Archives de la liste
- To: Mawussi Zounon <mawussi.zounon@manchester.ac.uk>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Jakub Sistek <jakub.sistek@manchester.ac.uk>, Negin Bagherpour <negin.bagherpour@manchester.ac.uk>
- Subject: Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL
- Date: Mon, 25 Sep 2017 12:19:26 -0400
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi Mawussi,
Sure! :-)
Best regards,
Olivier
> Le 25 sept. 2017 à 12:18, Mawussi Zounon <mawussi.zounon@manchester.ac.uk>
> a écrit :
> Hi Oliver,
> It can worth including the StarPU initialization in at least one routine,
> for the sake of comparison,
> just to evaluate the gain of the Samuel's improvement.
> Best regards,
> --Mawussi
> ________________________________________
> From: Olivier Aumage [olivier.aumage@inria.fr]
> Sent: Monday, September 25, 2017 5:13 PM
> To: Mawussi Zounon
> Cc: Samuel Thibault; Negin Bagherpour; starpu-devel@lists.gforge.inria.fr;
> Jakub Sistek
> self-hosted KNL
>> Le 25 sept. 2017 à 12:10, Mawussi Zounon <mawussi.zounon@manchester.ac.uk>
>> a écrit :
>> Thanks Samuel,
>> I will perform a quick benchmark then be back to you.
> Hi Mawussi,
> Even with a single topology load from hwloc now, it is still not advised to
> perform a starpu_init()/starpu_shutdown() on every PLASMA call. :-)
> Best regards,
> Olivier
>> Best regards,
>> --Mawussi
>> From: Samuel Thibault [samuel.thibault@inria.fr]
>> Sent: Monday, September 25, 2017 1:16 PM
>> To: Olivier Aumage; Mawussi Zounon; Negin Bagherpour;
>> starpu-devel@lists.gforge.inria.fr; Jakub Sistek
>> self-hosted KNL
>> Samuel Thibault, on ven. 22 sept. 2017 11:48:12 +0200, wrote:
>>> Olivier Aumage, on ven. 22 sept. 2017 09:12:27 +0200, wrote:
>>>> The main reason for the initialization cost on KNL is the large number
>>>> of cores and the fact that those cores are individually much less
>>>> powerful and advanced than Broadwell's cores. Initializing libhwloc on
>>>> the KNL takes about 0.5 to 1 second.
>>> And we do it twice, once for the whole architecture, and a second
>>> time in _starpu_build_tree to get only the structure of the
>>> architecture. Perhaps that second call could be avoided, it's probably
>>> less expensive to make build_tree cope with structure-useless hwloc
>>> object, than asking hwloc discovery a second time.
>> I have fixed this.
>> Samuel
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, (suite)
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Mawussi Zounon, 21/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Olivier Aumage, 21/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Olivier Aumage, 22/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Jakub Sistek, 22/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Samuel Thibault, 22/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Samuel Thibault, 25/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Mawussi Zounon, 25/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Olivier Aumage, 25/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Samuel Thibault, 20/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Olivier Aumage, 20/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Mawussi Zounon, 18/09/2017
