Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU 1.2.0 not working with CUDA 8 and Ubuntu
Archives de la liste
Chronologique Discussions
  • To: Gabriel Gazolla <gabrielgazolla@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU 1.2.0 not working with CUDA 8 and Ubuntu
  • Date: Tue, 7 Feb 2017 10:38:50 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23:9lrPOhIwG1PAkIaFG9mcpTZWNBhigK39O0sv0rFitYgUKPnxwZ3uMQTl6Ol3ixeRBMOAuq4C1Lud6/uoGTRZp83e4DZaKN0EfiRGoPtVtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdazdU7TfhMWv1u2054abI0AR3GL8MvtOK0CZpA/Lt8QSyaRrOKE1zhKB9nRBcf5XyGdnLECUmxL1zsi19Z9ntS9XvqRy2dRHVPDBdqElQLgQMDQnOWko4NGj4QLKSBaC4j0AUmQcmwdMHyDE6gv7V9H/qH2p5aJGxCCGMJiuHvgPUjO44vIuEUewhQ==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Gabriel Gazolla, on Tue 07 Feb 2017 00:36:22 -0200, wrote:
> Attached on this email are the files you requested:
Thanks
> FAIL: starpu_machine_display
Ah, that's unfortunately due to this:
> lt-starpu_machine_display: ../../src/core/debug.c:48:
> _starpu_open_debug_logfile: Assertion `logfile' failed.
In verbose mode, starpu writes some logs to the starpu.log file, so the
current directory needs to be writable. You can specify another file
destination thanks to the STARPU_LOGFILENAME environment variable.
Also, I probably forgot: please run
make check -k
-k meant to make it continue even on some errors, so as to get most
available information.
Samuel
Haut de le page
