir}'
> includedir='${prefix}/include'
> infodir='${datarootdir}/info'
> install_sh='${SHELL}
> /project/k1044/favergm/src/starpu-1.2.0rc4/build-aux/install-sh'
> libdir='${exec_prefix}/lib'
> libexecdir='${exec_prefix}/libexec'
> localedir='${datarootdir}/locale'
> localstatedir='${prefix}/var'
> mandir='${datarootdir}/man'
> mkdir_p='$(MKDIR_P)'
> mpicc_path='cc'
> mpiexec_path='/sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/mpiexec'
> oldincludedir='/usr/include'
> pdfdir='${docdir}'
> pdflatexcommand=''
> pkglibdir='${libdir}/starpu'
> prefix='/project/k1044/favergm/opt-gcc/starpu-1.2.0rc4'
> program_transform_name='s,x,x,'
> psdir='${docdir}'
> sbindir='${exec_prefix}/sbin'
> sharedstatedir='${prefix}/com'
> smpirun_path=''
> svncommand='/usr/bin/svn'
> svnversioncommand='/usr/bin/svnversion'
> sysconfdir='${prefix}/etc'
> target='x86_64-unknown-linux-gnu'
> target_alias=''
> target_cpu='x86_64'
> target_os='linux-gnu'
> target_vendor='unknown'
> ## confdefs.h. ##
> /* confdefs.h */
> #define STARPU_SRC_DIR "/lustre/project/k1044/favergm/src/starpu-1.2.0rc4/."
> configure: exit 0
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Dr Nathalie Furmento Ingénieur de recherche CNRS
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
- [Starpu-devel] Cannot find MPI, Mathieu Faverge, 15/11/2015
- Re: [Starpu-devel] Cannot find MPI, Nathalie Furmento, 16/11/2015
- Re: [Starpu-devel] Cannot find MPI, Mathieu Faverge, 16/11/2015
