Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5
  • Date: Wed, 17 Aug 2016 15:54:26 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=schnorr@inf.ufrgs.br; spf=Pass smtp.mailfrom=schnorr@inf.ufrgs.br; spf=None smtp.helo=postmaster@smtp.inf.ufrgs.br
  • Ironport-phdr: 9a23:3NjRUh9N1u6Rzf9uRHKM819IXTAuvvDOBiVQ1KB91O0cTK2v8tzYMVDF4r011RmSDNydsasP1rqe8/i5HzdRudDZ6DFKWacPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvjotuJOk4V1HL9Oeo0d0Tu612J94E/ushLEu4J0BzHo39FKax95FhDAhatpSv6/dq655V58i5d6LoL/s9EVrjmLexjFeQLRGduD2dg/9HirwHeCAeC+HYYemEXiQZTRQfL6wv1U9HwtDH7v6xzwnq0J8rzGPoQRD+r9O9ODlfTgycBMCQjuimDkcdwiqVBujqgoRI53oDOb5rTPuAoLfCVRs8TWWcUBpUZbCdGGI7pN4Y=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
I am using spack to install Starpu. Spack has been installed this way:
git clone https://github.com/fpruvost/spack.git;
cd spack;
git checkout morse
source share/spack/setup-env.sh
Then, I launch starpu installation this way:
$ spack install -v -n --keep-stage starpu@svn-trunk+fxt~opencl %gcc@6.1.0
==> Installing starpu
==> fxt is already installed in /home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck
==> hwloc is already installed in /home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx
==> Already fetched /home/lschnorr/spack-orion/var/spack/stage/starpu-svn-trunk-ew2ffhhvxulnikubqm76rijyluvps7ho/trunk
==> Already staged starpu-svn-trunk-ew2ffhhvxulnikubqm76rijyluvps7ho in /home/lschnorr/spack-orion/var/spack/stage/starpu-svn-trunk-ew2ffhhvxulnikubqm76rijyluvps7ho
==> No patches needed for starpu
==> Building starpu
#Several messages
configure: error: cannot find hwloc
==> Error: Command exited with status 1:
'./configure' '--prefix=/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/starpu-svn-trunk-ew2ffhhvxulnikubqm76rijyluvps7ho' '--disable-build-doc' '--disable-starpu-top' '--with-fxt=/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck' '--enable-paje-codelet-details' '--with-hwloc=/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx' '--without-mpicc' '--disable-cuda' '--disable-opencl' '--enable-openmp=no'
I am attaching the corresponding spack-build.out.
The problem is that starpu's configure script is not taking into account :
When attempting to link against hwloc. The header is correctly found. I've already tried to edit the configure.ac, but without success. My system is a debian testing updated today (currently deployed in one machine of the orion cluster).
$ uname -a
Linux orion-4.lyon.grid5000.fr 4.6.0-1-amd64 #1 SMP Debian 4.6.4-1 (2016-07-18) x86_64 GNU/Linux
lschnorr@orion-4:~/spack-orion$
Any ideas how to overcome this problem?
I tested also against 1.2.0rc5 but the same problem happens.
Thanks
Lucas
Lucas M. Schnorr, UFRGS
http://www.inf.ufrgs.br/~schnorr/
autoreconf: Entering directory `.'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal -I m4 --force -I m4
autoreconf: configure.ac: tracing
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, 'build-aux'.
libtoolize: copying file 'build-aux/ltmain.sh'
libtoolize: putting macros in 'm4'.
libtoolize: copying file 'm4/libtool.m4'
libtoolize: copying file 'm4/ltoptions.m4'
libtoolize: copying file 'm4/ltsugar.m4'
libtoolize: copying file 'm4/ltversion.m4'
libtoolize: copying file 'm4/lt~obsolete.m4'
libtoolize: Consider adding 'AC_CONFIG_MACRO_DIRS([m4])' to configure.ac,
libtoolize: and rerunning libtoolize and aclocal.
autoreconf: running: /usr/bin/autoconf --include=m4 --force
autoreconf: running: /usr/bin/autoheader --include=m4 --force
autoreconf: running: automake --add-missing --copy --force-missing
configure.ac:72: installing 'build-aux/compile'
configure.ac:63: installing 'build-aux/missing'
starpu-mynvcc.mk:5: warning: V_mynvcc_$(AM_DEFAULT_VERBOSITY: non-POSIX
recursive variable expansion
examples/Makefile.am:82: 'starpu-mynvcc.mk' included from here
starpu-mynvcc.mk:8: warning: V_mynvcc_$(V: non-POSIX recursive variable
expansion
examples/Makefile.am:543: warning: source file 'axpy/axpy.c' is in a
subdirectory,
examples/Makefile.am:543: but option 'subdir-objects' is disabled
automake: warning: possible forward-incompatibility.
automake: At least a source file is in a subdirectory, but the
'subdir-objects'
automake: automake option hasn't been enabled. For now, the corresponding
output
automake: object file(s) will be placed in the top-level directory. However,
automake: this behaviour will change in future Automake versions: they will
automake: unconditionally cause object files to be placed in the same
subdirectory
automake: of the corresponding sources.
automake: You are advised to start using 'subdir-objects' option throughout
your
automake: project, to avoid future incompatibilities.
examples/Makefile.am:543: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:547: warning: source file 'axpy/axpy_opencl.c' is in a
subdirectory,
examples/Makefile.am:547: but option 'subdir-objects' is disabled
examples/Makefile.am:425: warning: source file 'basic_examples/block.c' is in
a subdirectory,
examples/Makefile.am:425: but option 'subdir-objects' is disabled
examples/Makefile.am:425: warning: source file 'basic_examples/block_cpu.c'
examples/Makefile.am:435: warning: source file
'basic_examples/block_opencl.c' is in a subdirectory,
examples/Makefile.am:435: but option 'subdir-objects' is disabled
automake: warning: source file 'basic_examples/dynamic_handles.c' is in a
subdirectory,
automake: but option 'subdir-objects' is disabled
examples/Makefile.am:193: while processing program
'basic_examples/dynamic_handles'
automake: warning: source file 'basic_examples/hello_world.c' is in a
subdirectory,
'basic_examples/hello_world'
automake: warning: source file 'basic_examples/mult.c' is in a subdirectory,
examples/Makefile.am:193: while processing program 'basic_examples/mult'
examples/Makefile.am:401: warning: source file 'basic_examples/multiformat.c'
examples/Makefile.am:401: but option 'subdir-objects' is disabled
'basic_examples/multiformat_conversion_codelets.c' is in a subdirectory,
examples/Makefile.am:412: warning: source file
'basic_examples/multiformat_opencl.c' is in a subdirectory,
examples/Makefile.am:412: but option 'subdir-objects' is disabled
'basic_examples/multiformat_conversion_codelets_opencl.c' is in a
subdirectory,
examples/Makefile.am:445: warning: source file 'basic_examples/variable.c' is
in a subdirectory,
examples/Makefile.am:445: but option 'subdir-objects' is disabled
'basic_examples/variable_kernels_cpu.c' is in a subdirectory,
examples/Makefile.am:454: warning: source file
'basic_examples/variable_kernels_opencl.c' is in a subdirectory,
examples/Makefile.am:454: but option 'subdir-objects' is disabled
examples/Makefile.am:324: warning: source file 'basic_examples/vector_scal.c'
examples/Makefile.am:324: but option 'subdir-objects' is disabled
'basic_examples/vector_scal_cpu.c' is in a subdirectory,
examples/Makefile.am:342: warning: source file
'basic_examples/vector_scal_opencl.c' is in a subdirectory,
examples/Makefile.am:342: but option 'subdir-objects' is disabled
examples/Makefile.am:349: warning: source file
'basic_examples/vector_scal_fortran.F' is in a subdirectory,
examples/Makefile.am:349: but option 'subdir-objects' is disabled
'basic_examples/vector_scal_c.c' is in a subdirectory,
examples/Makefile.am:832: warning: source file 'binary/binary.c' is in a
subdirectory,
examples/Makefile.am:832: but option 'subdir-objects' is disabled
examples/Makefile.am:835: warning: source file
'incrementer/incrementer_kernels_opencl.c' is in a subdirectory,
examples/Makefile.am:835: but option 'subdir-objects' is disabled
automake: warning: source file 'callback/callback.c' is in a subdirectory,
examples/Makefile.am:193: while processing program 'callback/callback'
automake: warning: source file 'callback/prologue.c' is in a subdirectory,
examples/Makefile.am:193: while processing program 'callback/prologue'
examples/Makefile.am:749: warning: source file 'cg/cg.c' is in a subdirectory,
examples/Makefile.am:749: but option 'subdir-objects' is disabled
examples/Makefile.am:749: warning: source file 'cg/cg_kernels.c' is in a
subdirectory,
examples/Makefile.am:749: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:603: warning: source file
'cholesky/cholesky_grain_tag.c' is in a subdirectory,
examples/Makefile.am:603: but option 'subdir-objects' is disabled
examples/Makefile.am:603: warning: source file 'cholesky/cholesky_models.c'
examples/Makefile.am:603: warning: source file 'cholesky/cholesky_kernels.c'
examples/Makefile.am:603: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:612: warning: source file 'cholesky/cholesky_implicit.c'
examples/Makefile.am:612: but option 'subdir-objects' is disabled
examples/Makefile.am:612: warning: source file 'cholesky/cholesky_models.c'
examples/Makefile.am:612: warning: source file 'cholesky/cholesky_kernels.c'
'sched_ctx_utils/sched_ctx_utils.c' is in a subdirectory,
examples/Makefile.am:612: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:585: warning: source file 'cholesky/cholesky_tag.c' is
in a subdirectory,
examples/Makefile.am:585: but option 'subdir-objects' is disabled
examples/Makefile.am:585: warning: source file 'cholesky/cholesky_models.c'
examples/Makefile.am:585: warning: source file 'cholesky/cholesky_kernels.c'
examples/Makefile.am:585: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:594: warning: source file 'cholesky/cholesky_tile_tag.c'
examples/Makefile.am:594: but option 'subdir-objects' is disabled
examples/Makefile.am:594: warning: source file 'cholesky/cholesky_models.c'
examples/Makefile.am:594: warning: source file 'cholesky/cholesky_kernels.c'
examples/Makefile.am:594: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:799: warning: source file 'cpp/incrementer_cpp.cpp' is
in a subdirectory,
examples/Makefile.am:799: but option 'subdir-objects' is disabled
examples/Makefile.am:807: warning: source file
examples/Makefile.am:807: but option 'subdir-objects' is disabled
examples/Makefile.am:518: warning: source file
'filters/custom_mf/custom_mf_filter.c' is in a subdirectory,
examples/Makefile.am:518: but option 'subdir-objects' is disabled
'filters/custom_mf/custom_interface.c' is in a subdirectory,
'filters/custom_mf/custom_conversion_codelets.c' is in a subdirectory,
examples/Makefile.am:530: warning: source file
'filters/custom_mf/conversion_opencl.c' is in a subdirectory,
examples/Makefile.am:530: but option 'subdir-objects' is disabled
'filters/custom_mf/custom_opencl.c' is in a subdirectory,
examples/Makefile.am:464: warning: source file 'filters/fblock.c' is in a
subdirectory,
examples/Makefile.am:464: but option 'subdir-objects' is disabled
examples/Makefile.am:464: warning: source file 'filters/fblock_cpu.c' is in a
subdirectory,
examples/Makefile.am:473: warning: source file 'filters/fblock_opencl.c' is
in a subdirectory,
examples/Makefile.am:473: but option 'subdir-objects' is disabled
automake: warning: source file 'filters/fmatrix.c' is in a subdirectory,
examples/Makefile.am:193: while processing program 'filters/fmatrix'
examples/Makefile.am:479: warning: source file 'filters/fmultiple_manual.c'
examples/Makefile.am:479: but option 'subdir-objects' is disabled
examples/Makefile.am:487: warning: source file 'filters/fmultiple_submit.c'
