Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Cannot find MPI
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Cannot find MPI
  • Date: Mon, 16 Nov 2015 11:32:48 +0300
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
I printed the value of $mpicc_path:
MPICC: no
Mathieu
Le 16/11/2015 11:20, Mathieu Faverge a écrit :
564991D1.1050107@inria.fr">
Hello,
whatever I do, mpicc or not, it is always the same result: MPI is disabled.
Mathieu
Le 16/11/2015 10:55, Nathalie Furmento a écrit :
Hi Mathieu,
configure only checks if the MPI compiler is executable.
if test ! -x $mpicc_path; then
	AC_MSG_RESULT(The mpicc compiler is not valid)
You should change the message below the if
to print the value of $mpicc_path.
Ah, i just saw you specified a value to --with-mpicc, you
should not need to do that. It looks like your system is
finding a MPI runtime in /sw/xc40/xalt/0.5.4/sles11.3_gnu4.9.2/bin/
Cheers,
Nathalie
On Nov 15, 11:26, Mathieu Faverge wrote:
> Hello,
> Any ideas why I always get :
>     StarPU Extensions:
>            MPI enabled:                                 no
> I don't see why the test fails.
> Mathieu
Mathieu Faverge
Maitre de conférence / Assistant Professor
Institut Polytechnique de Bordeaux - ENSEIRB-Matmeca
INRIA Bordeaux - Sud-Ouest, HiePACS Team
200 avenue de la vielle tour
33405 Talence Cedex
Phone: (+33) 5 24 57 40 73
Mathieu Faverge
33405 Talence Cedex
Haut de le page
