Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU 1.2.0 not working with CUDA 8 and Ubuntu
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, Gabriel Gazolla <gabrielgazolla@gmail.com>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU 1.2.0 not working with CUDA 8 and Ubuntu
  • Date: Tue, 14 Feb 2017 23:02:40 -0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gabrielgazolla@gmail.com; spf=Pass smtp.mailfrom=gabrielgazolla@gmail.com; spf=None smtp.helo=postmaster@mail-yb0-f180.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello Samuel,
Thanks for the ultra fast answer !
I would really like to send you , but I just formatted the computer again to see if its going to work on Ubuntu 16 and CUDA 8, I will let you know if it worked as soon as i finish,
Thanks again for all the info,
If you need any test let me know, and i will be happy to help,
Thanks !
Joao
On Tue, Feb 14, 2017 at 10:38 PM, Samuel Thibault <samuel.thibault@inria.fr> wrote:
Hello,
Gabriel Gazolla, on mar. 14 févr. 2017 22:30:18 -0200, wrote:
> 1) Why do you think it worked now ?
I don't really know, perhaps the reinstallation of the system has fixed
something in the driver.
> because of the option -k ?
-k only makes make check continue in case of errors. Here it was useful
because datawizard/data_implicit_deps failed.  Could you send
tests/datawizard/data_implicit_deps.log which should contain the
detailed log of what happened?
> 2) Do you think everything is working fine?
Almost, apparently, yes.
> or maybe because i turned off the
> errors, maybe theres still errors there?
No, only the "FAIL" line indicate an error, and there is just one.
> 3) when are you going to release a new starpu version ?
Possibly a 1.2.1 more or less soon. In the meanwhile, you can use a
nightly snapshot from
http://starpu.gforge.inria.fr/testing/branches/starpu-1.2/starpu-nightly-latest.tar.gz
which contains all fixes since the 1.2.0 release, and not the
developments we are doing for the future 1.3.0
> 4) am I receiving a lot of messages during starPU execution because of the
> configure with verbose mode ?
Yes.
Samuel
Gabriel Gazolla
Doutorando em Computação - IC/UFF
Haut de le page
