Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] StarPU v1.2.3 released
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: starpu-announce@lists.gforge.inria.fr
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
  • Subject: [Starpu-devel] StarPU v1.2.3 released
  • Date: Thu, 9 Nov 2017 16:49:55 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=None smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
  • Ironport-phdr: 9a23:rQurvxYe6eEHSamsh+X4/bH/LSx+4OfEezUN459isYplN5qZpcyzbnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76xXcoFx7+LQt4IPjuUs6X1pzvlrP6x5qGeBlBniKgJLp0KhKrqw7cns0Xmpd5bKk/zQHGrz1Jff5XzCVmPwG9hRH5s+G54J5q9yVd89w87ctNV7n9N/A+RKBYBTAnPiY7+dfuuB/fSiOL73EGUyMYiEwbUED+8BjmU8Kp4WPBve1n1XzfZJWuQA==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
All,
The StarPU team is really pleased to announce the v1.2.3 release!
This release notably brings an out-of-core support, a MIC Xeon Phi
support, an OpenMP runtime support, and a new internal communication
system for MPI.
The tarball along with the md5sum file and the OpenPGP signature are
available on the starpu web site
http://starpu.gforge.inria.fr/files/
or directly on the Gforge web site
https://gforge.inria.fr/frs/?group_id=1570
Nathalie, for the StarPU team.
StarPU 1.2.3 (svn revision 22444)
New features:
* Add per-node MPI data.
Small features:
* When debug is enabled, starpu data accessors first check the
validity of the data interface type
* Print disk bus performances when STARPU_BUS_STATS is set
* Add starpu_vector_filter_list_long filter.
* Data interfaces now define a name through the struct
starpu_data_interface_ops
* StarPU-MPI :
- allow predefined data interface not to define a mpi datatype and
to be exchanged through pack/unpack operations
- New function starpu_mpi_comm_get_attr() which allows to return
the value of the attribute STARPU_MPI_TAG_UB, i.e the upper
bound for tag value.
- New configure option enable-mpi-verbose to manage the display of
extra MPI debug messages.
* Add STARPU_WATCHDOG_DELAY environment variable.
* Add a 'waiting' worker status
* Allow new value 'extra' for configure option --enable-verbose
Small changes:
* Add data_unregister event in traces
* StarPU-MPI
- push detached requests at the back of the testing list, so they
are tested last since they will most probably finish latest
* Automatically initialize handles on data acquisition when
reduction methods are provided, and make sure a handle is
initialized before trying to read it.
Haut de le page
