Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Gabriel Piscoya Davila <gpiscoya2013@hotmail.com>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] OpenCl and Starpu
- Date: Tue, 25 Oct 2016 10:28:49 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=None smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
Which kind of OpenCL devices do you have on your machine ? If you have some Nvidia GPU devices, you can run the command nvidia-smi to see if they are properly detected. The command lstopo of the package hwloc should also show you your GPU devices. Cheers, Nathalie On 24/10/2016 23:43, Gabriel Piscoya Davila wrote: Hello
The configuration i've made is:
./configure -enable-stats -enable-maxbuffers=50
and the result is:
configure: CPUs enabled: yes CUDA enabled: no OpenCL enabled: yes SCC enabled: no MIC enabled: no Compile-time limits (change these with --enable-maxcpus, --enable-maxcudadev, --enable-maxopencldev, --enable-maxmicdev, --enable-maxnodes, --enable-maxbuffers) (Note these numbers do not represent the number of detected devices, but the maximum number of devices StarPU can manage) Maximum number of CPUs: 64 Maximum number of CUDA devices: 0 Maximum number of OpenCL devices: 8 Maximum number of SCC devices: 0 Maximum number of MIC threads: 0 Maximum number of memory nodes: 16 Maximum number of task buffers: 50 GPU-GPU transfers: no Allocation cache: yes Magma enabled: no BLAS library: none hwloc: yes FxT trace enabled: no StarPU-Top: no Documentation: no Examples: yes StarPU Extensions: MPI enabled: yes MPI test suite: no FFT Support: no GCC plug-in: no GCC plug-in test suite (requires GNU Guile): no OpenMP runtime support enabled: no SOCL enabled: yes SOCL test suite: no Scheduler Hypervisor: no simgrid enabled: no ayudame enabled: no Native fortran support: no Native MPI fortran support: configure: WARNING: SOCL test suite will not be run as the environment variable SOCL_OCL_LIB_OPENCL is not defined. To run the tests, you need to install the OCL implementation of ICD (https://forge.imag.fr/projects/ocl-icd/ or Debian package ocl-icd-libopencl1) and set the variable SOCL_OCL_LIB_OPENCL to the location of the libOpenCL.so. then when I make the starpu_machine_diplay is shows
StarPU has found :
4 CPU threads CPU 0 CPU 1 CPU 2 CPU 3 0 CUDA devices 0 OpenCL devices topology ... core 0 PU 0 CPU 0 core 1 PU 1 CPU 1 core 2 PU 2 CPU 2 core 3 PU 3 CPU 3
thanks.
——————------------------------ Gabriel
Piscoya
Dávila
Student of Computing Engineering
Instituto de Informática - Universidade
Federal do Rio Grande do Sul
Av. Bento Gonçalves, 9500 - Campus do
Vale. Bloco IV
CP15064
91501-970- Porto Alegre-Brazil
_______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] OpenCl and Starpu, Gabriel Piscoya Davila, 24/10/2016
- Re: [Starpu-devel] OpenCl and Starpu, Nathalie Furmento, 25/10/2016
- Re: [Starpu-devel] OpenCl and Starpu, Samuel Thibault, 25/10/2016
- Re: [Starpu-devel] OpenCl and Starpu, Gabriel Piscoya Davila, 25/10/2016
