Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU 1.2.0 not working with CUDA 8 and Ubuntu
- Date: Tue, 7 Feb 2017 00:36:22 -0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gabrielgazolla@gmail.com; spf=Pass smtp.mailfrom=gabrielgazolla@gmail.com; spf=None smtp.helo=postmaster@mail-yw0-f177.google.com
- Ironport-phdr: 9a23:NpDxchcd24m0/6Fka3LfS0cClGMj4u6mDksu8pMizoh2WeGdxcW5YB7h7PlgxGXEQZ/co6odzbGH7+a/CSdcvt6oizMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpTEdFQ/iOgVrO+/7BpDdj9it1+C15pbffxhEiCCzbL52Ixi6twfcu8oZjYZtKKs61wfErGZPd+lK321jOEidnwz75se+/Z5j9zpftvc8/MNeUqv0Yro1Q6VAADspL2466svrtQLeTQSU/XsTTn8WkhtTDAfb6hzxQ4r8vTH7tup53ymaINH2QLUpUjms86tnVBnlgzocOjUn7G/YlNB/jKNDoBKguRN/xZLUYJqIP/Z6Z6/RYM8WSXZEUstXSidPAJ6zb5EXAuobP+lYoYnzqVUNoxWjGwejGPjiyjpUinLsx6A2z/gtHAPA0Qc9H9wOqnPUrNDtOakTS++617PIzTTdYPNSxDzz6ZLHcxEmofGIWbJ/a9faxE4gFwzflVqQs43lMC2R1uQCqWea7u1gVeari2E9sAxxrT2vyd0tionNnI4a1lfE9SBgzYszONa2Rkl7Ydu+H5tRsSGXL5d2Q80jQ2F0pCY11KcGtYSncygNzZQqwQPUZf+fc4WQ/B7vSOKcLS17iX9lYr6zmhe//VW6xuHhVMS50lBHpTdfnNbWrHACzRnT59CHSvRj+keh3i6C1wXJ5eFFJUA4jKraKpA9zrIpmJofrEbOEy3slEX5i6+WcUok+uy25Oj9frrmoZqcO5d1igH4LKsuhtSyDfokPgUKRWSW+uSx2Kf+8UD4XblGlOA6n6vbvZzCIMQUvK+5Awtb0oY57Ba/Ci+r0NsCknYcNlJFeQyIj4zmO17UIfH4CvO/g1C2nzpwyPDGO6fuApTJLnTZjLjherN951ZGyAUv1dBf+45UCrYZLfLoRk/+rsbYDgckMwCt3unoFst92Z0aWW+UBq+ZMbjSsUOT5u41LOmMaogVuCzyK/c7/fLujHk5mUUcfaazx5cXZmq4TbxaJBCiaH/xj9NJLWcLtAMjSPCi3EaLVCNeYzCuX6M27yw/FKqnC53CT8ajmurFlDynF4dOeyVKB06BFV/sdp6YQLEDZiWILcInkzoeVLHnRZVy7xy2sB7GzO9oJ+DO+yAcupvx09xx7sXckBgz8Xp/CMHO/XuKSjRbl2kSRjIylI92s0t5zl7LhadxieZZGNhc7uFOVgMzHZHZxu1+Tdv1X1SSLZ+yVF+6T4D+UnkKRdUrzopLOh4lFg==
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello Samuel,
Sorry for the huge delay, I was on vacation and after that forgot to answer the email for you, was using CUDA 7.5 so I didn`t need to worry about this issue, but now I need to use StarPU on CUDA 8...
Attached on this email are the files you requested:
- configure output with verbose enabled
- make check output
- test.c software you sent me to test and its output
- starpumachinedisplay output is also attached.
Tell me if you need me to do any other tests...
I did this test on a machine using Ubuntu 14.04 LTS and CUDA 8. Cuda 7.5 everything works fine, but CUDA 8 dont, I am using starpu 1.2.0 release of 25.08.2016.
Hope to hear back from you soon,
Thanks,
Joao Gazolla
On Wed, Nov 23, 2016 at 4:50 PM, Samuel Thibault <samuel.thibault@inria.fr> wrote:
Gabriel Gazolla, on Wed 23 Nov 2016 16:38:24 -0200, wrote:
> If you try to compile StarPU 1.2 with CUDA 8 probably you will receive a lot of
> warnings about sm_20. Did you notice that?
Yes. It's "funny" in that we don't request that architecture at all...
It seems like nvcc just always emit that warning unless we explicitly
request for a more recent architecture... But then if we request for an
explicit more recent architecture, later on it'll become obsolete and
that'll turn into an actual error... I guess I'll just disable the
warning for releases.
Samuel
configure, verbose enabled
Description: Binary data
makeCheck
driver version 8000 runtime version 8000 CUDA0 GeForce GTX 670MX 2.939 GB 5 MP
#include <stdio.h> #include <cuda.h> #include <cuda_runtime.h> int main(void) { int n, i, version; cudaError_t err; err = cudaGetDeviceCount(&n); if (err) { fprintf(stderr,"cuda error %d\n", err); exit(1); } cudaDriverGetVersion(&version); printf("driver version %d\n", version); cudaRuntimeGetVersion(&version); printf("runtime version %d\n", version); printf("\n"); for (i = 0; i < n; i++) { struct cudaDeviceProp props; printf("CUDA%d\n", i); err = cudaGetDeviceProperties(&props, i); if (err) { fprintf(stderr,"cuda error %d\n", err); continue; } printf("%s\n", props.name); printf("%0.3f GB\n", (float) props.totalGlobalMem / (1<<30)); printf("%u MP\n", props.multiProcessorCount); printf("\n"); } return 0; }
starPUMachineDisplayOUTPUT
- Re: [Starpu-devel] StarPU 1.2.0 not working with CUDA 8 and Ubuntu, Gabriel Gazolla, 07/02/2017
- Re: [Starpu-devel] StarPU 1.2.0 not working with CUDA 8 and Ubuntu, Samuel Thibault, 07/02/2017
- Re: [Starpu-devel] StarPU 1.2.0 not working with CUDA 8 and Ubuntu, Gabriel Gazolla, 15/02/2017
- Re: [Starpu-devel] StarPU 1.2.0 not working with CUDA 8 and Ubuntu, Samuel Thibault, 15/02/2017
