Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL
Archives de la liste
Chronologique Discussions
  • To: Mawussi Zounon <mawussi.zounon@manchester.ac.uk>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Jakub Sistek <jakub.sistek@manchester.ac.uk>, Negin Bagherpour <negin.bagherpour@manchester.ac.uk>
  • Subject: Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL
  • Date: Mon, 25 Sep 2017 12:13:33 -0400
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
> Le 25 sept. 2017 à 12:10, Mawussi Zounon <mawussi.zounon@manchester.ac.uk>
> a écrit :
> Thanks Samuel,
> I will perform a quick benchmark then be back to you.
Hi Mawussi,
Even with a single topology load from hwloc now, it is still not advised to
perform a starpu_init()/starpu_shutdown() on every PLASMA call. :-)
Best regards,
Olivier
> Best regards,
> --Mawussi
> ________________________________________
> From: Samuel Thibault [samuel.thibault@inria.fr]
> Sent: Monday, September 25, 2017 1:16 PM
> To: Olivier Aumage; Mawussi Zounon; Negin Bagherpour;
> starpu-devel@lists.gforge.inria.fr; Jakub Sistek
> self-hosted KNL
> Samuel Thibault, on ven. 22 sept. 2017 11:48:12 +0200, wrote:
>> Olivier Aumage, on ven. 22 sept. 2017 09:12:27 +0200, wrote:
>>> The main reason for the initialization cost on KNL is the large number of
>>> cores and the fact that those cores are individually much less powerful
>>> and advanced than Broadwell's cores. Initializing libhwloc on the KNL
>>> takes about 0.5 to 1 second.
>> And we do it twice, once for the whole architecture, and a second
>> time in _starpu_build_tree to get only the structure of the
>> architecture. Perhaps that second call could be avoided, it's probably
>> less expensive to make build_tree cope with structure-useless hwloc
>> object, than asking hwloc discovery a second time.
> I have fixed this.
> Samuel
Haut de le page