examples/Makefile.am:487: but option 'subdir-objects' is disabled
examples/Makefile.am:495: warning: source file
'filters/fmultiple_submit_readonly.c' is in a subdirectory,
examples/Makefile.am:495: but option 'subdir-objects' is disabled
automake: warning: source file 'filters/fvector.c' is in a subdirectory,
examples/Makefile.am:193: while processing program 'filters/fvector'
automake: warning: source file 'filters/shadow.c' is in a subdirectory,
examples/Makefile.am:100: while processing program 'filters/shadow'
automake: warning: source file 'filters/shadow2d.c' is in a subdirectory,
examples/Makefile.am:100: while processing program 'filters/shadow2d'
automake: warning: source file 'filters/shadow3d.c' is in a subdirectory,
examples/Makefile.am:100: while processing program 'filters/shadow3d'
examples/Makefile.am:361: warning: source file 'fortran/hello_c.c' is in a
subdirectory,
examples/Makefile.am:361: but option 'subdir-objects' is disabled
examples/Makefile.am:361: warning: source file 'fortran/hello.F' is in a
subdirectory,
examples/Makefile.am:368: warning: source file 'fortran90/mod_types.f90' is
in a subdirectory,
examples/Makefile.am:368: but option 'subdir-objects' is disabled
'$(top_srcdir)/include/starpu_mod.f90' is in a subdirectory,
examples/Makefile.am:368: warning: source file 'fortran90/mod_interface.f90'
examples/Makefile.am:368: warning: source file 'fortran90/mod_compute.f90' is
in a subdirectory,
examples/Makefile.am:368: warning: source file 'fortran90/marshalling.c' is
in a subdirectory,
examples/Makefile.am:368: warning: source file 'fortran90/f90_example.f90' is
in a subdirectory,
examples/Makefile.am:954: warning: source file 'gl_interop/gl_interop.c' is
in a subdirectory,
examples/Makefile.am:954: but option 'subdir-objects' is disabled
examples/Makefile.am:960: warning: source file 'gl_interop/gl_interop_idle.c'
examples/Makefile.am:960: but option 'subdir-objects' is disabled
examples/Makefile.am:725: warning: source file 'heat/heat.c' is in a
subdirectory,
examples/Makefile.am:725: but option 'subdir-objects' is disabled
examples/Makefile.am:725: warning: source file 'heat/dw_factolu.c' is in a
subdirectory,
examples/Makefile.am:725: warning: source file 'heat/dw_factolu_tag.c' is in
a subdirectory,
examples/Makefile.am:725: warning: source file 'heat/dw_factolu_grain.c' is
in a subdirectory,
examples/Makefile.am:725: warning: source file 'heat/dw_sparse_cg.c' is in a
subdirectory,
examples/Makefile.am:725: warning: source file 'heat/heat_display.c' is in a
subdirectory,
examples/Makefile.am:725: warning: source file 'heat/lu_kernels_model.c' is
in a subdirectory,
examples/Makefile.am:725: warning: source file 'heat/dw_sparse_cg_kernels.c'
examples/Makefile.am:725: warning: source file 'heat/dw_factolu_kernels.c' is
in a subdirectory,
examples/Makefile.am:725: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:815: warning: source file 'incrementer/incrementer.c' is
in a subdirectory,
examples/Makefile.am:815: but option 'subdir-objects' is disabled
examples/Makefile.am:822: warning: source file
examples/Makefile.am:822: but option 'subdir-objects' is disabled
examples/Makefile.am:843: warning: source file 'interface/complex.c' is in a
subdirectory,
examples/Makefile.am:843: but option 'subdir-objects' is disabled
'interface/complex_interface.c' is in a subdirectory,
examples/Makefile.am:852: warning: source file
'interface/complex_kernels_opencl.c' is in a subdirectory,
examples/Makefile.am:852: but option 'subdir-objects' is disabled
examples/Makefile.am:167: warning: source file '../tests/loader.c' is in a
subdirectory,
examples/Makefile.am:167: but option 'subdir-objects' is disabled
examples/Makefile.am:693: warning: source file
'lu/lu_example_complex_double.c' is in a subdirectory,
examples/Makefile.am:693: but option 'subdir-objects' is disabled
examples/Makefile.am:693: warning: source file 'lu/zlu.c' is in a
subdirectory,
examples/Makefile.am:693: warning: source file 'lu/zlu_pivot.c' is in a
subdirectory,
examples/Makefile.am:693: warning: source file 'lu/zlu_kernels.c' is in a
subdirectory,
examples/Makefile.am:693: warning: source file 'lu/blas_complex.c' is in a
subdirectory,
examples/Makefile.am:693: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:671: warning: source file
'lu/lu_example_complex_float.c' is in a subdirectory,
examples/Makefile.am:671: but option 'subdir-objects' is disabled
examples/Makefile.am:671: warning: source file 'lu/clu.c' is in a
subdirectory,
examples/Makefile.am:671: warning: source file 'lu/clu_pivot.c' is in a
subdirectory,
examples/Makefile.am:671: warning: source file 'lu/clu_kernels.c' is in a
subdirectory,
examples/Makefile.am:671: warning: source file 'lu/blas_complex.c' is in a
subdirectory,
examples/Makefile.am:671: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:640: warning: source file 'lu/lu_example_double.c' is in
a subdirectory,
examples/Makefile.am:640: but option 'subdir-objects' is disabled
examples/Makefile.am:640: warning: source file 'lu/dlu.c' is in a
subdirectory,
examples/Makefile.am:640: warning: source file 'lu/dlu_pivot.c' is in a
subdirectory,
examples/Makefile.am:640: warning: source file 'lu/dlu_kernels.c' is in a
subdirectory,
examples/Makefile.am:640: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:630: warning: source file 'lu/lu_example_float.c' is in
a subdirectory,
examples/Makefile.am:630: but option 'subdir-objects' is disabled
examples/Makefile.am:630: warning: source file 'lu/slu.c' is in a
subdirectory,
examples/Makefile.am:630: warning: source file 'lu/slu_pivot.c' is in a
subdirectory,
examples/Makefile.am:630: warning: source file 'lu/slu_kernels.c' is in a
subdirectory,
examples/Makefile.am:630: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:704: warning: source file
examples/Makefile.am:704: but option 'subdir-objects' is disabled
examples/Makefile.am:704: warning: source file 'lu/zlu_implicit.c' is in a
subdirectory,
examples/Makefile.am:704: warning: source file 'lu/zlu_implicit_pivot.c' is
in a subdirectory,
examples/Makefile.am:704: warning: source file 'lu/zlu_kernels.c' is in a
subdirectory,
examples/Makefile.am:704: warning: source file 'lu/blas_complex.c' is in a
subdirectory,
examples/Makefile.am:704: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:682: warning: source file
examples/Makefile.am:682: but option 'subdir-objects' is disabled
examples/Makefile.am:682: warning: source file 'lu/clu_implicit.c' is in a
subdirectory,
examples/Makefile.am:682: warning: source file 'lu/clu_implicit_pivot.c' is
in a subdirectory,
examples/Makefile.am:682: warning: source file 'lu/clu_kernels.c' is in a
subdirectory,
examples/Makefile.am:682: warning: source file 'lu/blas_complex.c' is in a
subdirectory,
examples/Makefile.am:682: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:660: warning: source file 'lu/lu_example_double.c' is in
a subdirectory,
examples/Makefile.am:660: but option 'subdir-objects' is disabled
examples/Makefile.am:660: warning: source file 'lu/dlu_implicit.c' is in a
subdirectory,
examples/Makefile.am:660: warning: source file 'lu/dlu_implicit_pivot.c' is
in a subdirectory,
examples/Makefile.am:660: warning: source file 'lu/dlu_kernels.c' is in a
subdirectory,
examples/Makefile.am:660: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:650: warning: source file 'lu/lu_example_float.c' is in
a subdirectory,
examples/Makefile.am:650: but option 'subdir-objects' is disabled
examples/Makefile.am:650: warning: source file 'lu/slu_implicit.c' is in a
subdirectory,
examples/Makefile.am:650: warning: source file 'lu/slu_implicit_pivot.c' is
in a subdirectory,
examples/Makefile.am:650: warning: source file 'lu/slu_kernels.c' is in a
subdirectory,
examples/Makefile.am:650: warning: source file 'common/blas.c' is in a
subdirectory,
automake: warning: source file 'mandelbrot/mandelbrot.c' is in a subdirectory,
examples/Makefile.am:100: while processing program 'mandelbrot/mandelbrot'
automake: warning: source file 'matvecmult/matvecmult.c' is in a subdirectory,
examples/Makefile.am:193: while processing program 'matvecmult/matvecmult'
examples/Makefile.am:570: warning: source file 'mult/dgemm.c' is in a
subdirectory,
examples/Makefile.am:570: but option 'subdir-objects' is disabled
examples/Makefile.am:570: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:563: warning: source file 'mult/sgemm.c' is in a
subdirectory,
examples/Makefile.am:563: but option 'subdir-objects' is disabled
examples/Makefile.am:563: warning: source file 'common/blas.c' is in a
subdirectory,
examples/Makefile.am:392: warning: source file
'native_fortran/nf_dynbuf_cl.f90' is in a subdirectory,
examples/Makefile.am:392: but option 'subdir-objects' is disabled
'$(top_srcdir)/include/fstarpu_mod.f90' is in a subdirectory,
examples/Makefile.am:392: warning: source file 'native_fortran/nf_dynbuf.f90'
examples/Makefile.am:386: warning: source file 'native_fortran/nf_types.f90'
examples/Makefile.am:386: but option 'subdir-objects' is disabled
'native_fortran/nf_compute.f90' is in a subdirectory,
'native_fortran/nf_example.f90' is in a subdirectory,
examples/Makefile.am:381: warning: source file
'native_fortran/nf_codelets.f90' is in a subdirectory,
examples/Makefile.am:381: but option 'subdir-objects' is disabled
examples/Makefile.am:381: warning: source file 'native_fortran/nf_matrix.f90'
examples/Makefile.am:376: warning: source file
examples/Makefile.am:376: but option 'subdir-objects' is disabled
examples/Makefile.am:376: warning: source file 'native_fortran/nf_vector.f90'
automake: warning: source file 'openmp/vector_scal_omp.c' is in a
subdirectory,
examples/Makefile.am:299: while processing program 'openmp/vector_scal_omp'
examples/Makefile.am:923: warning: source file 'pi/pi.c' is in a subdirectory,
examples/Makefile.am:923: but option 'subdir-objects' is disabled
examples/Makefile.am:923: warning: source file 'pi/SobolQRNG/sobol_gold.c' is
in a subdirectory,
'pi/SobolQRNG/sobol_primitives.c' is in a subdirectory,
examples/Makefile.am:934: warning: source file 'pi/pi_redux.c' is in a
subdirectory,
examples/Makefile.am:934: but option 'subdir-objects' is disabled
examples/Makefile.am:972: warning: source file 'pipeline/pipeline.c' is in a
subdirectory,
examples/Makefile.am:972: but option 'subdir-objects' is disabled
examples/Makefile.am:972: warning: source file 'common/blas.c' is in a
subdirectory,
automake: warning: source file 'ppm_downscaler/ppm_downscaler.c' is in a
subdirectory,
'ppm_downscaler/ppm_downscaler'
automake: warning: source file 'ppm_downscaler/yuv_downscaler.c' is in a
subdirectory,
'ppm_downscaler/yuv_downscaler'
automake: warning: source file 'profiling/profiling.c' is in a subdirectory,
examples/Makefile.am:193: while processing program 'profiling/profiling'
examples/Makefile.am:871: warning: source file 'reductions/dot_product.c' is
in a subdirectory,
examples/Makefile.am:871: but option 'subdir-objects' is disabled
automake: warning: source file 'reductions/minmax_reduction.c' is in a
subdirectory,
'reductions/minmax_reduction'
automake: warning: source file 'sched_ctx/dummy_sched_with_ctx.c' is in a
subdirectory,
'sched_ctx/dummy_sched_with_ctx'
automake: warning: source file 'sched_ctx/nested_sched_ctxs.c' is in a
subdirectory,
'sched_ctx/nested_sched_ctxs'
