Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, Mathieu Faverge <mathieu.faverge@inria.fr>, Sameh Abdulah <sameh.abdulah@kaust.edu.sa>, Nathalie Furmento <nathalie.furmento@labri.fr>, starpu-devel@lists.gforge.inria.fr, morse-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu
- Date: Tue, 21 Feb 2017 13:28:16 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sameh.abdulah@kaust.edu.sa; spf=Pass smtp.mailfrom=sameh.abdulah@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ua0-f178.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
I check our system and I found that we rely on cray mpich and this gives me only 21 bits not 31 bits for tag width. if I need to cover all my tiles I need 19 bits out of 21 bits and 2 bits only will not be enough for my descriptors. Can you advice me what to do?
--Sameh
On Mon, Feb 20, 2017 at 5:24 PM, Sameh Abdulah <sameh.abdulah@kaust.edu.sa> wrote:
Thanks guys for your help. I will try Mathieu's solutions and I will come back to you.--SamehOn Mon, Feb 20, 2017 at 4:36 PM, Samuel Thibault <samuel.thibault@inria.fr> wrote:Hello,
Mathieu Faverge, on lun. 20 févr. 2017 11:28:58 +0100, wrote:
> Be careful, if you MPI implementation allows less than 31 bits,
Starting with StarPU 1.2, we use our own tag support, which always
includes 32bits, so that should not be a problem. We could also increase
that to 64bit.
Samuel
- [Starpu-devel] MPI tags limitation with Starpu, Sameh Abdulah, 19/02/2017
- Re: [Starpu-devel] MPI tags limitation with Starpu, Nathalie Furmento, 20/02/2017
- Re: [Starpu-devel] MPI tags limitation with Starpu, Sameh Abdulah, 20/02/2017
- Re: [Starpu-devel] MPI tags limitation with Starpu, Mathieu Faverge, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Samuel Thibault, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Sameh Abdulah, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Sameh Abdulah, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Mathieu Faverge, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Samuel Thibault, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Nathalie Furmento, 21/02/2017
