Archives de la liste
- To: "Hoque, Reazul" <rhoque@vols.utk.edu>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPu build error
- Date: Wed, 14 Sep 2016 10:59:28 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
> Le 13 sept. 2016 à 21:57, Hoque, Reazul <rhoque@vols.utk.edu> a écrit :
> Samuel,
> Thank you for the prompt response. I did.
> Thanks
> Reazul
Dear Reazul,
Could you please check the version of the Fortran compiler that generated the
error?
I have conducted fresh tests today, with GNU GFortran versions 4.9, 5.1.0,
5.4 and 6.1, but I do not get the warnings and errors you encountered.
The native Fortran support of StarPU is known to be incompatible with
GFortran <= 4.8 and Intel Fortran <= 2015, and is automatically disabled by
the configure script when these Fortran compilers are in use.
Thanks for your report.
Best regards,
Olivier Aumage
> From: Samuel Thibault <samuel.thibault@inria.fr>
> Sent: Tuesday, September 13, 2016 3:39:23 PM
> To: Hoque, Reazul
> Cc: starpu-devel@lists.gforge.inria.fr
> Hello,
> Hoque, Reazul, on Tue 13 Sep 2016 18:59:22 +0000, wrote:
> > I am trying to build StarPu 1.2.0 with gcc5.1 and getting the following
> > error.
> > Am I doing something wrong?
> No, it's probably a fortran compatibility issue. You can try to pass
> --disable-fortran to ./configure to perhaps just avoid the issue.
> Samuel
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] StarPu build error, Hoque, Reazul, 13/09/2016
- Re: [Starpu-devel] StarPu build error, Samuel Thibault, 13/09/2016
- Re: [Starpu-devel] StarPu build error, Hoque, Reazul, 13/09/2016
- Re: [Starpu-devel] StarPu build error, Olivier Aumage, 14/09/2016
- Re: [Starpu-devel] StarPu build error, Alfredo Buttari, 14/09/2016
- Re: [Starpu-devel] StarPu build error, Hoque, Reazul, 14/09/2016
