Archives de la liste
- To: vedran.novakovic@stfc.ac.uk
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU on IBM Power8 systems
- Date: Thu, 3 Aug 2017 17:35:11 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Hello,
vedran.novakovic@stfc.ac.uk, on mar. 20 juin 2017 15:10:32 +0000, wrote:
> Good news:
> StarPU (SVN version 21567) indeed builds on Power8LE, with CUDA support.
Cool :)
> Bad news (but not really bad at all):
> Unless some debugging flags that XL compilers don't understand are removed,
> as with:
> find . -name 'Makefile' -exec sed -i -e 's/\-gdwarf\-2//g' -e 's/\-g3/-g/g'
> (i.e., -gdwarf-2 -g3 to -g)
> they fail with
> xlc_r: error: 1501-230 Internal compiler error...
Erf. I'm surprised that we get to pass -gdwarf-2 to xlc. Does it really
get recognized as a gcc compiler? It's really a pain if a compiler
which is not actually compatible with gcc does announce itself as being
gcc...
> Running `make check` gives me these failures so far, for your information
> (it takes a long time to run):
Thanks!
> [starpu][starpu_unistd_o_direct_global_async_write][assert failure] The
> unistd_o_direct variant can only write a multiple of page size 65536 Bytes
> (Here 2183168). Use the non-o_direct unistd variant if your data is not a
> multiple of 65536
Ah, indeed, non-x86 architectures use pages bigger than 4096, so we need
to round it up for the o_direct Out-of-Core support. I have fixed it.
> with these tests skipped or expected to fail:
> SKIP: main/static_restartable_using_initializer
> SKIP: datawizard/interfaces/multiformat/advanced/multiformat_cuda_opencl
> SKIP: datawizard/readonly
> XFAIL: errorcheck/invalid_blocking_calls
Yes, errorcheck/invalid_blocking_calls really is expected to fail: it
tests that we do error out on invalid blocking calls :)
Samuel
- Re: [Starpu-devel] StarPU on IBM Power8 systems, Samuel Thibault, 03/08/2017
- Re: [Starpu-devel] StarPU on IBM Power8 systems, vedran.novakovic, 04/08/2017
