Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] STARPU_STATS does not print statistics
Archives de la liste
Chronologique Discussions
  • To: Mirko Myllykoski <mirkom@cs.umu.se>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] STARPU_STATS does not print statistics
  • Date: Wed, 1 Feb 2017 14:56:35 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Mirko Myllykoski, on Wed 01 Feb 2017 14:53:38 +0100, wrote:
> On 2017-02-01 14:23, Samuel Thibault wrote:
> >Mirko Myllykoski, on Wed 01 Feb 2017 14:06:48 +0100, wrote:
> >>I noticed that the STARPU_PROFILING=1 STARPU_STATS=1 environmental
> >>variable
> >>combination does no longer print the per worker statistics.
> >>I am using the latest nightly tarball (2017-02-01, 19801) but the same
> >>thing
> >>happened with the older versions as well.
> >>Has something changed or is this a bug? Or am I doing something wrong?
> >You need to set STARPU_ENABLE_STATS=1, which does the measurements.
> >STARPU_STATS=0 only avoids displaying at the end of the execution, the
> >default for that variable is already 1.
> >Samuel
> Hi,
> If I enable STARPU_ENABLE_STATS, then the only things that get printed are
> MSI cache stats and allocation cache stats.
Ah, you want the worker stats, it is STARPU_WORKER_STATS=1 then.
Samuel
Haut de le page
