Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Fwd: Strong interest in contributions and integrations
Archives de la liste
Chronologique Discussions
  • To: Andra Hugo <andra.hugo@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr, Dennis Hoppe <dennis.hoppe@hlrs.de>, Dmitry Khabi <khabi@hlrs.de>, Michael Gienger <gienger@hlrs.de>, Fangli Pi <hpcfapix@hlrs.de>
  • Subject: Re: [Starpu-devel] Fwd: Strong interest in contributions and integrations
  • Date: Tue, 24 May 2016 13:50:21 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Thanks Andra for the good feedback :) Just additional comments here:
Andra Hugo, on Mon 23 May 2016 12:07:12 +0200, wrote:
> 1. Do you measure energy or power? Maybe the field names don't match
> properly(you store the energy value in the power field).
Perhaps the field names were improperly chosen :)
> I am however a little bit worried about interfering with the application's
> cmd line parameters. We usually use env variables for runtime options for
> starpu.
Yes, please do not use cmd line parameters, they become a nightmare when
combined with mpirun, simgrid, etc. environment variable pose way less
problems :)
> 10. This is more like a suggestion: In order to monitor the processors you
> create a set of threads to take care of this. StarPU also has its own set
> of threads. Leaving the OS deal with the context switch might affect
> performance. Did you consider maybe using starpu's threads instead? I
> understand that your approach client server is definitely a better software
> engineering solution, and it can then be easily integrated in any software
> without modifying the code, but the overhead might be significant.
If there is only a couple of communication between threads for each
task, it would seem OK to me, provided that there is no synchronization,
only signalling (I haven't read the source, so I don't know how they
communicate). Otherwise it will become a bottleneck that will pose
problem.
Samuel
Haut de le page
