Archives de la liste
Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5
- Date: Thu, 18 Aug 2016 18:30:59 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=schnorr@inf.ufrgs.br; spf=Pass smtp.mailfrom=schnorr@inf.ufrgs.br; spf=None smtp.helo=postmaster@smtp.inf.ufrgs.br
- Ironport-phdr: 9a23:QeogBBZ8pvwNS9qvB0uqPAP/LSx+4OfEezUN459isYplN5qZpcW7bnLW6fgltlLVR4KTs6sC0LuP9fq8Ej1eqdbZ6TZZIcQKD0dEwewt3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9JIfegoyN2vyo/NWLOkMT1WP7O+85fUv+7V2I8JJH2c06cud54yCKi0MAQ/5Ry2JsKADbtDfHzeD0wqRe9T9Nsekq7c9KXPayVa05SbtFEGZuaDhtt4XdnEKcFk7XujNcDz1XwVJ0BF3e8BjgRoq0vibku+5V3CiBIdawQr4zQzuvqaZtUh7hzikdZBAj92SCwOhth6tA6Dfn7yd0w4jTepvffK5ldaPbeskAbWtHUIBMWTZOGcW2dd1cXKI6Ie9Eotyl9BM1phykCFzxXO4=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi,
On 08/18/2016 03:28 PM, Florent Pruvost wrote:
So Lucas can you try to figure out how hwloc was able to detect opencl on your system and understand why your linker is not able to retreive it?
It seems your libOpenCL.so is not located in some standard system paths so check the output files build.env and build.out into the .spack/ sub-directory of your hwloc installation, maybe you can get some intel on how hwloc found opencl?!
The g5k image was created from jessie-x64-std then dist-upgraded to debian stretch (testing). It had opencl-headers installed, making hwloc believe there was some opencl library installed, which is not the case. Removing the opencl-headers package solved the problem.
Thanks for all your support.
A+
Lucas
Lucas M. Schnorr, UFRGS
http://www.inf.ufrgs.br/~schnorr/
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, (suite)
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Lucas M. Schnorr, 17/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Nathalie Furmento, 18/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Lucas M. Schnorr, 18/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Brice Goglin, 18/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Samuel Thibault, 18/08/2016
- Re: [Starpu-devel] hwloc detection problem when configuring starpu-svn-trunk and starpu-1.2.0rc5, Florent Pruvost, 18/08/2016