automake: warning: source file 'sched_ctx/parallel_code.c' is in a
subdirectory,
examples/Makefile.am:306: while processing program 'sched_ctx/parallel_code'
automake: warning: source file 'sched_ctx/parallel_tasks_reuse_handle.c' is
in a subdirectory,
'sched_ctx/parallel_tasks_reuse_handle'
automake: warning: source file 'sched_ctx/parallel_tasks_with_cluster_api.c'
examples/Makefile.am:312: while processing program
'sched_ctx/parallel_tasks_with_cluster_api'
automake: warning: source file 'sched_ctx/prio.c' is in a subdirectory,
examples/Makefile.am:186: while processing program 'sched_ctx/prio'
automake: warning: source file 'sched_ctx/sched_ctx.c' is in a subdirectory,
examples/Makefile.am:193: while processing program 'sched_ctx/sched_ctx'
automake: warning: source file 'sched_ctx/sched_ctx_without_sched_policy.c'
'sched_ctx/sched_ctx_without_sched_policy'
'sched_ctx/sched_ctx_without_sched_policy_awake.c' is in a subdirectory,
'sched_ctx/sched_ctx_without_sched_policy_awake'
automake: warning: source file 'scheduler/dummy_sched.c' is in a subdirectory,
examples/Makefile.am:193: while processing program 'scheduler/dummy_sched'
automake: warning: source file 'scheduler/heteroprio_test.c' is in a
subdirectory,
'scheduler/heteroprio_test'
examples/Makefile.am:768: warning: source file 'spmd/vector_scal_spmd.c' is
in a subdirectory,
examples/Makefile.am:768: but option 'subdir-objects' is disabled
examples/Makefile.am:785: warning: source file 'spmv/dw_block_spmv.c' is in a
subdirectory,
examples/Makefile.am:785: but option 'subdir-objects' is disabled
examples/Makefile.am:785: warning: source file 'spmv/dw_block_spmv_kernels.c'
'spmv/matrix_market/mm_to_bcsr.c' is in a subdirectory,
examples/Makefile.am:785: warning: source file 'spmv/matrix_market/mmio.c' is
in a subdirectory,
examples/Makefile.am:775: warning: source file 'spmv/spmv.c' is in a
subdirectory,
examples/Makefile.am:775: but option 'subdir-objects' is disabled
examples/Makefile.am:775: warning: source file 'spmv/spmv_kernels.c' is in a
subdirectory,
automake: warning: source file 'tag_example/tag_example.c' is in a
subdirectory,
examples/Makefile.am:193: while processing program 'tag_example/tag_example'
automake: warning: source file 'tag_example/tag_example2.c' is in a
subdirectory,
'tag_example/tag_example2'
automake: warning: source file 'tag_example/tag_example3.c' is in a
subdirectory,
'tag_example/tag_example3'
automake: warning: source file 'tag_example/tag_example4.c' is in a
subdirectory,
'tag_example/tag_example4'
automake: warning: source file 'tag_example/tag_restartable.c' is in a
subdirectory,
'tag_example/tag_restartable'
examples/Makefile.am:910: warning: source file 'top/hello_world_top.c' is in
a subdirectory,
examples/Makefile.am:910: but option 'subdir-objects' is disabled
automake: warning: source file 'worker_collections/worker_list_example.c' is
in a subdirectory,
'worker_collections/worker_list_example'
automake: warning: source file 'worker_collections/worker_tree_example.c' is
in a subdirectory,
'worker_collections/worker_tree_example'
examples/Makefile.am: installing 'build-aux/depcomp'
examples/stencil/Makefile.am:40: 'starpu-mynvcc.mk' included from here
expansion
examples/stencil/Makefile.am:76: warning: source file '../../tests/loader.c'
examples/stencil/Makefile.am:76: but option 'subdir-objects' is disabled
gcc-plugin/examples/Makefile.am:95: 'starpu-mynvcc.mk' included from here
expansion
gcc-plugin/examples/Makefile.am:35: warning: source file
'../../tests/loader.c' is in a subdirectory,
gcc-plugin/examples/Makefile.am:35: but option 'subdir-objects' is disabled
gcc-plugin/examples/Makefile.am:88: warning: source file
'vector_scal/vector_scal.c' is in a subdirectory,
gcc-plugin/examples/Makefile.am:88: but option 'subdir-objects' is disabled
mpi/examples/Makefile.am:88: 'starpu-mynvcc.mk' included from here
expansion
automake: warning: source file 'comm/comm.c' is in a subdirectory,
mpi/examples/Makefile.am:312: while processing program 'comm/comm'
automake: warning: source file 'comm/mix_comm.c' is in a subdirectory,
mpi/examples/Makefile.am:312: while processing program 'comm/mix_comm'
mpi/examples/Makefile.am:315: warning: source file 'complex/mpi_complex.c' is
in a subdirectory,
mpi/examples/Makefile.am:315: but option 'subdir-objects' is disabled
'../../examples/interface/complex_interface.c' is in a subdirectory,
mpi/examples/Makefile.am:31: warning: source file '../../tests/loader.c' is
in a subdirectory,
mpi/examples/Makefile.am:31: but option 'subdir-objects' is disabled
mpi/examples/Makefile.am:219: warning: source file
'matrix_decomposition/mpi_cholesky.c' is in a subdirectory,
mpi/examples/Makefile.am:219: but option 'subdir-objects' is disabled
'matrix_decomposition/mpi_cholesky_models.c' is in a subdirectory,
'matrix_decomposition/mpi_cholesky_kernels.c' is in a subdirectory,
'matrix_decomposition/mpi_cholesky_codelets.c' is in a subdirectory,
'matrix_decomposition/mpi_decomposition_params.c' is in a subdirectory,
'matrix_decomposition/mpi_decomposition_matrix.c' is in a subdirectory,
'../../examples/common/blas.c' is in a subdirectory,
mpi/examples/Makefile.am:232: warning: source file
'matrix_decomposition/mpi_cholesky_distributed.c' is in a subdirectory,
mpi/examples/Makefile.am:232: but option 'subdir-objects' is disabled
mpi/examples/Makefile.am:259: warning: source file 'matrix_mult/mm.c' is in a
subdirectory,
mpi/examples/Makefile.am:259: but option 'subdir-objects' is disabled
mpi/examples/Makefile.am:152: warning: source file
'mpi_lu/plu_example_double.c' is in a subdirectory,
mpi/examples/Makefile.am:152: but option 'subdir-objects' is disabled
'mpi_lu/plu_solve_double.c' is in a subdirectory,
mpi/examples/Makefile.am:152: warning: source file 'mpi_lu/pdlu_kernels.c' is
in a subdirectory,
mpi/examples/Makefile.am:152: warning: source file 'mpi_lu/pdlu.c' is in a
subdirectory,
mpi/examples/Makefile.am:140: warning: source file
'mpi_lu/plu_example_float.c' is in a subdirectory,
mpi/examples/Makefile.am:140: but option 'subdir-objects' is disabled
mpi/examples/Makefile.am:140: warning: source file 'mpi_lu/plu_solve_float.c'
mpi/examples/Makefile.am:140: warning: source file 'mpi_lu/pslu_kernels.c' is
in a subdirectory,
mpi/examples/Makefile.am:140: warning: source file 'mpi_lu/pslu.c' is in a
subdirectory,
mpi/examples/Makefile.am:176: warning: source file
'mpi_lu/plu_implicit_example_double.c' is in a subdirectory,
mpi/examples/Makefile.am:176: but option 'subdir-objects' is disabled
mpi/examples/Makefile.am:176: warning: source file 'mpi_lu/pdlu_kernels.c' is
in a subdirectory,
mpi/examples/Makefile.am:176: warning: source file 'mpi_lu/pdlu_implicit.c'
mpi/examples/Makefile.am:164: warning: source file
'mpi_lu/plu_implicit_example_float.c' is in a subdirectory,
mpi/examples/Makefile.am:164: but option 'subdir-objects' is disabled
mpi/examples/Makefile.am:164: warning: source file 'mpi_lu/plu_solve_float.c'
mpi/examples/Makefile.am:164: warning: source file 'mpi_lu/pslu_kernels.c' is
in a subdirectory,
mpi/examples/Makefile.am:164: warning: source file 'mpi_lu/pslu_implicit.c'
mpi/examples/Makefile.am:200: warning: source file
'mpi_lu/plu_outofcore_example_double.c' is in a subdirectory,
mpi/examples/Makefile.am:200: but option 'subdir-objects' is disabled
mpi/examples/Makefile.am:200: warning: source file 'mpi_lu/pdlu_kernels.c' is
in a subdirectory,
mpi/examples/Makefile.am:200: warning: source file 'mpi_lu/pdlu_implicit.c'
mpi/examples/Makefile.am:188: warning: source file
'mpi_lu/plu_outofcore_example_float.c' is in a subdirectory,
mpi/examples/Makefile.am:188: but option 'subdir-objects' is disabled
mpi/examples/Makefile.am:188: warning: source file 'mpi_lu/plu_solve_float.c'
mpi/examples/Makefile.am:188: warning: source file 'mpi_lu/pslu_kernels.c' is
in a subdirectory,
mpi/examples/Makefile.am:188: warning: source file 'mpi_lu/pslu_implicit.c'
mpi/examples/Makefile.am:291: warning: source file
'$(top_srcdir)/mpi/include/fstarpu_mpi_mod.f90' is in a subdirectory,
mpi/examples/Makefile.am:291: but option 'subdir-objects' is disabled
'native_fortran/nf_basic_ring.f90' is in a subdirectory,
mpi/examples/Makefile.am:281: warning: source file
'native_fortran/nf_mm_cl.f90' is in a subdirectory,
mpi/examples/Makefile.am:281: but option 'subdir-objects' is disabled
mpi/examples/Makefile.am:281: warning: source file 'native_fortran/nf_mm.f90'
automake: warning: source file 'stencil/stencil5.c' is in a subdirectory,
mpi/examples/Makefile.am:110: while processing program 'stencil/stencil5'
mpi/examples/Makefile.am:334: warning: source file
'user_datatype/user_datatype.c' is in a subdirectory,
mpi/examples/Makefile.am:334: but option 'subdir-objects' is disabled
'user_datatype/my_interface.c' is in a subdirectory,
mpi/tests/Makefile.am:67: 'starpu-mynvcc.mk' included from here
expansion
mpi/tests/Makefile.am:28: warning: source file '../../tests/loader.c' is in a
subdirectory,
mpi/tests/Makefile.am:28: but option 'subdir-objects' is disabled
mpi/tests/Makefile.am:324: warning: source file
mpi/tests/Makefile.am:324: but option 'subdir-objects' is disabled
mpi/tests/Makefile.am:326: warning: source file
mpi/tests/Makefile.am:326: but option 'subdir-objects' is disabled
mpi/tests/Makefile.am:321: warning: source file
mpi/tests/Makefile.am:321: but option 'subdir-objects' is disabled
sc_hypervisor/examples/Makefile.am:53: warning: source file
'app_driven_test/app_driven_test.c' is in a subdirectory,
sc_hypervisor/examples/Makefile.am:53: but option 'subdir-objects' is disabled
sc_hypervisor/examples/Makefile.am:40: warning: source file
'cholesky/cholesky_implicit.c' is in a subdirectory,
sc_hypervisor/examples/Makefile.am:40: but option 'subdir-objects' is disabled
'cholesky/cholesky_models.c' is in a subdirectory,
'cholesky/cholesky_kernels.c' is in a subdirectory,
automake: warning: source file 'hierarchical_ctxs/resize_hierarchical_ctxs.c'
sc_hypervisor/examples/Makefile.am:23: while processing program
'hierarchical_ctxs/resize_hierarchical_ctxs'
automake: warning: source file 'lp_test/lp_resize_test.c' is in a
subdirectory,
'lp_test/lp_resize_test'
automake: warning: source file 'lp_test/lp_test.c' is in a subdirectory,
'lp_test/lp_test'
sc_hypervisor/src/Makefile.am:24: warning: source file
'policies_utils/policy_tools.c' is in a subdirectory,
sc_hypervisor/src/Makefile.am:24: but option 'subdir-objects' is disabled
'policies_utils/speed.c' is in a subdirectory,
'policies_utils/task_pool.c' is in a subdirectory,
'policies_utils/lp_tools.c' is in a subdirectory,
'policies_utils/lp_programs.c' is in a subdirectory,
'policies_utils/dichotomy.c' is in a subdirectory,
'hypervisor_policies/idle_policy.c' is in a subdirectory,
'hypervisor_policies/app_driven_policy.c' is in a subdirectory,
'hypervisor_policies/gflops_rate_policy.c' is in a subdirectory,
'hypervisor_policies/feft_lp_policy.c' is in a subdirectory,
'hypervisor_policies/teft_lp_policy.c' is in a subdirectory,
'hypervisor_policies/ispeed_policy.c' is in a subdirectory,
'hypervisor_policies/ispeed_lp_policy.c' is in a subdirectory,
'hypervisor_policies/throughput_lp_policy.c' is in a subdirectory,
'hypervisor_policies/hard_coded_policy.c' is in a subdirectory,
'hypervisor_policies/perf_count_policy.c' is in a subdirectory,
