Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPu build error
Archives de la liste
Chronologique Discussions
  • To: Alfredo Buttari <alfredo.buttari@enseeiht.fr>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, "Hoque, Reazul" <rhoque@vols.utk.edu>
  • Subject: Re: [Starpu-devel] StarPu build error
  • Date: Wed, 14 Sep 2016 11:19:33 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Alfredo,
Indeed (I added a note about that technical specification in StarPU's
documentation earlier this morning :-) and there is also a nice paragraph on
that topic in GNU GFortran's manual).
However, the initial message from Reazul indicated that gcc 5.1 was in use
when he got the error, but the Fortran compiler brand and version were not
mentioned. Thus I would like to know these informations in order to fix my
configure script.
Regards,
Olivier
> Le 14 sept. 2016 à 11:05, Alfredo Buttari <alfredo.buttari@enseeiht.fr> a
> écrit :
> Hello,
> the message refers to assumed-shape arrays in bind(C) procedures which
> (as far as I understand) is not possible unless the ISO/IEC TS
> 29113:2012 technical specification is implemented, which is not the
> case for gfortran < 4.9. I have had the same problem.
> Regards,
> Alfredo
> On Wed, Sep 14, 2016 at 10:59 AM, Olivier Aumage
> <olivier.aumage@inria.fr> wrote:
>> Dear Reazul,
>> Could you please check the version of the Fortran compiler that generated
>> the error?
>> I have conducted fresh tests today, with GNU GFortran versions 4.9, 5.1.0,
>> 5.4 and 6.1, but I do not get the warnings and errors you encountered.
>> The native Fortran support of StarPU is known to be incompatible with
>> GFortran <= 4.8 and Intel Fortran <= 2015, and is automatically disabled
>> by the configure script when these Fortran compilers are in use.
>> Thanks for your report.
>> Best regards,
> Alfredo Buttari, PhD
> CNRS-IRIT
> 2 rue Camichel, 31071 Toulouse, France
> http://buttari.perso.enseeiht.fr
Haut de le page
