Archives de la liste
- To: Sameh Abdulah <sameh.abdulah@kaust.edu.sa>, Samuel Thibault <samuel.thibault@inria.fr>, Nathalie Furmento <nathalie.furmento@labri.fr>, starpu-devel@lists.gforge.inria.fr, morse-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu
- Date: Tue, 21 Feb 2017 11:32:34 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello Sameh,
Can't you reuse the descriptor multiple times, as I suggested ? Mathieu Le 21/02/2017 à 11:28, Sameh Abdulah a écrit : Hello,
I check our system and I found that we rely on cray mpich
and this gives me only 21 bits not 31 bits for tag width. if I
need to cover all my tiles I need 19 bits out of 21 bits and 2
bits only will not be enough for my descriptors. Can you
advice me what to do?
--Sameh
On Mon, Feb 20, 2017 at 5:24 PM, Sameh
wrote:
Thanks guys for your help. I will try
Mathieu's solutions and I will come back to you.
--Sameh
On Mon, Feb 20, 2017 at 4:36
PM, Samuel Thibault <samuel.thibault@inria.fr>
wrote:
Hello, Mathieu Faverge, on lun. 20 févr. 2017 11:28:58 +0100, wrote: > Be careful, if you MPI implementation allows less than 31 bits, Starting with StarPU 1.2, we use our own tag support, which always includes 32bits, so that should not be a problem. We could also increase that to 64bit. Samuel -- -- Mathieu Faverge Maitre de conférence / Associate Professor Institut Polytechnique de Bordeaux - ENSEIRB-Matmeca INRIA Bordeaux - Sud-Ouest, HiePACS Team 200 avenue de la vielle tour 33405 Talence Cedex Phone: (+33) 5 24 57 40 73 |
- [Starpu-devel] MPI tags limitation with Starpu, Sameh Abdulah, 19/02/2017
- Re: [Starpu-devel] MPI tags limitation with Starpu, Nathalie Furmento, 20/02/2017
- Re: [Starpu-devel] MPI tags limitation with Starpu, Sameh Abdulah, 20/02/2017
- Re: [Starpu-devel] MPI tags limitation with Starpu, Mathieu Faverge, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Samuel Thibault, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Sameh Abdulah, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Sameh Abdulah, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Mathieu Faverge, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Samuel Thibault, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Nathalie Furmento, 21/02/2017