socl/examples/Makefile.am:71: warning: source file 'basic/basic.c' is in a
subdirectory,
socl/examples/Makefile.am:71: but option 'subdir-objects' is disabled
socl/examples/Makefile.am:73: warning: source file 'clinfo/clinfo.c' is in a
subdirectory,
socl/examples/Makefile.am:73: but option 'subdir-objects' is disabled
socl/examples/Makefile.am:40: warning: source file '../../tests/loader.c' is
in a subdirectory,
socl/examples/Makefile.am:40: but option 'subdir-objects' is disabled
socl/examples/Makefile.am:76: warning: source file 'mansched/mansched.c' is
in a subdirectory,
socl/examples/Makefile.am:76: but option 'subdir-objects' is disabled
socl/examples/Makefile.am:74: warning: source file 'matmul/matmul.c' is in a
subdirectory,
socl/examples/Makefile.am:74: but option 'subdir-objects' is disabled
socl/examples/Makefile.am:72: warning: source file 'testmap/testmap.c' is in
a subdirectory,
socl/examples/Makefile.am:72: but option 'subdir-objects' is disabled
src/Makefile.am:153: warning: source file 'common/barrier.c' is in a
subdirectory,
src/Makefile.am:153: but option 'subdir-objects' is disabled
src/Makefile.am:153: warning: source file 'common/barrier_counter.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'common/bitmap.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'common/hash.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'common/rwlock.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'common/starpu_spinlock.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'common/timing.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'common/fxt.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'common/utils.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'common/thread.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'common/rbtree.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'common/graph.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/jobs.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'core/task.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'core/task_bundle.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/tree.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'core/workers.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/combined_workers.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/topology.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/disk.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'core/debug.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'core/errorcheck.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/progress_hook.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/dependencies/cg.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/dependencies/dependencies.c'
'core/dependencies/implicit_data_deps.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'core/dependencies/tags.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/dependencies/task_deps.c' is
in a subdirectory,
'core/dependencies/data_concurrency.c' is in a subdirectory,
'core/dependencies/data_arbiter_concurrency.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'core/disk_ops/disk_stdio.c' is in
a subdirectory,
src/Makefile.am:153: warning: source file 'core/disk_ops/disk_unistd.c' is in
a subdirectory,
'core/disk_ops/unistd/disk_unistd_global.c' is in a subdirectory,
'core/perfmodel/perfmodel_history.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'core/perfmodel/perfmodel_bus.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'core/perfmodel/perfmodel.c' is in
a subdirectory,
src/Makefile.am:153: warning: source file 'core/perfmodel/perfmodel_print.c'
src/Makefile.am:153: warning: source file 'core/perfmodel/perfmodel_nan.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'core/perfmodel/regression.c' is in
a subdirectory,
src/Makefile.am:153: warning: source file 'core/sched_policy.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/simgrid.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/sched_ctx.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/sched_ctx_list.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/parallel_task.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'core/detect_combined_workers.c' is
in a subdirectory,
'sched_policies/eager_central_policy.c' is in a subdirectory,
'sched_policies/eager_central_priority_policy.c' is in a subdirectory,
'sched_policies/work_stealing_policy.c' is in a subdirectory,
'sched_policies/deque_modeling_policy_data_aware.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/random_policy.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/fifo_queues.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/parallel_heft.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/parallel_eager.c'
src/Makefile.am:153: warning: source file 'sched_policies/heteroprio.c' is in
a subdirectory,
'sched_policies/graph_test_policy.c' is in a subdirectory,
'drivers/driver_common/driver_common.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'drivers/disk/driver_disk.c' is in
a subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/memory_nodes.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/write_back.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/coherency.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/data_request.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/datawizard.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/copy_driver.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/filters.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/sort_data_handles.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/malloc.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/memory_manager.c' is in
a subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/memalloc.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/memstats.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/footprint.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/datastats.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/user_interactions.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'datawizard/reduction.c' is in a
subdirectory,
'datawizard/interfaces/data_interface.c' is in a subdirectory,
'datawizard/interfaces/bcsr_interface.c' is in a subdirectory,
'datawizard/interfaces/coo_interface.c' is in a subdirectory,
'datawizard/interfaces/csr_interface.c' is in a subdirectory,
'datawizard/interfaces/matrix_filters.c' is in a subdirectory,
'datawizard/interfaces/matrix_interface.c' is in a subdirectory,
'datawizard/interfaces/block_filters.c' is in a subdirectory,
'datawizard/interfaces/block_interface.c' is in a subdirectory,
'datawizard/interfaces/vector_interface.c' is in a subdirectory,
'datawizard/interfaces/bcsr_filters.c' is in a subdirectory,
'datawizard/interfaces/csr_filters.c' is in a subdirectory,
'datawizard/interfaces/vector_filters.c' is in a subdirectory,
'datawizard/interfaces/variable_interface.c' is in a subdirectory,
'datawizard/interfaces/void_interface.c' is in a subdirectory,
'datawizard/interfaces/multiformat_interface.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'util/execute_on_all.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'util/starpu_create_sync_task.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'util/file.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'util/fstarpu.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'util/misc.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'util/openmp_runtime_support.c' is
in a subdirectory,
'util/openmp_runtime_support_environment.c' is in a subdirectory,
'util/openmp_runtime_support_omp_api.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'util/starpu_data_cpy.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'util/starpu_task_insert.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'util/starpu_task_insert_utils.c'
src/Makefile.am:153: warning: source file 'debug/traces/starpu_fxt.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'debug/traces/starpu_fxt_mpi.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'debug/traces/starpu_fxt_dag.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'debug/traces/starpu_paje.c' is in
a subdirectory,
src/Makefile.am:153: warning: source file 'debug/traces/anim.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'debug/latency.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'debug/structures_size.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'profiling/profiling.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'profiling/bound.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'profiling/profiling_helpers.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'top/starpu_top.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'top/starpu_top_task.c' is in a
subdirectory,
src/Makefile.am:153: warning: source file 'top/starpu_top_message_queue.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'top/starpu_top_connection.c' is in
a subdirectory,
src/Makefile.am:153: warning: source file 'worker_collection/worker_list.c'
src/Makefile.am:153: warning: source file 'worker_collection/worker_tree.c'
src/Makefile.am:153: warning: source file 'sched_policies/component_worker.c'
src/Makefile.am:153: warning: source file 'sched_policies/component_sched.c'
src/Makefile.am:153: warning: source file 'sched_policies/component_fifo.c'
src/Makefile.am:153: warning: source file 'sched_policies/prio_deque.c' is in
a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/helper_mct.c' is in
a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/component_prio.c'
src/Makefile.am:153: warning: source file 'sched_policies/component_random.c'
src/Makefile.am:153: warning: source file 'sched_policies/component_eager.c'
'sched_policies/component_eager_calibration.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/component_mct.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/component_heft.c'
'sched_policies/component_best_implementation.c' is in a subdirectory,
'sched_policies/component_perfmodel_select.c' is in a subdirectory,
'sched_policies/component_composed.c' is in a subdirectory,
'sched_policies/component_work_stealing.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/modular_eager.c' is
in a subdirectory,
'sched_policies/modular_eager_prefetching.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/modular_prio.c' is
in a subdirectory,
'sched_policies/modular_prio_prefetching.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/modular_random.c'
'sched_policies/modular_random_prefetching.c' is in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/modular_heft.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/modular_heft2.c' is
in a subdirectory,
src/Makefile.am:153: warning: source file 'sched_policies/modular_ws.c' is in
a subdirectory,
src/Makefile.am:296: warning: source file 'core/disk_ops/disk_leveldb.cpp' is
in a subdirectory,
src/Makefile.am:296: but option 'subdir-objects' is disabled
src/Makefile.am:300: warning: source file 'drivers/cpu/driver_cpu.c' is in a
subdirectory,
src/Makefile.am:300: but option 'subdir-objects' is disabled
src/Makefile.am:304: warning: source file 'drivers/cuda/driver_cuda.c' is in
a subdirectory,
src/Makefile.am:304: but option 'subdir-objects' is disabled
src/Makefile.am:307: warning: source file 'drivers/cuda/driver_cuda.c' is in
