Archives de la liste
- From: Alfredo Buttari <alfredo.buttari@enseeiht.fr>
- To: Olivier Aumage <olivier.aumage@inria.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, "Hoque, Reazul" <rhoque@vols.utk.edu>
- Subject: Re: [Starpu-devel] StarPu build error
- Date: Wed, 14 Sep 2016 11:05:46 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=alfredo.buttari@gmail.com; spf=Pass smtp.mailfrom=alfredo.buttari@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f46.google.com
- Ironport-phdr: 9a23:Ox8nTB96rs5IWv9uRHKM819IXTAuvvDOBiVQ1KB90ewcTK2v8tzYMVDF4r011RmSDNydtKgP07ae8/i5HzdfsdDZ6DFKWacPfiFGoP1epxYnDs+BBB+zB9/RRAt+Iv5/UkR49WqwK0lfFZW2TVTTpnqv8WxaQU2nZkJdb974EY/Kjsmxy/v6u9iKO10J13KBZuZVKBSorAjL/uALhIJtJ+5lzR/IvHpFYaJf2GZhKl+7nhDm58728oQ1oApKvPd03spOS6j2eOwSUKBEBS4nezQ84MPxuBXECwGS+mcVSGQ+nxxTDgXE7A28UI2n4XiyjfZ0xCTPZZ6+drszQzn3qv4zEBI=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
the message refers to assumed-shape arrays in bind(C) procedures which
(as far as I understand) is not possible unless the ISO/IEC TS
29113:2012 technical specification is implemented, which is not the
case for gfortran < 4.9. I have had the same problem.
Regards,
Alfredo
On Wed, Sep 14, 2016 at 10:59 AM, Olivier Aumage
<olivier.aumage@inria.fr> wrote:
> Dear Reazul,
> Could you please check the version of the Fortran compiler that generated
> the error?
> I have conducted fresh tests today, with GNU GFortran versions 4.9, 5.1.0,
> 5.4 and 6.1, but I do not get the warnings and errors you encountered.
> The native Fortran support of StarPU is known to be incompatible with
> GFortran <= 4.8 and Intel Fortran <= 2015, and is automatically disabled by
> the configure script when these Fortran compilers are in use.
> Thanks for your report.
> Best regards,
Alfredo Buttari, PhD
CNRS-IRIT
2 rue Camichel, 31071 Toulouse, France
http://buttari.perso.enseeiht.fr
- [Starpu-devel] StarPu build error, Hoque, Reazul, 13/09/2016
- Re: [Starpu-devel] StarPu build error, Samuel Thibault, 13/09/2016
- Re: [Starpu-devel] StarPu build error, Hoque, Reazul, 13/09/2016
- Re: [Starpu-devel] StarPu build error, Olivier Aumage, 14/09/2016
- Re: [Starpu-devel] StarPu build error, Alfredo Buttari, 14/09/2016
- Re: [Starpu-devel] StarPu build error, Hoque, Reazul, 14/09/2016
