Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5
Archives de la liste
Chronologique Discussions
  • To: Florent Pruvost <florent.pruvost@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5
  • Date: Thu, 18 Aug 2016 15:33:30 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23:f3neohdAt+duBgGkopq3PlLplGMj4u6mDksu8pMizoh2WeGdxc+6bB7h7PlgxGXEQZ/co6odzbGH6ua6BSdeut7B6ClEK80UEUddyI0/pE8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUrDbg8n/7e2u4ZqbO1wO32vkJ+kuZ0vt5UWJ749N0NMkcv5wgjLy4VJwM9xMwm1pIV/B1z3d3eyXuKBZziJLpvg6/NRBW6ipN44xTLhfESh0ezttvJ6jnVD5QACO/noRVHkN2loNWlCdrUKyYpCknC/9rOd7xGGiJ9DoSqsoEWCs66BxRRn0zj8dKiA+633/i8pqjasdrgj39DJlxIuBW4iQKfd6Np/dfNkTWG5dFpJKXilcD4f6c4sOBeMcOfpwro/nplJIowHoVlrkP//m1jId3iy+5qY9yel0VFiehAE=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Florent Pruvost, on Thu 18 Aug 2016 15:28:05 +0200, wrote:
> Le 18/08/2016 14:17, Nathalie Furmento a écrit :
> > It's likely you need to add in your LD_LIBRARY_PATH the
> >path to the OpenCL library.
> In spack, the LD_LIBRARY_PATH is unset to avoid being polluted by the
> external environment.
Mmm... That might have to be reconsidered: how can starpu etc. work if
cuda etc. are not installed in the standard location?
Samuel
Haut de le page