a subdirectory,
src/Makefile.am:307: but option 'subdir-objects' is disabled
src/Makefile.am:153: warning: source file 'drivers/cuda/starpu_cublas.c' is
in a subdirectory,
src/Makefile.am:314: warning: source file 'drivers/opencl/driver_opencl.c' is
in a subdirectory,
src/Makefile.am:314: but option 'subdir-objects' is disabled
'drivers/opencl/driver_opencl_utils.c' is in a subdirectory,
src/Makefile.am:318: warning: source file 'drivers/opencl/driver_opencl.c' is
in a subdirectory,
src/Makefile.am:318: but option 'subdir-objects' is disabled
src/Makefile.am:323: warning: source file 'drivers/scc/driver_scc_common.c'
src/Makefile.am:323: but option 'subdir-objects' is disabled
src/Makefile.am:323: warning: source file 'drivers/scc/driver_scc_source.c'
src/Makefile.am:323: warning: source file 'drivers/scc/driver_scc_sink.c' is
in a subdirectory,
src/Makefile.am:323: warning: source file 'drivers/scc/driver_scc_utils.c' is
in a subdirectory,
src/Makefile.am:330: warning: source file
'core/disk_ops/disk_unistd_o_direct.c' is in a subdirectory,
src/Makefile.am:330: but option 'subdir-objects' is disabled
src/Makefile.am:337: warning: source file 'util/starpu_clusters_create.c' is
in a subdirectory,
src/Makefile.am:337: but option 'subdir-objects' is disabled
src/Makefile.am:350: warning: source file 'drivers/mp_common/mp_common.c' is
in a subdirectory,
src/Makefile.am:350: but option 'subdir-objects' is disabled
src/Makefile.am:350: warning: source file 'drivers/mp_common/source_common.c'
src/Makefile.am:350: warning: source file 'drivers/mp_common/sink_common.c'
src/Makefile.am:362: warning: source file 'drivers/mic/driver_mic_common.c'
src/Makefile.am:362: but option 'subdir-objects' is disabled
src/Makefile.am:362: warning: source file 'drivers/mic/driver_mic_source.c'
src/Makefile.am:362: warning: source file 'drivers/mic/driver_mic_sink.c' is
in a subdirectory,
src/Makefile.am:362: warning: source file 'drivers/mic/driver_mic_utils.c' is
in a subdirectory,
starpufft/src/Makefile.am:44: 'starpu-mynvcc.mk' included from here
expansion
starpufft/tests/Makefile.am:40: warning: source file '../../tests/loader.c'
starpufft/tests/Makefile.am:40: but option 'subdir-objects' is disabled
tests/Makefile.am:75: 'starpu-mynvcc.mk' included from here
expansion
automake: warning: source file 'datawizard/acquire_cb.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'datawizard/acquire_cb'
automake: warning: source file 'datawizard/acquire_cb_insert.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program
'datawizard/acquire_cb_insert'
tests/Makefile.am:371: warning: source file 'datawizard/acquire_release.c' is
in a subdirectory,
tests/Makefile.am:371: but option 'subdir-objects' is disabled
tests/Makefile.am:378: warning: source file
'datawizard/acquire_release_opencl.c' is in a subdirectory,
tests/Makefile.am:378: but option 'subdir-objects' is disabled
tests/Makefile.am:384: warning: source file 'datawizard/acquire_release2.c'
tests/Makefile.am:384: but option 'subdir-objects' is disabled
tests/Makefile.am:391: warning: source file
tests/Makefile.am:391: but option 'subdir-objects' is disabled
automake: warning: source file 'datawizard/allocate.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'datawizard/allocate'
automake: warning: source file 'datawizard/cache.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/cache'
automake: warning: source file 'datawizard/commute.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/commute'
automake: warning: source file 'datawizard/commute2.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/commute2'
automake: warning: source file 'datawizard/copy.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/copy'
'datawizard/critical_section_with_void_interface.c' is in a subdirectory,
'datawizard/critical_section_with_void_interface'
automake: warning: source file 'datawizard/data_implicit_deps.c' is in a
subdirectory,
'datawizard/data_implicit_deps'
automake: warning: source file 'datawizard/data_invalidation.c' is in a
subdirectory,
'datawizard/data_invalidation'
automake: warning: source file 'datawizard/data_lookup.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/data_lookup'
automake: warning: source file 'datawizard/dining_philosophers.c' is in a
subdirectory,
'datawizard/dining_philosophers'
automake: warning: source file 'datawizard/double_parameter.c' is in a
subdirectory,
'datawizard/double_parameter'
automake: warning: source file 'datawizard/dsm_stress.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/dsm_stress'
tests/Makefile.am:504: warning: source file 'datawizard/gpu_ptr_register.c'
tests/Makefile.am:504: but option 'subdir-objects' is disabled
tests/Makefile.am:504: warning: source file 'datawizard/scal.c' is in a
subdirectory,
tests/Makefile.am:492: warning: source file 'datawizard/gpu_register.c' is in
a subdirectory,
tests/Makefile.am:492: but option 'subdir-objects' is disabled
tests/Makefile.am:492: warning: source file 'datawizard/scal.c' is in a
subdirectory,
automake: warning: source file 'datawizard/handle_to_pointer.c' is in a
subdirectory,
'datawizard/handle_to_pointer'
tests/Makefile.am:456: warning: source file 'datawizard/in_place_partition.c'
tests/Makefile.am:456: but option 'subdir-objects' is disabled
tests/Makefile.am:456: warning: source file 'datawizard/scal.c' is in a
subdirectory,
automake: warning: source file 'datawizard/increment_init.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/increment_init'
automake: warning: source file 'datawizard/increment_redux.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/increment_redux'
automake: warning: source file 'datawizard/increment_redux_lazy.c' is in a
subdirectory,
'datawizard/increment_redux_lazy'
automake: warning: source file 'datawizard/increment_redux_v2.c' is in a
subdirectory,
'datawizard/increment_redux_v2'
tests/Makefile.am:695: warning: source file
'datawizard/interfaces/test_interfaces.c' is in a subdirectory,
tests/Makefile.am:695: but option 'subdir-objects' is disabled
'datawizard/interfaces/bcsr/bcsr_interface.c' is in a subdirectory,
tests/Makefile.am:705: warning: source file
'datawizard/interfaces/bcsr/bcsr_opencl.c' is in a subdirectory,
tests/Makefile.am:705: but option 'subdir-objects' is disabled
tests/Makefile.am:676: warning: source file
tests/Makefile.am:676: but option 'subdir-objects' is disabled
'datawizard/interfaces/block/block_interface.c' is in a subdirectory,
tests/Makefile.am:686: warning: source file
'datawizard/interfaces/block/block_opencl.c' is in a subdirectory,
tests/Makefile.am:686: but option 'subdir-objects' is disabled
tests/Makefile.am:714: warning: source file
tests/Makefile.am:714: but option 'subdir-objects' is disabled
'datawizard/interfaces/coo/coo_interface.c' is in a subdirectory,
tests/Makefile.am:724: warning: source file
'datawizard/interfaces/coo/coo_opencl.c' is in a subdirectory,
tests/Makefile.am:724: but option 'subdir-objects' is disabled
automake: warning: source file 'datawizard/interfaces/copy_interfaces.c' is
in a subdirectory,
'datawizard/interfaces/copy_interfaces'
tests/Makefile.am:733: warning: source file
tests/Makefile.am:733: but option 'subdir-objects' is disabled
'datawizard/interfaces/csr/csr_interface.c' is in a subdirectory,
tests/Makefile.am:743: warning: source file
'datawizard/interfaces/csr/csr_opencl.c' is in a subdirectory,
tests/Makefile.am:743: but option 'subdir-objects' is disabled
tests/Makefile.am:769: warning: source file
tests/Makefile.am:769: but option 'subdir-objects' is disabled
'datawizard/interfaces/matrix/matrix_interface.c' is in a subdirectory,
tests/Makefile.am:779: warning: source file
'datawizard/interfaces/matrix/matrix_opencl.c' is in a subdirectory,
tests/Makefile.am:779: but option 'subdir-objects' is disabled
tests/Makefile.am:809: warning: source file
'datawizard/interfaces/multiformat/advanced/generic.c' is in a subdirectory,
tests/Makefile.am:809: but option 'subdir-objects' is disabled
'datawizard/interfaces/multiformat/advanced/multiformat_cuda_opencl.c' is in
a subdirectory,
tests/Makefile.am:813: warning: source file
tests/Makefile.am:813: but option 'subdir-objects' is disabled
'datawizard/interfaces/multiformat/advanced/multiformat_data_release.c' is in
a subdirectory,
tests/Makefile.am:821: warning: source file
tests/Makefile.am:821: but option 'subdir-objects' is disabled
'datawizard/interfaces/multiformat/advanced/multiformat_handle_conversion.c'
tests/Makefile.am:817: warning: source file
tests/Makefile.am:817: but option 'subdir-objects' is disabled
'datawizard/interfaces/multiformat/advanced/multiformat_worker.c' is in a
subdirectory,
tests/Makefile.am:825: warning: source file
tests/Makefile.am:825: but option 'subdir-objects' is disabled
'datawizard/interfaces/multiformat/advanced/same_handle.c' is in a
subdirectory,
tests/Makefile.am:789: warning: source file
tests/Makefile.am:789: but option 'subdir-objects' is disabled
'datawizard/interfaces/multiformat/multiformat_interface.c' is in a
subdirectory,
'datawizard/interfaces/multiformat/multiformat_conversion_codelets.c' is in a
subdirectory,
tests/Makefile.am:801: warning: source file
'datawizard/interfaces/multiformat/multiformat_opencl.c' is in a subdirectory,
tests/Makefile.am:801: but option 'subdir-objects' is disabled
'datawizard/interfaces/multiformat/multiformat_conversion_codelets_opencl.c'
tests/Makefile.am:830: warning: source file
tests/Makefile.am:830: but option 'subdir-objects' is disabled
'datawizard/interfaces/variable/variable_interface.c' is in a subdirectory,
tests/Makefile.am:840: warning: source file
'datawizard/interfaces/variable/variable_opencl.c' is in a subdirectory,
tests/Makefile.am:840: but option 'subdir-objects' is disabled
tests/Makefile.am:750: warning: source file
'datawizard/interfaces/vector/test_vector_interface.c' is in a subdirectory,
tests/Makefile.am:750: but option 'subdir-objects' is disabled
tests/Makefile.am:760: warning: source file
'datawizard/interfaces/vector/test_vector_opencl.c' is in a subdirectory,
tests/Makefile.am:760: but option 'subdir-objects' is disabled
tests/Makefile.am:849: warning: source file
tests/Makefile.am:849: but option 'subdir-objects' is disabled
'datawizard/interfaces/void/void_interface.c' is in a subdirectory,
automake: warning: source file 'datawizard/lazy_allocation.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/lazy_allocation'
automake: warning: source file 'datawizard/lazy_unregister.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/lazy_unregister'
automake: warning: source file 'datawizard/locality.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'datawizard/locality'
automake: warning: source file 'datawizard/manual_reduction.c' is in a
subdirectory,
'datawizard/manual_reduction'
tests/Makefile.am:408: warning: source file 'datawizard/mpi_like.c' is in a
subdirectory,
tests/Makefile.am:408: but option 'subdir-objects' is disabled
tests/Makefile.am:415: warning: source file
'datawizard/opencl_codelet_unsigned_inc.c' is in a subdirectory,
tests/Makefile.am:415: but option 'subdir-objects' is disabled
tests/Makefile.am:421: warning: source file 'datawizard/mpi_like_async.c' is
in a subdirectory,
tests/Makefile.am:421: but option 'subdir-objects' is disabled
tests/Makefile.am:428: warning: source file
