Archives de la liste
- To: Fangli Pi <hpcfapix@hlrs.de>
- Cc: starpu-devel <starpu-devel@lists.gforge.inria.fr>, Dennis Hoppe <dennis.hoppe@hlrs.de>, Dmitry Khabi <khabi@hlrs.de>, Michael Gienger <gienger@hlrs.de>
- Subject: Re: [Starpu-devel] Fwd: Strong interest in contributions and integrations
- Date: Tue, 24 May 2016 14:16:31 +0200 (CEST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
----- Mail original -----
> De: "Fangli Pi" <hpcfapix@hlrs.de>
> À: "Andra Hugo" <andra.hugo@inria.fr>
> Cc: "starpu-devel" <starpu-devel@lists.gforge.inria.fr>, "Dennis Hoppe"
> <dennis.hoppe@hlrs.de>, "Dmitry Khabi"
> <khabi@hlrs.de>, "Michael Gienger" <gienger@hlrs.de>
> Envoyé: Lundi 23 Mai 2016 17:26:01
> Objet: Re: [Starpu-devel] Fwd: Strong interest in contributions and
> integrations
> Hi Andra,
> Thanks very much for your reply. Although I cannot answer all the questions
> right now, they are all very valuable and we will take time to try to
> implement towards the direction.
> Following what I can answer now:
> 1. I did feed energy in Joule back to the profiling_info->power_consumed.
> Because in StarPU handbook, it is written that "double
> starpu_task_expected_power() returns expected power consumption in J", and I
> thought that they need to be consistent. (Am I right?)
Yes indeed, as Sam said it might be a bad naming in starpu.
> 2. I didn't use directly the time (start_time, submit_time, etc.) in the
> profiling_info because these times are relative to the initialization time
> of StarPU, however I need the absolute date and time. If StarPU could
> provide this, it would be great.
I see
> 3, 4, 5, 6. It is helpful to get these reviews and I will make changes
> accordingly in soon.
> 7. The calls to sleep is due to the delay of communication and the database.
> I will try to reduce these by increase the update rate of the database.
> 8. The monitoring framework we use is a light-weight and near-real time
> tool.
> There is one paper introducing it and one paragraph about overhead measuring
> is included. Please find the paper in the attachment. Since the monitoring
> framework is still under development, its updated overhead (for papi-based
> plugin) is reduced from 2.0%+ to 1.7%+ for an update rate of 100ms, and from
> 18.1% to 14.2% for an update rate of 10ms.
> 9. It is true that the energy measurement cannot separate for different CPU
> cores, so that if multiple tasks are executed in parallel, the finally
> retrieved energy data is the energy consumed for all CPU and GPU. One
> possible solution could be that a task which power data are profiled and
> power model is calibrating is considered to be in a training mode rather
> than an executing mode, and the tasks can only be executed asynchronously.
> Once the tasks are calibrated, it is possible to execute them in parallel.
> 10. This is an interesting point, which we haven't thought before. Maybe we
> can have a study of starpu threads first and see how hard it is to modify
> the monitoring framework according. It would also be nice if you could
> provide more info in this direction.
> All in all, I will update the repo according to your reviews and I will let
> you know once it is ready.
> Best regards,
> Fangli
> ----- Original Message -----
> From: "Andra Hugo" <andra.hugo@inria.fr>
> To: "Fangli Pi" <hpcfapix@hlrs.de>
> <dennis.hoppe@hlrs.de>, "Dmitry Khabi" <khabi@hlrs.de>, "Michael Gienger"
> <gienger@hlrs.de>
> Sent: Monday, May 23, 2016 12:07:12 PM
> integrations
> Hi Fangli,
> I looked into the code you provided and I have a few suggestions/questions.
> I
> will separate them in 2 parts. Let me know if it makes sense and if I can
> help with anything.
> A. Code reviewing
> 1. Do you measure energy or power? Maybe the field names don't match
> properly(you store the energy value in the power field).
> 2. The task already has a structure called profiling_info that has different
> fields (start_time, submit_time, etc.), no need to add one per job
> 3. We have a source file with some general functions used by all the drivers
> driver_common.c, here we update all the profiling information, and it would
> be a more appropriate place to update the energy and avoid code replication.
> 4. It would be good to have a configure option that activates this
> measurements when the user requires them
> 5. It would be maybe better to integrate the code of ex_starpu_ini in
> starpu_profiling_init. I am however a little bit worried about interfering
> with the application's cmd line parameters. We usually use env variables for
> runtime options for starpu.
> 6. It might be unnecessary overhead to count all the sockets at each time
> you
> measure the power, they won't change their number at runtime (I don't think
> starpu deals with any fault tolerance problems).
> 7. In starpu_ex.c there are some calls to sleep, are they really necessary?
