Archives de la liste
Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5
Chronologique Discussions
- To: Nathalie Furmento <nathalie.furmento@labri.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5
- Date: Wed, 17 Aug 2016 17:02:36 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=schnorr@inf.ufrgs.br; spf=Pass smtp.mailfrom=schnorr@inf.ufrgs.br; spf=None smtp.helo=postmaster@smtp.inf.ufrgs.br
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
This is a multi-part message in MIME format. Hi Nathalie,
On 08/17/2016 04:02 PM, Nathalie Furmento wrote:
Could you also please send the config.log file of StarPU?
Attached to this e-mail.
configure.ac checks the availability of the library with
LDFLAGS="${SAVED_LDFLAGS} -L$hwloc_dir/lib"
AC_HAVE_LIBRARY([hwloc],[have_valid_hwloc=yes],[have_valid_hwloc=no])
Could you check the contents of the directory /home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib ?
Here are the contents:
lschnorr@orion-4:~/spack-orion$ find /home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib/libhwloc.so
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib/libhwloc.la
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib/pkgconfig
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib/pkgconfig/hwloc.pc
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib/libhwloc.so.5
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib/libhwloc.so.5.7.0
A+
Lucas
Lucas M. Schnorr, UFRGS
http://www.inf.ufrgs.br/~schnorr/
This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by StarPU configure 1.3.0, which was generated by GNU Autoconf 2.69. Invocation command line was $ ./configure --prefix=/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/starpu-svn-trunk-ew2ffhhvxulnikubqm76rijyluvps7ho --disable-build-doc --disable-starpu-top --with-fxt=/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck --enable-paje-codelet-details --with-hwloc=/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx --without-mpicc --disable-cuda --disable-opencl --enable-openmp=no ## --------- ## ## Platform. ## ## --------- ## hostname = orion-4.lyon.grid5000.fr uname -m = x86_64 uname -r = 4.6.0-1-amd64 uname -s = Linux uname -v = #1 SMP Debian 4.6.4-1 (2016-07-18) /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = unknown /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown
- [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Lucas M. Schnorr, 17/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Nathalie Furmento, 17/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Lucas M. Schnorr, 17/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Nathalie Furmento, 18/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Lucas M. Schnorr, 18/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Brice Goglin, 18/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Samuel Thibault, 18/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Florent Pruvost, 18/08/2016
