Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] STARPU_STATS does not print statistics
- Date: Wed, 01 Feb 2017 14:06:48 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
- Ironport-phdr: 9a23:R2L4YhOYHmxsSsPThqIl6mtUPXoX/o7sNwtQ0KIMzox0K/TzrarrMEGX3/hxlliBBdydsKMYzbSJ+Py+ESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9ScbuiJGsy+mo44CWbwhWiT6VZbJpMA7wogvWrMYbx4pkMKc4jBXT8VVSfOED4GJyJlXbugf44taz+4Vg8mwEvvM79MlFea7hObk9UPpDAWJ1YCgO+MT3uEybHkO07XwGXzBOnw==
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi,
I noticed that the STARPU_PROFILING=1 STARPU_STATS=1 environmental variable combination does no longer print the per worker statistics.
I am using the latest nightly tarball (2017-02-01, 19801) but the same thing happened with the older versions as well.
Has something changed or is this a bug? Or am I doing something wrong?
Best Regards,
Mirko Myllykoski
- [Starpu-devel] STARPU_STATS does not print statistics, Mirko Myllykoski, 01/02/2017
- Re: [Starpu-devel] STARPU_STATS does not print statistics, Samuel Thibault, 01/02/2017
- Re: [Starpu-devel] STARPU_STATS does not print statistics, Mirko Myllykoski, 01/02/2017
