Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Question about sequential transfers in Starpu/SimGrid
Archives de la liste
Chronologique Discussions
  • To: Lionel Eyraud-Dubois <lionel.eyraud-dubois@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Question about sequential transfers in Starpu/SimGrid
  • Date: Fri, 10 Nov 2017 17:07:02 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hello,
Lionel Eyraud-Dubois, on jeu. 09 nov. 2017 14:55:50 +0100, wrote:
>    I was reading core/simgrid.c to understand the way StarPU models GPU
> transfers, which ones are sequential. And I found the following lines of
> code (simgrid.c:643) :
>     /* GPU-GPU transfers are sequential with any RAM->GPU transfer */
>     if (new_is_gpu_gpu
>             && old_transfer->dst_node == new_transfer->src_node
>             && old_transfer->dst_node == new_transfer->dst_node)
>         return 1;
>     if (old_is_gpu_gpu
>             && new_transfer->dst_node == old_transfer->src_node
>             && new_transfer->dst_node == old_transfer->dst_node)
>         return 1;
> And this confuses me because this can only be true if new_transfer->src_node
> == new_transfer->dst_node (resp. for old_transfer in the second case), which
> I believe is not supposed to happen. Am I missing anything ?
It seems it should have been an || there indeed, now fixed.
Thanks!
Samuel
Haut de le page