tests/Makefile.am:428: but option 'subdir-objects' is disabled
automake: warning: source file 'datawizard/no_unregister.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/no_unregister'
automake: warning: source file 'datawizard/noreclaim.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/noreclaim'
automake: warning: source file 'datawizard/nowhere.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/nowhere'
tests/Makefile.am:468: warning: source file 'datawizard/partition_dep.c' is
in a subdirectory,
tests/Makefile.am:468: but option 'subdir-objects' is disabled
tests/Makefile.am:468: warning: source file 'datawizard/scal.c' is in a
subdirectory,
tests/Makefile.am:480: warning: source file 'datawizard/partition_lazy.c' is
in a subdirectory,
tests/Makefile.am:480: but option 'subdir-objects' is disabled
tests/Makefile.am:480: warning: source file 'datawizard/scal.c' is in a
subdirectory,
automake: warning: source file 'datawizard/readers_and_writers.c' is in a
subdirectory,
'datawizard/readers_and_writers'
automake: warning: source file 'datawizard/readonly.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/readonly'
automake: warning: source file 'datawizard/reclaim.c' is in a subdirectory,
tests/Makefile.am:342: while processing program 'datawizard/reclaim'
tests/Makefile.am:395: warning: source file 'datawizard/scratch.c' is in a
subdirectory,
tests/Makefile.am:395: but option 'subdir-objects' is disabled
tests/Makefile.am:402: warning: source file 'datawizard/scratch_opencl.c' is
in a subdirectory,
tests/Makefile.am:402: but option 'subdir-objects' is disabled
automake: warning: source file 'datawizard/simgrid-locality.c' is in a
subdirectory,
'datawizard/simgrid-locality'
tests/Makefile.am:521: warning: source file 'datawizard/specific_node.c' is
in a subdirectory,
tests/Makefile.am:521: but option 'subdir-objects' is disabled
tests/Makefile.am:528: warning: source file
tests/Makefile.am:528: but option 'subdir-objects' is disabled
tests/Makefile.am:432: warning: source file
'datawizard/sync_and_notify_data.c' is in a subdirectory,
tests/Makefile.am:432: but option 'subdir-objects' is disabled
tests/Makefile.am:439: warning: source file
'datawizard/sync_and_notify_data_opencl.c' is in a subdirectory,
tests/Makefile.am:439: but option 'subdir-objects' is disabled
tests/Makefile.am:445: warning: source file
'datawizard/sync_and_notify_data_implicit.c' is in a subdirectory,
tests/Makefile.am:445: but option 'subdir-objects' is disabled
tests/Makefile.am:452: warning: source file
tests/Makefile.am:452: but option 'subdir-objects' is disabled
automake: warning: source file 'datawizard/sync_with_data_with_mem.c' is in a
subdirectory,
'datawizard/sync_with_data_with_mem'
'datawizard/sync_with_data_with_mem_non_blocking.c' is in a subdirectory,
'datawizard/sync_with_data_with_mem_non_blocking'
'datawizard/sync_with_data_with_mem_non_blocking_implicit.c' is in a
subdirectory,
'datawizard/sync_with_data_with_mem_non_blocking_implicit'
'datawizard/task_with_multiple_time_the_same_handle.c' is in a subdirectory,
'datawizard/task_with_multiple_time_the_same_handle'
tests/Makefile.am:532: warning: source file 'datawizard/test_arbiter.cpp' is
in a subdirectory,
tests/Makefile.am:532: but option 'subdir-objects' is disabled
automake: warning: source file 'datawizard/unpartition.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'datawizard/unpartition'
automake: warning: source file 'datawizard/user_interaction_implicit.c' is in
a subdirectory,
'datawizard/user_interaction_implicit'
automake: warning: source file 'datawizard/variable_parameters.c' is in a
subdirectory,
'datawizard/variable_parameters'
automake: warning: source file 'datawizard/write_only_tmp_buffer.c' is in a
subdirectory,
'datawizard/write_only_tmp_buffer'
tests/Makefile.am:518: warning: source file 'datawizard/wt_broadcast.c' is in
a subdirectory,
tests/Makefile.am:518: but option 'subdir-objects' is disabled
tests/Makefile.am:516: warning: source file 'datawizard/wt_host.c' is in a
subdirectory,
tests/Makefile.am:516: but option 'subdir-objects' is disabled
automake: warning: source file 'disk/disk_compute.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'disk/disk_compute'
automake: warning: source file 'disk/disk_copy.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'disk/disk_copy'
automake: warning: source file 'disk/disk_pack.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'disk/disk_pack'
automake: warning: source file 'disk/mem_reclaim.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'disk/mem_reclaim'
automake: warning: source file 'errorcheck/invalid_blocking_calls.c' is in a
subdirectory,
'errorcheck/invalid_blocking_calls'
automake: warning: source file 'errorcheck/invalid_tasks.c' is in a
subdirectory,
tests/Makefile.am:126: while processing program 'errorcheck/invalid_tasks'
automake: warning: source file 'errorcheck/starpu_init_noworker.c' is in a
subdirectory,
'errorcheck/starpu_init_noworker'
automake: warning: source file 'errorcheck/workers_cpuid.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'errorcheck/workers_cpuid'
tests/Makefile.am:668: warning: source file
tests/Makefile.am:668: but option 'subdir-objects' is disabled
tests/Makefile.am:668: warning: source file 'fortran90/init_01.f90' is in a
subdirectory,
automake: warning: source file 'helper/cublas_init.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'helper/cublas_init'
automake: warning: source file 'helper/execute_on_all.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'helper/execute_on_all'
automake: warning: source file 'helper/pinned_memory.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'helper/pinned_memory'
automake: warning: source file 'helper/starpu_create_sync_task.c' is in a
subdirectory,
'helper/starpu_create_sync_task'
automake: warning: source file 'helper/starpu_data_cpy.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'helper/starpu_data_cpy'
automake: warning: source file 'main/codelet_null_callback.c' is in a
subdirectory,
tests/Makefile.am:126: while processing program 'main/codelet_null_callback'
automake: warning: source file 'main/declare_deps_after_submission.c' is in a
subdirectory,
automake: but option 'subdir-objects' is disabled
'main/declare_deps_after_submission'
'main/declare_deps_after_submission_synchronous.c' is in a subdirectory,
'main/declare_deps_after_submission_synchronous'
automake: warning: source file 'main/declare_deps_in_callback.c' is in a
subdirectory,
'main/declare_deps_in_callback'
automake: warning: source file 'main/deploop.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/deploop'
automake: warning: source file 'main/deprecated_func.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/deprecated_func'
automake: warning: source file 'main/driver_api/init_run_deinit.c' is in a
subdirectory,
'main/driver_api/init_run_deinit'
automake: warning: source file 'main/driver_api/run_driver.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'main/driver_api/run_driver'
automake: warning: source file 'main/empty_task.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'main/empty_task'
automake: warning: source file 'main/empty_task_chain.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'main/empty_task_chain'
automake: warning: source file 'main/empty_task_sync_point.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'main/empty_task_sync_point'
automake: warning: source file 'main/empty_task_sync_point_tasks.c' is in a
subdirectory,
'main/empty_task_sync_point_tasks'
automake: warning: source file 'main/execute_on_a_specific_worker.c' is in a
subdirectory,
'main/execute_on_a_specific_worker'
automake: warning: source file 'main/execute_schedule.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'main/execute_schedule'
automake: warning: source file 'main/get_children_tasks.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'main/get_children_tasks'
automake: warning: source file 'main/get_current_task.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/get_current_task'
automake: warning: source file 'main/insert_task.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/insert_task'
automake: warning: source file 'main/insert_task_array.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'main/insert_task_array'
automake: warning: source file 'main/insert_task_dyn_handles.c' is in a
subdirectory,
'main/insert_task_dyn_handles'
automake: warning: source file 'main/insert_task_many.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/insert_task_many'
automake: warning: source file 'main/insert_task_nullcodelet.c' is in a
subdirectory,
'main/insert_task_nullcodelet'
automake: warning: source file 'main/insert_task_pack.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'main/insert_task_pack'
automake: warning: source file 'main/insert_task_value.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'main/insert_task_value'
automake: warning: source file 'main/multithreaded.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/multithreaded'
automake: warning: source file 'main/multithreaded_init.c' is in a
subdirectory,
tests/Makefile.am:126: while processing program 'main/multithreaded_init'
automake: warning: source file 'main/pack.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/pack'
automake: warning: source file 'main/pause_resume.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/pause_resume'
automake: warning: source file 'main/regenerate.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/regenerate'
automake: warning: source file 'main/regenerate_pipeline.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'main/regenerate_pipeline'
automake: warning: source file 'main/restart.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'main/restart'
automake: warning: source file 'main/starpu_init.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/starpu_init'
automake: warning: source file 'main/starpu_task_bundle.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'main/starpu_task_bundle'
automake: warning: source file 'main/starpu_task_wait.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/starpu_task_wait'
automake: warning: source file 'main/starpu_task_wait_for_all.c' is in a
subdirectory,
'main/starpu_task_wait_for_all'
automake: warning: source file 'main/starpu_worker_exists.c' is in a
subdirectory,
tests/Makefile.am:126: while processing program 'main/starpu_worker_exists'
automake: warning: source file 'main/static_restartable.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'main/static_restartable'
automake: warning: source file 'main/static_restartable_tag.c' is in a
subdirectory,
'main/static_restartable_tag'
automake: warning: source file 'main/static_restartable_using_initializer.c'
'main/static_restartable_using_initializer'
tests/Makefile.am:537: warning: source file 'main/subgraph_repeat.c' is in a
subdirectory,
tests/Makefile.am:537: but option 'subdir-objects' is disabled
tests/Makefile.am:551: warning: source file
'main/subgraph_repeat_regenerate.c' is in a subdirectory,
tests/Makefile.am:551: but option 'subdir-objects' is disabled
tests/Makefile.am:558: warning: source file
'main/subgraph_repeat_regenerate_tag.c' is in a subdirectory,
tests/Makefile.am:558: but option 'subdir-objects' is disabled
