Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] STARPU_STATS does not print statistics
Archives de la liste
Chronologique Discussions
  • To: Mirko Myllykoski <mirkom@cs.umu.se>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] STARPU_STATS does not print statistics
  • Date: Wed, 01 Feb 2017 14:53:38 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 2017-02-01 14:23, Samuel Thibault wrote:
Hello,
Mirko Myllykoski, on Wed 01 Feb 2017 14:06:48 +0100, wrote:
I noticed that the STARPU_PROFILING=1 STARPU_STATS=1 environmental variable
combination does no longer print the per worker statistics.
I am using the latest nightly tarball (2017-02-01, 19801) but the same thing
happened with the older versions as well.
Has something changed or is this a bug? Or am I doing something wrong?
You need to set STARPU_ENABLE_STATS=1, which does the measurements.
STARPU_STATS=0 only avoids displaying at the end of the execution, the
default for that variable is already 1.
Samuel
Hi,
If I enable STARPU_ENABLE_STATS, then the only things that get printed are MSI cache stats and allocation cache stats.
- Mirko
Haut de le page
