Archives de la liste
- From: Gabriel Piscoya Davila <gpiscoya2013@hotmail.com>
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] OpenCl and Starpu
- Date: Tue, 25 Oct 2016 19:32:07 +0000
- Accept-language: es-PE, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gpiscoya2013@hotmail.com; spf=Pass smtp.mailfrom=gpiscoya2013@hotmail.com; spf=None smtp.helo=postmaster@COL004-OMC1S17.hotmail.com
- Ironport-phdr: 9a23:iIt0NhEcRuU5fAGBFhqNmZ1GYnF86YWxBRYc798ds5kLTJ74p86wAkXT6L1XgUPTWs2DsrQf2rCQ7f+rADZcqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ3p7xib/5osePKyxzxxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JsKSrnzZbwlCLBVEjkiG2Q0/9Hw8xbNShGA6z0dVH8Xm1xGGUKNuArmV43pr272u/Rw3AGePNbqVvY7VzO44KotSRnyiS5BOSRvo0/Njcklo6tRuhOso1RHwpXfZ5CcfNZ3YKLZdJtOSnJARc1WRiUbWtrnR4sIE+8IPOIepI748Qhd5SCiDBWhUbu8ggRDgWX7iPU3
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
hello
I installed the hwloc again and the APU figures in the starpu_machine_display list, so i assume that the problem is solve.
StarPU has found :
3 CPU threads
CPU 0
CPU 1
CPU 2
0 CUDA devices
1 OpenCL devices
OpenCL 0 (Spectre 1.6 GiB)
3 CPU threads
CPU 0
CPU 1
CPU 2
0 CUDA devices
1 OpenCL devices
How can i know if there are workers executing on the openCL device ? I' m executing the vector_scaling example and want to know where and how much time the workers use the device, this informations are avaliable in the stats ? and how do i collect these
data
Gabriel
De: Samuel Thibault <samuel.thibault@inria.fr>
Enviado: martes, 25 de octubre de 2016 10:33:08 a.m.
Para: Gabriel Piscoya Davila
Cc: starpu-devel@lists.gforge.inria.fr
Asunto: Re: [Starpu-devel] OpenCl and Starpu
Hello,
Gabriel Piscoya Davila, on Mon 24 Oct 2016 21:43:37 +0000, wrote:
> The configuration i've made is:
> ./configure -enable-stats -enable-maxbuffers=50
You could add --enable-verbose which will add printfs in our opencl
driver, to see what it found.
Samuel
Samuel
- [Starpu-devel] OpenCl and Starpu, Gabriel Piscoya Davila, 24/10/2016
- Re: [Starpu-devel] OpenCl and Starpu, Nathalie Furmento, 25/10/2016
- Re: [Starpu-devel] OpenCl and Starpu, Samuel Thibault, 25/10/2016
- Re: [Starpu-devel] OpenCl and Starpu, Gabriel Piscoya Davila, 25/10/2016
