Archives de la liste
- From: Gabriel Piscoya Davila <gpiscoya2013@hotmail.com>
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] OpenCl and Starpu
- Date: Mon, 24 Oct 2016 21:43:37 +0000
- Accept-language: es-PE, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gpiscoya2013@hotmail.com; spf=Pass smtp.mailfrom=gpiscoya2013@hotmail.com; spf=None smtp.helo=postmaster@SNT004-OMC4S9.hotmail.com
- Ironport-phdr: 9a23:p06fUxUY2EwL5uY4miCHHm/gIt3V8LGtZVwlr6E/grcLSJyIuqrYZhCFt8tkgFKBZ4jH8fUM07OQ6PG6HzJdqs/c6DhCKMUKDEBVz51O3kQJO42sNw7SFLbSdSs0HcBPBhdO3kqQFgxrIvv4fEDYuXao7DQfSV3VPAtxIfnpSMaJ15zkn7P6x5qGKR5UjSClfPZ+IQu7qS3Vt9IKms1tJKErxRaPo31Seu0Qy3kibQaIgx/m/tr18JN9/iB4v/M669UGXqv9Zas1C71eFjUvdW4vsp7Frx7GGCSG7GEdX2FeqhtTCA/U5VnWV4nwtiKy4uVl2TKROtz/F+htAhyi6LtuQR7sziwAMmhqoynslsVsgfcD81qarBtlztuMbQ==
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Hello
My name is Gabriel and i am trying to use Starpu with Opencl. When show the starpu_machine_display there are no opencl devices recognized but i have made the proper configurations on starpu (I guess).
The configuration i've made is:
./configure -enable-stats -enable-maxbuffers=50
and the result is:
configure:
CPUs enabled: yes
CUDA enabled: no
OpenCL enabled: yes
SCC enabled: no
MIC enabled: no
Compile-time limits
(change these with --enable-maxcpus, --enable-maxcudadev,
--enable-maxopencldev, --enable-maxmicdev, --enable-maxnodes,
--enable-maxbuffers)
(Note these numbers do not represent the number of detected
devices, but the maximum number of devices StarPU can manage)
Maximum number of CPUs: 64
Maximum number of CUDA devices: 0
Maximum number of OpenCL devices: 8
Maximum number of SCC devices: 0
Maximum number of MIC threads: 0
Maximum number of memory nodes: 16
Maximum number of task buffers: 50
GPU-GPU transfers: no
Allocation cache: yes
Magma enabled: no
BLAS library: none
hwloc: yes
FxT trace enabled: no
StarPU-Top: no
Documentation: no
Examples: yes
StarPU Extensions:
MPI enabled: yes
MPI test suite: no
FFT Support: no
GCC plug-in: no
GCC plug-in test suite (requires GNU Guile): no
OpenMP runtime support enabled: no
SOCL enabled: yes
SOCL test suite: no
Scheduler Hypervisor: no
simgrid enabled: no
ayudame enabled: no
Native fortran support: no
Native MPI fortran support:
configure:
WARNING: SOCL test suite will not be run as the environment variable SOCL_OCL_LIB_OPENCL is not defined.
To run the tests, you need to install the OCL implementation of ICD
(https://forge.imag.fr/projects/ocl-icd/ or Debian package ocl-icd-libopencl1)
and set the variable SOCL_OCL_LIB_OPENCL to the location of the libOpenCL.so.
then when I make the starpu_machine_diplay is shows
StarPU has found :
4 CPU threads
CPU 0
CPU 1
CPU 2
CPU 3
0 CUDA devices
0 OpenCL devices
topology ...
core 0 PU 0 CPU 0
core 1 PU 1 CPU 1
core 2 PU 2 CPU 2
core 3 PU 3 CPU 3
4 CPU threads
CPU 0
CPU 1
CPU 2
CPU 3
0 CUDA devices
0 OpenCL devices
topology ...
core 0 PU 0 CPU 0
core 1 PU 1 CPU 1
core 2 PU 2 CPU 2
core 3 PU 3 CPU 3
I dont know where could be the error, could you give me some help??
thanks.
Gabriel
Piscoya
Dávila
Student of Computing Engineering
Instituto de Informática - Universidade Federal do Rio Grande do Sul
Av. Bento Gonçalves, 9500 - Campus do Vale. Bloco IV
CP15064
91501-970- Porto Alegre-Brazil
- [Starpu-devel] OpenCl and Starpu, Gabriel Piscoya Davila, 24/10/2016
- Re: [Starpu-devel] OpenCl and Starpu, Nathalie Furmento, 25/10/2016
- Re: [Starpu-devel] OpenCl and Starpu, Samuel Thibault, 25/10/2016
- Re: [Starpu-devel] OpenCl and Starpu, Gabriel Piscoya Davila, 25/10/2016