tests/Makefile.am:544: warning: source file 'main/subgraph_repeat_tag.c' is
in a subdirectory,
tests/Makefile.am:544: but option 'subdir-objects' is disabled
automake: warning: source file 'main/submit.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/submit'
automake: warning: source file 'main/tag_get_task.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/tag_get_task'
automake: warning: source file 'main/tag_task_data_deps.c' is in a
subdirectory,
tests/Makefile.am:342: while processing program 'main/tag_task_data_deps'
automake: warning: source file 'main/tag_wait_api.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/tag_wait_api'
automake: warning: source file 'main/task_wait_api.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'main/task_wait_api'
automake: warning: source file 'main/wait_all_regenerable_tasks.c' is in a
subdirectory,
'main/wait_all_regenerable_tasks'
automake: warning: source file 'microbenchs/async_tasks_overhead.c' is in a
subdirectory,
'microbenchs/async_tasks_overhead'
automake: warning: source file 'microbenchs/display_structures_size.c' is in
a subdirectory,
'microbenchs/display_structures_size'
automake: warning: source file 'microbenchs/local_pingpong.c' is in a
subdirectory,
tests/Makefile.am:126: while processing program 'microbenchs/local_pingpong'
automake: warning: source file 'microbenchs/matrix_as_vector.c' is in a
subdirectory,
'microbenchs/matrix_as_vector'
'microbenchs/parallel_dependent_homogeneous_tasks_data.c' is in a
subdirectory,
tests/Makefile.am:324: while processing program
'microbenchs/parallel_dependent_homogeneous_tasks_data'
'microbenchs/parallel_independent_heterogeneous_tasks.c' is in a subdirectory,
'microbenchs/parallel_independent_heterogeneous_tasks'
'microbenchs/parallel_independent_heterogeneous_tasks_data.c' is in a
subdirectory,
'microbenchs/parallel_independent_heterogeneous_tasks_data'
'microbenchs/parallel_independent_homogeneous_tasks.c' is in a subdirectory,
'microbenchs/parallel_independent_homogeneous_tasks'
'microbenchs/parallel_independent_homogeneous_tasks_data.c' is in a
subdirectory,
'microbenchs/parallel_independent_homogeneous_tasks_data'
automake: warning: source file 'microbenchs/prefetch_data_on_node.c' is in a
subdirectory,
'microbenchs/prefetch_data_on_node'
automake: warning: source file 'microbenchs/redundant_buffer.c' is in a
subdirectory,
'microbenchs/redundant_buffer'
automake: warning: source file 'microbenchs/sync_tasks_overhead.c' is in a
subdirectory,
'microbenchs/sync_tasks_overhead'
automake: warning: source file 'microbenchs/tasks_overhead.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'microbenchs/tasks_overhead'
automake: warning: source file 'microbenchs/tasks_size_overhead.c' is in a
subdirectory,
'microbenchs/tasks_size_overhead'
tests/Makefile.am:577: warning: source file 'openmp/api_01.c' is in a
subdirectory,
tests/Makefile.am:577: but option 'subdir-objects' is disabled
tests/Makefile.am:661: warning: source file 'openmp/array_slice_01.c' is in a
subdirectory,
tests/Makefile.am:661: but option 'subdir-objects' is disabled
tests/Makefile.am:664: warning: source file 'openmp/cuda_task_01.c' is in a
subdirectory,
tests/Makefile.am:664: but option 'subdir-objects' is disabled
tests/Makefile.am:574: warning: source file 'openmp/environment.c' is in a
subdirectory,
tests/Makefile.am:574: but option 'subdir-objects' is disabled
tests/Makefile.am:568: warning: source file 'openmp/init_exit_01.c' is in a
subdirectory,
tests/Makefile.am:568: but option 'subdir-objects' is disabled
tests/Makefile.am:571: warning: source file 'openmp/init_exit_02.c' is in a
subdirectory,
tests/Makefile.am:571: but option 'subdir-objects' is disabled
tests/Makefile.am:580: warning: source file 'openmp/parallel_01.c' is in a
subdirectory,
tests/Makefile.am:580: but option 'subdir-objects' is disabled
tests/Makefile.am:583: warning: source file 'openmp/parallel_02.c' is in a
subdirectory,
tests/Makefile.am:583: but option 'subdir-objects' is disabled
tests/Makefile.am:586: warning: source file 'openmp/parallel_03.c' is in a
subdirectory,
tests/Makefile.am:586: but option 'subdir-objects' is disabled
tests/Makefile.am:589: warning: source file 'openmp/parallel_barrier_01.c' is
in a subdirectory,
tests/Makefile.am:589: but option 'subdir-objects' is disabled
tests/Makefile.am:613: warning: source file 'openmp/parallel_critical_01.c'
tests/Makefile.am:613: but option 'subdir-objects' is disabled
tests/Makefile.am:616: warning: source file
'openmp/parallel_critical_inline_01.c' is in a subdirectory,
tests/Makefile.am:616: but option 'subdir-objects' is disabled
tests/Makefile.am:619: warning: source file
'openmp/parallel_critical_named_01.c' is in a subdirectory,
tests/Makefile.am:619: but option 'subdir-objects' is disabled
tests/Makefile.am:622: warning: source file
'openmp/parallel_critical_named_inline_01.c' is in a subdirectory,
tests/Makefile.am:622: but option 'subdir-objects' is disabled
tests/Makefile.am:631: warning: source file 'openmp/parallel_for_01.c' is in
a subdirectory,
tests/Makefile.am:631: but option 'subdir-objects' is disabled
tests/Makefile.am:634: warning: source file 'openmp/parallel_for_02.c' is in
a subdirectory,
tests/Makefile.am:634: but option 'subdir-objects' is disabled
tests/Makefile.am:637: warning: source file
'openmp/parallel_for_ordered_01.c' is in a subdirectory,
tests/Makefile.am:637: but option 'subdir-objects' is disabled
tests/Makefile.am:592: warning: source file 'openmp/parallel_master_01.c' is
in a subdirectory,
tests/Makefile.am:592: but option 'subdir-objects' is disabled
tests/Makefile.am:595: warning: source file
'openmp/parallel_master_inline_01.c' is in a subdirectory,
tests/Makefile.am:595: but option 'subdir-objects' is disabled
tests/Makefile.am:628: warning: source file
'openmp/parallel_nested_lock_01.c' is in a subdirectory,
tests/Makefile.am:628: but option 'subdir-objects' is disabled
tests/Makefile.am:640: warning: source file 'openmp/parallel_sections_01.c'
tests/Makefile.am:640: but option 'subdir-objects' is disabled
tests/Makefile.am:643: warning: source file
'openmp/parallel_sections_combined_01.c' is in a subdirectory,
tests/Makefile.am:643: but option 'subdir-objects' is disabled
tests/Makefile.am:625: warning: source file
'openmp/parallel_simple_lock_01.c' is in a subdirectory,
tests/Makefile.am:625: but option 'subdir-objects' is disabled
tests/Makefile.am:607: warning: source file
'openmp/parallel_single_copyprivate_01.c' is in a subdirectory,
tests/Makefile.am:607: but option 'subdir-objects' is disabled
tests/Makefile.am:610: warning: source file
'openmp/parallel_single_copyprivate_inline_01.c' is in a subdirectory,
tests/Makefile.am:610: but option 'subdir-objects' is disabled
tests/Makefile.am:604: warning: source file
'openmp/parallel_single_inline_01.c' is in a subdirectory,
tests/Makefile.am:604: but option 'subdir-objects' is disabled
tests/Makefile.am:601: warning: source file
'openmp/parallel_single_nowait_01.c' is in a subdirectory,
tests/Makefile.am:601: but option 'subdir-objects' is disabled
tests/Makefile.am:598: warning: source file
'openmp/parallel_single_wait_01.c' is in a subdirectory,
tests/Makefile.am:598: but option 'subdir-objects' is disabled
tests/Makefile.am:646: warning: source file 'openmp/task_01.c' is in a
subdirectory,
tests/Makefile.am:646: but option 'subdir-objects' is disabled
tests/Makefile.am:649: warning: source file 'openmp/task_02.c' is in a
subdirectory,
tests/Makefile.am:649: but option 'subdir-objects' is disabled
tests/Makefile.am:655: warning: source file 'openmp/taskgroup_01.c' is in a
subdirectory,
tests/Makefile.am:655: but option 'subdir-objects' is disabled
tests/Makefile.am:658: warning: source file 'openmp/taskgroup_02.c' is in a
subdirectory,
tests/Makefile.am:658: but option 'subdir-objects' is disabled
tests/Makefile.am:652: warning: source file 'openmp/taskwait_01.c' is in a
subdirectory,
tests/Makefile.am:652: but option 'subdir-objects' is disabled
tests/Makefile.am:854: warning: source file 'overlap/gpu_concurrency.c' is in
a subdirectory,
tests/Makefile.am:854: but option 'subdir-objects' is disabled
automake: warning: source file 'overlap/overlap.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'overlap/overlap'
automake: warning: source file 'parallel_tasks/cuda_only.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'parallel_tasks/cuda_only'
automake: warning: source file 'parallel_tasks/explicit_combined_worker.c' is
in a subdirectory,
'parallel_tasks/explicit_combined_worker'
automake: warning: source file 'parallel_tasks/parallel_kernels.c' is in a
subdirectory,
'parallel_tasks/parallel_kernels'
automake: warning: source file 'parallel_tasks/parallel_kernels_spmd.c' is in
a subdirectory,
'parallel_tasks/parallel_kernels_spmd'
automake: warning: source file 'parallel_tasks/spmd_peager.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'parallel_tasks/spmd_peager'
tests/Makefile.am:879: warning: source file 'perfmodels/feed.c' is in a
subdirectory,
tests/Makefile.am:879: but option 'subdir-objects' is disabled
automake: warning: source file 'perfmodels/memory.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'perfmodels/memory'
tests/Makefile.am:871: warning: source file
'perfmodels/non_linear_regression_based.c' is in a subdirectory,
tests/Makefile.am:871: but option 'subdir-objects' is disabled
tests/Makefile.am:875: warning: source file 'perfmodels/opencl_memset.c' is
in a subdirectory,
tests/Makefile.am:875: but option 'subdir-objects' is disabled
tests/Makefile.am:861: warning: source file 'perfmodels/regression_based.c'
tests/Makefile.am:861: but option 'subdir-objects' is disabled
tests/Makefile.am:865: warning: source file 'perfmodels/opencl_memset.c' is
in a subdirectory,
tests/Makefile.am:865: but option 'subdir-objects' is disabled
automake: warning: source file 'perfmodels/user_base.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'perfmodels/user_base'
automake: warning: source file 'perfmodels/valid_model.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'perfmodels/valid_model'
automake: warning: source file 'perfmodels/value_nan.c' is in a subdirectory,
tests/Makefile.am:126: while processing program 'perfmodels/value_nan'
tests/Makefile.am:565: warning: source file 'sched_ctx/sched_ctx_list.c' is
in a subdirectory,
tests/Makefile.am:565: but option 'subdir-objects' is disabled
automake: warning: source file 'sched_policies/data_locality.c' is in a
subdirectory,
'sched_policies/data_locality'
automake: warning: source file 'sched_policies/execute_all_tasks.c' is in a
subdirectory,
'sched_policies/execute_all_tasks'
automake: warning: source file 'sched_policies/prio.c' is in a subdirectory,
tests/Makefile.am:155: while processing program 'sched_policies/prio'
automake: warning: source file 'sched_policies/simple_cpu_gpu_sched.c' is in
a subdirectory,
'sched_policies/simple_cpu_gpu_sched'
automake: warning: source file 'sched_policies/simple_deps.c' is in a
subdirectory,
tests/Makefile.am:155: while processing program 'sched_policies/simple_deps'
tools/Makefile.am:178: warning: source file '../tests/loader.c' is in a
subdirectory,
tools/Makefile.am:178: but option 'subdir-objects' is disabled
autoreconf: Leaving directory `.'
