Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Deadlock with starpu_calibrate
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr, Ian Masliah <ian.masliah@inria.fr>
  • Subject: Re: [Starpu-devel] Deadlock with starpu_calibrate
  • Date: Sun, 4 Dec 2016 19:59:55 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Ok I'll check but it might just be that I didn't use the same cuda on the compilation and compute node.
Mathieu
Le 04/12/2016 à 19:44, Samuel Thibault a écrit :
Hello,
Mathieu Faverge, on Sun 04 Dec 2016 19:39:07 +0100, wrote:
doesn't seem to make any progress. It is stuck after printing:
$ starpu_calibrate_bus
[starpu][check_bus_config_file] No performance model for the bus,
calibrating...
[starpu][benchmark_all_gpu_devices] CUDA 0...
[starpu][benchmark_all_gpu_devices] CUDA 1...
[starpu][benchmark_all_gpu_devices] CUDA 2...
[starpu][benchmark_all_gpu_devices] CUDA 0 -> 1...
[starpu][measure_bandwidth_between_dev_and_dev_cuda] GPU-Direct 1 -> 0
[starpu][measure_bandwidth_between_dev_and_dev_cuda] GPU-Direct 0 -> 1
Could you get a backtrace? I'm afraid it's probably just stuck inside a
CUDA call.
Samuel
Mathieu Faverge
Maitre de conférence / Associate Professor
Institut Polytechnique de Bordeaux - ENSEIRB-Matmeca
INRIA Bordeaux - Sud-Ouest, HiePACS Team
200 avenue de la vielle tour
33405 Talence Cedex
Phone: (+33) 5 24 57 40 73
Haut de le page
