Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Cannot find MPI
- Date: Mon, 16 Nov 2015 11:54:15 +0300
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
The -x test is definitely not the first
one.
> grep mpicc configure mpicc_path with_mpicc --with-mpicc=<path to mpicc> Path of the mpicc compiler # Check whether --with-mpicc was given. if test "${with_mpicc+set}" = set; then : withval=$with_mpicc; as_fn_error $? "--with-mpicc must be given a pathname" "$LINENO" 5 mpicc_path=$withval DEFAULT_MPICC=smpicc DEFAULT_MPICC=mpicc if ${ac_cv_path_mpicc_path+:} false; then : case $mpicc_path in ac_cv_path_mpicc_path="$mpicc_path" # Let the user override the test with a path. ac_cv_path_mpicc_path="$as_dir/$ac_word$ac_exec_ext" test -z "$ac_cv_path_mpicc_path" && ac_cv_path_mpicc_path="no" mpicc_path=$ac_cv_path_mpicc_path if test -n "$mpicc_path"; then { $as_echo "$as_me:${as_lineno-$LINENO}: result: $mpicc_path" >&5 $as_echo "$mpicc_path" >&6; } $as_echo "MPICC: $mpicc_path" >&1 if test ! -x $mpicc_path; then { $as_echo "$as_me:${as_lineno-$LINENO}: result: The mpicc compiler is not valid" >&5 $as_echo "The mpicc compiler is not valid" >&6; } { $as_echo "$as_me:${as_lineno-$LINENO}: checking mpicc path" >&5 $as_echo_n "checking mpicc path... " >&6; } { $as_echo "$as_me:${as_lineno-$LINENO}: result: $mpicc_path" >&5 $as_echo "$mpicc_path" >&6; } MPICC=$mpicc_path cc_or_mpicc=$mpicc_path # For some reason, libtool uses gcc instead of mpicc when linking MPICC_LDFLAGS=`$mpicc_path --showme:link` cc_or_mpicc=$CC CC_OR_MPICC=$cc_or_mpicc as_dummy="$(dirname $mpicc_path):$PATH" Le 16/11/2015 11:36, Nathalie Furmento a écrit : 56499581.9060509@labri.fr"> -- -- Mathieu Faverge Maitre de conférence / Assistant Professor Institut Polytechnique de Bordeaux - ENSEIRB-Matmeca INRIA Bordeaux - Sud-Ouest, HiePACS Team 200 avenue de la vielle tour 33405 Talence Cedex Phone: (+33) 5 24 57 40 73 |
- [Starpu-devel] Cannot find MPI, Mathieu Faverge, 15/11/2015
- Re: [Starpu-devel] Cannot find MPI, Nathalie Furmento, 16/11/2015
- Re: [Starpu-devel] Cannot find MPI, Mathieu Faverge, 16/11/2015