==> './configure'
'--prefix=/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/starpu-svn-trunk-ew2ffhhvxulnikubqm76rijyluvps7ho'
'--disable-build-doc' '--disable-starpu-top'
'--with-fxt=/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck'
'--enable-paje-codelet-details'
'--with-hwloc=/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx'
'--without-mpicc' '--disable-cuda' '--disable-opencl' '--enable-openmp=no'
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether make supports nested variables... (cached) yes
checking for style of include used by make... GNU
checking for gcc... /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc accepts
-g... yes
checking for /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc option to
accept ISO C89... none needed
checking whether /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc understands
-c and -o together... yes
checking dependency style of
/home/lschnorr/spack-orion/lib/spack/env/gcc/gcc... gcc3
checking for ar... ar
checking the archiver (ar) interface... ar
checking for gcc... (cached) /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc
checking whether we are using the GNU C compiler... (cached) yes
-g... (cached) yes
accept ISO C89... (cached) none needed
-c and -o together... (cached) yes
/home/lschnorr/spack-orion/lib/spack/env/gcc/gcc... (cached) gcc3
checking whether we are using the GNU C++ compiler... yes
checking whether /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ accepts
-g... yes
/home/lschnorr/spack-orion/lib/spack/env/gcc/g++... gcc3
checking how to run the C preprocessor...
/home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E
checking for a sed that does not truncate output... /bin/sed
checking whether ln -s works... yes
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran
accepts -g... yes
checking whether we are using the GNU Fortran compiler... yes
accepts -g... yes
checking for gstat... gstat
checking for gdate... no
checking for date... date
checking how to print strings... printf
checking for a sed that does not truncate output... (cached) /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc...
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld
checking if the linker
(/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld)
is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu
format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format...
checking for
option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from
/home/lschnorr/spack-orion/lib/spack/env/gcc/gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc supports
-fno-rtti -fno-exceptions... no
produce PIC... -fPIC -DPIC
checking if /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc PIC flag -fPIC
-DPIC works... yes
checking if /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc static flag
-static works... yes
checking if /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc supports -c -o
file.o... yes
file.o... (cached) yes
checking whether the /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc linker
-m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking how to run the C++ preprocessor...
/home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -E
checking for ld used by /home/lschnorr/spack-orion/lib/spack/env/gcc/g++...
-m elf_x86_64
-m elf_x86_64) is GNU ld... yes
checking whether the /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ linker
checking for /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ option to
checking if /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ PIC flag -fPIC
-DPIC works... yes
checking if /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ static flag
checking if /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ supports -c -o
file.o... yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking for /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran option to
checking if /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran PIC flag
-fPIC works... yes
checking if /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran static flag
checking if /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran supports -c
-o file.o... yes
-o file.o... (cached) yes
checking whether the /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran
linker
-fPIC works... yes
-o file.o... yes
linker
checking for ANSI C header files... (cached) yes
checking for C/C++ restrict keyword... __restrict
checking for bash... /bin/bash
checking for svn... /usr/bin/svn
checking for svnversion... /usr/bin/svnversion
checking for lib... no
checking size of void *... 8
checking for struct timespec... yes
checking for unistd.h... (cached) yes
checking for pthread_create in -lpthread... yes
checking for library containing sqrt... -lm
checking for main in -lws2_32... no
checking for sysconf... yes
checking for pthread_spin_lock... yes
checking for pthread_barrier_init... yes
checking for pthread_setaffinity_np... yes
checking for posix_memalign... yes
checking for memalign... yes
checking for drand48... yes
checking for erand48_r... yes
checking for strerror_r... yes
checking for setenv... yes
checking for unsetenv... yes
checking for nearbyintf... yes
checking for rintf... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking valgrind/valgrind.h usability... yes
checking valgrind/valgrind.h presence... yes
checking for valgrind/valgrind.h... yes
checking valgrind/memcheck.h usability... yes
checking valgrind/memcheck.h presence... yes
checking for valgrind/memcheck.h... yes
checking valgrind/helgrind.h usability... yes
checking valgrind/helgrind.h presence... yes
checking for valgrind/helgrind.h... yes
checking for sched_yield... yes
checking aio.h usability... yes
checking aio.h presence... yes
checking for aio.h... yes
checking for mkostemp... yes
checking for pread... yes
checking for pwrite... yes
checking whether the target supports __sync_val_compare_and_swap... yes
checking whether the target supports __sync_bool_compare_and_swap... yes
checking whether the target supports __sync_fetch_and_add... yes
checking whether the target supports __sync_fetch_and_or... yes
checking whether the target supports __sync_lock_test_and_set... yes
checking whether the target supports __sync_synchronize... yes
checking for library containing set_mempolicy... -lnuma
checking whether libnuma is available... yes
checking maximum number of sched_ctxs... 10
checking maximum number of CPUs... 64
checking whether CPUs should be used... yes
checking maximum number of CUDA devices... 4
checking whether CUDA should be used... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking whether MAGMA should be used... no
checking for cufftDoubleComplex... no
checking whether CURAND is available... no
checking maximum number of OpenCL devices... 8
checking whether OpenCL should be used... no
checking whether asynchronous copy should be disabled... no
checking whether asynchronous CUDA copy should be disabled... no
checking whether asynchronous OpenCL copy should be disabled... no
checking whether asynchronous MIC copy should be disabled... no
checking whether SimGrid is enabled... no
checking whether blocking drivers should be enabled... no
checking maximum number of MIC devices... 4
checking maximum number of MIC threads...
checking RCCE.h usability... no
checking RCCE.h presence... no
checking for RCCE.h... no
checking for RCCE_init in -lRCCE_bigflags_nongory_nopwrmgmt... no
checking whether RCCE should be used... no
checking Maximum number of message-passing kernels... 10
checking whether debug mode should be enabled... no
checking whether extra checks should be performed... no
checking whether debug messages should be displayed... no
checking whether coverage testing should be enabled... no
checking whether coverity mode should be enabled... no
checking whether FxT traces should be generated... yes using
checking for FXT... yes
checking for enable_fut_flush... yes
checking for fut_set_filename... yes
checking whether enable_fut_flush is declared... no
checking whether fut_set_filename is declared... no
checking for POTI... no
checking whether additional locking systems FxT traces should be enabled... no
checking whether performance debugging should be enabled... no
checking whether performance model debugging should be enabled... no
checking whether memory stats should be displayed... no
checking glpk.h usability... no
checking glpk.h presence... no
checking for glpk.h... no
checking for main in -lglpk... no
checking Ayudame.h usability... no
checking Ayudame.h presence... no
checking for Ayudame.h... no
checking how many buffers can be manipulated per task... 8
checking maximum number of nodes to use... checking maximum number of memory
nodes... 4
checking whether allocation cache should be used... yes
checking using explicit performance model location... no
checking performance models location... $HOME/.starpu/sampling/
checking for clock_gettime in -lrt... yes
checking for clock_gettime... yes
checking Maximum number of workers... 64
checking Maximum number of workers combinations... 64
checking maximum number of implementations... 4
checking calibration heuristic of history-based StarPU calibrator... 50
The mpicc compiler 'no' does not have the execute permission
checking mpicc path... no
checking for mpiexec... no
checking whether mpiexec is available... no
The mpiexec script is not valid
checking whether the StarPU MPI library should be generated... no
checking for StarPU-Top... checking whether compiler support -Wall... yes
checking whether compiler support -Werror=implicit... yes
checking whether compiler support -Werror=implicit-function-declaration... yes
checking whether GCC supports plug-ins... no
configure: WARNING: GCC plug-ins not supported; StarPU's GCC plug-in will not
be built
checking for OpenMP runtime support... no
checking for SOCL... no
checking for gdb... /usr/bin/gdb
checking whether OpenGL rendering is enabled... no
checking for X... no
checking for library containing sgemm_... -lblas
checking which BLAS lib should be used... system
checking for FFTW... no
checking for FFTWF... no
checking for FFTWL... no
checking hwloc.h usability... yes
checking hwloc.h presence... yes
checking for hwloc.h... yes
checking for main in -lhwloc... no
configure: error: cannot find hwloc
Haut de le page
