Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU on IBM Power8 systems
Archives de la liste
Chronologique Discussions
  • To: <samuel.thibault@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU on IBM Power8 systems
  • Date: Fri, 4 Aug 2017 15:57:21 +0000
  • Accept-language: en-GB, en-US
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vedran.novakovic@stfc.ac.uk; spf=None smtp.mailfrom=vedran.novakovic@stfc.ac.uk; spf=None smtp.helo=postmaster@smtp-out6.electric.net
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
Thank you for the clarifications!
For XLC, I'm not currently using the Power8 system, so I could not tell
how it gets recognised, sorry.
Regards,
Vedran
On 03/08/2017, 16:35, "Samuel Thibault" <samuel.thibault@inria.fr> wrote:
>Hello,
>vedran.novakovic@stfc.ac.uk, on mar. 20 juin 2017 15:10:32 +0000, wrote:
>> Good news:
>> StarPU (SVN version 21567) indeed builds on Power8LE, with CUDA support.
>Cool :)
>> Bad news (but not really bad at all):
>> Unless some debugging flags that XL compilers don't understand are
>>removed, as with:
>> find . -name 'Makefile' -exec sed -i -e 's/\-gdwarf\-2//g' -e
>>'s/\-g3/-g/g' {} \;
>> (i.e., -gdwarf-2 -g3 to -g)
>> they fail with
>> xlc_r: error: 1501-230 Internal compiler error...
>Erf. I'm surprised that we get to pass -gdwarf-2 to xlc. Does it really
>get recognized as a gcc compiler? It's really a pain if a compiler
>which is not actually compatible with gcc does announce itself as being
>gcc...
>> Running `make check` gives me these failures so far, for your
>>information (it takes a long time to run):
>Thanks!
>> [starpu][starpu_unistd_o_direct_global_async_write][assert failure] The
>>unistd_o_direct variant can only write a multiple of page size 65536
>>Bytes (Here 2183168). Use the non-o_direct unistd variant if your data
>>is not a multiple of 65536
>Ah, indeed, non-x86 architectures use pages bigger than 4096, so we need
>to round it up for the o_direct Out-of-Core support. I have fixed it.
>> with these tests skipped or expected to fail:
>> SKIP: main/static_restartable_using_initializer
>> SKIP: datawizard/interfaces/multiformat/advanced/multiformat_cuda_opencl
>> SKIP: datawizard/readonly
>> XFAIL: errorcheck/invalid_blocking_calls
>Yes, errorcheck/invalid_blocking_calls really is expected to fail: it
>tests that we do error out on invalid blocking calls :)
>Samuel
Haut de le page
