Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, Nathalie Furmento <nathalie.furmento@labri.fr>, Sameh Abdulah <sameh.abdulah@kaust.edu.sa>, starpu-devel@lists.gforge.inria.fr, morse-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu
- Date: Tue, 21 Feb 2017 12:48:07 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Sameh,
Since it looks like it will need some discussions. If you are sure you are using StarPU., Comment the section of the code that updates the tag fields based on MPI_TAG_UB, and that should be fine for now, for your code.
You can follow the evolution of this discussion on:
https://gitlab.inria.fr/solverstack/chameleon/issues/17
Best,
Mathieu
Le 21/02/2017 à 11:54, Samuel Thibault a écrit :
Nathalie Furmento, on mar. 21 févr. 2017 11:46:30 +0100, wrote:
Yes, for StarPU 1.2. However this is a internal mechanism, i am not surePerhaps StarPU could provide a function that returns the proper TAG_UB
the application should make any assumptions on how we handle MPI comms,
and we may want to change it in futur releases depending on the MPI
implementation.
depending on how tags are handled?
Samuel
Mathieu Faverge
Maitre de conférence / Associate Professor
Institut Polytechnique de Bordeaux - ENSEIRB-Matmeca
INRIA Bordeaux - Sud-Ouest, HiePACS Team
200 avenue de la vielle tour
33405 Talence Cedex
Phone: (+33) 5 24 57 40 73
- Re: [Starpu-devel] MPI tags limitation with Starpu, (suite)
- Re: [Starpu-devel] MPI tags limitation with Starpu, Sameh Abdulah, 20/02/2017
- Re: [Starpu-devel] MPI tags limitation with Starpu, Mathieu Faverge, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Samuel Thibault, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Sameh Abdulah, 20/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Sameh Abdulah, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Mathieu Faverge, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Samuel Thibault, 21/02/2017
- Re: [Starpu-devel] [Morse-devel] MPI tags limitation with Starpu, Nathalie Furmento, 21/02/2017
