Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Cc: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Subject: [Starpu-devel] MPI tags limitation with Starpu
- Date: Sun, 19 Feb 2017 09:21:43 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sameh.abdulah@kaust.edu.sa; spf=Pass smtp.mailfrom=sameh.abdulah@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-vk0-f54.google.com
- Ironport-phdr: 9a23:OJwQjRGTTPGpwFrDsl6Wn51GYnF86YWxBRYc798ds5kLTJ75psuwAkXT6L1XgUPTWs2DsrQf2reQ6/GrCDNIoc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScb6xv663OGq+pDVfx4AxH/kOeszf12KqlDKqsAMmZYnJqsvxx/hpnpTZ/8Qym1vP12e2Rf6/Ma5upB5oApKvPd0zMdFXKWyVq40ULhRDHxyKGkw6c2tvBPPUA+G5lMfW3gNjlxFDxWD9xisDcS5iTfzqucogHrSBsbxV71hHG36t6o=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Dear Team
I am working on chameleon and starpu to do Cholesky for large matrices on distributed systems. I need to do Cholesky for several iterations (>50) for 200K matrices. My configuration is as follows:
N: 200K
Tile Size:320
Nodes 144 (with 7 cores each)
I got this error: Too many tiles in the descriptor for MPI tags. When I checked it I found that I need to change the default values of both tag_width = 31 and tag_sep =24 on runtime_descriptor.c using this function "MORSE_user_tag_size(int tag_width, int tag_sep)". I do not know what is the correct values I need for both to handle my case. I played with different numbers but I am still having the same error and if I can avoid this error using a certain values I got another error "Number of descriptor available in MPI mode out of stock".
Please can I know the best configuration for my case and if I need to use larger thank 200K matrix how can I play with these values.
Thank you.
--Sameh Abdulah
Postdoc, ECRC, KAUST.
- [Starpu-devel] MPI tags limitation with Starpu, Sameh Abdulah, 19/02/2017
- Re: [Starpu-devel] MPI tags limitation with Starpu, Nathalie Furmento, 20/02/2017
- Re: [Starpu-devel] MPI tags limitation with Starpu, Sameh Abdulah, 20/02/2017
- Re: [Starpu-devel] MPI tags limitation with Starpu, Mathieu Faverge, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Samuel Thibault, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Sameh Abdulah, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Sameh Abdulah, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Mathieu Faverge, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Samuel Thibault, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Nathalie Furmento, 21/02/2017