> B. Performance
> 8. Do you have some measurements or a paper that shows the overhead of your
> approach? The client-server communication seams a lot of overhead added
> exactly when we pop tasks which is the most performance sensitive part of
> starpu.
> 9. It seams that you measure the power of all CPU cores and GPUs after the
> execution of each task (ex_starpu_get_power(j->ex_start_ts, j->ex_end_ts,
> ALL_POWER))). Am I correct? How does this work for a parallel application,
> when anther processor executes another task?
> 10. This is more like a suggestion: In order to monitor the processors you
> create a set of threads to take care of this. StarPU also has its own set of
> threads. Leaving the OS deal with the context switch might affect
> performance. Did you consider maybe using starpu's threads instead? I
> understand that your approach client server is definitely a better software
> engineering solution, and it can then be easily integrated in any software
> without modifying the code, but the overhead might be significant.
> That's all I can see for now. Please let me know if you have any questions
> or
> if I can help in any way.
> Best,
> Andra
> > À: starpu-devel@lists.gforge.inria.fr
> > Cc: "Dennis Hoppe" <dennis.hoppe@hlrs.de>, "Dmitry Khabi" <khabi@hlrs.de>,
> > Envoyé: Lundi 9 Mai 2016 12:15:03
> > Objet: [Starpu-devel] Fwd: Strong interest in contributions and
> > integrations
> > Dear StarPU devel-group,
> > Sorry for bothering you again with my mail sent two weeks ago.
> > Being afraid that there will be delays due to mail barriers or holidays
> > during these two weeks, I would here restate my deep interest in
> > contributing in StarPU by our project team.
> > In these two weeks we have succeed in integrating the energy measurements
> > in
> > StarPU (version 1.2.0rc5) for cpu drivers (first step towards the
> > integration). Changes based on StarPU source can be found in the following
> > link:
> > http://gitlab.excess-project.eu/hpcfapix/starpu-ex-1-2-0rc5.git
> > We are now keeping the development private and it would be grateful to get
> > your permission to make it public after all development is done. It is
> > still
> > of great interest by our side to merge the extension into StarPU and
> > hopefully it would also be an usable feature for StarPU.
> > Sincerely looking forward to your reply.
> > Best regards,
> > Fangli Pi
> > ----- Forwarded Message -----
> > From: "Fangli Pi" <hpcfapix@hlrs.de>
> > To: "starpu-devel" <starpu-devel@lists.gforge.inria.fr>
> > Cc: "Michael Gienger" <gienger@hlrs.de>, "Dennis Hoppe"
> > Sent: Monday, April 25, 2016 10:27:27 AM
> > Subject: Strong interest in contributions and integrations
> > I am now working on an EU project (EXCESS, http://excess-project.eu/)
> > using
> > StarPU as a runtime system. For the project's concentration on
> > energy-efficient computation, we have tried to extend StarPU power model
> > to
> > retrieve energy and power measurements from one monitoring framework,
> > developed by our team.
> > Following is the link of our StarPU power extension, including the source
> > code, some examples and a basic introduction.
> > https://github.com/excess-project/starpu-energy-aware-extension.git
> > As we are currently thinking about an integration with StarPU, it would be
> > very beneficial to get your professional opinions and relevant supports
> > upon
> > the aspect of StarPU.
> > Looking forward to your reply and a possible cooperation in the future.
> > Best regards,
> > Fangli Pi
> > High Performance Computing Center (HLRS)
> > University of Stuttgart
> > Nobelstr. 19
> > D-70569 Stuttgart, Germany
> > phone: ++49-711-685-60442
> > Nobelstr. 19
> > _______________________________________________
> > Starpu-devel mailing list
> > Starpu-devel@lists.gforge.inria.fr
> > http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
> Nobelstr. 19
- [Starpu-devel] Fwd: Strong interest in contributions and integrations, Fangli Pi, 09/05/2016
- Re: [Starpu-devel] Fwd: Strong interest in contributions and integrations, Samuel Thibault, 11/05/2016
- Re: [Starpu-devel] Fwd: Strong interest in contributions and integrations, Fangli Pi, 13/05/2016
- Re: [Starpu-devel] Fwd: Strong interest in contributions and integrations, Andra Hugo, 23/05/2016
- Re: [Starpu-devel] Fwd: Strong interest in contributions and integrations, Fangli Pi, 23/05/2016
- Re: [Starpu-devel] Fwd: Strong interest in contributions and integrations, Samuel Thibault, 24/05/2016
- Re: [Starpu-devel] Fwd: Strong interest in contributions and integrations, Andra Hugo, 24/05/2016
- Re: [Starpu-devel] Fwd: Strong interest in contributions and integrations, Fangli Pi, 24/05/2016
