Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Suggestions about creating starpu threads
Archives de la liste
Chronologique Discussions
  • To: Andra Hugo <andra.hugo@inria.fr>
  • Cc: starpu-devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] Suggestions about creating starpu threads
  • Date: Wed, 25 May 2016 16:30:23 +0200 (CEST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=hpcfapix@hlrs.de; spf=None smtp.mailfrom=hpcfapix@hlrs.de; spf=None smtp.helo=postmaster@mail.hlrs.de
  • Dkim-filter: OpenDKIM Filter v2.9.2 mail.hlrs.de 200C9850D
  • Ironport-phdr: 9a23:4AkorhZANsbRy2YxURAd6lr/LSx+4OfEezUN459isYplN5qZpcq8bnLW6fgltlLVR4KTs6sC0LqH9fy7EjBdqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7H0p8aYP1gArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIZoGJ/3dKUgTLFeEC9ucyVsvJWq5lH/Sl6m4HcGWy02jxVPS1zM6h3gV9HxryT9nut7wiiTe8PsG+MaQzOnuoliThDsiW8/NnZt8HnchMVojbJzoBa7vFpzztiHM8muKPNic/aFLpshTm1bU5MUDnQZDw==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Andra,
I have created a new email as I think the only open point now is the point 10.
Regarding to your suggestion about creating StarPU threads and get power data
directly from mf_agent, I have discussed with my colleague and got an
impression that it may take significant work, while the architecture of our
monitoring framework would need to be changed and I am not sure if the new
method will be efficient as before (for example, rapl need to be started and
stopped every time you need the power measurements).
Besides, although there are overhead of mf_server query, it will not effect
the performance of StarPU tasks. Since the query only happens when the user
turns on the training mode of power model (like calibrate for the performance
model), which is not the real runtime mode of StarPU. After enough training,
the power model could be used to predict the power consumption of the task
during runtime and for scheduling. In another word, it may become slow once
the user turns on the training mode, however, for all the other cases
performance will not be effected. After all, the performance during training
is not so important, right?
Please let me know if it would make sense. Or if you think it is very
important to keep the performance in a training mode, please feel free to
correct me.
Best regards,
Fangli
High Performance Computing Center (HLRS)
University of Stuttgart
Nobelstr. 19
D-70569 Stuttgart, Germany
phone: ++49-711-685-60442
Haut de le page
