Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] StarPU task cancellation/resubmission
- Date: Wed, 28 Jun 2017 11:11:38 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ejens005@odu.edu; spf=Pass smtp.mailfrom=ejens005@odu.edu; spf=None smtp.helo=postmaster@mail-wm0-f48.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
I'm a Ph.D. researcher working at Old Dominion University (Norfolk, Va, USA) with Dr. Masha Sosonkina.
I'm wondering if there is any way for StarPU to handle cancelling or rescheduling/resubmitting a task, such as in the case that a node fails or a fault is simulated?
Thank you,
Erik Jensen
- [Starpu-devel] StarPU task cancellation/resubmission, Erik Jensen, 28/06/2017
- Re: [Starpu-devel] StarPU task cancellation/resubmission, Samuel Thibault, 28/06/2017
- Re: [Starpu-devel] StarPU task cancellation/resubmission, Erik Jensen, 28/06/2017
