Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL
Archives de la liste
Chronologique Discussions
  • From: Mawussi Zounon <mawussi.zounon@manchester.ac.uk>
  • To: Samuel Thibault <samuel.thibault@inria.fr>
  • Cc: Jakub Sistek <jakub.sistek@manchester.ac.uk>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Negin Bagherpour <negin.bagherpour@manchester.ac.uk>
  • Subject: Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL
  • Date: Mon, 18 Sep 2017 21:33:09 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mawussi.zounon@manchester.ac.uk; spf=Pass smtp.mailfrom=mawussi.zounon@manchester.ac.uk; spf=None smtp.helo=postmaster@serenity.mcc.ac.uk
  • Ironport-phdr: 9a23:9NlOyRKEclWQsSKEtdmcpTZWNBhigK39O0sv0rFitYgUK/rxwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBX660e/5j8KGxj5KRE9ZqGsQtaT3IyL0LWJ8pjObgEAuDq8a7pvKAn++R7Ys9Qbhc1+Kqc7wwbNvlNJff5XzCVmPwTAsQz745KV9YF+6D9R88Am6shHV+2ueq0nUKdDDXI0NH0z48vDsBDFRguC/WcRSCMfmVxVAF6Wv1nBQp7tv36i5aJG0y6AMJizFOhsVA==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear Samuel,
We are using StarPU 1.2.2.
In terms of scheduling, I tried eager, and lws, but didn't notice a
significant difference though lws seems better.
Currently we are not using priority, but we will need it very soon with LU.
I will try the trunk and be back to you.
Best regards
--Mawussi
________________________________________
Sent: Monday, September 18, 2017 5:27 PM
To: Mawussi Zounon
Cc: starpu-devel@lists.gforge.inria.fr; Olivier Aumage; Jakub Sistek; Negin
Bagherpour
Subject: Re: Performance issue of StarPU on Intel self-hosted KNL
Hello,
Which version of StarPU is this?
Which scheduler did you use? The default scheduler in StarPU 1.2 is
still "eager", which is a real bottleneck for 60-y-core systems :)
Using "lws" would probably be a better go.
Trying the StarPU trunk (it is very stable ATM, we will probably branch
to 1.3 sooner or later) could be useful too, its default scheduler is
now lws too.
Also, you might want to try the trunk's --enable-numa option. It is
still very experimental and was not really benchmarked, but possibly it
could help.
Are there priorities defined in your algorithm?
Samuel
Haut de le page
