Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU v1.2.3 released
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: starpu-announce@lists.gforge.inria.fr
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] StarPU v1.2.3 released
  • Date: Thu, 9 Nov 2017 16:57:21 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=None smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta02.u-bordeaux.fr
  • Ironport-phdr: 9a23:viA3tBO4mNKJz6LIdpYl6mtUPXoX/o7sNwtQ0KIMzox0KPzyrarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6aijSI4DUTAhTyMxZubqSwQ9aKzpf/6+fn4IHaeR1VwTO7Z7RvKh67hQHQrdUNx4RsLbw+x13IpGFJcqJY3zBGP1WWyjD1+se5+J9uuwpNofcs8dJHGfH8drg4RLhZAXIoLnow6cv3sjHHRAGV5z0SSDNFwVJzHwHZ4USiDd/KuSzgu784gXHCMA==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
I was told my message was not quite clear. The OOC/MIC/OpenMP support
were already part of the previous releases of the serie 1.2.x.
1.2.3 brings the features and changes listed at the bottom of the message.
Cheers,
Nathalie
On 09/11/2017 16:49, Nathalie Furmento wrote:
> All,
> The StarPU team is really pleased to announce the v1.2.3 release!
> This release notably brings an out-of-core support, a MIC Xeon Phi
> support, an OpenMP runtime support, and a new internal communication
> system for MPI.
> The tarball along with the md5sum file and the OpenPGP signature are
> available on the starpu web site
> http://starpu.gforge.inria.fr/files/
> or directly on the Gforge web site
> https://gforge.inria.fr/frs/?group_id=1570
> Nathalie, for the StarPU team.
> StarPU 1.2.3 (svn revision 22444)
> New features:
> * Add per-node MPI data.
> Small features:
> * When debug is enabled, starpu data accessors first check the
> validity of the data interface type
> * Print disk bus performances when STARPU_BUS_STATS is set
> * Add starpu_vector_filter_list_long filter.
> * Data interfaces now define a name through the struct
> starpu_data_interface_ops
> * StarPU-MPI :
> - allow predefined data interface not to define a mpi datatype and
> to be exchanged through pack/unpack operations
> - New function starpu_mpi_comm_get_attr() which allows to return
> the value of the attribute STARPU_MPI_TAG_UB, i.e the upper
> bound for tag value.
> - New configure option enable-mpi-verbose to manage the display of
> extra MPI debug messages.
> * Add STARPU_WATCHDOG_DELAY environment variable.
> * Add a 'waiting' worker status
> * Allow new value 'extra' for configure option --enable-verbose
> Small changes:
> * Add data_unregister event in traces
> * StarPU-MPI
> - push detached requests at the back of the testing list, so they
> are tested last since they will most probably finish latest
> * Automatically initialize handles on data acquisition when
> reduction methods are provided, and make sure a handle is
> initialized before trying to read it.
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Haut de le page
